[U-Boot] [PATCH v2 1/6] mx6: soc: Staticize set_vddsoc()
set_vddsoc() is not used anywhere else, so make it static.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - None
arch/arm/cpu/armv7/mx6/soc.c | 2 +- arch/arm/include/asm/arch-mx6/sys_proto.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index a390296..6cbade7 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -101,7 +101,7 @@ void init_aips(void) * Possible values are from 0.725V to 1.450V in steps of * 0.025V (25mV). */ -void set_vddsoc(u32 mv) +static void set_vddsoc(u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; u32 val, reg = readl(&anatop->reg_core); diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index 8c21364..17125a6 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -29,8 +29,6 @@ u32 get_cpu_rev(void); const char *get_imx_type(u32 imxtype); unsigned imx_ddr_size(void);
-void set_vddsoc(u32 mv); - /* * Initializes on-chip ethernet controllers. * to override, implement board_eth_init()
Since ROM may modify the LDO ramp up time according to fuse setting, it is safer to reset the ramp up field to its default value of 00:
00: 64 cycles of 24MHz clock; 01: 128 cycles of 24MHz clock; 02: 256 cycles of 24MHz clock; 03: 512 cycles of 24MHz clock;
Signed-off-by: Anson Huang b20788@freescale.com Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - None
arch/arm/cpu/armv7/mx6/soc.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 6cbade7..13b9e36 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -93,6 +93,20 @@ void init_aips(void) writel(0x00000000, &aips2->opacr4); }
+static void clear_ldo_ramp(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + int reg; + + /* ROM may modify LDO ramp up time according to fuse setting, so in + * order to be in the safe side we neeed to reset these settings to + * match the reset value: 0'b00 + */ + reg = readl(&anatop->ana_misc2); + reg &= ~(0x3f << 24); + writel(reg, &anatop->ana_misc2); +} + /* * Set the VDDSOC * @@ -113,6 +127,8 @@ static void set_vddsoc(u32 mv) else val = (mv - 700) / 25;
+ clear_ldo_ramp(); + /* * Mask out the REG_CORE[22:18] bits (REG2_TRIG) * and set them to the calculated value (0.7V + val * 0.25V)
Changes since v1:
- None
Best regards, Stefano Babic
mx6 datasheet specifies that the minimum VDDSOC at 792 MHz is 1.15 V. Add a 25 mV margin and set it to 1.175V.
This also matches the VDDSOC voltages for 792MHz operation that the kernel configures: http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/ma...
arch/arm/cpu/armv7/mx6/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 13b9e36..0136eb0 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -151,7 +151,7 @@ int arch_cpu_init(void) { init_aips();
- set_vddsoc(1200); /* Set VDDSOC to 1.2V */ + set_vddsoc(1175); /* Set VDDSOC to 1.175V */
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
Introduce set_ldo_voltage() so that all three LDO regulators can be configured.
arch/arm/cpu/armv7/mx6/soc.c | 33 ++++++++++++++++++++++++++------- 1 file changed, 26 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 0136eb0..ee888ce 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -19,6 +19,12 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h>
+enum ldo_reg { + LDO_ARM, + LDO_SOC, + LDO_PU, +}; + struct scu_regs { u32 ctrl; u32 config; @@ -115,10 +121,11 @@ static void clear_ldo_ramp(void) * Possible values are from 0.725V to 1.450V in steps of * 0.025V (25mV). */ -static void set_vddsoc(u32 mv) +static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; u32 val, reg = readl(&anatop->reg_core); + u8 shift;
if (mv < 725) val = 0x00; /* Power gated off */ @@ -129,12 +136,24 @@ static void set_vddsoc(u32 mv)
clear_ldo_ramp();
- /* - * Mask out the REG_CORE[22:18] bits (REG2_TRIG) - * and set them to the calculated value (0.7V + val * 0.25V) - */ - reg = (reg & ~(0x1F << 18)) | (val << 18); + switch (ldo) { + case LDO_SOC: + shift = 18; + break; + case LDO_PU: + shift = 9; + break; + case LDO_ARM: + shift = 0; + break; + default: + return -EINVAL; + } + + reg = (reg & ~(0x1F << shift)) | (val << shift); writel(reg, &anatop->reg_core); + + return 0; }
static void imx_set_wdog_powerdown(bool enable) @@ -151,7 +170,7 @@ int arch_cpu_init(void) { init_aips();
- set_vddsoc(1175); /* Set VDDSOC to 1.175V */ + set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */
When changing LDO voltages we need to wait for the required amount of time for the voltage to settle.
