[PATCH 0/4] Kconfig: some cleanups
I looked as cleaning up some dependencies and I found that qconfig is reporting some issues. This series is fixing some of them. But there are still some other pending. That's why please go and fix them if they are related to your board.
Thanks, Michal
drivers/pinctrl/intel/Kconfig:12: warning: style: quotes recommended around 'n' in 'bool n' warning: the choice symbol CPU_ARCEM6 (defined at arch/arc/Kconfig:46) is selected by the following symbols, but select/imply has no effect on choice symbols - TARGET_EMSDP (defined at arch/arc/Kconfig:173) - TARGET_IOT_DEVKIT (defined at arch/arc/Kconfig:180) warning: the choice symbol ARC_MMU_ABSENT (defined at arch/arc/Kconfig:77) is selected by the following symbols, but select/imply has no effect on choice symbols - CPU_ARCEM6 (defined at arch/arc/Kconfig:46) - CPU_ARCHS36 (defined at arch/arc/Kconfig:53) warning: the choice symbol ARC_MMU_V2 (defined at arch/arc/Kconfig:82) is selected by the following symbols, but select/imply has no effect on choice symbols - CPU_ARC750D (defined at arch/arc/Kconfig:32) warning: the choice symbol ARC_MMU_V3 (defined at arch/arc/Kconfig:89) is selected by the following symbols, but select/imply has no effect on choice symbols - CPU_ARC770D (defined at arch/arc/Kconfig:39) warning: the choice symbol ARC_MMU_V4 (defined at arch/arc/Kconfig:97) is selected by the following symbols, but select/imply has no effect on choice symbols - CPU_ARCHS38 (defined at arch/arc/Kconfig:60) warning: the choice symbol FSP_VERSION2 (defined at arch/x86/Kconfig:396) is selected by the following symbols, but select/imply has no effect on choice symbols - INTEL_APOLLOLAKE (defined at arch/x86/cpu/apollolake/Kconfig:6) warning: the choice symbol SPL_RISCV_MMODE (defined at arch/riscv/Kconfig:184) is implied by the following symbols, but select/imply has no effect on choice symbols - BOARD_SPECIFIC_OPTIONS (defined at board/bsh/imx8mn_smm_s2/Kconfig:21, board/bsh/imx8mn_smm_s2/Kconfig:41, board/engicam/px30_core/Kconfig:12, board/theobroma-systems/ringneck_px30/Kconfig:12, board/radxa/rockpi4-rk3399/Kconfig:12, board/theobroma-systems/puma_rk3399/Kconfig:12, board/theobroma-systems/jaguar_rk3588/Kconfig:12, board/edgeble/neural-compute-module-2/Kconfig:12, board/itead/sonoff-ihost/Kconfig:12, board/emulation/qemu-arm/Kconfig:6, board/emulation/qemu-arm/Kconfig:22, board/freescale/ls1012aqds/Kconfig:27, board/freescale/ls1012ardb/Kconfig:27, board/freescale/ls1012ardb/Kconfig:76, board/freescale/ls1012afrdm/Kconfig:27, board/advantech/som-db5800-som-6867/Kconfig:18, board/congatec/conga-qeval20-qa3-e3845/Kconfig:17, board/coreboot/coreboot/Kconfig:15, board/dfi/dfi-bt700/Kconfig:17, board/efi/efi-x86_app/Kconfig:12, board/efi/efi-x86_payload/Kconfig:15, board/emulation/qemu-x86/Kconfig:16, board/google/chromebook_coral/Kconfig:18, board/google/chromebook_link/Kconfig:19, board/google/chromebox_panther/Kconfig:19, board/google/chromebook_samus/Kconfig:19, board/intel/bayleybay/Kconfig:15, board/intel/cherryhill/Kconfig:15, board/intel/cougarcanyon2/Kconfig:15, board/intel/crownbay/Kconfig:15, board/intel/edison/Kconfig:24, board/intel/galileo/Kconfig:15, board/intel/minnowmax/Kconfig:15, board/intel/slimbootloader/Kconfig:19, board/AndesTech/ae350/Kconfig:34, board/emulation/qemu-riscv/Kconfig:32, board/microchip/mpfs_icicle/Kconfig:19, board/openpiton/riscv64/Kconfig:26, board/sifive/unleashed/Kconfig:26, board/sifive/unmatched/Kconfig:26, board/sipeed/maix/Kconfig:30, board/sophgo/milkv_duo/Kconfig:24, board/starfive/visionfive2/Kconfig:26, board/thead/th1520_lpi4a/Kconfig:30, board/xilinx/mbv/Kconfig:22, board/keymile/km83xx/Kconfig:34, board/keymile/km83xx/Kconfig:54, board/keymile/km83xx/Kconfig:74, board/keymile/km83xx/Kconfig:93, board/keymile/km83xx/Kconfig:112, board/keymile/km83xx/Kconfig:131, board/keymile/km83xx/Kconfig:150, board/keymile/kmcent2/Kconfig:12, board/keymile/pg-wcom-ls102xa/Kconfig:15, board/keymile/pg-wcom-ls102xa/Kconfig:35) warning: