Broken powerpc compilation since commit 141659187667 ("pylibfdt: Fix disable version normalization")
Hello! Now I was going to test urgent release workaround/fix for this issue https://lists.denx.de/pipermail/u-boot/2023-January/503900.html but I figured out that I cannot compile u-boot from master branch for powerpc platform. make throws following error:
LDS u-boot.lds HOSTLD scripts/dtc/dtc Traceback (most recent call last): File "scripts/dtc/pylibfdt/setup.py", line 23, in <module> from setuptools import setup, Extension, sic ImportError: cannot import name 'sic' from 'setuptools' (/usr/lib/python3/dist-packages/setuptools/__init__.py) make[2]: *** [scripts/dtc/pylibfdt/Makefile:33: rebuild] Error 1 make[1]: *** [scripts/Makefile.build:398: scripts/dtc/pylibfdt] Error 2 make: *** [Makefile:2031: scripts_dtc] Error 2
git bisect showed me that problematic commit is one from yesterday:
Reverting it on top of master branch compiled u-boot for powerpc without issues.
It looks like a bit complicated issue as that commit is fixing another commit from two weeks before:
440098c42e73 ("pylibfdt: Fix version normalization warning")
Tom, do you have an idea how to handle this?
What host distro are you on?
On this build machine I have currently Debian 10.
OK, and does undoing the mentioned commit and trying: https://github.com/u-boot/u-boot/pull/266/commits/eb76bf5864b53938db639867ad... instead work there?
I checkout master branch, then I reverted commit 141659187667 and then I applied a495b8f497dc from github. But it does not work, it throws error:
LDS u-boot.lds HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o Traceback (most recent call last): File "scripts/dtc/pylibfdt/setup.py", line 25, in <module> from packaging import version ModuleNotFoundError: No module named 'packaging' make[2]: *** [scripts/dtc/pylibfdt/Makefile:33: rebuild] Error 1 make[1]: *** [scripts/Makefile.build:398: scripts/dtc/pylibfdt] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [Makefile:2031: scripts_dtc] Error 2
Sigh, let me see if I can come up with something. I assume you're doing a local revert for the moment to test the memsize thing?
Yes!
Try this, which should just bring us back to printing an annoying but harmless warning: diff --git a/scripts/dtc/pylibfdt/setup.py b/scripts/dtc/pylibfdt/setup.py index c07f65e6bcaf..8baae08770ca 100755 --- a/scripts/dtc/pylibfdt/setup.py +++ b/scripts/dtc/pylibfdt/setup.py @@ -20,12 +20,17 @@ allows this script to be run stand-alone, e.g.: ./pylibfdt/setup.py install [--prefix=...] """
-from setuptools import setup, Extension, sic +from setuptools import setup, Extension from setuptools.command.build_py import build_py as _build_py import os import re import sys
+try: + from setuptools import sic +except ImportError: + pass + srcdir = os.path.dirname(__file__)
with open(os.path.join(srcdir, "../README"), "r") as fh: @@ -113,7 +118,10 @@ progname = sys.argv[0] files = os.environ.get('SOURCES', '').split() cflags = os.environ.get('CPPFLAGS', '').split() objdir = os.environ.get('OBJDIR') -version = os.environ.get('VERSION') +try: + version = sic(os.environ.get('VERSION')) +except: + version = os.environ.get('VERSION') swig_opts = os.environ.get('SWIG_OPTS', '').split()
# If we were called directly rather than through our Makefile (which is often @@ -137,7 +145,7 @@ class build_py(_build_py):
setup( name='libfdt', - version=sic(version), + version=version, cmdclass = {'build_py' : build_py}, author='Simon Glass', author_email='sjg@chromium.org',
+try:
- from setuptools import sic
- pass
- version = sic(os.environ.get('VERSION'))
+except:
- version = os.environ.get('VERSION')
- version=version, cmdclass = {'build_py' : build_py}, author='Simon Glass', author_email='sjg@chromium.org',
-- Tom
This one works fine. It prints that UserWarning but u-boot.bin is built.
Pali Rohár
