[U-Boot] [PATCH v3 0/3] i2c, mxc: switch to new multibus/multiadapter framework
This serie is composed of three patches: - one to fix the i2c init on the generic board - one to port the i2c mxc driver to new subsystem - one to update all configurations with i2c mxc driver
This serie was tested with success on armadeus apf27.
Difference between v3 and v2: - change title of patch 2 (specify mxc)
Difference between v2 and v1: - change title of the serie - use define for speed and slave for each i2c bus - sort i2c driver list - define mxc function as static - remove CONFIG_I2C_MULTI_BUS in config using i2c mxc
Philippe Reynes (3): i2c: fix init on generic board i2c: mxc: move to new subsystem i2c: update config using mxc driver to new subsystem
README | 11 +++ arch/arm/cpu/armv7/mx5/clock.c | 2 +- arch/arm/cpu/armv7/mx6/clock.c | 2 +- arch/arm/imx-common/Makefile | 2 +- common/board_f.c | 4 + drivers/i2c/Makefile | 2 +- drivers/i2c/mxc_i2c.c | 137 +++++++++++++++++++++---------------- include/configs/apf27.h | 11 ++-- include/configs/flea3.h | 9 +-- include/configs/imx31_phycore.h | 7 +- include/configs/m53evk.h | 7 +- include/configs/mx25pdk.h | 7 +- include/configs/mx35pdk.h | 7 +- include/configs/mx53ard.h | 7 +- include/configs/mx53evk.h | 7 +- include/configs/mx53loco.h | 7 +- include/configs/mx53smd.h | 7 +- include/configs/mx6qsabreauto.h | 4 +- include/configs/nitrogen6x.h | 4 +- include/configs/titanium.h | 4 +- include/configs/vf610twr.h | 7 +- include/configs/woodburn_common.h | 7 +- 22 files changed, 143 insertions(+), 119 deletions(-)
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr --- common/board_f.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 0ada1af..f0664bc 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -249,7 +249,11 @@ void dram_init_banksize(void) static int init_func_i2c(void) { puts("I2C: "); +#ifdef CONFIG_SYS_I2C + i2c_init_all(); +#else i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif puts("ready\n"); return 0; }
Hi Philippe,
It looks good, but please can we have an explanation in the commit message?
i2c_init_all();
+#else i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif puts("ready\n"); return 0; } -- 1.7.4.4
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr --- README | 11 +++ arch/arm/cpu/armv7/mx5/clock.c | 2 +- arch/arm/cpu/armv7/mx6/clock.c | 2 +- arch/arm/imx-common/Makefile | 2 +- drivers/i2c/Makefile | 2 +- drivers/i2c/mxc_i2c.c | 137 +++++++++++++++++++++++----------------- 6 files changed, 93 insertions(+), 63 deletions(-)
diff --git a/README b/README index 63706be..5d9ecc2 100644 --- a/README +++ b/README @@ -1995,6 +1995,17 @@ CBFS (Coreboot Filesystem) support - CONFIG_SYS_I2C_PPC4XX_CH0 activate hardware channel 0 - CONFIG_SYS_I2C_PPC4XX_CH1 activate hardware channel 1
+ - drivers/i2c/i2c_mxc.c + - activate this driver with CONFIG_SYS_I2C_MXC + - define speed for bus 1 with CONFIG_SYS_MXC_I2C1_SPEED + - define slave for bus 1 with CONFIG_SYS_MXC_I2C1_SLAVE + - define speed for bus 2 with CONFIG_SYS_MXC_I2C2_SPEED + - define slave for bus 2 with CONFIG_SYS_MXC_I2C2_SLAVE + - define speed for bus 3 with CONFIG_SYS_MXC_I2C3_SPEED + - define slave for bus 3 with CONFIG_SYS_MXC_I2C3_SLAVE + If thoses defines are not set, default value is 100000 + for speed, and 0 for slave. + additional defines:
CONFIG_SYS_NUM_I2C_BUSES diff --git a/arch/arm/cpu/armv7/mx5/clock.c b/arch/arm/cpu/armv7/mx5/clock.c index 6bef254..fb3b128 100644 --- a/arch/arm/cpu/armv7/mx5/clock.c +++ b/arch/arm/cpu/armv7/mx5/clock.c @@ -94,7 +94,7 @@ void enable_usboh3_clk(bool enable) MXC_CCM_CCGR2_USBOH3_60M(cg)); }
-#ifdef CONFIG_I2C_MXC +#ifdef CONFIG_SYS_I2C_MXC /* i2c_num can be from 0, to 1 for i.MX51 and 2 for i.MX53 */ int enable_i2c_clk(unsigned char enable, unsigned i2c_num) { diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 7efb0d2..8130827 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -48,7 +48,7 @@ void enable_usboh3_clk(unsigned char enable)
