[U-Boot] [PATCH] power: pwm regulator: support live tree
Use live tree compatible api for pwm regulator.
Signed-off-by: Andy Yan andy.yan@rock-chips.com ---
drivers/power/regulator/pwm_regulator.c | 12 ++++-------- 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/power/regulator/pwm_regulator.c b/drivers/power/regulator/pwm_regulator.c index b63f941..bf13b94 100644 --- a/drivers/power/regulator/pwm_regulator.c +++ b/drivers/power/regulator/pwm_regulator.c @@ -94,13 +94,10 @@ static int pwm_regulator_set_voltage(struct udevice *dev, int uvolt) static int pwm_regulator_ofdata_to_platdata(struct udevice *dev) { struct pwm_regulator_info *priv = dev_get_priv(dev); - struct fdtdec_phandle_args args; - const void *blob = gd->fdt_blob; - int node = dev_of_offset(dev); + struct ofnode_phandle_args args; int ret;
- ret = fdtdec_parse_phandle_with_args(blob, node, "pwms", "#pwm-cells", - 0, 0, &args); + ret = dev_read_phandle_with_args(dev, "pwms", "#pwm-cells", 0, 0, &args); if (ret) { debug("%s: Cannot get PWM phandle: ret=%d\n", __func__, ret); return ret; @@ -109,14 +106,13 @@ static int pwm_regulator_ofdata_to_platdata(struct udevice *dev) priv->period_ns = args.args[1]; priv->polarity = args.args[2];
- priv->init_voltage = fdtdec_get_int(blob, node, - "regulator-init-microvolt", -1); + priv->init_voltage = dev_read_u32_default(dev, "regulator-init-microvolt", -1); if (priv->init_voltage < 0) { printf("Cannot find regulator pwm init_voltage\n"); return -EINVAL; }
- ret = uclass_get_device_by_of_offset(UCLASS_PWM, args.node, &priv->pwm); + ret = uclass_get_device_by_ofnode(UCLASS_PWM, args.node, &priv->pwm); if (ret) { debug("%s: Cannot get PWM: ret=%d\n", __func__, ret); return ret;
Andy Yan