the choice symbol SYS_BIG_ENDIAN (defined at arch/Kconfig:528) is selected by the following symbols, but select/imply has no effect on choice symbols - ARC (defined at arch/Kconfig:53) warning: the choice symbol SYS_LITTLE_ENDIAN (defined at arch/Kconfig:532) is selected by the following symbols, but select/imply has no effect on choice symbols - ARC (defined at arch/Kconfig:53) warning: the choice symbol OF_SEPARATE (defined at dts/Kconfig:108) is selected by the following symbols, but select/imply has no effect on choice symbols - ARCH_MVEBU (defined at arch/arm/Kconfig:620) - ARCH_SNAPDRAGON (defined at arch/arm/Kconfig:1074) - ARCH_SUNXI (defined at arch/arm/Kconfig:1143) - ARCH_S5P4418 (defined at arch/arm/mach-nexell/Kconfig:3) warning: the choice symbol MULTI_DTB_FIT_USER_DEFINED_AREA (defined at dts/Kconfig:242) is implied by the following symbols, but select/imply has no effect on choice symbols - RZG2L (defined at arch/arm/mach-renesas/Kconfig:70) - TARGET_BEACON_RZG2M (defined at arch/arm/mach-renesas/Kconfig.rcar3:82) - TARGET_HIHOPE_RZG2 (defined at arch/arm/mach-renesas/Kconfig.rcar3:130) - TARGET_SALVATOR_X (defined at arch/arm/mach-renesas/Kconfig.rcar3:149) - TARGET_ULCB (defined at arch/arm/mach-renesas/Kconfig.rcar3:160) warning: the choice symbol SYS_NAND_SOFT_ECC (defined at drivers/mtd/nand/raw/Kconfig:184) is selected by the following symbols, but select/imply has no effect on choice symbols - NAND_SANDBOX (defined at drivers/mtd/nand/raw/Kconfig:450) warning: the choice symbol USB_ULPI_VIEWPORT (defined at drivers/usb/ulpi/Kconfig:11) is selected by the following symbols, but select/imply has no effect on choice symbols - USB_EHCI_MSM (defined at drivers/usb/host/Kconfig:263) warning: the choice symbol LIB_RAND (defined at lib/Kconfig:275) is selected by the following symbols, but select/imply has no effect on choice symbols - CMD_LINK_LOCAL (defined at cmd/Kconfig:1994) warning: the choice symbol EFI_APP (defined at lib/efi/Kconfig:15) is selected by the following symbols, but select/imply has no effect on choice symbols - TARGET_EFI_APP32 (defined at board/efi/Kconfig:7) - TARGET_EFI_APP64 (defined at board/efi/Kconfig:16)
Michal Simek (4): Kconfig: Remove trailing whitespace in its prompt Kconfig: Add missing quotes around source file Kconfig: Add missing quotes around default string value Kconfig: Make all Kconfig encoding ascii
arch/arm/mach-rockchip/px30/Kconfig | 4 ++-- arch/arm/mach-rockchip/rk3588/Kconfig | 24 ++++++++++++------------ arch/arm/mach-rockchip/rv1108/Kconfig | 4 ++-- arch/arm/mach-rockchip/rv1126/Kconfig | 8 ++++---- cmd/Kconfig | 2 +- drivers/clk/Kconfig | 10 +++++----- drivers/crypto/Kconfig | 8 ++++---- drivers/ddr/imx/imx8ulp/Kconfig | 2 +- drivers/mtd/spi/Kconfig | 2 +- lib/Kconfig | 18 +++++++++--------- lib/efi_loader/Kconfig | 2 +- 11 files changed, 42 insertions(+), 42 deletions(-)
All errors are generated by ./tools/qconfig.py -b -j8 -i whatever. Error look like this: warning: SPL_CLK_CCF (defined at drivers/clk/Kconfig:59) has leading or trailing whitespace in its prompt
Signed-off-by: Michal Simek michal.simek@amd.com ---
drivers/clk/Kconfig | 10 +++++----- drivers/ddr/imx/imx8ulp/Kconfig | 2 +- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 017dd260a544..bda6873be331 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -57,27 +57,27 @@ config CLK_BOSTON Enable this to support the clocks
config SPL_CLK_CCF - bool "SPL Common Clock Framework [CCF] support " + bool "SPL Common Clock Framework [CCF] support" depends on SPL help Enable this option if you want to (re-)use the Linux kernel's Common Clock Framework [CCF] code in U-Boot's SPL.