-#ifdef CONFIG_I2C_MXC +#ifdef CONFIG_SYS_I2C_MXC /* i2c_num can be from 0 - 2 */ int enable_i2c_clk(unsigned char enable, unsigned i2c_num) { diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 727a052..6c78dd9 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -16,7 +16,7 @@ COBJS-y = iomux-v3.o endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) COBJS-y += timer.o cpu.o speed.o -COBJS-$(CONFIG_I2C_MXC) += i2c-mxv7.o +COBJS-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) COBJS-y += misc.o diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 37ccbd1..2433182 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -14,7 +14,6 @@ COBJS-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o COBJS-$(CONFIG_DW_I2C) += designware_i2c.o COBJS-$(CONFIG_I2C_MVTWSI) += mvtwsi.o COBJS-$(CONFIG_I2C_MV) += mv_i2c.o -COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o COBJS-$(CONFIG_I2C_MXS) += mxs_i2c.o COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o @@ -29,6 +28,7 @@ COBJS-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o COBJS-$(CONFIG_SYS_I2C) += i2c_core.o COBJS-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o COBJS-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o +COBJS-$(CONFIG_SYS_I2C_MXC) += mxc_i2c.o COBJS-$(CONFIG_SYS_I2C_PPC4XX) += ppc4xx_i2c.o COBJS-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o COBJS-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 06ba4e3..595019b 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -102,6 +102,28 @@ static u16 i2c_clk_div[50][2] = { }; #endif
+ +#ifndef CONFIG_SYS_MXC_I2C1_SPEED +#define CONFIG_SYS_MXC_I2C1_SPEED 100000 +#endif +#ifndef CONFIG_SYS_MXC_I2C2_SPEED +#define CONFIG_SYS_MXC_I2C2_SPEED 100000 +#endif +#ifndef CONFIG_SYS_MXC_I2C3_SPEED +#define CONFIG_SYS_MXC_I2C3_SPEED 100000 +#endif + +#ifndef CONFIG_SYS_MXC_I2C1_SLAVE +#define CONFIG_SYS_MXC_I2C1_SLAVE 0 +#endif +#ifndef CONFIG_SYS_MXC_I2C2_SLAVE +#define CONFIG_SYS_MXC_I2C2_SLAVE 0 +#endif +#ifndef CONFIG_SYS_MXC_I2C3_SLAVE +#define CONFIG_SYS_MXC_I2C3_SLAVE 0 +#endif + + /* * Calculate and set proper clock divider */ @@ -153,21 +175,6 @@ static int bus_i2c_set_bus_speed(void *base, int speed) return 0; }
-/* - * Get I2C Speed - */ -static unsigned int bus_i2c_get_bus_speed(void *base) -{ - struct mxc_i2c_regs *i2c_regs = (struct mxc_i2c_regs *)base; - u8 clk_idx = readb(&i2c_regs->ifdr); - u8 clk_div; - - for (clk_div = 0; i2c_clk_div[clk_div][1] != clk_idx; clk_div++) - ; - - return mxc_get_clock(MXC_I2C_CLK) / i2c_clk_div[clk_div][0]; -} - #define ST_BUS_IDLE (0 | (I2SR_IBB << 8)) #define ST_BUS_BUSY (I2SR_IBB | (I2SR_IBB << 8)) #define ST_IIF (I2SR_IIF | (I2SR_IIF << 8)) @@ -410,20 +417,30 @@ struct sram_data { */ static struct sram_data __attribute__((section(".data"))) srdata;
-void *get_base(void) -{ -#ifdef CONFIG_SYS_I2C_BASE -#ifdef CONFIG_I2C_MULTI_BUS - void *ret = srdata.i2c_data[srdata.curr_i2c_bus].base; - if (ret) - return ret; -#endif - return (void *)CONFIG_SYS_I2C_BASE; -#elif defined(CONFIG_I2C_MULTI_BUS) - return srdata.i2c_data[srdata.curr_i2c_bus].base; +static void * const i2c_bases[] = { +#if defined(CONFIG_MX25) + (void *)IMX_I2C_BASE, + (void *)IMX_I2C2_BASE, + (void *)IMX_I2C3_BASE +#elif defined(CONFIG_MX27) + (void *)IMX_I2C1_BASE, + (void *)IMX_I2C2_BASE +#elif defined(CONFIG_MX31) || defined(CONFIG_MX35) || \ + defined(CONFIG_MX51) || defined(CONFIG_MX53) || \ + defined(CONFIG_MX6) + (void *)I2C1_BASE_ADDR, + (void *)I2C2_BASE_ADDR, + (void *)I2C3_BASE_ADDR +#elif defined(CONFIG_VF610) + (void *)I2C0_BASE_ADDR #else - return srdata.i2c_data[0].base; +#error "architecture not supported" #endif +}; + +void *i2c_get_base(struct i2c_adapter *adap) +{ + return i2c_bases[adap->hwadapnr]; }
static struct i2c_parms *i2c_get_parms(void *base) @@ -448,39 +465,26 @@ static int i2c_idle_bus(void *base) return 0; }
