Pull request: u-boot-rockchip/for-next
Hi Tom,
Please pull the updates for rockchip platform for next: - Add support for rv1126 soc and rv1126 neu2 io board; - Add support for rk3399 pine64 pinephone pro board; - dts sync from linux for rk3399;
Travis: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/14601
Thanks, - Kever
The following changes since commit a95410696d21d38b629c61a09c100197c5fc533a:
Merge branch '2023-01-02-platform-updates' into next (2023-01-02 18:07:41 -0500)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git for-next
for you to fetch changes up to 7c2c42aa4b623dae0dd59064ff2b147eb01dbb75:
rockchip: Add initial support for the PINE64 Pinephone Pro (2023-01-04 17:00:48 +0800)
---------------------------------------------------------------- Christopher Obbard (1): configs: roc-pc-rk3399: Enable rockchip efuse support
Jagan Teki (25): ram: Mark ram-uclass depend on TPL_DM or SPL_DM ram: rockchip: Add common ddr type configs ram: rockchip: Compute ddr capacity based on grf split ram: rockchip: Update ddr pctl regs for px30 ram: rockchip: Add rv1126 ddr3 support ram: rockchip: Add rv1126 ddr loader params ram: rockchip: Add rv1126 ddr driver support ram: rockchip: rv1126: Control ddr init prints via DEBUG ram: rockchip: Add rv1126 lpddr4 support pinctrl: rockchip: Add pinctrl route types pinctrl: rockchip: Add rv1126 support arch: rockchip: Add cru header for rv1126 dt-bindings: clk: Add dt-binding header for RV1126 clk: rockchip: Add rv1126 clk support dt-bindings: power: Add power-domain header for rv1126 arm: rockchip: Add grf header for rv1126 ARM: dts: rockchip: Add Rockchip RV1126 pinctrl ARM: dts: rockchip: Add Rockchip RV1126 SoC arm: rockchip: Add RV1126 arch core support arm: rockchip: rv1126: Set dram area unsecure for SPL rockchip: mkimage: Add rv1126 support ARM: dts: rockchip: rv1126: Add Edgeble Neural Compute Module 2(Neu2) ARM: dts: rockchip: rv1126: Add Edgeble Neural Compute Module 2(Neu2) IO ARM: dts: rockchip: Add rv1126-u-boot.dtsi board: rockchip: Add Edgeble Neu2 IO Board
John Keeping (2): rc4: mark key as const rockchip: mkimage: make RC4 key const
Peter Robinson (3): arm64: dts: rk3399: sync rk3399.dtsi from 6.1-rc1 arm64: dts: rk3399: Add upstream Pinephone Pro dts rockchip: Add initial support for the PINE64 Pinephone Pro
Quentin Schulz (3): rockchip: px30: make watchdog and tsadc trigger a first global reset rockchip: clk: add watchdog clock to px30_clk_enable rockchip: puma-rk3399: sync DTS with Linux kernel next-20221114
arch/arm/dts/Makefile | 4 + arch/arm/dts/rk3399-opp.dtsi | 6 +- arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi | 31 + arch/arm/dts/rk3399-pinephone-pro.dts | 474 +++ arch/arm/dts/rk3399-puma-haikou.dts | 5 +- arch/arm/dts/rk3399-puma.dtsi | 32 +- arch/arm/dts/rk3399-u-boot.dtsi | 36 +- arch/arm/dts/rk3399.dtsi | 200 +- arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi | 10 + arch/arm/dts/rv1126-edgeble-neu2-io.dts | 42 + arch/arm/dts/rv1126-edgeble-neu2.dtsi | 338 ++ arch/arm/dts/rv1126-pinctrl.dtsi | 211 ++ arch/arm/dts/rv1126-u-boot.dtsi | 62 + arch/arm/dts/rv1126.dtsi | 438 +++ arch/arm/include/asm/arch-rockchip/cru_rv1126.h | 459 +++ .../include/asm/arch-rockchip/dram_spec_timing.h | 452 +++ arch/arm/include/asm/arch-rockchip/grf_rv1126.h | 251 ++ arch/arm/include/asm/arch-rockchip/sdram_common.h | 214 +- arch/arm/include/asm/arch-rockchip/sdram_msch.h | 12 + .../include/asm/arch-rockchip/sdram_pctl_px30.h | 100 +- .../include/asm/arch-rockchip/sdram_phy_rv1126.h | 93 + arch/arm/include/asm/arch-rockchip/sdram_rv1126.h | 420 +++ arch/arm/include/asm/arch-rv1126/boot0.h | 11 + arch/arm/include/asm/arch-rv1126/gpio.h | 11 + arch/arm/mach-rockchip/Kconfig | 46 + arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/px30/px30.c | 4 + arch/arm/mach-rockchip/rk3399/Kconfig | 8 + arch/arm/mach-rockchip/rv1126/Kconfig | 59 + arch/arm/mach-rockchip/rv1126/Makefile | 13 + arch/arm/mach-rockchip/rv1126/clk_rv1126.c | 33 + arch/arm/mach-rockchip/rv1126/rv1126.c | 75 + arch/arm/mach-rockchip/rv1126/syscon_rv1126.c | 47 + board/edgeble/neural-compute-module-2/Kconfig | 16 + board/edgeble/neural-compute-module-2/MAINTAINERS | 6 + board/edgeble/neural-compute-module-2/Makefile | 7 + board/edgeble/neural-compute-module-2/neu2.c | 4 + board/engicam/px30_core/Kconfig | 2 +- board/pine64/pinephone-pro-rk3399/Kconfig | 15 + board/pine64/pinephone-pro-rk3399/MAINTAINERS | 8 + board/pine64/pinephone-pro-rk3399/Makefile | 1 + .../pinephone-pro-rk3399/pinephone-pro-rk3399.c | 76 + common/spl/Kconfig.tpl | 2 +- configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/neu2-io-rv1126_defconfig | 57 + configs/pinebook-pro-rk3399_defconfig | 2 +- configs/pinephone-pro-rk3399_defconfig | 104 + configs/roc-pc-mezzanine-rk3399_defconfig | 4 +- configs/roc-pc-rk3399_defconfig | 4 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- doc/board/rockchip/rockchip.rst | 3 + drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_px30.c | 3 + drivers/clk/rockchip/clk_rk3399.c | 2 +- drivers/clk/rockchip/clk_rv1126.c | 1889 +++++++++++ drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl-px30.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rockchip-core.c | 45 +- drivers/pinctrl/rockchip/pinctrl-rockchip.h | 58 +- drivers/pinctrl/rockchip/pinctrl-rv1126.c | 416 +++ drivers/ram/Makefile | 2 +- drivers/ram/rockchip/Kconfig | 32 +- drivers/ram/rockchip/Makefile | 1 + .../ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-328.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-396.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-528.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-664.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-784.inc | 72 + .../ram/rockchip/sdram-rv1126-ddr3-detect-924.inc | 72 + .../ram/rockchip/sdram-rv1126-loader_params.inc | 197 ++ .../rockchip/sdram-rv1126-lpddr4-detect-1056.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-328.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-396.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-528.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-664.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-784.inc | 78 + .../rockchip/sdram-rv1126-lpddr4-detect-924.inc | 78 + drivers/ram/rockchip/sdram_common.c | 6 +- drivers/ram/rockchip/sdram_pctl_px30.c | 6 +- drivers/ram/rockchip/sdram_px30.c | 8 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 9 +- drivers/ram/rockchip/sdram_rv1126.c | 3543 ++++++++++++++++++++ include/configs/neural-compute-module-2.h | 21 + include/configs/pinephone-pro-rk3399.h | 19 + include/configs/rv1126_common.h | 40 + include/dt-bindings/clock/rk3399-cru.h | 24 +- include/dt-bindings/clock/rockchip,rv1126-cru.h | 632 ++++ include/dt-bindings/power/rk3399-power.h | 1 + include/dt-bindings/power/rockchip,rv1126-power.h | 35 + include/rc4.h | 2 +- lib/rc4.c | 2 +- tools/rkcommon.c | 3 +- 106 files changed, 12456 insertions(+), 196 deletions(-) create mode 100644 arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts create mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io.dts create mode 100644 arch/arm/dts/rv1126-edgeble-neu2.dtsi create mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi create mode 100644 arch/arm/dts/rv1126-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/dram_spec_timing.