[PATCH 01/16] kbuild: Allow for CONFIG_SYS_CONFIG_NAME to be unset
It is possible to have a platform which does not require a board.h file to build, but today we need an empty one for our generated config.h file to be valid. Allow for omitting this file if CONFIG_SYS_CONFIG_NAME is not set.
Signed-off-by: Tom Rini trini@konsulko.com --- scripts/Makefile.autoconf | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index 0ade91642ae3..8208ffe22744 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -113,7 +113,7 @@ vpl/include/autoconf.mk: vpl/u-boot.cfg define filechk_config_h (echo "/* Automatically generated - do not edit */"; \ echo #define CFG_BOARDDIR board/$(if $(VENDOR),$(VENDOR)/)$(BOARD);\ - echo #include <configs/$(CONFIG_SYS_CONFIG_NAME).h>; \ + $(if $(CONFIG_SYS_CONFIG_NAME),echo #include <configs/$(CONFIG_SYS_CONFIG_NAME).h> ;) \ echo #include <asm/config.h>; \ echo #include <linux/kconfig.h>; \ echo #include <config_fallbacks.h>;)
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the xilinx_mbv platforms and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Michal Simek michal.simek@amd.com --- board/xilinx/mbv/Kconfig | 3 --- board/xilinx/mbv/MAINTAINERS | 1 - include/configs/xilinx_mbv.h | 6 ------ 3 files changed, 10 deletions(-) delete mode 100644 include/configs/xilinx_mbv.h
diff --git a/board/xilinx/mbv/Kconfig b/board/xilinx/mbv/Kconfig index 4bc9f72c541b..d2dec397ed6f 100644 --- a/board/xilinx/mbv/Kconfig +++ b/board/xilinx/mbv/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_CPU default "generic"
-config SYS_CONFIG_NAME - default "xilinx_mbv" - config TEXT_BASE default 0x80000000 if !RISCV_SMODE default 0x80400000 if RISCV_SMODE && ARCH_RV32I diff --git a/board/xilinx/mbv/MAINTAINERS b/board/xilinx/mbv/MAINTAINERS index 445654fe740e..db9f03388df9 100644 --- a/board/xilinx/mbv/MAINTAINERS +++ b/board/xilinx/mbv/MAINTAINERS @@ -4,4 +4,3 @@ S: Maintained F: arch/riscv/dts/xilinx-mbv* F: board/xilinx/mbv/ F: configs/xilinx_mbv* -F: include/configs/xilinx_mbv.h diff --git a/include/configs/xilinx_mbv.h b/include/configs/xilinx_mbv.h deleted file mode 100644 index dba398aeec49..000000000000 --- a/include/configs/xilinx_mbv.h +++ /dev/null @@ -1,6 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * (C) Copyright 2023, Advanced Micro Devices, Inc. - * - * Michal Simek michal.simek@amd.com - */
- (C) Copyright 2023, Advanced Micro Devices, Inc.
- Michal Simek michal.simek@amd.com
Acked-by: Michal Simek michal.simek@amd.com
But maybe in future we need to revert this patch to add more options there. Or do you plan to remove all of these configs? I can imagine distro boot wiring but that can be done via vars file only but it is not practical.
Thanks, Michal
diff --git a/board/xilinx/mbv/Kconfig b/board/xilinx/mbv/Kconfig index 4bc9f72c541b..d2dec397ed6f 100644 --- a/board/xilinx/mbv/Kconfig +++ b/board/xilinx/mbv/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_CPU default "generic" -config SYS_CONFIG_NAME
Do you mean that plain text environment feels impractical for standard boot (which should be used instead of the pure scripts of distro_boot) ?
I didn't play with standard boot yet to find out how to prioritize certain devices at run time. But normally we are trying to keep all amd platforms in sync to make sure that from user perspective doesn't really matter if you are on microblaze, arm32, arm64 or risc-v based platform.
There are still a lot of configs like GUIDs, dfu and others that I don't think we will end up without these config files anytime soon. But it doesn't mean we shouldn't aim for it.
Thanks, Michal
OK. Yeah, after a quick look at include/configs/xilinx* today, a lot of that could just be in standard boot and plain text environment and just like there's include/env/ti/ today to share common logic, we should get include/env/amd/ to share some common logic too. Or you and your team can suggest a better sharing alternative too.
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the coreboot platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/coreboot/coreboot/Kconfig | 7 ------- board/coreboot/coreboot/MAINTAINERS | 1 - include/configs/coreboot.h | 4 ---- 3 files changed, 12 deletions(-) delete mode 100644 include/configs/coreboot.h
diff --git a/board/coreboot/coreboot/Kconfig b/board/coreboot/coreboot/Kconfig index 4f41ce1abf10..abbf08ac695e 100644 --- a/board/coreboot/coreboot/Kconfig +++ b/board/coreboot/coreboot/Kconfig @@ -29,10 +29,3 @@ config SYS_CAR_SIZE This option specifies the board specific Cache-As-RAM (CAR) size.