config SPL_CLK_COMPOSITE_CCF - bool "SPL Common Clock Framework [CCF] composite clk support " + bool "SPL Common Clock Framework [CCF] composite clk support" depends on SPL_CLK_CCF help Enable this option if you want to (re-)use the Linux kernel's Common Clock Framework [CCF] composite code in U-Boot's SPL.
config CLK_CCF - bool "Common Clock Framework [CCF] support " + bool "Common Clock Framework [CCF] support" help Enable this option if you want to (re-)use the Linux kernel's Common Clock Framework [CCF] code in U-Boot's clock driver.
config CLK_COMPOSITE_CCF - bool "Common Clock Framework [CCF] composite clk support " + bool "Common Clock Framework [CCF] composite clk support" depends on CLK_CCF help Enable this option if you want to (re-)use the Linux kernel's Common @@ -164,7 +164,7 @@ config CLK_OCTEON Enable this to support the clocks on Octeon MIPS platforms.
config SANDBOX_CLK_CCF - bool "Sandbox Common Clock Framework [CCF] support " + bool "Sandbox Common Clock Framework [CCF] support" depends on SANDBOX select CLK_CCF help diff --git a/drivers/ddr/imx/imx8ulp/Kconfig b/drivers/ddr/imx/imx8ulp/Kconfig index 5448c33838ce..005f581f4baa 100644 --- a/drivers/ddr/imx/imx8ulp/Kconfig +++ b/drivers/ddr/imx/imx8ulp/Kconfig @@ -5,7 +5,7 @@ config IMX8ULP_DRAM bool "imx8m dram"
config IMX8ULP_DRAM_PHY_PLL_BYPASS - bool "Enable the DDR PHY PLL bypass mode, so PHY clock is from DDR_CLK " + bool "Enable the DDR PHY PLL bypass mode, so PHY clock is from DDR_CLK" depends on IMX8ULP_DRAM
config SAVED_DRAM_TIMING_BASE
All errors are generated by ./tools/qconfig.py -b -j8 -i whatever. Error look like this: drivers/crypto/Kconfig:9: warning: style: quotes recommended around 'drivers/crypto/nuvoton/Kconfig' in 'source drivers/crypto/nuvoton/Kconfig'
arch/arm/mach-rockchip/rk3588/Kconfig | 18 +++++++++--------- arch/arm/mach-rockchip/rv1108/Kconfig | 4 ++-- arch/arm/mach-rockchip/rv1126/Kconfig | 4 ++-- cmd/Kconfig | 2 +- drivers/crypto/Kconfig | 8 ++++---- lib/Kconfig | 18 +++++++++--------- 6 files changed, 27 insertions(+), 27 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index d7e4af31f24c..eb956b097c74 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -221,14 +221,14 @@ config ROCKCHIP_COMMON_STACK_ADDR config TEXT_BASE default 0x00a00000
-source board/edgeble/neural-compute-module-6/Kconfig -source board/friendlyelec/nanopc-t6-rk3588/Kconfig -source board/pine64/quartzpro64-rk3588/Kconfig -source board/turing/turing-rk1-rk3588/Kconfig -source board/radxa/rock5a-rk3588s/Kconfig -source board/radxa/rock5b-rk3588/Kconfig -source board/rockchip/evb_rk3588/Kconfig -source board/rockchip/toybrick_rk3588/Kconfig -source board/theobroma-systems/jaguar_rk3588/Kconfig +source "board/edgeble/neural-compute-module-6/Kconfig" +source "board/friendlyelec/nanopc-t6-rk3588/Kconfig" +source "board/pine64/quartzpro64-rk3588/Kconfig" +source "board/turing/turing-rk1-rk3588/Kconfig" +source "board/radxa/rock5a-rk3588s/Kconfig" +source "board/radxa/rock5b-rk3588/Kconfig" +source "board/rockchip/evb_rk3588/Kconfig" +source "board/rockchip/toybrick_rk3588/Kconfig" +source "board/theobroma-systems/jaguar_rk3588/Kconfig"
