[U-Boot] [PATCH] net: phy: add TSE PCS support to dwmac-socfpga
This adds support for TSE PCS that uses SGMII adapter when the phy-mode in device tree is set to sgmii.
Signed-off-by: Ooi, Joyce joyce.ooi@intel.com --- drivers/net/Makefile | 3 +- drivers/net/designware.c | 5 ++ drivers/net/designware.h | 1 + drivers/net/dwmac_socfpga.c | 121 +++++++++++++++++++++++++ drivers/net/phy/altr_tse_pcs.c | 197 +++++++++++++++++++++++++++++++++++++++++ drivers/net/phy/altr_tse_pcs.h | 59 ++++++++++++ 6 files changed, 385 insertions(+), 1 deletion(-) create mode 100644 drivers/net/phy/altr_tse_pcs.c create mode 100644 drivers/net/phy/altr_tse_pcs.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 48a2878..c2333b5 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o obj-$(CONFIG_CS8900) += cs8900.o obj-$(CONFIG_TULIP) += dc2114x.o obj-$(CONFIG_ETH_DESIGNWARE) += designware.o -obj-$(CONFIG_ETH_DESIGNWARE_SOCFPGA) += dwmac_socfpga.o +obj-$(CONFIG_ETH_DESIGNWARE_SOCFPGA) += dwmac-socfpga.o obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_E1000) += e1000.o @@ -73,3 +73,4 @@ obj-$(CONFIG_PIC32_ETH) += pic32_mdio.o pic32_eth.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ obj-$(CONFIG_SNI_AVE) += sni_ave.o +dwmac-socfpga-objs := phy/altr_tse_pcs.o dwmac_socfpga.o diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 19db0a8..666cf41 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -235,6 +235,8 @@ static int dw_adjust_link(struct dw_eth_dev *priv, struct eth_mac_regs *mac_p, struct phy_device *phydev) { u32 conf = readl(&mac_p->conf) | FRAMEBURSTENABLE | DISABLERXOWN; + struct udevice *dev = priv->phydev->dev; + struct dw_eth_pdata *dw_pdata = dev_get_platdata(dev);
if (!phydev->link) { printf("%s: No link.\n", phydev->dev->name); @@ -254,6 +256,9 @@ static int dw_adjust_link(struct dw_eth_dev *priv, struct eth_mac_regs *mac_p,
writel(conf, &mac_p->conf);
+ if (dw_pdata->pcs_adjust_link) + dw_pdata->pcs_adjust_link(dev, phydev); + printf("Speed: %d, %s duplex%s\n", phydev->speed, (phydev->duplex) ? "full" : "half", (phydev->port == PORT_FIBRE) ? ", fiber mode" : ""); diff --git a/drivers/net/designware.h b/drivers/net/designware.h index dea12b7..3a5a93f 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -255,6 +255,7 @@ extern const struct eth_ops designware_eth_ops; struct dw_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3]; + void (*pcs_adjust_link)(struct udevice *dev, struct phy_device *phydev); };
int designware_eth_init(struct dw_eth_dev *priv, u8 *enetaddr); diff --git a/drivers/net/dwmac_socfpga.c b/drivers/net/dwmac_socfpga.c index 08fc967..a096d29 100644 --- a/drivers/net/dwmac_socfpga.c +++ b/drivers/net/dwmac_socfpga.c @@ -9,12 +9,16 @@ #include <asm/io.h> #include <dm.h> #include <clk.h> +#include <fdt_support.h> #include <phy.h> #include <regmap.h> #include <reset.h> #include <syscon.h> #include "designware.h" +#include "phy/altr_tse_pcs.h"