-#ifdef CONFIG_I2C_MULTI_BUS -unsigned int i2c_get_bus_num(void) -{ - return srdata.curr_i2c_bus; -} - -int i2c_set_bus_num(unsigned bus_idx) -{ - if (bus_idx >= ARRAY_SIZE(srdata.i2c_data)) - return -1; - if (!srdata.i2c_data[bus_idx].base) - return -1; - srdata.curr_i2c_bus = bus_idx; - return 0; -} -#endif - -int i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len) +static int mxc_i2c_read(struct i2c_adapter *adap, uint8_t chip, + uint addr, int alen, uint8_t *buffer, + int len) { - return bus_i2c_read(get_base(), chip, addr, alen, buf, len); + return bus_i2c_read(i2c_get_base(adap), chip, addr, alen, buffer, len); }
-int i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) +static int mxc_i2c_write(struct i2c_adapter *adap, uint8_t chip, + uint addr, int alen, uint8_t *buffer, + int len) { - return bus_i2c_write(get_base(), chip, addr, alen, buf, len); + return bus_i2c_write(i2c_get_base(adap), chip, addr, alen, buffer, len); }
/* * Test if a chip at a given address responds (probe the chip) */ -int i2c_probe(uchar chip) +static int mxc_i2c_probe(struct i2c_adapter *adap, uint8_t chip) { - return bus_i2c_write(get_base(), chip, 0, 0, NULL, 0); + return bus_i2c_write(i2c_get_base(adap), chip, 0, 0, NULL, 0); }
void bus_i2c_init(void *base, int speed, int unused, @@ -510,23 +514,38 @@ void bus_i2c_init(void *base, int speed, int unused, /* * Init I2C Bus */ -void i2c_init(int speed, int unused) +static void mxc_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) { - bus_i2c_init(get_base(), speed, unused, NULL, NULL); + bus_i2c_init(i2c_get_base(adap), speed, slaveaddr, NULL, NULL); }
/* * Set I2C Speed */ -int i2c_set_bus_speed(unsigned int speed) +static uint mxc_i2c_set_bus_speed(struct i2c_adapter *adap, uint speed) { - return bus_i2c_set_bus_speed(get_base(), speed); + return bus_i2c_set_bus_speed(i2c_get_base(adap), speed); }
/* - * Get I2C Speed + * Register mxc i2c adapters */ -unsigned int i2c_get_bus_speed(void) -{ - return bus_i2c_get_bus_speed(get_base()); -} +U_BOOT_I2C_ADAP_COMPLETE(mxc0, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C1_SPEED, + CONFIG_SYS_MXC_I2C1_SLAVE, 0) +U_BOOT_I2C_ADAP_COMPLETE(mxc1, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C2_SPEED, + CONFIG_SYS_MXC_I2C2_SLAVE, 1) +#if defined(CONFIG_MX31) || defined(CONFIG_MX35) ||\ + defined(CONFIG_MX51) || defined(CONFIG_MX53) ||\ + defined(CONFIG_MX6) +U_BOOT_I2C_ADAP_COMPLETE(mxc2, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C3_SPEED, + CONFIG_SYS_MXC_I2C3_SLAVE, 2) +#endif
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr --- include/configs/apf27.h | 11 ++++++----- include/configs/flea3.h | 9 ++++----- include/configs/imx31_phycore.h | 7 +++---- include/configs/m53evk.h | 7 +++---- include/configs/mx25pdk.h | 7 +++---- include/configs/mx35pdk.h | 7 +++---- include/configs/mx53ard.h | 7 +++---- include/configs/mx53evk.h | 7 +++---- include/configs/mx53loco.h | 7 +++---- include/configs/mx53smd.h | 7 +++---- include/configs/mx6qsabreauto.h | 4 ++-- include/configs/nitrogen6x.h | 4 ++-- include/configs/titanium.h | 4 ++-- include/configs/vf610twr.h | 7 +++---- include/configs/woodburn_common.h | 7 +++---- 15 files changed, 46 insertions(+), 56 deletions(-)
diff --git a/include/configs/apf27.h b/include/configs/apf27.h index e7e258f..1193013 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -321,11 +321,12 @@ */
#ifdef CONFIG_CMD_I2C -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE IMX_I2C1_BASE -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_MXC_I2C1_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_MXC_I2C1_SLAVE 0x7F +#define CONFIG_SYS_MXC_I2C2_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_MXC_I2C2_SLAVE 0x7F #define CONFIG_SYS_I2C_NOPROBES { }
