[PATCH] ARM: imx: Deduplicate i.MX8M SNVS LPGPR unlock
Pull this LPGPR unlock into common code, since it is used in multiple systems already.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/include/asm/arch-imx8m/imx-regs.h | 5 +++++ arch/arm/mach-imx/imx8m/soc.c | 12 ++++++++++ .../imx8mm_data_modul_edm_sbc.c | 22 ------------------- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 17 -------------- board/menlo/mx8menlo/mx8menlo.c | 17 -------------- 5 files changed, 17 insertions(+), 56 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index ff3b9ddd9f7..29d5baaab8b 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -27,6 +27,7 @@ #define IOMUXC_GPR_BASE_ADDR 0x30340000 #define OCOTP_BASE_ADDR 0x30350000 #define ANATOP_BASE_ADDR 0x30360000 +#define SNVS_BASE_ADDR 0x30370000 #define CCM_BASE_ADDR 0x30380000 #define SRC_BASE_ADDR 0x30390000 #define GPC_BASE_ADDR 0x303A0000 @@ -113,6 +114,10 @@ #define SRC_DDR1_RCR_CORE_RESET_N_MASK BIT(1) #define SRC_DDR1_RCR_PRESET_N_MASK BIT(0)
+#define SNVS_LPSR 0x4c +#define SNVS_LPLVDR 0x64 +#define SNVS_LPPGDR_INIT 0x41736166 + struct iomuxc_gpr_base_regs { u32 gpr[47]; }; diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index d115b25a5b6..5739546c022 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -544,6 +544,16 @@ static int imx8m_check_clock(void *ctx, struct event *event) } EVENT_SPY(EVT_DM_POST_INIT, imx8m_check_clock);
+static void imx8m_setup_snvs(void) +{ + /* Enable SNVS clock */ + clock_enable(CCGR_SNVS, 1); + /* Initialize glitch detect */ + writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); + /* Clear interrupt status */ + writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); +} + int arch_cpu_init(void) { struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; @@ -594,6 +604,8 @@ int arch_cpu_init(void) writel(0x200, &ocotp->ctrl_clr); }
+ imx8m_setup_snvs(); + return 0; }
diff --git a/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c b/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c index 6dc4e6a9a2b..a5905051dad 100644 --- a/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c +++ b/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c @@ -34,22 +34,6 @@ int board_phys_sdram_size(phys_size_t *size) return 0; }
-/* IMX8M SNVS registers needed for the bootcount functionality */ -#define SNVS_BASE_ADDR 0x30370000 -#define SNVS_LPSR 0x4c -#define SNVS_LPLVDR 0x64 -#define SNVS_LPPGDR_INIT 0x41736166 - -static void setup_snvs(void) -{ - /* Enable SNVS clock */ - clock_enable(CCGR_SNVS, 1); - /* Initialize glitch detect */ - writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); - /* Clear interrupt status */ - writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); -} - static void setup_mac_address(void) { unsigned char enetaddr[6]; @@ -97,12 +81,6 @@ static void setup_boot_device(void) env_set_ulong("devnum", 1); }
-int board_init(void) -{ - setup_snvs(); - return 0; -} - int board_late_init(void) { struct udevice *dev; diff --git a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c index 6f06daf86f7..9d8e19d994a 100644 --- a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c +++ b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c @@ -37,22 +37,6 @@ int board_phys_sdram_size(phys_size_t *size) return 0; }
-/* IMX8M SNVS registers needed for the bootcount functionality */ -#define SNVS_BASE_ADDR 0x30370000 -#define SNVS_LPSR 0x4c -#define SNVS_LPLVDR 0x64 -#define SNVS_LPPGDR_INIT 0x41736166 - -static void setup_snvs(void) -{ - /* Enable SNVS clock */ - clock_enable(CCGR_SNVS, 1); - /* Initialize glitch detect */ - writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); - /* Clear interrupt status */ - writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); -} - static void setup_eqos(void) { struct iomuxc_gpr_base_regs *gpr = @@ -145,7 +129,6 @@ int board_init(void) { setup_eqos(); setup_fec(); - setup_snvs(); return 0; }
diff --git a/board/menlo/mx8menlo/mx8menlo.c b/board/menlo/mx8menlo/mx8menlo.c index 9d3708a3637..61fc4ec85f0 100644 --- a/board/menlo/mx8menlo/mx8menlo.c +++ b/board/menlo/mx8menlo/mx8menlo.c @@ -12,24 +12,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <spl.h>
-#define SNVS_BASE_ADDR 0x30370000 -#define SNVS_LPSR 0x4c -#define SNVS_LPLVDR 0x64 -#define SNVS_LPPGDR_INIT 0x41736166 - -static void setup_snvs(void) -{ - /* Enable SNVS clock */ - clock_enable(CCGR_SNVS, 1); - /* Initialize glitch detect */ - writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); - /* Clear interrupt status */ - writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); -} - void board_early_init(void) { init_uart_clk(1); - - setup_snvs(); }
Reviewed-by: Fabio Estevam festevam@denx.de
Board is not built clean after applying this patch, I had to remove it. See:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/498918
Best regards, Stefano
Fabio Estevam
Stefano Babic
