[U-Boot-Users] [PATCH] ppc4xx: Fix compilation warnings and coding style issues in HCU4/HCU5
Signed-off-by: Stefan Roese sr@denx.de --- board/netstal/hcu4/Makefile | 4 ++-- board/netstal/hcu4/hcu4.c | 1 + board/netstal/hcu5/Makefile | 4 ++-- board/netstal/hcu5/hcu5.c | 3 --- board/netstal/hcu5/sdram.c | 23 +++++++++++------------ 5 files changed, 16 insertions(+), 19 deletions(-)
diff --git a/board/netstal/hcu4/Makefile b/board/netstal/hcu4/Makefile index c0d719f..b13d9d4 100644 --- a/board/netstal/hcu4/Makefile +++ b/board/netstal/hcu4/Makefile @@ -27,11 +27,11 @@ vpath hcu_flash.c ../common vpath nm_bsp.c ../common
# NOBJS : Netstal common objects -NOBJS = fixed_sdram.o hcu_flash.o nm_bsp.o +NOBJS = ../common/fixed_sdram.o ../common/hcu_flash.o ../common/nm_bsp.o COBJS = $(BOARD).o SOBJS =
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) ../common/$(NOBJS:.o=.c) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(NOBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) NOBJS := $(addprefix $(obj),$(NOBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) diff --git a/board/netstal/hcu4/hcu4.c b/board/netstal/hcu4/hcu4.c index 714b98e..4fbe701 100644 --- a/board/netstal/hcu4/hcu4.c +++ b/board/netstal/hcu4/hcu4.c @@ -37,6 +37,7 @@ DECLARE_GLOBAL_DATA_PTR; #if defined(DEBUG) void show_sdram_registers(void); #endif +long int fixed_hcu4_sdram (unsigned int dram_size);
/* * This function is run very early, out of flash, and before devices are diff --git a/board/netstal/hcu5/Makefile b/board/netstal/hcu5/Makefile index 9645e45..9f248a4 100644 --- a/board/netstal/hcu5/Makefile +++ b/board/netstal/hcu5/Makefile @@ -26,11 +26,11 @@ vpath hcu_flash.c ../common vpath nm_bsp.c ../common
# NOBJS : Netstal common objects -NOBJS = hcu_flash.o nm_bsp.o +NOBJS = ../common/hcu_flash.o ../common/nm_bsp.o COBJS = $(BOARD).o sdram.o SOBJS = init.o
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) ../common/$(NOBJS:.o=.c) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(NOBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) NOBJS := $(addprefix $(obj),$(NOBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index c5e0f08..2c7afe2 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -497,9 +497,6 @@ int post_hotkeys_pressed(void) #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { - u32 val[4]; - int rc; - ft_cpu_setup(blob, bd);
} diff --git a/board/netstal/hcu5/sdram.c b/board/netstal/hcu5/sdram.c index 83d9456..5435de1 100644 --- a/board/netstal/hcu5/sdram.c +++ b/board/netstal/hcu5/sdram.c @@ -62,6 +62,11 @@ void dflush(void); #define DDR0_22_CTRL_RAW_ECC_ENABLE 0x03000000 /* ECC correcting on */ #define DDR0_03_CASLAT_DECODE(n) ((((unsigned long)(n))>>16)&0x7)
+#define ECC_RAM 0x03267F0B +#define NO_ECC_RAM 0x00267F0B + +#define HCU_HW_SDRAM_CONFIG_MASK 0x7 + #define MY_TLB_WORD2_I_ENABLE TLB_WORD2_I_ENABLE /* disable caching on DDR2 */
@@ -71,6 +76,7 @@ void board_add_ram_info(int use_default) { PPC4xx_SYS_INFO board_cfg; u32 val; + mfsdram(DDR0_22, val); val &= DDR0_22_CTRL_RAW_MASK; switch (val) { @@ -163,18 +169,17 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes)
/* Check whether vxWorks is using EDR logging, if yes zero */ /* also PostMortem and user reserved memory */ - magic= in_be32(start_address + num_bytes - - (CONFIG_PRAM*1024) + sizeof(u32)); + magic = (u32 *)in_be32((u32 *)(start_address + num_bytes - + (CONFIG_PRAM*1024) + sizeof(u32)));
debug("\n%s: CONFIG_PRAM %d kB magic 0x%x 0x%p -> 0x%x\n", __FUNCTION__, CONFIG_PRAM, - start_address + num_bytes - (CONFIG_PRAM*1024) + sizeof(u32), + start_address + num_bytes - (CONFIG_PRAM*1024) + sizeof(u32), magic, in_be32(magic)); if (in_be32(magic) == 0xbeefbabe) - num_bytes -= (CONFIG_PRAM*1024) - PM_RESERVED_MEM; + num_bytes -= (CONFIG_PRAM*1024) - PM_RESERVED_MEM; #endif
- sync(); eieio();
@@ -204,7 +209,6 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes)
return; } - #endif
@@ -215,9 +219,6 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes) ************************************************************************/ long int initdram (int board_type) { -#define HCU_HW_SDRAM_CONFIG_MASK 0x7 -#define INVALID_HW_CONFIG "Invalid HW-Config" - u16 *hwVersReg = (u16 *) HCU_HW_VERSION_REGISTER; unsigned int dram_size = 0;
mtsdram(DDR0_02, 0x00000000); @@ -228,7 +229,7 @@ long int initdram (int board_type) mtsdram(DDR0_03, 0x02030602); mtsdram(DDR0_04, 0x0A020200); mtsdram(DDR0_05, 0x02020307); - switch (*hwVersReg & HCU_HW_SDRAM_CONFIG_MASK) { + switch (in_be16((u16 *)HCU_HW_VERSION_REGISTER) & HCU_HW_SDRAM_CONFIG_MASK) { case 1: dram_size = 256 * 1024 * 1024 ; mtsdram(DDR0_06, 0x0102C812); /* 256MB RAM */ @@ -259,8 +260,6 @@ long int initdram (int board_type) mtsdram(DDR0_19, 0x1D1D1D1D); mtsdram(DDR0_20, 0x0B0B0B0B); mtsdram(DDR0_21, 0x0B0B0B0B); - #define ECC_RAM 0x03267F0B - #define NO_ECC_RAM 0x00267F0B #ifdef CONFIG_DDR_ECC mtsdram(DDR0_22, ECC_RAM); #else
Hi Stefan
Thanks for fixing the compile warnings. I fixed my compilation script to look for warnings in order to fix these kind of problems before submitting to the u-boot list.
# NOBJS : Netstal common objects -NOBJS = fixed_sdram.o hcu_flash.o nm_bsp.o +NOBJS = ../common/fixed_sdram.o ../common/hcu_flash.o \ ../common/nm_bsp.o COBJS = $(BOARD).o SOBJS =
I think that your fixes for the Makefiles are wrong, as they do not work when one wants to compile out-of-tree. E.g if I specify O=../build, then I get errors like FATAL: can't create /home/ng/u-boot/build/board/netstal/hcu5/../common/hcu_flash.o: No such file or directory
Is it okay if I submit a patch to revert the changes or do you suggest another way how to fix the Makefiles?
Best regards
Niklaus Giger
Hi Niklaus,
Good. And please keep me on CC on such mails/patches. Makes it easier for me to spot things.
Right, I missed this.
No, please don't revert my fixes, since my patch also changes other issues. Please send a new patch which really fixes only this problem. Not your previous version, since this had compile warnings too.
Thanks.
Best regards, Stefan
Niklaus Giger
Stefan Roese