endif # CONFIG_VENDOR_COREBOOT - -if TARGET_COREBOOT - -config SYS_CONFIG_NAME - default "coreboot" - -endif diff --git a/board/coreboot/coreboot/MAINTAINERS b/board/coreboot/coreboot/MAINTAINERS index f77736580006..d97383c030cd 100644 --- a/board/coreboot/coreboot/MAINTAINERS +++ b/board/coreboot/coreboot/MAINTAINERS @@ -2,7 +2,6 @@ COREBOOT BOARD M: Simon Glass sjg@chromium.org S: Maintained F: board/coreboot/ -F: include/configs/coreboot.h F: configs/coreboot_defconfig
COREBOOT64 BOARD diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h deleted file mode 100644 index e00c408f29a5..000000000000 --- a/include/configs/coreboot.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the bayleybay platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/intel/bayleybay/Kconfig | 3 --- board/intel/bayleybay/MAINTAINERS | 1 - include/configs/bayleybay.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/bayleybay.h
diff --git a/board/intel/bayleybay/Kconfig b/board/intel/bayleybay/Kconfig index 97228d630878..af08566014dc 100644 --- a/board/intel/bayleybay/Kconfig +++ b/board/intel/bayleybay/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "baytrail"
-config SYS_CONFIG_NAME - default "bayleybay" - config TEXT_BASE default 0xfff00000
diff --git a/board/intel/bayleybay/MAINTAINERS b/board/intel/bayleybay/MAINTAINERS index 85fa51626af7..5ab5d73f59e5 100644 --- a/board/intel/bayleybay/MAINTAINERS +++ b/board/intel/bayleybay/MAINTAINERS @@ -2,5 +2,4 @@ Intel Bayley Bay M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/intel/bayleybay -F: include/configs/bayleybay.h F: configs/bayleybay_defconfig diff --git a/include/configs/bayleybay.h b/include/configs/bayleybay.h deleted file mode 100644 index 9b0f5cedcd79..000000000000 --- a/include/configs/bayleybay.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the cherryhill platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/intel/cherryhill/Kconfig | 3 --- board/intel/cherryhill/MAINTAINERS | 1 - include/configs/cherryhill.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/cherryhill.h
diff --git a/board/intel/cherryhill/Kconfig b/board/intel/cherryhill/Kconfig index 009cd93b6d44..28e4735e4d65 100644 --- a/board/intel/cherryhill/Kconfig +++ b/board/intel/cherryhill/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "braswell"
-config SYS_CONFIG_NAME - default "cherryhill" - config TEXT_BASE default 0xffe00000
diff --git a/board/intel/cherryhill/MAINTAINERS b/board/intel/cherryhill/MAINTAINERS index 6e90f642125e..7c1b311990c4 100644 --- a/board/intel/cherryhill/MAINTAINERS +++ b/board/intel/cherryhill/MAINTAINERS @@ -2,5 +2,4 @@ INTEL CHERRYHILL BOARD M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/intel/cherryhill/ -F: include/configs/cherryhill.h F: configs/cherryhill_defconfig diff --git a/include/configs/cherryhill.h b/include/configs/cherryhill.h deleted file mode 100644 index a3009571de98..000000000000 --- a/include/configs/cherryhill.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the cougarcanyon2 platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/intel/cougarcanyon2/Kconfig | 3 --- board/intel/cougarcanyon2/MAINTAINERS | 1 - include/configs/cougarcanyon2.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/cougarcanyon2.h
diff --git a/board/intel/cougarcanyon2/Kconfig b/board/intel/cougarcanyon2/Kconfig index 32407025bc16..841e041167e8 100644 --- a/board/intel/cougarcanyon2/Kconfig +++ b/board/intel/cougarcanyon2/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "ivybridge"
-config SYS_CONFIG_NAME - default "cougarcanyon2" - config TEXT_BASE default 0xffe00000
diff --git a/board/intel/cougarcanyon2/MAINTAINERS b/board/intel/cougarcanyon2/MAINTAINERS index a486739b5eea..a4f465cf5df3 100644 --- a/board/intel/cougarcanyon2/MAINTAINERS +++ b/board/intel/cougarcanyon2/MAINTAINERS @@ -2,5 +2,4 @@ INTEL COUGAR CANYON 2 BOARD M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/intel/cougarcanyon2/ -F: include/configs/cougarcanyon2.h F: configs/cougarcanyon2_defconfig diff --git a/include/configs/cougarcanyon2.h b/include/configs/cougarcanyon2.h deleted file mode 100644 index 0406786f7c66..000000000000 --- a/include/configs/cougarcanyon2.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the crownbay platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/intel/crownbay/Kconfig | 3 --- board/intel/crownbay/MAINTAINERS | 1 - include/configs/crownbay.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/crownbay.h
diff --git a/board/intel/crownbay/Kconfig b/board/intel/crownbay/Kconfig index eb2290cfafbe..09614ab8d155 100644 --- a/board/intel/crownbay/Kconfig +++ b/board/intel/crownbay/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "queensbay"
