[U-Boot-Users] Issues with U-boot port
Hi all,
1) We have a custom board based on MPC8280 processor. U-boot flash part is running properly on the board, even relocation is happening. This was confirmed by seeing the copied data from flash to RAM. But after printing the RAM size on the serial console u-boot is not proceeding. The system hangs. 2) If I try to switch on the DEBUG flag in the config.mk, my hardware is getting continuous reset. It is doing so because of getting some wrong addressing while executing init_debug module in start.S. Is point 1 and 2 related ? Also my printfs do not work. 3) Even when I do a debug using GDB I face a problem as stated in 2). In 2 and 3 what we see is that flash gets into command mode and whenever we use BDi2000 to display the flash area, we see that flash is in command mode and is displaying the status of the last command (Possible reason for a reset). We have to write 0xffffffff manually to make it come out of the command mode . We use a micron Flash compatible with Intel strata flash. MT28F128J3. (P.S : we have commented out the flash initialization part)
Thanking you all.
With Regards, C.R.Srivatsan
(P.S : please excuse me if this mail reaches in HTML format, I have selected text mode here. I am not sure whats the problem. Excuse me).
Srivatsan CR