+#include <asm/arch/mailbox_s10.h> +#include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
enum dwmac_type { @@ -27,8 +31,122 @@ struct dwmac_socfpga_platdata { struct dw_eth_pdata dw_eth_pdata; enum dwmac_type type; void *phy_intf; + struct tse_pcs pcs; };
+static void socfpga_tse_pcs_adjust_link(struct udevice *dev, + struct phy_device *phydev) +{ + struct dwmac_socfpga_platdata *pdata = dev_get_platdata(dev); + phys_addr_t tse_pcs_base = pdata->pcs.tse_pcs_base; + phys_addr_t sgmii_adapter_base = pdata->pcs.sgmii_adapter_base; + + if ((tse_pcs_base) && (sgmii_adapter_base)) + writew(SGMII_ADAPTER_DISABLE, + sgmii_adapter_base + SGMII_ADAPTER_CTRL_REG); + + if ((tse_pcs_base) && (sgmii_adapter_base)) + tse_pcs_fix_mac_speed(&pdata->pcs, phydev, phydev->speed); +} + +static int socfpga_dw_tse_pcs_init(struct udevice *dev) +{ + struct dwmac_socfpga_platdata *pdata = dev_get_platdata(dev); + struct dw_eth_pdata *dw_pdata = &pdata->dw_eth_pdata; + struct eth_pdata *eth_pdata = &pdata->dw_eth_pdata.eth_pdata; + phys_addr_t tse_pcs_base = pdata->pcs.tse_pcs_base; + phys_addr_t sgmii_adapter_base = pdata->pcs.sgmii_adapter_base; + const fdt32_t *reg; + int ret = 0; + int parent, index, na, ns, offset, len; + + offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), + "altr,gmii-to-sgmii-converter"); + if (offset > 0) { + /* check FPGA status */ + ret = mbox_get_fpga_config_status(MBOX_CONFIG_STATUS); + if (ret) { + debug("%s: FPGA status returns %d\n", __func__, ret); + return -EPERM; + } + + /* enable HPS bridge */ + socfpga_bridges_reset(1); + + parent = fdt_parent_offset(gd->fdt_blob, offset); + if (parent < 0) { + debug("s10-hps-bridge DT not found\n"); + return -ENODEV; + } + + na = fdt_address_cells(gd->fdt_blob, parent); + if (na < 1) { + debug("bad #address-cells\n"); + return -EINVAL; + } + + ns = fdt_size_cells(gd->fdt_blob, parent); + if (ns < 1) { + debug("bad #size-cells\n"); + return -EINVAL; + } + + index = fdt_stringlist_search(gd->fdt_blob, offset, "reg-names", + "eth_tse_control_port"); + if (index < 0) { + debug("fail to find eth_tse_control_port: %s\n", + fdt_strerror(index)); + return -ENOENT; + } + + reg = fdt_getprop(gd->fdt_blob, offset, "reg", &len); + if (!reg || (len <= (index * sizeof(fdt32_t) * (na + ns)))) + return -EINVAL; + + reg += index * (na + ns); + tse_pcs_base = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); + if (tse_pcs_base == FDT_ADDR_T_NONE) { + debug("tse pcs address not found\n"); + return -EINVAL; + } + + index = fdt_stringlist_search(gd->fdt_blob, offset, "reg-names", + "gmii_to_sgmii_adapter_avalon_slave"); + if (index < 0) { + debug("fail to find gmii_to_sgmii_adapter_avalon_slave: %s\n", + fdt_strerror(index)); + return -EINVAL; + } + + reg = fdt_getprop(gd->fdt_blob, offset, "reg", &len); + if (!reg || (len <= (index * sizeof(fdt32_t) * (na + ns)))) + return -EINVAL; + + reg += index * (na + ns); + sgmii_adapter_base = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); + if (sgmii_adapter_base == FDT_ADDR_T_NONE) { + debug("gmii-to-sgmii adapter address not found\n"); + return -EINVAL; + } + + if (eth_pdata->phy_interface == PHY_INTERFACE_MODE_SGMII) { + if (tse_pcs_init(tse_pcs_base, &pdata->pcs) != 0) { + debug("Unable to intiialize TSE PCS\n"); + return -EINVAL; + } + } + /* Clear sgmii_adapter_base first */ + writel(0, sgmii_adapter_base); + + pdata->pcs.tse_pcs_base = tse_pcs_base; + pdata->pcs.sgmii_adapter_base = sgmii_adapter_base; + dw_pdata->pcs_adjust_link = socfpga_tse_pcs_adjust_link; + } + return ret; +} + static int dwmac_socfpga_ofdata_to_platdata(struct udevice *dev) { struct dwmac_socfpga_platdata *pdata = dev_get_platdata(dev); @@ -94,6 +212,7 @@ static int dwmac_socfpga_probe(struct udevice *dev) switch (edata->phy_interface) { case PHY_INTERFACE_MODE_MII: case PHY_INTERFACE_MODE_GMII: + case PHY_INTERFACE_MODE_SGMII: modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; break; case PHY_INTERFACE_MODE_RMII: @@ -122,6 +241,8 @@ static int dwmac_socfpga_probe(struct udevice *dev) reset_release_bulk(&reset_bulk); }
+ socfpga_dw_tse_pcs_init(dev); + return designware_eth_probe(dev); }
diff --git a/drivers/net/phy/altr_tse_pcs.c b/drivers/net/phy/altr_tse_pcs.c new file mode 100644 index 0000000..fa8077c --- /dev/null +++ b/drivers/net/phy/altr_tse_pcs.c @@ -0,0 +1,197 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2018, Intel Corporation. All rights reserved + */ + +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <net.h> +#include <linux/compat.h> +#include <phy.h> +#include <timer.h> +#include <linux/ethtool.h> + +#include <asm/omap_common.h> +#include <asm/omap_musb.h> + +#include "altr_tse_pcs.h" + +static int tse_pcs_reset(phys_addr_t base, struct tse_pcs *pcs) +{ + int counter = 0; + u16 val; + + val = readw(base + TSE_PCS_CONTROL_REG); + val |= TSE_PCS_SW_RST_MASK; + + writew(val, base + TSE_PCS_CONTROL_REG); + + while (counter < TSE_PCS_SW_RESET_TIMEOUT) { + val = readw(base + TSE_PCS_CONTROL_REG); + val &= TSE_PCS_SW_RST_MASK; + if (val == 0) + break; + counter++; + udelay(1); + } + + if (counter >= TSE_PCS_SW_RESET_TIMEOUT) { + debug("%s: PCS could not get out of sw reset\n", __func__); + return -ETIMEDOUT; + } + + return 0; +} + +int tse_pcs_init(phys_addr_t base, struct tse_pcs *pcs) +{ + int ret = 0; + + writew(TSE_PCS_USE_SGMII_ENA, base + TSE_PCS_IF_MODE_REG); + writew(TSE_PCS_SGMII_LINK_TIMER_0, base + TSE_PCS_LINK_TIMER_0_REG); + writew(TSE_PCS_SGMII_LINK_TIMER_1, base + TSE_PCS_LINK_TIMER_1_REG); + + ret = tse_pcs_reset(base, pcs); + if (ret == 0) + writew(SGMII_ADAPTER_ENABLE, + pcs->sgmii_adapter_base + SGMII_ADAPTER_CTRL_REG); + + return ret; +} + +static void pcs_link_timer_callback(struct tse_pcs *pcs) +{ + u16 val = 0; + phys_addr_t tse_pcs_base = pcs->tse_pcs_base; + phys_addr_t sgmii_adapter_base = pcs->sgmii_adapter_base; + + val = readw(tse_pcs_base + TSE_PCS_STATUS_REG); + val &= TSE_PCS_STATUS_LINK_MASK; + + if (val != 0) { + printf("Adapter: Link is established\n"); + writew(SGMII_ADAPTER_ENABLE, + sgmii_adapter_base + SGMII_ADAPTER_CTRL_REG); + } else { + printf("Adapter: Link fail to establish\n"); + } +} + +static void auto_nego_timer_callback(struct tse_pcs *pcs) +{ + u16 val = 0; + u16 speed = 0; + u16 duplex = 0; + phys_addr_t tse_pcs_base = pcs->tse_pcs_base; + phys_addr_t sgmii_adapter_base = pcs->sgmii_adapter_base; + + val = readw(tse_pcs_base + TSE_PCS_STATUS_REG); + val &= TSE_PCS_STATUS_AN_COMPLETED_MASK; + + if (val != 0) { + printf("Adapter: Auto Negotiation is completed\n"); + val = readw(tse_pcs_base + TSE_PCS_PARTNER_ABILITY_REG); + speed = val & TSE_PCS_PARTNER_SPEED_MASK; + duplex = val & TSE_PCS_PARTNER_DUPLEX_MASK; + + if (speed == TSE_PCS_PARTNER_SPEED_10 && + duplex == TSE_PCS_PARTNER_DUPLEX_FULL) + printf("Adapter: Link Partner is Up - 10/Full\n"); + else if (speed == TSE_PCS_PARTNER_SPEED_100 && + duplex == TSE_PCS_PARTNER_DUPLEX_FULL) + printf("Adapter: Link Partner is Up - 100/Full\n"); + else if (speed == TSE_PCS_PARTNER_SPEED_1000 && + duplex == TSE_PCS_PARTNER_DUPLEX_FULL) + printf("Adapter: Link Partner is Up - 1000/Full\n"); + else if (speed == TSE_PCS_PARTNER_SPEED_10 && + duplex == TSE_PCS_PARTNER_DUPLEX_HALF) + printf("Adapter does not support Half Duplex\n"); + else if (speed == TSE_PCS_PARTNER_SPEED_100 && + duplex == TSE_PCS_PARTNER_DUPLEX_HALF) + printf("Adapter does not support Half Duplex\n"); + else if (speed == TSE_PCS_PARTNER_SPEED_1000 && + duplex == TSE_PCS_PARTNER_DUPLEX_HALF) + printf("Adapter does not support Half Duplex\n"); + else + printf("Adapter: Invalid Partner Speed and Duplex\n"); + + if (duplex == TSE_PCS_PARTNER_DUPLEX_FULL && + (speed == TSE_PCS_PARTNER_SPEED_10 || + speed == TSE_PCS_PARTNER_SPEED_100 || + speed == TSE_PCS_PARTNER_SPEED_1000)) + writew(SGMII_ADAPTER_ENABLE, + sgmii_adapter_base + SGMII_ADAPTER_CTRL_REG); + } else { + printf("Auto-negotioation failed\n"); + } +} + +void tse_pcs_fix_mac_speed(struct tse_pcs *pcs, struct phy_device *phy_dev, + unsigned int speed) +{ + phys_addr_t tse_pcs_base = pcs->tse_pcs_base; + phys_addr_t sgmii_adapter_base = pcs->sgmii_adapter_base; + u32 val, start; + + writew(SGMII_ADAPTER_ENABLE, + sgmii_adapter_base + SGMII_ADAPTER_CTRL_REG); + pcs->autoneg = phy_dev->autoneg; + + if (pcs->autoneg == AUTONEG_ENABLE) { + val = readw(tse_pcs_base + TSE_PCS_CONTROL_REG); + val |= TSE_PCS_CONTROL_AN_EN_MASK; + writew(val, tse_pcs_base + TSE_PCS_CONTROL_REG); + + val = readw(tse_pcs_base + TSE_PCS_IF_MODE_REG); + val |= TSE_PCS_USE_SGMII_AN_MASK; + writew(val, tse_pcs_base + TSE_PCS_IF_MODE_REG); + + val = readw(tse_pcs_base + TSE_PCS_CONTROL_REG); + val |= TSE_PCS_CONTROL_RESTART_AN_MASK; + + tse_pcs_reset(tse_pcs_base, pcs); + + } else if (pcs->autoneg == AUTONEG_DISABLE) { + val = readw(tse_pcs_base + TSE_PCS_CONTROL_REG); + val &= ~TSE_PCS_CONTROL_AN_EN_MASK; + writew(val, tse_pcs_base + TSE_PCS_CONTROL_REG); + + val = readw(tse_pcs_base + TSE_PCS_IF_MODE_REG); + val &= ~TSE_PCS_USE_SGMII_AN_MASK; + writew(val, tse_pcs_base + TSE_PCS_IF_MODE_REG); + + val = readw(tse_pcs_base + TSE_PCS_IF_MODE_REG); + val &= ~TSE_PCS_SGMII_SPEED_MASK; + + switch (speed) { + case 1000: + val |= TSE_PCS_SGMII_SPEED_1000; + break; + case 100: + val |= TSE_PCS_SGMII_SPEED_100; + break; + case 10: + val |= TSE_PCS_SGMII_SPEED_10; + break; + default: + return; + } + writew(val, tse_pcs_base + TSE_PCS_IF_MODE_REG); + + tse_pcs_reset(tse_pcs_base, pcs); + } + + start = get_timer(0); + while (1) { + if (get_timer(start) >= AUTONEGO_LINK_TIMER) { + if (pcs->autoneg == AUTONEG_ENABLE) + auto_nego_timer_callback(pcs); + else if (pcs->autoneg == AUTONEG_DISABLE) + pcs_link_timer_callback(pcs); + return; + } + udelay(100); + } +} diff --git a/drivers/net/phy/altr_tse_pcs.h b/drivers/net/phy/altr_tse_pcs.h new file mode 100644 index 0000000..9a2016a --- /dev/null +++ b/drivers/net/phy/altr_tse_pcs.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017-2018, Intel Corporation. All rights reserved + */ + +#ifndef __TSE_PCS_H__ +#define __TSE_PCS_H__ + +#define TSE_PCS_CONTROL_AN_EN_MASK BIT(12) +#define TSE_PCS_CONTROL_REG 0x00 +#define TSE_PCS_CONTROL_RESTART_AN_MASK BIT(9) +#define TSE_PCS_IF_MODE_REG 0x28 +#define TSE_PCS_LINK_TIMER_0_REG 0x24 +#define TSE_PCS_LINK_TIMER_1_REG 0x26 +#define TSE_PCS_SIZE 0x40 +#define TSE_PCS_STATUS_AN_COMPLETED_MASK BIT(5) +#define TSE_PCS_STATUS_LINK_MASK 0x0004 +#define TSE_PCS_STATUS_REG 0x02 +#define TSE_PCS_SGMII_SPEED_1000 BIT(3) +#define TSE_PCS_SGMII_SPEED_100 BIT(2) +#define TSE_PCS_SGMII_SPEED_10 0x0 +#define TSE_PCS_SW_RST_MASK 0x8000 +#define TSE_PCS_PARTNER_ABILITY_REG 0x0A +#define TSE_PCS_PARTNER_DUPLEX_FULL 0x1000 +#define TSE_PCS_PARTNER_DUPLEX_HALF 0x0000 +#define TSE_PCS_PARTNER_DUPLEX_MASK 0x1000 +#define TSE_PCS_PARTNER_SPEED_MASK GENMASK(11, 10) +#define TSE_PCS_PARTNER_SPEED_1000 BIT(11) +#define TSE_PCS_PARTNER_SPEED_100 BIT(10) +#define TSE_PCS_PARTNER_SPEED_10 0x0000 +#define TSE_PCS_PARTNER_SPEED_1000 BIT(11) +#define TSE_PCS_PARTNER_SPEED_100 BIT(10) +#define TSE_PCS_PARTNER_SPEED_10 0x0000 +#define TSE_PCS_SGMII_SPEED_MASK GENMASK(3, 2) +#define TSE_PCS_SGMII_LINK_TIMER_0 0x0D40 +#define TSE_PCS_SGMII_LINK_TIMER_1 0x0003 +#define TSE_PCS_SW_RESET_TIMEOUT 100 +#define TSE_PCS_USE_SGMII_AN_MASK BIT(1) +#define TSE_PCS_USE_SGMII_ENA BIT(0) + +#define SGMII_ADAPTER_CTRL_REG 0x00 +#define SGMII_ADAPTER_DISABLE 0x0001 +#define SGMII_ADAPTER_ENABLE 0x0000 + +#define AUTONEGO_LINK_TIMER 20 + +struct tse_pcs { + struct device *dev; + phys_addr_t tse_pcs_base; + phys_addr_t sgmii_adapter_base; + struct timer_list aneg_link_timer; + int autoneg; +}; + +int tse_pcs_init(phys_addr_t base, struct tse_pcs *pcs); +void tse_pcs_fix_mac_speed(struct tse_pcs *pcs, struct phy_device *phy_dev, + unsigned int speed); + +#endif /* __TSE_PCS_H__ */
Can you add a bit more description to your commit message? TSE(Triple Speed Ethernet), but what is PCS?