-config SYS_CONFIG_NAME - default "crownbay" - config TEXT_BASE default 0xfff00000
diff --git a/board/intel/crownbay/MAINTAINERS b/board/intel/crownbay/MAINTAINERS index 1eb68693df3e..e2d8e6bc1d0d 100644 --- a/board/intel/crownbay/MAINTAINERS +++ b/board/intel/crownbay/MAINTAINERS @@ -2,5 +2,4 @@ INTEL CROWNBAY BOARD M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/intel/crownbay/ -F: include/configs/crownbay.h F: configs/crownbay_defconfig diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h deleted file mode 100644 index 0c842dd01ebe..000000000000 --- a/include/configs/crownbay.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the edison platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Andy Shevchenko andriy.shevchenko@linux.intel.com --- board/intel/edison/Kconfig | 3 --- board/intel/edison/MAINTAINERS | 1 - include/configs/edison.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/edison.h
diff --git a/board/intel/edison/Kconfig b/board/intel/edison/Kconfig index 5efda4b3a554..daa8d2035cd5 100644 --- a/board/intel/edison/Kconfig +++ b/board/intel/edison/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "tangier"
-config SYS_CONFIG_NAME - default "edison" - config SYS_MALLOC_LEN default 0x08000000
diff --git a/board/intel/edison/MAINTAINERS b/board/intel/edison/MAINTAINERS index 4bc4a00c8ad8..26b27c5dfe15 100644 --- a/board/intel/edison/MAINTAINERS +++ b/board/intel/edison/MAINTAINERS @@ -2,5 +2,4 @@ Intel Edison Board M: Andy Shevchenko andriy.shevchenko@linux.intel.com S: Maintained F: board/intel/edison -F: include/configs/edison.h F: configs/edison_defconfig diff --git a/include/configs/edison.h b/include/configs/edison.h deleted file mode 100644 index 127c2c4546e0..000000000000 --- a/include/configs/edison.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2017 Intel Corp. - */
Acked-by: Andy Shevchenko andriy.shevchenko@linux.intel.com
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the efi-x86_app* platforms and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Simon Glass sjg@chromium.org Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- board/efi/efi-x86_app/Kconfig | 3 --- board/efi/efi-x86_app/MAINTAINERS | 2 -- include/configs/efi-x86_app.h | 4 ---- 3 files changed, 9 deletions(-) delete mode 100644 include/configs/efi-x86_app.h
diff --git a/board/efi/efi-x86_app/Kconfig b/board/efi/efi-x86_app/Kconfig index ecd08d73146a..f9cbef0a864c 100644 --- a/board/efi/efi-x86_app/Kconfig +++ b/board/efi/efi-x86_app/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "efi"
-config SYS_CONFIG_NAME - default "efi-x86_app" - config BOARD_SPECIFIC_OPTIONS # dummy def_bool y imply VIDEO_EFI diff --git a/board/efi/efi-x86_app/MAINTAINERS b/board/efi/efi-x86_app/MAINTAINERS index 584619c51dff..693f367311bc 100644 --- a/board/efi/efi-x86_app/MAINTAINERS +++ b/board/efi/efi-x86_app/MAINTAINERS @@ -3,7 +3,6 @@ M: Simon Glass sjg@chromium.org S: Maintained F: board/efi/Kconfig F: board/efi/efi-x86_app/ -F: include/configs/efi-x86_app.h F: configs/efi-x86_app32_defconfig
EFI-X86_APP64 BOARD @@ -11,5 +10,4 @@ M: Simon Glass sjg@chromium.org S: Maintained F: board/efi/Kconfig F: board/efi/efi-x86_app/ -F: include/configs/efi-x86_app.h F: configs/efi-x86_app64_defconfig diff --git a/include/configs/efi-x86_app.h b/include/configs/efi-x86_app.h deleted file mode 100644 index d5824049d697..000000000000 --- a/include/configs/efi-x86_app.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2015 Google, Inc - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the efi-x86_payload* platforms and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Simon Glass sjg@chromium.org Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- board/efi/efi-x86_payload/Kconfig | 3 --- board/efi/efi-x86_payload/MAINTAINERS | 1 - include/configs/efi-x86_payload.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/efi-x86_payload.h
diff --git a/board/efi/efi-x86_payload/Kconfig b/board/efi/efi-x86_payload/Kconfig index 6d062499346d..c500ca02ebf5 100644 --- a/board/efi/efi-x86_payload/Kconfig +++ b/board/efi/efi-x86_payload/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "efi"
-config SYS_CONFIG_NAME - default "efi-x86_payload" - config TEXT_BASE default 0x00200000
