[PATCH 1/2] board: phytec: imx8mm-phycore: Remove duplicate binman node
The binman node is part of the imx8mm-u-boot.dtsi file which is duplicated in phycore-imx8mm-u-boot.dtsi and causes a build error. Remove the duplicate.
Fixes: 3cbb31f0e848 ("arm64: dts: imx8mm: use common binman configuration") Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi index f842e02c77..7c2dfb4a27 100644 --- a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi +++ b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi @@ -7,10 +7,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -73,121 +69,3 @@ &wdog1 { u-boot,dm-spl; }; - -&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl: blob-ext@1 { - filename = "spl.bin"; - offset = <0x0>; - }; - - uboot: blob-ext@2 { - filename = "u-boot.itb"; - offset = <0x57c00>; - }; - }; -};
The binman node is part of the imx8mm-u-boot.dtsi file which is duplicated in imx8mm-kontron-n801x-s-u-boot.dtsi and causes a build error. Remove the duplicate.
diff --git a/arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi index 5e368a61bc..22d18e6f1c 100644 --- a/arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi @@ -11,10 +11,6 @@ usb1 = &usbotg2; };
- binman: binman { - multiple-images; - }; - wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -130,145 +126,3 @@ &wdog1 { u-boot,dm-spl; }; - -&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl: blob-ext@1 { - offset = <0x0>; - filename = "spl.bin"; - }; - - uboot: blob-ext@2 { - offset = <0x57c00>; - filename = "u-boot.itb"; - }; - }; - - u-boot-update { - filename = "firmware-update.itb"; - - fit { - description = "Configuration for firmware update file"; - - images { - flash-bin { - description = "U-Boot flash image"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compress = "none"; - load = <0>; /* unused */ - - blob { - filename = "flash.bin"; - }; - - }; - }; - }; - }; -};
Reviewed-by: Fabio Estevam festevam@gmail.com
Fixes: 3cbb31f0e848 ("arm64: dts: imx8mm: use common binman configuration") Reviewed-by: Fabio Estevam festevam@gmail.com Signed-off-by: Adam Ford aford173@gmail.com
Fixes: 3cbb31f0e848 ("arm64: dts: imx8mm: use common binman configuration") Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com
Adam Ford
Fabio Estevam