Huh? What's this change for?
Also, I'm getting these compile errors against the latest U-Boot, top commit = "284b27cf81da10d55 Merge branch 'master' of git://git.denx.de/u-boot-mips" :
drivers/net/dwmac_socfpga.c: In function ‘socfpga_dw_tse_pcs_init’: drivers/net/dwmac_socfpga.c:67:9: warning: implicit declaration of function ‘mbox_get_fpga_config_status’ [-Wimplicit-function-declaration] ret = mbox_get_fpga_config_status(MBOX_CONFIG_STATUS); ^~~~~~~~~~~~~~~~~~~~~~~~~~~ LD common/built-in.o LD drivers/net/dwmac-socfpga.o LD drivers/net/built-in.o LD cmd/built-in.o CC lib/smbios.o CC lib/display_options.o CC lib/efi_loader/efi_reloc.o CC lib/efi_loader/helloworld.o LD lib/efi_loader/helloworld_efi.so OBJCOPY lib/efi_loader/helloworld.efi rm lib/efi_loader/helloworld_efi.so lib/efi_loader/helloworld.o LD lib/built-in.o LD u-boot drivers/net/built-in.o: In function `dwmac_socfpga_ofdata_to_platdata': /home/dinguyen/linux_dev/u-boot/drivers/net/dwmac_socfpga.c:170: undefined reference to `syscon_node_to_regmap' /home/dinguyen/linux_dev/u-boot/drivers/net/dwmac_socfpga.c:177: undefined reference to `regmap_get_range' drivers/net/built-in.o: In function `socfpga_dw_tse_pcs_init': /home/dinguyen/linux_dev/u-boot/drivers/net/dwmac_socfpga.c:67: undefined reference to `mbox_get_fpga_config_status'
In the future, please test before submitting patches.
Thanks, Dinh
For the arria10 defconfig, I get the following compile error:
drivers/net/dwmac_socfpga.c: In function ‘socfpga_dw_tse_pcs_init’: drivers/net/dwmac_socfpga.c:67:9: warning: implicit declaration of function ‘mbox_get_fpga_config_status’ [-Wimplicit-function-declaration] ret = mbox_get_fpga_config_status(MBOX_CONFIG_STATUS); ^~~~~~~~~~~~~~~~~~~~~~~~~~~ drivers/net/dwmac_socfpga.c:74:3: error: too many arguments to function ‘socfpga_bridges_reset’ socfpga_bridges_reset(1); ^~~~~~~~~~~~~~~~~~~~~ In file included from ./arch/arm/include/asm/arch/reset_manager.h:44:0, from drivers/net/dwmac_socfpga.c:21: ./arch/arm/include/asm/arch/reset_manager_arria10.h:15:5: note: declared here int socfpga_bridges_reset(void);
Dinh
Dinh Nguyen
Ooi, Joyce