diff --git a/board/efi/efi-x86_payload/MAINTAINERS b/board/efi/efi-x86_payload/MAINTAINERS index d795d60e09e4..3c5d48aa84cc 100644 --- a/board/efi/efi-x86_payload/MAINTAINERS +++ b/board/efi/efi-x86_payload/MAINTAINERS @@ -3,6 +3,5 @@ M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/efi/Kconfig F: board/efi/efi-x86_payload/ -F: include/configs/efi-x86_payload.h F: configs/efi-x86_payload32_defconfig F: configs/efi-x86_payload64_defconfig diff --git a/include/configs/efi-x86_payload.h b/include/configs/efi-x86_payload.h deleted file mode 100644 index e00c408f29a5..000000000000 --- a/include/configs/efi-x86_payload.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the galileo platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/intel/galileo/Kconfig | 3 --- board/intel/galileo/MAINTAINERS | 1 - include/configs/galileo.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/galileo.h
diff --git a/board/intel/galileo/Kconfig b/board/intel/galileo/Kconfig index 4c0451da48da..15c8d1254089 100644 --- a/board/intel/galileo/Kconfig +++ b/board/intel/galileo/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "quark"
-config SYS_CONFIG_NAME - default "galileo" - config TEXT_BASE default 0xfff10000
diff --git a/board/intel/galileo/MAINTAINERS b/board/intel/galileo/MAINTAINERS index dbbc82e8a1db..a5dcde7ad09d 100644 --- a/board/intel/galileo/MAINTAINERS +++ b/board/intel/galileo/MAINTAINERS @@ -2,5 +2,4 @@ INTEL GALILEO BOARD M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/intel/galileo/ -F: include/configs/galileo.h F: configs/galileo_defconfig diff --git a/include/configs/galileo.h b/include/configs/galileo.h deleted file mode 100644 index 9b0f5cedcd79..000000000000 --- a/include/configs/galileo.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the minnowmax platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Simon Glass sjg@chromium.org --- board/intel/minnowmax/Kconfig | 3 --- board/intel/minnowmax/MAINTAINERS | 1 - include/configs/minnowmax.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/minnowmax.h
diff --git a/board/intel/minnowmax/Kconfig b/board/intel/minnowmax/Kconfig index a03ef8678014..abb1d45ff614 100644 --- a/board/intel/minnowmax/Kconfig +++ b/board/intel/minnowmax/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "baytrail"
-config SYS_CONFIG_NAME - default "minnowmax" - config TEXT_BASE default 0xfff00000
diff --git a/board/intel/minnowmax/MAINTAINERS b/board/intel/minnowmax/MAINTAINERS index d655761d5783..5cb94b0f36c6 100644 --- a/board/intel/minnowmax/MAINTAINERS +++ b/board/intel/minnowmax/MAINTAINERS @@ -2,5 +2,4 @@ CircuitCo Minnowboard Max M: Simon Glass sjg@chromium.org S: Maintained F: board/intel/minnowmax -F: include/configs/minnowmax.h F: configs/minnowmax_defconfig diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h deleted file mode 100644 index 068a2af2c1fc..000000000000 --- a/include/configs/minnowmax.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2015 Google, Inc - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the qemu-x86* platforms and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Bin Meng bmeng.cn@gmail.com --- board/emulation/qemu-x86/Kconfig | 3 --- board/emulation/qemu-x86/MAINTAINERS | 2 -- include/configs/qemu-x86.h | 4 ---- 3 files changed, 9 deletions(-) delete mode 100644 include/configs/qemu-x86.h
diff --git a/board/emulation/qemu-x86/Kconfig b/board/emulation/qemu-x86/Kconfig index 01dc1d497aec..9a0611820ce1 100644 --- a/board/emulation/qemu-x86/Kconfig +++ b/board/emulation/qemu-x86/Kconfig @@ -9,9 +9,6 @@ config SYS_VENDOR config SYS_SOC default "qemu"
-config SYS_CONFIG_NAME - default "qemu-x86" - config TEXT_BASE default 0xfff00000 if !SUPPORT_SPL default 0x01110000 if SUPPORT_SPL diff --git a/board/emulation/qemu-x86/MAINTAINERS b/board/emulation/qemu-x86/MAINTAINERS index e62585a65d7d..efb8b46daaf4 100644 --- a/board/emulation/qemu-x86/MAINTAINERS +++ b/board/emulation/qemu-x86/MAINTAINERS @@ -3,7 +3,6 @@ M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/emulation/qemu-x86/ F: board/emulation/common/ -F: include/configs/qemu-x86.h F: configs/qemu-x86_defconfig
QEMU X86 64-bit BOARD @@ -11,5 +10,4 @@ M: Bin Meng bmeng.cn@gmail.com S: Maintained F: board/emulation/qemu-x86/ F: board/emulation/common/ -F: include/configs/qemu-x86.h F: configs/qemu-x86_64_defconfig diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h deleted file mode 100644 index 9b0f5cedcd79..000000000000 --- a/include/configs/qemu-x86.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the slimbootloader platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Aiden Park aiden.park@intel.com --- board/intel/slimbootloader/Kconfig | 3 --- board/intel/slimbootloader/MAINTAINERS | 1 - include/configs/slimbootloader.h | 4 ---- 3 files changed, 8 deletions(-) delete mode 100644 include/configs/slimbootloader.h
