[U-Boot] [PATCH v1 0/2] Add CONFIG_SYS_GENERIC_BOARD to all gdsys boards
Dirk Eibach (2): ppc: Make ppc4xx ready for CONFIG_SYS_GENERIC_BOARD board: Add CONFIG_SYS_GENERIC_BOARD to all gdsys boards
arch/powerpc/cpu/ppc4xx/cpu_init.c | 2 ++ include/configs/controlcenterd.h | 2 ++ include/configs/dlvision-10g.h | 1 + include/configs/dlvision.h | 1 + include/configs/gdppc440etx.h | 1 + include/configs/intip.h | 1 + include/configs/io.h | 1 + include/configs/io64.h | 1 + include/configs/iocon.h | 1 + include/configs/neo.h | 1 + 10 files changed, 12 insertions(+)
The generic board infrastructure assumes that gd is set by arch code.
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
arch/powerpc/cpu/ppc4xx/cpu_init.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index d465dcd..86891c1 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -451,6 +451,8 @@ cpu_init_f (void) mtdcr(PLB4A1_ACR, (mfdcr(PLB4A1_ACR) & ~PLB4Ax_ACR_RDP_MASK) | PLB4Ax_ACR_RDP_4DEEP); #endif /* CONFIG_440SP/SPE || CONFIG_460EX/GT || CONFIG_405EX */ + + gd = (gd_t *)(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); }
- gd = (gd_t *)(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); }
After applying both patches I get this:
Configuring for intip - Board: intip, Options: INTIB arch/powerpc/cpu/ppc4xx/cpu_init.c:455:2: error: 'gd' undeclared (first use in this function) make[1]: *** [arch/powerpc/cpu/ppc4xx/cpu_init.o] Error 1 make: *** [arch/powerpc/cpu/ppc4xx] Error 2 powerpc-linux-size: './u-boot': No such file arch/powerpc/cpu/ppc4xx/cpu_init.c: In function 'cpu_init_f': arch/powerpc/cpu/ppc4xx/cpu_init.c:455:2: error: 'gd' undeclared (first use in this function) arch/powerpc/cpu/ppc4xx/cpu_init.c:455:2: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [arch/powerpc/cpu/ppc4xx/cpu_init.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [arch/powerpc/cpu/ppc4xx] Error 2 make: *** Waiting for unfinished jobs....
Please fix and resubmit. And sorry for the delay.
Thanks, Stefan
Add the generic board infrastructure to all gdsys boards.
include/configs/controlcenterd.h | 2 ++ include/configs/dlvision-10g.h | 1 + include/configs/dlvision.h | 1 + include/configs/gdppc440etx.h | 1 + include/configs/intip.h | 1 + include/configs/io.h | 1 + include/configs/io64.h | 1 + include/configs/iocon.h | 1 + include/configs/neo.h | 1 + 9 files changed, 10 insertions(+)
diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 868813f..ed07a0f 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -45,6 +45,8 @@ #define CONFIG_CONTROLCENTERD #define CONFIG_MP /* support multiple processors */
+#define CONFIG_SYS_GENERIC_BOARD + #define CONFIG_SYS_NO_FLASH #define CONFIG_ENABLE_36BIT_PHYS #define CONFIG_FSL_LAW /* Use common FSL init code */ diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 7877897..ec85db2 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -24,6 +24,7 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT +#define CONFIG_SYS_GENERIC_BOARD
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */
diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index 1e86c55..af0d602 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -22,6 +22,7 @@
#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ #define CONFIG_MISC_INIT_R /* call misc_init_r */ +#define CONFIG_SYS_GENERIC_BOARD
diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 6810b3b..12fd75d 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -32,6 +32,7 @@
#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f*/ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ +#define CONFIG_SYS_GENERIC_BOARD
#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ #define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ diff --git a/include/configs/intip.h b/include/configs/intip.h index b56b3aa..928eb5b 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -45,6 +45,7 @@ #define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ #define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_SYS_GENERIC_BOARD #define CONFIG_BOARD_TYPES 1 /* support board types */ #define CONFIG_FIT #define CFG_ALT_MEMTEST diff --git a/include/configs/io.h b/include/configs/io.h index 9da6cc6..8c8afef 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -24,6 +24,7 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT +#define CONFIG_SYS_GENERIC_BOARD
diff --git a/include/configs/io64.h b/include/configs/io64.h index 6915b20..2a9ff37 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -43,6 +43,7 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT +#define CONFIG_SYS_GENERIC_BOARD
#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ #define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 79c4736..7fd7527 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -23,6 +23,7 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_LAST_STAGE_INIT +#define CONFIG_SYS_GENERIC_BOARD
diff --git a/include/configs/neo.h b/include/configs/neo.h index d549985..5fdeff1 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -25,6 +25,7 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT +#define CONFIG_SYS_GENERIC_BOARD
Ping.
2014-06-30 13:05 GMT+02:00 dirk.eibach@gdsys.cc:
-- 1.8.3
Dirk Eibach
Stefan Roese