endif diff --git a/arch/arm/mach-rockchip/rv1108/Kconfig b/arch/arm/mach-rockchip/rv1108/Kconfig index a12216dccf66..28ed0b245812 100644 --- a/arch/arm/mach-rockchip/rv1108/Kconfig +++ b/arch/arm/mach-rockchip/rv1108/Kconfig @@ -36,7 +36,7 @@ config SYS_SOC config SYS_MALLOC_F_LEN default 0x400
-source board/rockchip/evb_rv1108/Kconfig -source board/elgin/elgin_rv1108/Kconfig +source "board/rockchip/evb_rv1108/Kconfig" +source "board/elgin/elgin_rv1108/Kconfig"
endif diff --git a/arch/arm/mach-rockchip/rv1126/Kconfig b/arch/arm/mach-rockchip/rv1126/Kconfig index 55b11121203b..ae323ee91235 100644 --- a/arch/arm/mach-rockchip/rv1126/Kconfig +++ b/arch/arm/mach-rockchip/rv1126/Kconfig @@ -64,7 +64,7 @@ config SYS_MALLOC_F_LEN config TEXT_BASE default 0x600000
-source board/edgeble/neural-compute-module-2/Kconfig -source board/itead/sonoff-ihost/Kconfig +source "board/edgeble/neural-compute-module-2/Kconfig" +source "board/itead/sonoff-ihost/Kconfig"
endif diff --git a/cmd/Kconfig b/cmd/Kconfig index 8eeb99eea5ed..45c206369518 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -398,7 +398,7 @@ config CMD_BOOTEFI_HELLO for testing that EFI is working at a basic level, and for bringing up EFI support on a new architecture.
-source lib/efi_selftest/Kconfig +source "lib/efi_selftest/Kconfig" endif
config CMD_BOOTMENU diff --git a/drivers/crypto/Kconfig b/drivers/crypto/Kconfig index 12ef84ca05ca..8b49997030b4 100644 --- a/drivers/crypto/Kconfig +++ b/drivers/crypto/Kconfig @@ -1,11 +1,11 @@ menu "Hardware crypto devices"
-source drivers/crypto/hash/Kconfig +source "drivers/crypto/hash/Kconfig"
-source drivers/crypto/fsl/Kconfig +source "drivers/crypto/fsl/Kconfig"
-source drivers/crypto/aspeed/Kconfig +source "drivers/crypto/aspeed/Kconfig"
-source drivers/crypto/nuvoton/Kconfig +source "drivers/crypto/nuvoton/Kconfig"
endmenu diff --git a/lib/Kconfig b/lib/Kconfig index efb77978a652..189e6eb31aa1 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -416,7 +416,7 @@ config TRACE_EARLY_ADDR config CIRCBUF bool "Enable circular buffer support"
-source lib/dhry/Kconfig +source "lib/dhry/Kconfig"
menu "Security support"
@@ -429,10 +429,10 @@ config AES supported by the algorithm but only a 128-bit key is supported at present.
-source lib/ecdsa/Kconfig -source lib/rsa/Kconfig -source lib/crypto/Kconfig -source lib/crypt/Kconfig +source "lib/ecdsa/Kconfig" +source "lib/rsa/Kconfig" +source "lib/crypto/Kconfig" +source "lib/crypt/Kconfig"
config TPM bool "Trusted Platform Module (TPM) Support" @@ -1081,9 +1081,9 @@ config SMBIOS_PARSER help A simple parser for SMBIOS data.