diff --git a/board/intel/slimbootloader/Kconfig b/board/intel/slimbootloader/Kconfig index 015ed51dc89c..11e6cb37bd85 100644 --- a/board/intel/slimbootloader/Kconfig +++ b/board/intel/slimbootloader/Kconfig @@ -13,9 +13,6 @@ config SYS_VENDOR config SYS_SOC default "slimbootloader"
-config SYS_CONFIG_NAME - default "slimbootloader" - config TEXT_BASE default 0x00100000
diff --git a/board/intel/slimbootloader/MAINTAINERS b/board/intel/slimbootloader/MAINTAINERS index e6935517e01a..0208a382ac6b 100644 --- a/board/intel/slimbootloader/MAINTAINERS +++ b/board/intel/slimbootloader/MAINTAINERS @@ -2,5 +2,4 @@ Intel Slim Bootloader Payload M: Aiden Park aiden.park@intel.com S: Maintained F: board/intel/slimbootloader -F: include/configs/slimbootloader.h F: configs/slimbootloader_defconfig diff --git a/include/configs/slimbootloader.h b/include/configs/slimbootloader.h deleted file mode 100644 index 85f6a968e040..000000000000 --- a/include/configs/slimbootloader.h +++ /dev/null @@ -1,4 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2019 Intel Corporation <www.intel.com> - */
Now that we support having CONFIG_SYS_CONFIG_NAME be unset to indicate a lack of board.h file, unset this on the hc2910-2aghd05 platform and remove the otherwise empty file.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Yang Xiwen firbidden405@outlook.com --- board/skyworth/hc2910-2aghd05/Kconfig | 3 --- board/skyworth/hc2910-2aghd05/MAINTAINERS | 1 - include/configs/hc2910-2aghd05.h | 6 ------ 3 files changed, 10 deletions(-) delete mode 100644 include/configs/hc2910-2aghd05.h
diff --git a/board/skyworth/hc2910-2aghd05/Kconfig b/board/skyworth/hc2910-2aghd05/Kconfig index f85f1f2631de..620a3177f488 100644 --- a/board/skyworth/hc2910-2aghd05/Kconfig +++ b/board/skyworth/hc2910-2aghd05/Kconfig @@ -9,7 +9,4 @@ config SYS_VENDOR config SYS_SOC default "hi3798mv200"
-config SYS_CONFIG_NAME - default "hc2910-2aghd05" - endif diff --git a/board/skyworth/hc2910-2aghd05/MAINTAINERS b/board/skyworth/hc2910-2aghd05/MAINTAINERS index 2c1e750018e1..13915556bc5e 100644 --- a/board/skyworth/hc2910-2aghd05/MAINTAINERS +++ b/board/skyworth/hc2910-2aghd05/MAINTAINERS @@ -2,5 +2,4 @@ HC2910 2AGHD05 BOARD M: Yang Xiwen firbidden405@outlook.com S: Maintained F: board/skyworth/hc2910-2aghd05 -F: include/configs/hc2910-2aghd05.h F: configs/hc2910_2aghd05_defconfig diff --git a/include/configs/hc2910-2aghd05.h b/include/configs/hc2910-2aghd05.h deleted file mode 100644 index 3db9a474ec7f..000000000000 --- a/include/configs/hc2910-2aghd05.h +++ /dev/null @@ -1,6 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ - -#ifndef __HC2910_2AGHD05_CONFIG_H__ -#define __HC2910_2AGHD05_CONFIG_H__ - -#endif
Generally speaking, we do not prompt for this value and define it in the board specific Kconfig file. There are some valid use cases however today where we do prompt for this value, so instead of having this be done in a number of locations, do this at the top-level location only.
This removes the question from a number of other locations and makes it consistent that when we do set the value directly, we always do it the same way. We don't need to specify the type, it's always string.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/Kconfig | 11 ++++++++++- arch/arm/mach-mediatek/Kconfig | 6 ------ arch/arm/mach-meson/Kconfig | 8 -------- arch/arm/mach-versal-net/Kconfig | 8 -------- arch/arm/mach-versal/Kconfig | 8 -------- arch/arm/mach-zynq/Kconfig | 8 -------- arch/arm/mach-zynqmp-r5/Kconfig | 8 -------- arch/arm/mach-zynqmp/Kconfig | 8 -------- arch/mips/mach-mtmips/mt7620/Kconfig | 1 - arch/mips/mach-mtmips/mt7621/Kconfig | 1 - arch/mips/mach-mtmips/mt7628/Kconfig | 1 - arch/nios2/Kconfig | 7 ------- board/Marvell/octeon_ebb7304/Kconfig | 1 - board/Marvell/octeon_nic23/Kconfig | 1 - board/cadence/xtfpga/Kconfig | 1 - board/cavium/thunderx/Kconfig | 1 - board/freescale/imxrt1020-evk/Kconfig | 1 - board/freescale/imxrt1050-evk/Kconfig | 1 - board/freescale/imxrt1170-evk/Kconfig | 1 - board/kontron/sl-mx6ul/Kconfig | 1 - board/kontron/sl-mx8mm/Kconfig | 1 - board/samsung/starqltechn/Kconfig | 8 -------- board/st/stih410-b2260/Kconfig | 1 - board/st/stm32f429-discovery/Kconfig | 1 - board/st/stm32f429-evaluation/Kconfig | 1 - board/st/stm32f469-discovery/Kconfig | 1 - board/st/stm32f746-disco/Kconfig | 1 - board/st/stm32h743-disco/Kconfig | 1 - board/st/stm32h743-eval/Kconfig | 1 - board/st/stm32h750-art-pi/Kconfig | 1 - board/sysam/amcore/Kconfig | 1 - board/xilinx/microblaze-generic/Kconfig | 8 -------- 32 files changed, 10 insertions(+), 99 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index b6fb9e927337..0d3cce919f8f 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -361,7 +361,16 @@ config SYS_BOARD leave this option empty.