Also, as the timer is still not available when arch_cpu_init() is called, we need to call it later at board_postclk_init() phase.
arch/arm/cpu/armv7/mx6/soc.c | 22 +++++++++++++++++++--- include/configs/mx6_common.h | 1 + 2 files changed, 20 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index ee888ce..3aa3bb0 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -124,7 +124,7 @@ static void clear_ldo_ramp(void) static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; - u32 val, reg = readl(&anatop->reg_core); + u32 val, step, old, reg = readl(&anatop->reg_core); u8 shift;
if (mv < 725) @@ -150,9 +150,20 @@ static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) return -EINVAL; }
+ old = (reg & (0x1F << shift)) >> shift; + step = abs(val - old); + if (step == 0) + return 0; + reg = (reg & ~(0x1F << shift)) | (val << shift); writel(reg, &anatop->reg_core);
+ /* + * The LDO ramp-up is based on 64 clock cycles of 24 MHz = 2.6 us per + * step + */ + udelay(3 * step); + return 0; }
@@ -170,8 +181,6 @@ int arch_cpu_init(void) { init_aips();
- set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */ - imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
#ifdef CONFIG_APBH_DMA @@ -182,6 +191,13 @@ int arch_cpu_init(void) return 0; }
+int board_postclk_init(void) +{ + set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */ + + return 0; +} + #ifndef CONFIG_SYS_DCACHE_OFF void enable_caches(void) { diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 674bcd3..514d634 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -20,5 +20,6 @@ #define CONFIG_ARM_ERRATA_742230 #define CONFIG_ARM_ERRATA_743622 #define CONFIG_ARM_ERRATA_751472 +#define CONFIG_BOARD_POSTCLK_INIT
#endif
As U-boot does not use GPU/VPU peripherals, shutdown the VDDPU regulator in order to save power.
Signed-off-by: Anson Huang b20788@freescale.com Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Disable vddpu the same way as in kernel
arch/arm/cpu/armv7/mx6/soc.c | 41 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/crm_regs.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 23 ++++++++++++++++++ 3 files changed, 65 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 0208cba..b944edd 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -19,6 +19,8 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h>
+#define VDDPU_MASK (0x1f << 9) + enum ldo_reg { LDO_ARM, LDO_SOC, @@ -177,11 +179,50 @@ static void imx_set_wdog_powerdown(bool enable) writew(enable, &wdog2->wmcr); }
+static void imx_set_vddpu_power_down(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct gpc_regs *gpc = (struct gpc_regs *)GPC_BASE_ADDR; + + u32 reg; + + /* + * Disable the brown out detection since we are going to be + * disabling the LDO. + */ + reg = readl(&anatop->ana_misc2); + reg &= ~ANADIG_ANA_MISC2_REG1_BO_EN; + writel(reg, &anatop->ana_misc2); + + /* need to power down xPU in GPC before turning off PU LDO */ + reg = readl(&gpc->gpu_ctrl); + writel(reg | 0x1, &gpc->gpu_ctrl); + + reg = readl(&gpc->ctrl); + writel(reg | 0x1, &gpc->ctrl); + while (readl(&gpc->ctrl) & 0x1) + ; + + /* Mask the ANATOP brown out interrupt in the GPC. */ + reg = readl(&gpc->imr4); + reg |= 0x80000000; + writel(reg, &gpc->imr4); + + /* disable VDDPU */ + writel(VDDPU_MASK, &anatop->reg_core_clr); + + /* Clear the BO interrupt in the ANATOP. */ + reg = readl(&anatop->ana_misc1); + reg |= 0x80000000; + writel(reg, &anatop->ana_misc1); +} + int arch_cpu_init(void) { init_aips();
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */ + imx_set_vddpu_power_down();
#ifdef CONFIG_APBH_DMA /* Start APBH DMA */ diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7202073..aede126 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -890,4 +890,5 @@ struct mxc_ccm_reg { #define BF_ANADIG_PFD_528_PFD0_FRAC(v) \ (((v) << 0) & BM_ANADIG_PFD_528_PFD0_FRAC)
+#define ANADIG_ANA_MISC2_REG1_BO_EN (1 << 13) #endif /*__ARCH_ARM_MACH_MX6_CCM_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 7ef7152..fb0c4c7 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -659,5 +659,28 @@ struct wdog_regs { u16 wmcr; /* Miscellaneous Control */ };
+struct gpc_regs { + u32 ctrl; /* 0x000 */ + u32 pgr; /* 0x004 */ + u32 imr1; /* 0x008 */ + u32 imr2; /* 0x00c */ + u32 imr3; /* 0x010 */ + u32 imr4; /* 0x014 */ + u32 isr1; /* 0x018 */ + u32 isr2; /* 0x01c */ + u32 isr3; /* 0x020 */ + u32 isr4; /* 0x024 */ + u32 reserved1[0x86]; + u32 gpu_ctrl; /* 0x260 */ + u32 gpu_pupscr; /* 0x264 */ + u32 gpu_pdnscr; /* 0x268 */ + u32 gpu_sr; /* 0x26c */ + u32 reserved2[0xc]; + u32 cpu_ctrl; /* 0x2a0 */ + u32 cpu_pupscr; /* 0x2a4 */ + u32 cpu_pdnscr; /* 0x2a8 */ + u32 cpu_sr; /* 0x2ac */ +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
Hello,
It seems this patch makes 3.10.17-1.0.0-beta freeze in a customer board; reverting this makes this to work again. It freezes when loading Vivante module.