#ifdef CONFIG_CMD_EEPROM diff --git a/include/configs/flea3.h b/include/configs/flea3.h index cfcaf1b..a330d39 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -50,11 +50,10 @@ /* * Hardware drivers */ -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C3_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 0xfe +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 2 /* I2C3 */ +#define CONFIG_SYS_MXC_I2C3_SLAVE 0xfe #define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 720e1bf..db43f19 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -35,11 +35,10 @@ * Hardware drivers */
-#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 1 /* I2C2 */ #define CONFIG_SYS_I2C_CLK_OFFSET I2C2_CLK_OFFSET -#define CONFIG_SYS_I2C_SPEED 100000
#define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index ccb07e3..1fd8b72 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -161,10 +161,9 @@ * I2C */ #ifdef CONFIG_CMD_I2C -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 1 /* I2C2 */ #endif
/* diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 543c415..256b3c1 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -111,10 +111,9 @@
/* I2C Configs */ #define CONFIG_CMD_I2C -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE IMX_I2C_BASE -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0 /* I2C1 */
/* RTC */ #define CONFIG_RTC_IMXDI diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 68b225a..8966581 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -41,10 +41,9 @@ /* * Hardware drivers */ -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C1_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0 /* I2C1 */ #define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO
diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 122ffd0..f0cc483 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -44,10 +44,9 @@
/* I2C Configs */ #define CONFIG_CMD_I2C -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 1 /* I2C2 */
/* MMC Configs */ #define CONFIG_FSL_ESDHC diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index d39ce7b..2beb433 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -37,10 +37,9 @@
/* PMIC Configs */ #define CONFIG_POWER diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 7237da5..a936fb4 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -71,10 +71,9 @@ #define CONFIG_MXC_USB_FLAGS 0
/* I2C Configs */ -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C1_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0 /* I2C1 */
/* PMIC Controller */ #define CONFIG_POWER diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 7e4e1c9..72c21f9 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -34,10 +34,9 @@
/* MMC Configs */ #define CONFIG_FSL_ESDHC diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 5530fc6..e0200c7 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -36,8 +36,8 @@
/* I2C Configs */ #define CONFIG_CMD_I2C -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_SPEED 100000
#endif /* __MX6QSABREAUTO_CONFIG_H */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 3454b86..d515e49 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -52,8 +52,8 @@
/* OCOTP Configs */ diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 077e25e..0769f07 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -41,8 +41,8 @@
/* MMC Configs */ diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 5a7a066..34861f6 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -70,10 +70,9 @@
/* I2C Configs */ #define CONFIG_CMD_I2C -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C0_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0
#define CONFIG_BOOTDELAY 3
diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 6b7e81f..24f331a 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -45,10 +45,9 @@ /* * Hardware drivers */ -#define CONFIG_HARD_I2C -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_BASE I2C1_BASE_ADDR -#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0 #define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO
Philippe Reynes