config SYS_CONFIG_NAME - string + string "Board header file" if ARCH_MESON || ARCH_VERSAL || \ + ARCH_VERSAL_NET || ARCH_ZYNQ || ARCH_ZYNQMP || \ + ARCH_ZYNQMP_R5 || MICROBLAZE || NIOS2 + default "meson64" if ARCH_MESON + default "microblaze-generic" if MICROBLAZE + default "xilinx_versal" if ARCH_VERSAL + default "xilinx_versal_net" if ARCH_VERSAL_NET + default "xilinx_zynqmp" if ARCH_ZYNQMP + default "xilinx_zynqmp_r5" if ARCH_ZYNQMP_R5 + default "zynq-common" if ARCH_ZYNQ help This option should contain the base name of board header file. The header file include/configs/<CONFIG_SYS_CONFIG_NAME>.h diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index c3872f428697..82018bd9d3e3 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -133,7 +133,6 @@ config SYS_BOARD be used.
config SYS_CONFIG_NAME - string "Board configuration name" default "mt7622" if TARGET_MT7622 default "mt7623" if TARGET_MT7623 default "mt7629" if TARGET_MT7629 @@ -145,11 +144,6 @@ config SYS_CONFIG_NAME default "mt8512" if TARGET_MT8512 default "mt8516" if TARGET_MT8516 default "mt8518" if TARGET_MT8518 - default "" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration.
config MTK_BROM_HEADER_INFO string diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index d6c890580617..6e6f9c13f17d 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -88,12 +88,4 @@ config SYS_BOARD Based on this option board/<CONFIG_SYS_VENDOR>/<CONFIG_SYS_BOARD> will be used.
-config SYS_CONFIG_NAME - string "Board configuration name" - default "meson64" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - endif diff --git a/arch/arm/mach-versal-net/Kconfig b/arch/arm/mach-versal-net/Kconfig index edff5b039e91..1b5339993f83 100644 --- a/arch/arm/mach-versal-net/Kconfig +++ b/arch/arm/mach-versal-net/Kconfig @@ -13,14 +13,6 @@ config SYS_VENDOR config SYS_SOC default "versal-net"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "xilinx_versal_net" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config COUNTER_FREQUENCY int "Timer clock frequency" default 0 diff --git a/arch/arm/mach-versal/Kconfig b/arch/arm/mach-versal/Kconfig index 645f06add44d..629a14129d5a 100644 --- a/arch/arm/mach-versal/Kconfig +++ b/arch/arm/mach-versal/Kconfig @@ -13,14 +13,6 @@ config SYS_VENDOR config SYS_SOC default "versal"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "xilinx_versal" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config SYS_MALLOC_LEN default 0x2000000
diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index b4c439b4cd6d..265e9ce588ad 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -43,14 +43,6 @@ config SYS_VENDOR config SYS_SOC default "zynq"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "zynq-common" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config SYS_MALLOC_F_LEN default 0x800
diff --git a/arch/arm/mach-zynqmp-r5/Kconfig b/arch/arm/mach-zynqmp-r5/Kconfig index f14514b3c7c1..b2ba896e9b41 100644 --- a/arch/arm/mach-zynqmp-r5/Kconfig +++ b/arch/arm/mach-zynqmp-r5/Kconfig @@ -13,14 +13,6 @@ config SYS_VENDOR config SYS_SOC default "zynqmp-r5"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "xilinx_zynqmp_r5" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config CPU_FREQ_HZ int "CPU frequency" default 800000000 diff --git a/arch/arm/mach-zynqmp/Kconfig b/arch/arm/mach-zynqmp/Kconfig index 7e7c87d16fa9..6a7be0b42715 100644 --- a/arch/arm/mach-zynqmp/Kconfig +++ b/arch/arm/mach-zynqmp/Kconfig @@ -35,14 +35,6 @@ config SYS_VENDOR config SYS_SOC default "zynqmp"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "xilinx_zynqmp" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config SYS_MEM_RSVD_FOR_MMU bool "Reserve memory for MMU Table" help diff --git a/arch/mips/mach-mtmips/mt7620/Kconfig b/arch/mips/mach-mtmips/mt7620/Kconfig index 3ca711ad0f3f..398c7c6a9486 100644 --- a/arch/mips/mach-mtmips/mt7620/Kconfig +++ b/arch/mips/mach-mtmips/mt7620/Kconfig @@ -67,7 +67,6 @@ config CPU_FREQ_MULTI default 7 if CPU_FREQ_620MHZ
config SYS_CONFIG_NAME - string "Board configuration name" default "mt7620" if BOARD_MT7620_RFB || BOARD_MT7620_MT7530_RFB
config SYS_BOARD diff --git a/arch/mips/mach-mtmips/mt7621/Kconfig b/arch/mips/mach-mtmips/mt7621/Kconfig index 008a28f991ca..8fe6e0a2d9a8 100644 --- a/arch/mips/mach-mtmips/mt7621/Kconfig +++ b/arch/mips/mach-mtmips/mt7621/Kconfig @@ -102,7 +102,6 @@ config BOARD_MT7621_NAND_RFB endchoice