-source lib/efi/Kconfig -source lib/efi_loader/Kconfig -source lib/optee/Kconfig +source "lib/efi/Kconfig" +source "lib/efi_loader/Kconfig" +source "lib/optee/Kconfig"
config TEST_FDTDEC bool "enable fdtdec test" @@ -1148,4 +1148,4 @@ config PHANDLE_CHECK_SEQ
endmenu
-source lib/fwu_updates/Kconfig +source "lib/fwu_updates/Kconfig"
Should we add a qconfig.py test to our CI?
Best regards
Heinrich
endmenu
When things are without warnings that would be the best.
M
All errors are generated by ./tools/qconfig.py -b -j8 -i whatever. Error look like this: warning: style: quotes recommended around default value for string symbol EFI_VAR_SEED_FILE (defined at lib/efi_loader/Kconfig:130)
lib/efi_loader/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e13a6f9f4c3a..a5ab7d1b262f 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -129,7 +129,7 @@ if EFI_VARIABLES_PRESEED
config EFI_VAR_SEED_FILE string "File with initial values of non-volatile UEFI variables" - default ubootefi.var + default "ubootefi.var" help File with initial values of non-volatile UEFI variables. The file must be in the same format as the storage in the EFI system partition. The
- default "ubootefi.var" help File with initial values of non-volatile UEFI variables. The file must be in the same format as the storage in the EFI system partition. The
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Some of Kconfigs are using utf-8 encoding because of used chars. Convert all of them to ascii enconging.
There are other files which are using utf-8 enconding and pretty much I think we should convert all of them because there is no reason to use utf-8 encoding.
--- arch/arm/mach-rockchip/px30/Kconfig | 4 ++-- arch/arm/mach-rockchip/rk3588/Kconfig | 6 +++--- arch/arm/mach-rockchip/rv1126/Kconfig | 4 ++-- drivers/mtd/spi/Kconfig | 2 +- 4 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 41893920cb4d..23f8f430c4ae 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -36,9 +36,9 @@ config TARGET_PX30_CORE 10.1" OF for creating complete PX30.Core C.TOUCH 2.0 10.1" Open Frame.
config TARGET_RINGNECK_PX30 - bool "Theobroma Systems PX30-µQ7 (Ringneck)" + bool "Theobroma Systems PX30-uQ7 (Ringneck)" help - The PX30-uQ7 (Ringneck) SoM is a µQseven-compatible (40mmx70mm, + The PX30-uQ7 (Ringneck) SoM is a uQseven-compatible (40mmx70mm, MXM-230 connector) system-on-module from Theobroma Systems[1], featuring the Rockchip PX30.
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index eb956b097c74..39049ab35a9c 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -66,7 +66,7 @@ config TARGET_NANOPCT6_RK3588 HDMI2.0, and HDMI1.4 2x 4-lane MIPI-DSI, compatible with MIPI DPHY 2.0 or CPHY 1.1 USB-A: USB 3.0, Type A - USB-C: Full function USB Type‑C port, DP display up to 4Kp60, USB 3.0 + USB-C: Full function USB Type-C port, DP display up to 4Kp60, USB 3.0 40-pin 2.54mm header connector: up to 2x SPIs, 6x UARTs, 1x I2Cs, 8x PWMs, 2x I2Ss, 28x GPIOs Debug UART: 3 Pin 2.54mm header, 3V level, 1500000bps @@ -117,7 +117,7 @@ config TARGET_ROCK5A_RK3588 Mali G610MC4 GPU MIPI CSI 2 multiple lanes connector 4-lane MIPI DSI connector - Audio – 3.5mm earphone jack + Audio - 3.5mm earphone jack eMMC module connector uSD slot (up to 128GB) 2x USB 2.0, 2x USB 3.0 @@ -197,7 +197,7 @@ config TARGET_TOYBRICK_RK3588 4x ARM Cortex-A76, 4x ARM Cortex-A55 8/16GB Memory LPDDR4x Mali G610MC4 GPU - 2× MIPI-CSI0 Connector + 2x MIPI-CSI0 Connector 1x 2Lanes PCIe3.0 Connector 1x SATA3.0 Connector 32GB eMMC Module diff --git a/arch/arm/mach-rockchip/rv1126/Kconfig b/arch/arm/mach-rockchip/rv1126/Kconfig index ae323ee91235..64a70f61f894 100644 --- a/arch/arm/mach-rockchip/rv1126/Kconfig +++ b/arch/arm/mach-rockchip/rv1126/Kconfig @@ -6,8 +6,8 @@ config TARGET_RV1126_NEU2 Neu2: Neural Compute Module 2(Neu2) is a 96boards SoM-CB compute module based on Rockchip RV1126 from Edgeble AI. - Neu2 powered with Consumer grade (0 to +80 °C) RV1126 SoC. - Neu2k powered with Industrial grade (-40 °C to +85 °C) RV1126K SoC. + Neu2 powered with Consumer grade (0 to +80 C) RV1126 SoC. + Neu2k powered with Industrial grade (-40 C to +85 C) RV1126K SoC.