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rv1126.h create mode 100644 arch/arm/include/asm/arch-rv1126/boot0.h create mode 100644 arch/arm/include/asm/arch-rv1126/gpio.h create mode 100644 arch/arm/mach-rockchip/rv1126/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1126/Makefile create mode 100644 arch/arm/mach-rockchip/rv1126/clk_rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/syscon_rv1126.c create mode 100644 board/edgeble/neural-compute-module-2/Kconfig create mode 100644 board/edgeble/neural-compute-module-2/MAINTAINERS create mode 100644 board/edgeble/neural-compute-module-2/Makefile create mode 100644 board/edgeble/neural-compute-module-2/neu2.c create mode 100644 board/pine64/pinephone-pro-rk3399/Kconfig create mode 100644 board/pine64/pinephone-pro-rk3399/MAINTAINERS create mode 100644 board/pine64/pinephone-pro-rk3399/Makefile create mode 100644 board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c create mode 100644 configs/neu2-io-rv1126_defconfig create mode 100644 configs/pinephone-pro-rk3399_defconfig create mode 100644 drivers/clk/rockchip/clk_rv1126.c create mode 100644 drivers/pinctrl/rockchip/pinctrl-rv1126.c create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-loader_params.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram_rv1126.c create mode 100644 include/configs/neural-compute-module-2.h create mode 100644 include/configs/pinephone-pro-rk3399.h create mode 100644 include/configs/rv1126_common.h create mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h create mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
Hi Kever,
On Thu, Jan 5, 2023 at 9:02 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Tom,
Can you pick up v2 of the pinephone pro patch, which drops the rk3399.dtsi sync for the time being as it breaks some things, see both v1 and v2 threads for detail, also Ton's previous issue with your lost PR for this.
Peter
Thanks,
- Kever
On 2023/1/5 17:06, Peter Robinson wrote:
Hi Kever,
Hi Tom,
I do pick up the V2 of pinephone pro patch, but I did not notice that the rk3399.dtsi sync
has been dropped, what's the break by this patch? the build system has passed.
Thanks,
- Kever
Peter
Thanks,
- Kever
Hi Kever,
Hi Tom,
I mentioned some of the issues in the v2 cover letter, and Quentin also mentions some issues here:
https://lists.denx.de/pipermail/u-boot/2023-January/503274.html
Thanks,
- Kever
Peter
Thanks,
- Kever
Hi Kever,
On Thu, 5 Jan 2023 at 14:32, Kever Yang kever.yang@rock-chips.com wrote:
Hi Tom,
Can this go to the coming release?
Jagan.
Hi Tom,
I have remove the rk3399.dtsi sync patch and update the for-next branch.
Do you need me to resend a new PR, or could you merge the latest patches?
The new CI result:
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/14618
Thanks,
- Kever
On 2023/1/5 17:01, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Please send a new PR.
On Fri, Jan 6, 2023, 4:40 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Tom,
branch.
patches?
The new CI result:
Thanks,
- Kever
Hi Tom,
Travis:
Thanks,
- Kever
18:07:41 -0500)
2(Neu2)
2(Neu2) IO
reset
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
create mode 100644
Jagan Teki
Kever Yang
Peter Robinson