config SYS_CONFIG_NAME - string "Board configuration name" default "mt7621" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB
config SYS_BOARD diff --git a/arch/mips/mach-mtmips/mt7628/Kconfig b/arch/mips/mach-mtmips/mt7628/Kconfig index e7273591bca1..79b2ddc6692d 100644 --- a/arch/mips/mach-mtmips/mt7628/Kconfig +++ b/arch/mips/mach-mtmips/mt7628/Kconfig @@ -49,7 +49,6 @@ config SYS_BOARD default "mt7628" if BOARD_MT7628_RFB
config SYS_CONFIG_NAME - string "Board configuration name" default "mt7628" if BOARD_MT7628_RFB
source "board/gardena/smart-gateway-mt7688/Kconfig" diff --git a/arch/nios2/Kconfig b/arch/nios2/Kconfig index bb4fb2ac3a5c..b06b3efcf563 100644 --- a/arch/nios2/Kconfig +++ b/arch/nios2/Kconfig @@ -4,11 +4,4 @@ menu "Nios II architecture" config SYS_ARCH default "nios2"
-config SYS_CONFIG_NAME - string "Board header file" - help - This option should contain the base name of board header file. - The header file include/configs/<CONFIG_SYS_CONFIG_NAME>.h - should be included from include/config.h. - endmenu diff --git a/board/Marvell/octeon_ebb7304/Kconfig b/board/Marvell/octeon_ebb7304/Kconfig index ab54e6dbbc35..b3244f751b1f 100644 --- a/board/Marvell/octeon_ebb7304/Kconfig +++ b/board/Marvell/octeon_ebb7304/Kconfig @@ -9,7 +9,6 @@ config SYS_VENDOR default "Marvell"
config SYS_CONFIG_NAME - string default "octeon_ebb7304"
config DEFAULT_DEVICE_TREE diff --git a/board/Marvell/octeon_nic23/Kconfig b/board/Marvell/octeon_nic23/Kconfig index 3c42e8acdadc..468bbb756e61 100644 --- a/board/Marvell/octeon_nic23/Kconfig +++ b/board/Marvell/octeon_nic23/Kconfig @@ -9,7 +9,6 @@ config SYS_VENDOR default "Marvell"
config SYS_CONFIG_NAME - string default "octeon_nic23"
config DEFAULT_DEVICE_TREE diff --git a/board/cadence/xtfpga/Kconfig b/board/cadence/xtfpga/Kconfig index 69296be49c7a..a64961e6d6a3 100644 --- a/board/cadence/xtfpga/Kconfig +++ b/board/cadence/xtfpga/Kconfig @@ -25,7 +25,6 @@ config SYS_VENDOR default "cadence"
config SYS_CONFIG_NAME - string default "xtfpga"
config BOARD_SDRAM_SIZE diff --git a/board/cavium/thunderx/Kconfig b/board/cavium/thunderx/Kconfig index 927d8765d675..3d4b260ea29c 100644 --- a/board/cavium/thunderx/Kconfig +++ b/board/cavium/thunderx/Kconfig @@ -13,7 +13,6 @@ config SYS_VENDOR default "cavium"
config SYS_CONFIG_NAME - string default "thunderx_88xx"
config CMD_ATF diff --git a/board/freescale/imxrt1020-evk/Kconfig b/board/freescale/imxrt1020-evk/Kconfig index d00cbff094b7..3cb8fb1e6e9f 100644 --- a/board/freescale/imxrt1020-evk/Kconfig +++ b/board/freescale/imxrt1020-evk/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "imxrt1020"
config SYS_CONFIG_NAME - string default "imxrt1020-evk"
config IMX_CONFIG diff --git a/board/freescale/imxrt1050-evk/Kconfig b/board/freescale/imxrt1050-evk/Kconfig index 79e6e4524ad3..068130beca98 100644 --- a/board/freescale/imxrt1050-evk/Kconfig +++ b/board/freescale/imxrt1050-evk/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "imxrt1050"
config SYS_CONFIG_NAME - string default "imxrt1050-evk"
config IMX_CONFIG diff --git a/board/freescale/imxrt1170-evk/Kconfig b/board/freescale/imxrt1170-evk/Kconfig index c61fc579713d..b433d6e5df0b 100644 --- a/board/freescale/imxrt1170-evk/Kconfig +++ b/board/freescale/imxrt1170-evk/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "imxrt1170"
config SYS_CONFIG_NAME - string default "imxrt1170-evk"
config IMX_CONFIG diff --git a/board/kontron/sl-mx6ul/Kconfig b/board/kontron/sl-mx6ul/Kconfig index 4e58de209477..782e099cec22 100644 --- a/board/kontron/sl-mx6ul/Kconfig +++ b/board/kontron/sl-mx6ul/Kconfig @@ -9,7 +9,6 @@ config SYS_VENDOR default "kontron"
config SYS_CONFIG_NAME - string default "kontron-sl-mx6ul"
endif diff --git a/board/kontron/sl-mx8mm/Kconfig b/board/kontron/sl-mx8mm/Kconfig index 9dcf407c867c..1cfe9ee64bd8 100644 --- a/board/kontron/sl-mx8mm/Kconfig +++ b/board/kontron/sl-mx8mm/Kconfig @@ -9,7 +9,6 @@ config SYS_VENDOR default "kontron"
config SYS_CONFIG_NAME - string default "kontron-sl-mx8mm"
endif diff --git a/board/samsung/starqltechn/Kconfig b/board/samsung/starqltechn/Kconfig index 0eea666d0358..e928cb0ea89b 100644 --- a/board/samsung/starqltechn/Kconfig +++ b/board/samsung/starqltechn/Kconfig @@ -6,17 +6,9 @@ config SYS_BOARD starqltechn is a production board for S9 and S9+ phones(SM-G96x0) phones based on SDM845 SoC.
