[U-Boot] [PATCH 0/4] Some patman fixes
Patman is the great tool but I've found it nearly unusable for me. First of all I need to work with multiple signoffs in commits, then I'd like to use multiline changelog entries and I accostomed to putting changelog enties to the bottom of the commit.
These patches fix changelog processing and disables additional signoff and changelog processing.
Ilya Yanok (4): patman: fix end of changes detection patman: don't pick changes while processing patches patman: don't mess with changelog patman: don't mess with signoffs
tools/patman/patchstream.py | 22 ++++++++++------------ tools/patman/series.py | 5 ++--- 2 files changed, 12 insertions(+), 15 deletions(-)
Changes may end in '---' line or Signoff line (generated by git format-patch) in case of Series-changes: lines being the last ones in commit message. So detect it properly.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- tools/patman/patchstream.py | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index be40af3..036b129 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -36,6 +36,9 @@ re_remove = re.compile('^BUG=|^TEST=|^Change-Id:|^Review URL:' # Lines which are allowed after a TEST= line re_allowed_after_test = re.compile('^Signed-off-by:')
+# Signoffs +re_signoff = re.compile('^Signed-off-by:') + # The start of the cover letter re_cover = re.compile('^Cover-letter:')
@@ -207,6 +210,9 @@ class PatchStream: if is_blank: # Blank line ends this change list self.in_change = 0 + elif line == '---' or re_signoff.match(line): + self.in_change = 0 + out = self.ProcessLine(line) else: self.series.AddChange(self.in_change, self.commit, line) self.skip_blank = False
Dear Ilya Yanok,
In message 1344332768-11891-2-git-send-email-ilya.yanok@cogentembedded.com you wrote:
Applied, thanks.
We already got all changes from git log output and the comment to the ProcessLine function clearly states that 'patch' mode is not for scanning tags.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- tools/patman/patchstream.py | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 036b129..3de32d5 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -214,7 +214,8 @@ class PatchStream: self.in_change = 0 out = self.ProcessLine(line) else: - self.series.AddChange(self.in_change, self.commit, line) + if self.is_log: + self.series.AddChange(self.in_change, self.commit, line) self.skip_blank = False
# Detect Series-xxx tags
Dear Ilya Yanok,
In message 1344332768-11891-3-git-send-email-ilya.yanok@cogentembedded.com you wrote:
Applied, thanks.
Don't try to sort and uniq changelog entries as this breaks multiline entries. It will be better to add some real multi-line support but for now just preserve the entries as is.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- tools/patman/series.py | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/tools/patman/series.py b/tools/patman/series.py index 05d9e73..4e7cb71 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -154,10 +154,9 @@ class Series(dict): for this_commit, text in self.changes[change]: if commit and this_commit != commit: continue - if text not in out: - out.append(text) + out.append(text) if out: - out = ['Changes in v%d:' % change] + sorted(out) + out = ['Changes in v%d:' % change] + out if need_blank: out = [''] + out final += out
Dear Ilya Yanok,
In message 1344332768-11891-4-git-send-email-ilya.yanok@cogentembedded.com you wrote:
Applied, thanks.
Currently patman assumes that there should be only one Signoff line and this is obviously incorrect: we often have to work with patches containing other people signoffs. Moreover, it's really desirable to preserve the comments between signoffs.
So until some sophisticated signoff processing will be developed I suggest just don't mess with signoffs at all and treat them like plain text lines. The only drawback I've found so far is the case where you have a patch with someones else signoff but not yours and also have to patman tags under signoff line. In this case you will get extra empty line between signoffs.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- tools/patman/patchstream.py | 13 ++----------- 1 file changed, 2 insertions(+), 11 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 3de32d5..0503bac 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -46,7 +46,7 @@ re_cover = re.compile('^Cover-letter:') re_series = re.compile('^Series-(\w*): *(.*)')
# Commit tags that we want to collect and keep -re_tag = re.compile('^(Tested-by|Acked-by|Signed-off-by|Cc): (.*)') +re_tag = re.compile('^(Tested-by|Acked-by|Cc): (.*)')
# The start of a new commit in the git log re_commit = re.compile('^commit (.*)') @@ -241,15 +241,8 @@ class PatchStream:
# Detect tags in the commit message elif tag_match: - # Onlly allow a single signoff tag - if tag_match.group(1) == 'Signed-off-by': - if self.signoff: - self.warn.append('Patch has more than one Signed-off-by ' - 'tag') - self.signoff += [line] - # Remove Tested-by self, since few will take much notice - elif (tag_match.group(1) == 'Tested-by' and + if (tag_match.group(1) == 'Tested-by' and tag_match.group(2).find(os.getenv('USER') + '@') != -1): self.warn.append("Ignoring %s" % line) elif tag_match.group(1) == 'Cc': @@ -288,8 +281,6 @@ class PatchStream:
# Output the tags (signeoff first), then change list out = [] - if self.signoff: - out += self.signoff log = self.series.MakeChangeLog(self.commit) out += self.FormatTags(self.tags) out += [line] + log
Dear Ilya Yanok,
In message 1344332768-11891-5-git-send-email-ilya.yanok@cogentembedded.com you wrote:
Applied, thanks.
On Tue, Aug 7, 2012 at 2:46 AM, Ilya Yanok ilya.yanok@cogentembedded.com wrote:
I do wonder whether there should at least be options to sort/uniq entries and use the 'one line' format. I try to keep the changelog to a single line for each thing I change, and the merging that happens in the cover letter is useful, I think.
-- 1.7.9.5
Ilya Yanok