Can someone reproduce this freeze?
On Thu, Jan 9, 2014 at 3:50 PM, Otavio Salvador otavio@ossystems.com.br wrote:
VDDPU is needed for using the GPU, so the kernel should turn on the VDDPU regulator.
Looks like you are getting a kernel bug.
Regards,
Fabio Estevam
It might be but shouldn't we delay this patch for now?
On Thu, Jan 9, 2014 at 5:11 PM, Otavio Salvador otavio@ossystems.com.br wrote:
I don't think so.
Please post your dts file. Most likely you are using
pu-supply = <&pu_dummy>;
where you should be using the internal vddpu instead.
Also, please post your kernel log and make sure vddpu is being turned on.
Regards,
Fabio Estevam
I don't think so.
Please try this on your dts file: pu-supply = <®_pu>;
Regards,
Fabio Estevam
I don't think so.
Mine dts has:
&gpu { pu-supply = <®_pu>; };
The bootlog is at:
http://privatepaste.com/download/104a504b26
On Thu, Jan 9, 2014 at 5:39 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Mine dts has:
The bootlog is at:
According to your log:
vdd1p1: 800 <--> 1375 mV at 1125 mV vdd3p0: 2800 <--> 3150 mV at 3000 mV vdd2p5: 2000 <--> 2750 mV at 2425 mV cpu: 725 <--> 1450 mV at 1100 mV vddpu: 725 <--> 1450 mV
cpu regulator is at 1.1V, which is below the spec for 800MHz, so this is an issue.
vddpu is still turned off.
Hard to tell where the problem is without looking at your dts file.
Anyway, we are getting off topic on the U-boot list now :-)
Regards,
Fabio Estevam
Hi Otavio,
On 09/01/2014 20:11, Otavio Salvador wrote:
On Thu, Jan 9, 2014 at 5:06 PM, Fabio Estevam <festevam@gmail.com mailto:festevam@gmail.com> wrote:
On Thu, Jan 9, 2014 at 3:50 PM, Otavio Salvador <otavio@ossystems.com.br <mailto:otavio@ossystems.com.br>> wrote: > It seems this patch makes 3.10.17-1.0.0-beta freeze in a customer board; > reverting this makes this to work again. It freezes when loading Vivante > module. VDDPU is needed for using the GPU, so the kernel should turn on the VDDPU regulator. Looks like you are getting a kernel bug.
Now or later it does not change. The correct behavior is done with the patch, and the kernel must turn power on. If it does not, the patch is needed for the kernel, not here.
Stefano
Hello,
I've been debugging to make 3.10 to work with this patch, but without success...
I think this patch should be reverted and be added back to 2014.04 release so we have more time to debug this.
Hi Otavio, hi Fabio,
Generally, I disagree to fix an issue in U-Boot when it is clear that this should be fixed in another component (in our case, the FSL-3.10 kernel). A patch should be revert if it is buggy - but this patch does the work and generally U-Boot should not activate what it does not need.
I understand Otavio's reasons to avoid that users by taking the official releases for U-Boot and FSL-3.10 will get a not working system. But anyway, IMHO the fix should flow into FSL-3.10 and not here.
=Hello,
The kernel 3.0.35 freezes also on the SabreSD platform with this commit.
Best regards
-- View this message in context: http://u-boot.10912.n7.nabble.com/PATCH-v2-1-6-mx6-soc-Staticize-set-vddsoc-... Sent from the U-Boot mailing list archive at Nabble.com.
Hi Pierre,
On Thu, Jan 16, 2014 at 6:40 AM, Pierre Aubert p.aubert@staubli.com wrote:
=Hello,
What is the output of "md.l 0x20C8140 1' on your board?
What is the mx6 variant (solo, dl, q) and silicon version?
Regards,
Fabio Estevam
Hi Fabio,
Le 16/01/2014 12:19, Fabio Estevam a écrit :
Hi Pierre,
=Hello,
=> md.l 0x20C8140 1 020c8140: 004c0010
I'm using a SabreSDP with a iMX6DL :
U-Boot 2014.01-rc3-00077-g751be3b (Jan 16 2014 - 08:27:51)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz Reset cause: POR Board: MX6-SabreSD DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 No panel detected: default to Hannstar-XGA Display: Hannstar-XGA (1024x768) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0
Regards,
Fabio Estevam
Best regards
Hi Fabio,
participants (5)
Fabio Estevam
Otavio Salvador
Pierre AUBERT
Pierre Aubert
Stefano Babic