config SYS_CONFIG_NAME - string "Board configuration name" default "sdm845" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration.
config SYS_VENDOR default "samsung"
-config SYS_CONFIG_NAME - default "starqltechn" - endif diff --git a/board/st/stih410-b2260/Kconfig b/board/st/stih410-b2260/Kconfig index 590add05feab..441a83cbaea6 100644 --- a/board/st/stih410-b2260/Kconfig +++ b/board/st/stih410-b2260/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stih410"
config SYS_CONFIG_NAME - string default "stih410-b2260"
endif diff --git a/board/st/stm32f429-discovery/Kconfig b/board/st/stm32f429-discovery/Kconfig index e73d11bada4f..3c93df20afac 100644 --- a/board/st/stm32f429-discovery/Kconfig +++ b/board/st/stm32f429-discovery/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32f4"
config SYS_CONFIG_NAME - string default "stm32f429-discovery"
endif diff --git a/board/st/stm32f429-evaluation/Kconfig b/board/st/stm32f429-evaluation/Kconfig index ca4bb3d9c956..eaa40db8a74a 100644 --- a/board/st/stm32f429-evaluation/Kconfig +++ b/board/st/stm32f429-evaluation/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32f4"
config SYS_CONFIG_NAME - string default "stm32f429-evaluation"
endif diff --git a/board/st/stm32f469-discovery/Kconfig b/board/st/stm32f469-discovery/Kconfig index de61b6f2f6da..622a8d82d81a 100644 --- a/board/st/stm32f469-discovery/Kconfig +++ b/board/st/stm32f469-discovery/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32f4"
config SYS_CONFIG_NAME - string default "stm32f469-discovery"
endif diff --git a/board/st/stm32f746-disco/Kconfig b/board/st/stm32f746-disco/Kconfig index 09289d23238e..86ace17377c5 100644 --- a/board/st/stm32f746-disco/Kconfig +++ b/board/st/stm32f746-disco/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32f7"
config SYS_CONFIG_NAME - string default "stm32f746-disco"
endif diff --git a/board/st/stm32h743-disco/Kconfig b/board/st/stm32h743-disco/Kconfig index 7d6ec1d95864..bc116bcf32fa 100644 --- a/board/st/stm32h743-disco/Kconfig +++ b/board/st/stm32h743-disco/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32h7"
config SYS_CONFIG_NAME - string default "stm32h743-disco"
endif diff --git a/board/st/stm32h743-eval/Kconfig b/board/st/stm32h743-eval/Kconfig index ea879b13c8b0..ff86de25f7de 100644 --- a/board/st/stm32h743-eval/Kconfig +++ b/board/st/stm32h743-eval/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32h7"
config SYS_CONFIG_NAME - string default "stm32h743-eval"
endif diff --git a/board/st/stm32h750-art-pi/Kconfig b/board/st/stm32h750-art-pi/Kconfig index c31b9849fde6..ab2d0f227d72 100644 --- a/board/st/stm32h750-art-pi/Kconfig +++ b/board/st/stm32h750-art-pi/Kconfig @@ -13,7 +13,6 @@ config SYS_SOC default "stm32h7"
config SYS_CONFIG_NAME - string default "stm32h750-art-pi"
endif diff --git a/board/sysam/amcore/Kconfig b/board/sysam/amcore/Kconfig index dd9816ec2435..e13ee8f6e90e 100644 --- a/board/sysam/amcore/Kconfig +++ b/board/sysam/amcore/Kconfig @@ -13,7 +13,6 @@ config SYS_VENDOR default "sysam"
config SYS_CONFIG_NAME - string default "amcore"
endif diff --git a/board/xilinx/microblaze-generic/Kconfig b/board/xilinx/microblaze-generic/Kconfig index dd5eacef52a8..038ff0b61306 100644 --- a/board/xilinx/microblaze-generic/Kconfig +++ b/board/xilinx/microblaze-generic/Kconfig @@ -6,14 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "xilinx"
-config SYS_CONFIG_NAME - string "Board configuration name" - default "microblaze-generic" - help - This option contains information about board configuration name. - Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header - will be used for board configuration. - config XILINX_MICROBLAZE0_USE_MSR_INSTR int "USE_MSR_INSTR range (0:1)" default 0
Andy Shevchenko
Michal Simek
