[U-Boot] [PATCH v4 14/16] dm: spi: xilinx_spi: Convert to driver model
This converts the xilinx spi driver to use the driver model.
Signed-off-by: Jagan Teki jteki@openedev.com Acked-by: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com --- Changes for v4: - Removed cs_info ops, as it need to proper testing to verify.
Changes for v3: - Get the cs number from xfer using dm_spi_slave_platdata
Changes for v2: - Rebase to master
drivers/spi/xilinx_spi.c | 200 ++++++++++++++++++++++++++--------------------- 1 file changed, 112 insertions(+), 88 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 650e494..4b0b50f 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -4,6 +4,7 @@ * Supports 8 bit SPI transfers only, with or w/o FIFO * * Based on bfin_spi.c, by way of altera_spi.c + * Copyright (c) 2015 Jagan Teki jteki@openedev.com * Copyright (c) 2012 Stephan Linz linz@li-pro.net * Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca * Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw @@ -14,6 +15,8 @@
#include <config.h> #include <common.h> +#include <dm.h> +#include <errno.h> #include <malloc.h> #include <spi.h>
@@ -79,7 +82,7 @@ #endif
/* xilinx spi register set */ -struct xilinx_spi_reg { +struct xilinx_spi_regs { u32 __space0__[7]; u32 dgier; /* Device Global Interrupt Enable Register (DGIER) */ u32 ipisr; /* IP Interrupt Status Register (IPISR) */ @@ -97,113 +100,75 @@ struct xilinx_spi_reg { u32 spirfor; /* SPI Receive FIFO Occupancy Register (SPIRFOR) */ };
-/* xilinx spi slave */ -struct xilinx_spi_slave { - struct spi_slave slave; - struct xilinx_spi_reg *regs; +/* xilinx spi priv */ +struct xilinx_spi_priv { + struct xilinx_spi_regs *regs; unsigned int freq; unsigned int mode; };
-static inline struct xilinx_spi_slave *to_xilinx_spi_slave( - struct spi_slave *slave) -{ - return container_of(slave, struct xilinx_spi_slave, slave); -} - static unsigned long xilinx_spi_base_list[] = CONFIG_SYS_XILINX_SPI_LIST; -int spi_cs_is_valid(unsigned int bus, unsigned int cs) +static int xilinx_spi_probe(struct udevice *bus) { - return bus < ARRAY_SIZE(xilinx_spi_base_list) && cs < 32; -} + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs;
-void spi_cs_activate(struct spi_slave *slave) -{ - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + priv->regs = (struct xilinx_spi_regs *)xilinx_spi_base_list[bus->seq];
- writel(SPISSR_ACT(slave->cs), &xilspi->regs->spissr); -} + writel(SPISSR_RESET_VALUE, ®s->srr);
-void spi_cs_deactivate(struct spi_slave *slave) -{ - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); - - writel(SPISSR_OFF, &xilspi->regs->spissr); -} - -void spi_init(void) -{ - /* do nothing */ + return 0; }
-struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) +static void spi_cs_activate(struct udevice *dev, uint cs) { - struct xilinx_spi_slave *xilspi; + struct udevice *bus = dev_get_parent(dev); + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs;
- if (!spi_cs_is_valid(bus, cs)) { - printf("XILSPI error: unsupported bus %d / cs %d\n", bus, cs); - return NULL; - } - - xilspi = spi_alloc_slave(struct xilinx_spi_slave, bus, cs); - if (!xilspi) { - printf("XILSPI error: malloc of SPI structure failed\n"); - return NULL; - } - xilspi->regs = (struct xilinx_spi_reg *)xilinx_spi_base_list[bus]; - xilspi->freq = max_hz; - xilspi->mode = mode; - debug("spi_setup_slave: bus:%i cs:%i base:%p mode:%x max_hz:%d\n", - bus, cs, xilspi->regs, xilspi->mode, xilspi->freq); - - writel(SPISSR_RESET_VALUE, &xilspi->regs->srr); - - return &xilspi->slave; + writel(SPISSR_ACT(cs), ®s->spissr); }
-void spi_free_slave(struct spi_slave *slave) +static void spi_cs_deactivate(struct udevice *dev) { - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + struct udevice *bus = dev_get_parent(dev); + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs;
- free(xilspi); + writel(SPISSR_OFF, ®s->spissr); }
-int spi_claim_bus(struct spi_slave *slave) +static int xilinx_spi_claim_bus(struct udevice *dev) { - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); - u32 spicr; - - debug("spi_claim_bus: bus:%i cs:%i\n", slave->bus, slave->cs); - writel(SPISSR_OFF, &xilspi->regs->spissr); + struct udevice *bus = dev_get_parent(dev); + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs;
- spicr = XILSPI_SPICR_DFLT_ON; - if (xilspi->mode & SPI_LSB_FIRST) - spicr |= SPICR_LSB_FIRST; - if (xilspi->mode & SPI_CPHA) - spicr |= SPICR_CPHA; - if (xilspi->mode & SPI_CPOL) - spicr |= SPICR_CPOL; - if (xilspi->mode & SPI_LOOP) - spicr |= SPICR_LOOP; + writel(SPISSR_OFF, ®s->spissr); + writel(XILSPI_SPICR_DFLT_ON, ®s->spicr);
- writel(spicr, &xilspi->regs->spicr); return 0; }
-void spi_release_bus(struct spi_slave *slave) +static int xilinx_spi_release_bus(struct udevice *dev) { - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + struct udevice *bus = dev_get_parent(dev); + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs;
