[U-Boot] [PATCH 1/3] Blackfin: add cache_dump commands
A few debug-type commands used to dump the raw icache/dcache data. Useful when trying to track down cache-related bugs.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/Makefile | 1 + lib_blackfin/cmd_cache_dump.c | 145 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 146 insertions(+), 0 deletions(-) create mode 100644 lib_blackfin/cmd_cache_dump.c
diff --git a/lib_blackfin/Makefile b/lib_blackfin/Makefile index e32ecc9..4bdf6d3 100644 --- a/lib_blackfin/Makefile +++ b/lib_blackfin/Makefile @@ -40,6 +40,7 @@ COBJS-y += board.o COBJS-y += boot.o COBJS-y += cache.o COBJS-y += clocks.o +COBJS-$(CONFIG_CMD_CACHE_DUMP) += cmd_cache_dump.o COBJS-y += muldi3.o COBJS-$(CONFIG_POST) += post.o tests.o COBJS-y += string.o diff --git a/lib_blackfin/cmd_cache_dump.c b/lib_blackfin/cmd_cache_dump.c new file mode 100644 index 0000000..de5840e --- /dev/null +++ b/lib_blackfin/cmd_cache_dump.c @@ -0,0 +1,145 @@ +/* + * U-boot - cmd_cache_dump.c + * + * Copyright (c) 2007-2008 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <config.h> +#include <common.h> +#include <command.h> + +#include <asm/blackfin.h> +#include <asm/mach-common/bits/mpu.h> + +static int check_limit(const char *type, size_t start_limit, size_t end_limit, size_t start, size_t end) +{ + if (start >= start_limit && start <= end_limit && \ + end <= end_limit && end >= start_limit && \ + start <= end) + return 0; + + printf("%s limit violation: %zu <= (user:%zu) <= (user:%zu) <= %zu\n", + type, start_limit, start, end, end_limit); + return 1; +} + +int do_icache_dump(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int cache_status = icache_status(); + + if (cache_status) + icache_disable(); + + uint32_t cmd_base, tag, cache_upper, cache_lower; + + size_t way, way_start = 0, way_end = 3; + size_t sbnk, sbnk_start = 0, sbnk_end = 3; + size_t set, set_start = 0, set_end = 31; + size_t dw; + + if (argc > 1) { + way_start = way_end = simple_strtoul(argv[1], NULL, 10); + if (argc > 2) { + sbnk_start = sbnk_end = simple_strtoul(argv[2], NULL, 10); + if (argc > 3) + set_start = set_end = simple_strtoul(argv[3], NULL, 10); + } + } + + if (check_limit("way", 0, 3, way_start, way_end) || \ + check_limit("subbank", 0, 3, sbnk_start, sbnk_end) || \ + check_limit("set", 0, 31, set_start, set_end)) + return 1; + + puts("Way:Subbank:Set: [valid-tag lower upper] {invalid-tag lower upper}...\n"); + + for (way = way_start; way <= way_end; ++way) { + for (sbnk = sbnk_start; sbnk <= sbnk_end; ++sbnk) { + for (set = set_start; set <= set_end; ++set) { + printf("%zu:%zu:%2zu: ", way, sbnk, set); + for (dw = 0; dw < 4; ++dw) { + if (ctrlc()) + return 1; + + cmd_base = \ + (way << 26) | \ + (sbnk << 16) | \ + (set << 5) | \ + (dw << 3); + + /* first read the tag */ + bfin_write_ITEST_COMMAND(cmd_base | 0x0); + SSYNC(); + tag = bfin_read_ITEST_DATA0(); + printf("%c%08x ", (tag & 0x1 ? ' ' : '{'), tag); + + /* grab the data at this loc */ + bfin_write_ITEST_COMMAND(cmd_base | 0x4); + SSYNC(); + cache_lower = bfin_read_ITEST_DATA0(); + cache_upper = bfin_read_ITEST_DATA1(); + printf("%08x %08x%c ", cache_lower, cache_upper, (tag & 0x1 ? ' ' : '}')); + } + puts("\n"); + } + } + } + + if (cache_status) + icache_enable(); + + return 0; +} + +U_BOOT_CMD(icache_dump, 4, 0, do_icache_dump, + "icache_dump - dump current instruction cache\n", + "[way] [subbank] [set]"); + +int do_dcache_dump(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + u32 way, bank, subbank, set; + u32 status, addr; + u32 dmem_ctl = bfin_read_DMEM_CONTROL(); + + for (bank = 0; bank < 2; ++bank) { + if (!(dmem_ctl & (1 << (DMC1_P - bank)))) + continue; + + for (way = 0; way < 2; ++way) + for (subbank = 0; subbank < 4; ++subbank) { + printf("%i:%i:%i:\t", bank, way, subbank); + for (set = 0; set < 64; ++set) { + + if (ctrlc()) + return 1; + + /* retrieve a cache tag */ + bfin_write_DTEST_COMMAND( + way << 26 | + bank << 23 | + subbank << 16 | + set << 5 + ); + CSYNC(); + status = bfin_read_DTEST_DATA0(); + + /* construct the address using the tag */ + addr = (status & 0xFFFFC800) | (subbank << 12) | (set << 5); + + /* show it */ + if (set && !(set % 4)) + puts("\n\t"); + printf("%c%08x%c%08x%c ", (status & 0x1 ? '[' : '{'), status, (status & 0x2 ? 'd' : ' '), addr, (status & 0x1 ? ']' : '}')); + } + puts("\n"); + } + } + + return 0; +} + +U_BOOT_CMD(dcache_dump, 4, 0, do_dcache_dump, + "dcache_dump - dump current data cache\n", + "[bank] [way] [subbank] [set]");