Neu2-IO: Neural Compute Module 2(Neu2) IO board is an industrial form factor diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index d068b7860e1c..bedc4e970e43 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -246,7 +246,7 @@ config SPI_FLASH_USE_4K_SECTORS to erasing whole blocks (32/64 KiB). Changing a small part of the flash's contents is usually faster with small sectors. On the other hand erasing should be faster when using - 64 KiB block instead of 16 × 4 KiB sectors. + 64 KiB block instead of 16 x 4 KiB sectors.
Please note that some tools/drivers/filesystems may not work with 4096 B erase size (e.g. UBIFS requires 15 KiB as a minimum).
Hello Michal,
The commit message does not explain why we should refrain from using UTF-8.
- bool "Theobroma Systems PX30-uQ7 (Ringneck)" help
featuring the Rockchip PX30.The PX30-uQ7 (Ringneck) SoM is a uQseven-compatible (40mmx70mm, MXM-230 connector) system-on-module from Theobroma Systems[1],
40-pin 2.54mm header connector: up to 2x SPIs, 6x UARTs, 1x I2Cs, 8x PWMs, 2x I2Ss, 28x GPIOs Debug UART: 3 Pin 2.54mm header, 3V level, 1500000bpsUSB-C: Full function USB Type-C port, DP display up to 4Kp60, USB 3.0
eMMC module connector uSD slot (up to 128GB) 2x USB 2.0, 2x USB 3.0Audio - 3.5mm earphone jack
1x 2Lanes PCIe3.0 Connector 1x SATA3.0 Connector 32GB eMMC Module2x MIPI-CSI0 Connector
C is the sign for coulomb which is the unit of electric charge. How about 'deg C'?
Best regards
Heinrich
Hello Michal,
that's a good point. I was thinking about the reason for it and pretty much wanted to get feedback from Tom about it.
In doc/develop/sending_patches.rst is said that patches should be sent as plain text but encoding is not specified. Traditionally this was ASCII and I pretty much don't see the reason to use UTF encoding (even my name has special czech char which I am not using, the same is for Marek Vasut).
Thanks, Michal
Hello Michal,
My point of view is that I think ASCII should be used in general, with the exception being names (I won't force people to ASCII-ize their names, modern systems handle UTF-8 just fine). I actually don't know if we should also exclude rST doc files from this rule as well as UTF-8 should render fine and for example "°C" reads nicely in web/PDF/etc.
Hello Michal,
I think that people the most of time just simply don't know that they are using non ASCII chars. Anyway let me send v2 with also patch for .c and .h when appropriate.
Thanks, Michal
[snip]
I'll note that in Linux there's seemingly nothing consistent, and I'm fine with any of "deg C" or "degrees C" or "temperature range (-40 C to +85 C)" as all of those should be clear in context.
[snip]
My 2 cents ... while I agree with Tom that the context will make it clear, it is not making it correct nor nice. Using just "C" for Celsius degrees is horrible ...
Francesco
[snip]
I used deg C in v2 version.
Thanks, Michal
[snip]
FWIW, I usually use "oC", which is far from perfect, but IMHO also far from horrible. :)
"oC" is also horrible, "deg C" or "degrees C" that Heinrich proposed are the way to go if you need something 7-bit ascii :-).
Francesco
I agree, "deg C" or "degrees C" is the way to go, and my vote goes to "degrees C". Just to clarify, I use "oC" as some kind of a shorthand when having less to type outweighs the correctness. :)
participants (5)
Dragan Simic
Francesco Dolcini
Michal Simek