- debug("spi_release_bus: bus:%i cs:%i\n", slave->bus, slave->cs); - writel(SPISSR_OFF, &xilspi->regs->spissr); - writel(XILSPI_SPICR_DFLT_OFF, &xilspi->regs->spicr); + writel(SPISSR_OFF, ®s->spissr); + writel(XILSPI_SPICR_DFLT_OFF, ®s->spicr); + + return 0; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) +static int xilinx_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { - struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + struct udevice *bus = dev_get_parent(dev); + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs; + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); /* assume spi core configured to do 8 bit transfers */ unsigned int bytes = bitlen / XILSPI_MAX_XFER_BITS; const unsigned char *txp = dout; @@ -212,7 +177,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, unsigned global_timeout;
debug("spi_xfer: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", - slave->bus, slave->cs, bitlen, bytes, flags); + bus->seq, slave_plat->cs, bitlen, bytes, flags);
if (bitlen == 0) goto done; @@ -225,8 +190,8 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
/* empty read buffer */ - while (rxecount && !(readl(&xilspi->regs->spisr) & SPISR_RX_EMPTY)) { - readl(&xilspi->regs->spidrr); + while (rxecount && !(readl(®s->spisr) & SPISR_RX_EMPTY)) { + readl(®s->spidrr); rxecount--; }
@@ -236,11 +201,11 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); + spi_cs_activate(dev, slave_plat->cs);
/* at least 1usec or greater, leftover 1 */ - global_timeout = xilspi->freq > XILSPI_MAX_XFER_BITS * 1000000 ? 2 : - (XILSPI_MAX_XFER_BITS * 1000000 / xilspi->freq) + 1; + global_timeout = priv->freq > XILSPI_MAX_XFER_BITS * 1000000 ? 2 : + (XILSPI_MAX_XFER_BITS * 1000000 / priv->freq) + 1;
while (bytes--) { unsigned timeout = global_timeout; @@ -249,8 +214,8 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, debug("spi_xfer: tx:%x ", d);
/* write out and wait for processing (receive data) */ - writel(d & SPIDTR_8BIT_MASK, &xilspi->regs->spidtr); - while (timeout && readl(&xilspi->regs->spisr) + writel(d & SPIDTR_8BIT_MASK, ®s->spidtr); + while (timeout && readl(®s->spisr) & SPISR_RX_EMPTY) { timeout--; udelay(1); @@ -262,7 +227,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
/* read Rx element and push into data in buffer */ - d = readl(&xilspi->regs->spidrr) & SPIDRR_8BIT_MASK; + d = readl(®s->spidrr) & SPIDRR_8BIT_MASK; if (rxp) *rxp++ = d; debug("spi_xfer: rx:%x\n", d); @@ -270,7 +235,66 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout,
done: if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); + spi_cs_deactivate(dev);
return 0; } + +static int xilinx_spi_set_speed(struct udevice *bus, uint speed) +{ + struct xilinx_spi_priv *priv = dev_get_priv(bus); + + priv->freq = speed; + + debug("xilinx_spi_set_speed: regs=%p, mode=%d\n", priv->regs, + priv->freq); + + return 0; +} + +static int xilinx_spi_set_mode(struct udevice *bus, uint mode) +{ + struct xilinx_spi_priv *priv = dev_get_priv(bus); + struct xilinx_spi_regs *regs = priv->regs; + uint32_t spicr; + + spicr = readl(®s->spicr); + if (priv->mode & SPI_LSB_FIRST) + spicr |= SPICR_LSB_FIRST; + if (priv->mode & SPI_CPHA) + spicr |= SPICR_CPHA; + if (priv->mode & SPI_CPOL) + spicr |= SPICR_CPOL; + if (priv->mode & SPI_LOOP) + spicr |= SPICR_LOOP; + + writel(spicr, ®s->spicr); + priv->mode = mode; + + debug("xilinx_spi_set_mode: regs=%p, mode=%d\n", priv->regs, + priv->mode); + + return 0; +} + +static const struct dm_spi_ops xilinx_spi_ops = { + .claim_bus = xilinx_spi_claim_bus, + .release_bus = xilinx_spi_release_bus, + .xfer = xilinx_spi_xfer, + .set_speed = xilinx_spi_set_speed, + .set_mode = xilinx_spi_set_mode, +}; + +static const struct udevice_id xilinx_spi_ids[] = { + { .compatible = "xlnx,xilinx-spi" }, + { } +}; + +U_BOOT_DRIVER(xilinx_spi) = { + .name = "xilinx_spi", + .id = UCLASS_SPI, + .of_match = xilinx_spi_ids, + .ops = &xilinx_spi_ops, + .priv_auto_alloc_size = sizeof(struct xilinx_spi_priv), + .probe = xilinx_spi_probe, +};
Changes for v4:
Changes for v3:
Changes for v2:
- Rebase to master
- Supports 8 bit SPI transfers only, with or w/o FIFO
- Based on bfin_spi.c, by way of altera_spi.c
- Copyright (c) 2015 Jagan Teki jteki@openedev.com
- Copyright (c) 2012 Stephan Linz linz@li-pro.net
- Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca
- Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw
@@ -14,6 +15,8 @@
/* do nothing */
return NULL;
if (!xilspi) {
return NULL;
free(xilspi);
u32 spicr;
bus->seq, slave_plat->cs, bitlen, bytes, flags); if (bitlen == 0) goto done;
spi_cs_activate(dev, slave_plat->cs); /* at least 1usec or greater, leftover 1 */
(XILSPI_MAX_XFER_BITS * 1000000 / priv->freq) + 1; while (bytes--) { unsigned timeout = global_timeout;
spi_cs_deactivate(dev); return 0;
priv->freq = speed;
priv->freq);
uint32_t spicr;
priv->mode = mode;
priv->mode);
.id = UCLASS_SPI,
1.9.1
Applied to u-boot-spi/master
thanks!
Jagan Teki