The latest blackstamp boards can only run the SPI flash at 15MHz before they start to crap out, so lower the max speeds accordingly. The new SPI flash also has different sector requirements, so update the environment sizes as well.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/blackstamp.h | 9 ++++----- 1 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index 1e4c716..887f3fb 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -83,10 +83,9 @@ #endif
#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x4000 +#define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x40000 -#define ENV_IS_EMBEDDED_CUSTOM
/* * SDRAM settings & memory map @@ -245,9 +244,9 @@ * Serial Flash Infomation */ #define CONFIG_BFIN_SPI -/* For the M25P64 SCK Should be Kept < 20Mhz */ -#define CONFIG_ENV_SPI_MAX_HZ 20000000 -#define CONFIG_SF_DEFAULT_SPEED 20000000 +/* For the M25P64 SCK Should be Kept < 15Mhz */ +#define CONFIG_ENV_SPI_MAX_HZ 15000000 +#define CONFIG_SF_DEFAULT_SPEED 15000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
From: Harald Krapfenbauer Harald.Krapfenbauer@bluetechnix.at
The cm-bf561 module can easily hook up to the EXT-BF5xx-USB-ETH2 extender board, so add a simple example of how to do that in the board config.
Signed-off-by: Harald Krapfenbauer Harald.Krapfenbauer@bluetechnix.at Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/cm-bf561.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/configs/cm-bf561.h b/include/configs/cm-bf561.h index 53a2580..1153f11 100644 --- a/include/configs/cm-bf561.h +++ b/include/configs/cm-bf561.h @@ -60,8 +60,13 @@ * Network Settings */ #define ADI_CMDS_NETWORK 1 +/* The next 2 lines are for use with DEV-BF5xx */ #define CONFIG_DRIVER_SMC91111 1 #define CONFIG_SMC91111_BASE 0x28000300 +/* The next 3 lines are for use with EXT-BF5xx-USB-ETH2 */ +/* #define CONFIG_DRIVER_SMC911X 1 */ +/* #define CONFIG_DRIVER_SMC911X_BASE 0x24080000 // AMS1 */ +/* #define CONFIG_DRIVER_SMC911X_32_BIT 1 */ #define CONFIG_HOSTNAME cm-bf561 /* Uncomment next line to use fixed MAC address */ /* #define CONFIG_ETHADDR 02:80:ad:20:31:cf */
If doing a pure write with register address and data (not a read/write combo transfer), we don't set the initial transfer length properly which ends up causing only the register address to be transferred.
While we're here, fix the i2c_write() parameter description of the buffer.
Signed-off-by: Peter Meerwald pmeerw@pmeerw.net Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/i2c/bfin-twi_i2c.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/bfin-twi_i2c.c b/drivers/i2c/bfin-twi_i2c.c index cfe55cd..e790634 100644 --- a/drivers/i2c/bfin-twi_i2c.c +++ b/drivers/i2c/bfin-twi_i2c.c @@ -164,7 +164,7 @@ static int i2c_transfer(uchar chip, uint addr, int alen, uchar *buffer, int len,
/* prime the pump */ if (msg.alen) { - len = msg.alen; + len = (msg.flags & I2C_M_COMBO) ? msg.alen : msg.alen + len; debugi("first byte=0x%02x", *msg.abuf); bfin_write_TWI_XMT_DATA8(*(msg.abuf++)); --msg.alen; @@ -275,7 +275,7 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) * @chip: i2c chip addr * @addr: memory (register) address in the chip * @alen: byte size of address - * @buffer: buffer to store data read from chip + * @buffer: buffer holding data to write to chip * @len: how many bytes to write * @return: 0 on success, non-0 on failure */
Mike Frysinger
