[U-Boot] [PATCH] serial: serial_stm32: move clock config from driver to board
This patch removes the uart clock enable from serial driver & move it in the board code.
Signed-off-by: Vikas Manocha vikas.manocha@st.com --- arch/arm/include/asm/arch-stm32f4/stm32_defs.h | 15 ++++++++ arch/arm/include/asm/arch-stm32f4/stm32_periph.h | 27 +++++++++++++++ arch/arm/mach-stm32/stm32f4/clock.c | 20 +++++++++++ board/st/stm32f429-discovery/stm32f429-discovery.c | 3 ++ drivers/serial/serial_stm32.c | 40 ---------------------- 5 files changed, 65 insertions(+), 40 deletions(-) create mode 100644 arch/arm/include/asm/arch-stm32f4/stm32_defs.h create mode 100644 arch/arm/include/asm/arch-stm32f4/stm32_periph.h
diff --git a/arch/arm/include/asm/arch-stm32f4/stm32_defs.h b/arch/arm/include/asm/arch-stm32f4/stm32_defs.h new file mode 100644 index 0000000..29b98ae --- /dev/null +++ b/arch/arm/include/asm/arch-stm32f4/stm32_defs.h @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2016 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __STM32_DEFS_H__ +#define __STM32_DEFS_H__ +#include <asm/arch/stm32_periph.h> + +int clock_setup(enum periph_clock); + +#endif + diff --git a/arch/arm/include/asm/arch-stm32f4/stm32_periph.h b/arch/arm/include/asm/arch-stm32f4/stm32_periph.h new file mode 100644 index 0000000..a1af25c --- /dev/null +++ b/arch/arm/include/asm/arch-stm32f4/stm32_periph.h @@ -0,0 +1,27 @@ +/* + * (C) Copyright 2016 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARM_ARCH_PERIPH_H +#define __ASM_ARM_ARCH_PERIPH_H + +/* + * Peripherals required for pinmux configuration. List will + * grow with support for more devices getting added. + * Numbering based on interrupt table. + * + */ +enum periph_id { + UART1_GPIOA_9_10 = 0, + UART2_GPIOD_5_6, +}; + +enum periph_clock { + USART1_CLOCK_CFG = 0, + USART2_CLOCK_CFG, +}; + +#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/arch/arm/mach-stm32/stm32f4/clock.c b/arch/arm/mach-stm32/stm32f4/clock.c index 3deb17a..576d3e6 100644 --- a/arch/arm/mach-stm32/stm32f4/clock.c +++ b/arch/arm/mach-stm32/stm32f4/clock.c @@ -11,6 +11,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/stm32.h> +#include <asm/arch/stm32_periph.h>
#define RCC_CR_HSION (1 << 0) #define RCC_CR_HSEON (1 << 16) @@ -50,6 +51,14 @@
#define RCC_APB1ENR_PWREN (1 << 28)
+/* + * RCC USART specific definitions + */ +#define RCC_ENR_USART1EN (1 << 4) +#define RCC_ENR_USART2EN (1 << 17) +#define RCC_ENR_USART3EN (1 << 18) +#define RCC_ENR_USART6EN (1 << 5) + #define PWR_CR_VOS0 (1 << 14) #define PWR_CR_VOS1 (1 << 15) #define PWR_CR_VOS_MASK 0xC000 @@ -221,3 +230,14 @@ unsigned long clock_get(enum clock clck) break; } } + +void clock_setup(int peripheral) +{ + switch (peripheral) { + case USART1_CLOCK_CFG: + setbits_le32(&STM32_RCC->apb2enr, RCC_ENR_USART1EN); + break; + default: + break; + } +} diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index 8bc2d9e..fb8475f 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -19,6 +19,8 @@ #include <asm/arch/fmc.h> #include <dm/platdata.h> #include <dm/platform_data/serial_stm32.h> +#include <asm/arch/stm32_periph.h> +#include <asm/arch/stm32_defs.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -286,6 +288,7 @@ int board_early_init_f(void) res = uart_setup_gpio(); if (res) return res; + clock_setup(USART1_CLOCK_CFG);
return 0; } diff --git a/drivers/serial/serial_stm32.c b/drivers/serial/serial_stm32.c index 91a5dde..c793ba6 100644 --- a/drivers/serial/serial_stm32.c +++ b/drivers/serial/serial_stm32.c @@ -35,24 +35,6 @@ struct stm32_usart {
-#define MAX_SERIAL_PORTS 4 - -/* - * RCC USART specific definitions - */ -#define RCC_ENR_USART1EN (1 << 4) -#define RCC_ENR_USART2EN (1 << 17) -#define RCC_ENR_USART3EN (1 << 18) -#define RCC_ENR_USART6EN (1 << 5) - -/* Array used to figure out which RCC bit needs to be set */ -static const unsigned long usart_port_rcc_pairs[MAX_SERIAL_PORTS][2] = { - { STM32_USART1_BASE, RCC_ENR_USART1EN }, - { STM32_USART2_BASE, RCC_ENR_USART2EN }, - { STM32_USART3_BASE, RCC_ENR_USART3EN }, - { STM32_USART6_BASE, RCC_ENR_USART6EN } -}; - static int stm32_serial_setbrg(struct udevice *dev, int baudrate) { struct stm32_serial_platdata *plat = dev->platdata; @@ -114,28 +96,6 @@ static int stm32_serial_probe(struct udevice *dev) { struct stm32_serial_platdata *plat = dev->platdata; struct stm32_usart *const usart = plat->base; - int usart_port = -1; - int i; - - for (i = 0; i < MAX_SERIAL_PORTS; i++) { - if ((u32)usart == usart_port_rcc_pairs[i][0]) { - usart_port = i; - break; - } - } - - if (usart_port == -1) - return -EINVAL; - - if (((u32)usart & STM32_BUS_MASK) == STM32_APB1PERIPH_BASE) - setbits_le32(&STM32_RCC->apb1enr, - usart_port_rcc_pairs[usart_port][1]); - else if (((u32)usart & STM32_BUS_MASK) == STM32_APB2PERIPH_BASE) - setbits_le32(&STM32_RCC->apb2enr, - usart_port_rcc_pairs[usart_port][1]); - else - return -EINVAL; - setbits_le32(&usart->cr1, USART_CR1_RE | USART_CR1_TE | USART_CR1_UE);
You might consider adding a clock driver.
- Simon
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Wednesday, January 27, 2016 2:54 PM To: Vikas MANOCHA Cc: Albert ARIBAUD; Kamil Lulko; U-Boot Mailing List; Peter Griffin; Antonio Borneo; rev13@wp.pl; kunhuahuang Subject: Re: [PATCH] serial: serial_stm32: move clock config from driver to board
Thanks for reviewing.
Yes, I agree. After some cleanup, I am planning to add support for clock and pinmux driver.
Rgds, Vikas
- Simon
Hi Tom/Kamil,
Can you please apply this patch.
Cheers, Vikas
-----Original Message----- From: Vikas MANOCHA Sent: Wednesday, January 27, 2016 2:58 PM To: 'Simon Glass' Cc: Albert ARIBAUD; Kamil Lulko; U-Boot Mailing List; Peter Griffin; Antonio Borneo; rev13@wp.pl; kunhuahuang Subject: RE: [PATCH] serial: serial_stm32: move clock config from driver to board
Hi Simon,
Rgds, Vikas
- Simon
Signed-off-by: Vikas Manocha vikas.manocha@st.com Reviewed-by: Simon Glass sjg@chromium.org
Vikas MANOCHA
Vikas Manocha
