[U-Boot] [PATCH 0/9] ARM: UniPhier: a collection of nice cleanups of board/SoC support code
Masahiro Yamada (9): ARM: UniPhier: disable autostart by default ARM: UniPhier: use boot_is_swapped() macro for readability ARM: UniPhier: move CONFIG_UNIPHIER_SMP to Kconfig ARM: UniPhier: move support card select to Kconfig ARM: UniPhier: merge UniPhier config headers into a single file ARM: UniPhier: add more device nodes to device tree ARM: UniPhier: add device tree sources for PH1-sLD3 ARM: UniPhier: extend register area of init page table for PH1-sLD3 ARM: UniPhier: detect the number of flash banks at run-time
arch/arm/cpu/armv7/uniphier/Kconfig | 31 +++++- arch/arm/cpu/armv7/uniphier/Makefile | 1 + arch/arm/cpu/armv7/uniphier/board_early_init_r.c | 15 +++ arch/arm/cpu/armv7/uniphier/init_page_table.c | 7 +- arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 20 ++-- arch/arm/cpu/armv7/uniphier/support_card.c | 125 +++++++++++++++------- arch/arm/dts/Makefile | 1 + arch/arm/dts/uniphier-ph1-ld4-ref.dts | 23 +++- arch/arm/dts/uniphier-ph1-ld4.dtsi | 40 ++++++- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 26 ++++- arch/arm/dts/uniphier-ph1-pro4.dtsi | 64 ++++++++++- arch/arm/dts/uniphier-ph1-sld3-ref.dts | 57 ++++++++++ arch/arm/dts/uniphier-ph1-sld3.dtsi | 121 +++++++++++++++++++++ arch/arm/dts/uniphier-ph1-sld8-ref.dts | 23 +++- arch/arm/dts/uniphier-ph1-sld8.dtsi | 40 ++++++- arch/arm/include/asm/arch-uniphier/board.h | 7 ++ configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + include/configs/ph1_ld4.h | 53 --------- include/configs/ph1_pro4.h | 55 ---------- include/configs/ph1_sld8.h | 55 ---------- include/configs/{uniphier-common.h => uniphier.h} | 63 ++++++++--- 23 files changed, 582 insertions(+), 248 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/board_early_init_r.c create mode 100644 arch/arm/dts/uniphier-ph1-sld3-ref.dts create mode 100644 arch/arm/dts/uniphier-ph1-sld3.dtsi delete mode 100644 include/configs/ph1_ld4.h delete mode 100644 include/configs/ph1_pro4.h delete mode 100644 include/configs/ph1_sld8.h rename include/configs/{uniphier-common.h => uniphier.h} (84%)
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
include/configs/uniphier-common.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier-common.h index 2140fcc..31ab470 100644 --- a/include/configs/uniphier-common.h +++ b/include/configs/uniphier-common.h @@ -205,7 +205,6 @@ are defined. Select only one of them." "image_offset=0x00080000\0" \ "image_size=0x00f00000\0" \ "verify=n\0" \ - "autostart=yes\0" \ "norboot=run add_default_bootargs;" \ "bootm $image_offset\0" \ "nandboot=run add_default_bootargs;" \
arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c index f113db5..3c82a1a 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c @@ -22,16 +22,7 @@ void sbc_init(void) writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12); writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14);
- if (readl(SBBASE0) & 0x1) { - /* - * Boot Swap Off: boot from mask ROM - * 0x00000000-0x01ffffff: mask ROM - * 0x02000000-0x3effffff: memory bank (31MB) - * 0x03f00000-0x3fffffff: peripherals (1MB) - */ - writel(0x0000be01, SBBASE0); /* dummy */ - writel(0x0200be01, SBBASE1); - } else { + if (boot_is_swapped()) { /* * Boot Swap On: boot from external NOR/SRAM * 0x02000000-0x03ffffff is a mirror of 0x00000000-0x01ffffff. @@ -40,6 +31,15 @@ void sbc_init(void) * 0x01f00000-0x01ffffff, 0x03f00000-0x03ffffff: peripherals */ writel(0x0000bc01, SBBASE0); + } else { + /* + * Boot Swap Off: boot from mask ROM + * 0x00000000-0x01ffffff: mask ROM + * 0x02000000-0x3effffff: memory bank (31MB) + * 0x03f00000-0x3fffffff: peripherals (1MB) + */ + writel(0x0000be01, SBBASE0); /* dummy */ + writel(0x0200be01, SBBASE1); } #elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) #if !defined(CONFIG_SPL_BUILD)
arch/arm/cpu/armv7/uniphier/Kconfig | 4 ++++ include/configs/ph1_pro4.h | 2 -- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/cpu/armv7/uniphier/Kconfig index 36b7f11..31a03d9 100644 --- a/arch/arm/cpu/armv7/uniphier/Kconfig +++ b/arch/arm/cpu/armv7/uniphier/Kconfig @@ -9,11 +9,15 @@ config SYS_CONFIG_NAME default "ph1_ld4" if MACH_PH1_LD4 default "ph1_sld8" if MACH_PH1_SLD8
+config UNIPHIER_SMP + bool + choice prompt "UniPhier SoC select"
config MACH_PH1_PRO4 bool "PH1-Pro4" + select UNIPHIER_SMP
config MACH_PH1_LD4 bool "PH1-LD4" diff --git a/include/configs/ph1_pro4.h b/include/configs/ph1_pro4.h index fc5132d..7780030 100644 --- a/include/configs/ph1_pro4.h +++ b/include/configs/ph1_pro4.h @@ -37,8 +37,6 @@ #define CONFIG_DDR_NUM_CH0 2 #define CONFIG_DDR_NUM_CH1 2
-#define CONFIG_UNIPHIER_SMP - /* * Memory Size & Mapping */
There are two kinds of expansion boards which are often used for the UniPhier platform and they are only exclusively selectable. It can be better described by the "choice" menu of Kconfig.
arch/arm/cpu/armv7/uniphier/Kconfig | 23 +++++++++++++++++++++++ configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + include/configs/ph1_ld4.h | 15 --------------- include/configs/ph1_pro4.h | 15 --------------- include/configs/ph1_sld8.h | 15 --------------- include/configs/uniphier-common.h | 6 ------ 8 files changed, 26 insertions(+), 51 deletions(-)
diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/cpu/armv7/uniphier/Kconfig index 31a03d9..1d96db2 100644 --- a/arch/arm/cpu/armv7/uniphier/Kconfig +++ b/arch/arm/cpu/armv7/uniphier/Kconfig @@ -27,6 +27,29 @@ config MACH_PH1_SLD8
endchoice
+choice + prompt "UniPhier Support Card select" + optional + +config PFC_MICRO_SUPPORT_CARD + bool "Support card with PFC CPLD" + help + This option provides support for the expansion board with PFC + original address mapping. + + Say Y to use the on-board UART, Ether, LED devices. + +config DCC_MICRO_SUPPORT_CARD + bool "Support card with DCC CPLD" + help + This option provides support for the expansion board with DCC- + arranged address mapping that is compatible with legacy UniPhier + reference boards. + + Say Y to use the on-board UART, Ether, LED devices. + +endchoice + config CMD_PINMON bool "Enable boot mode pins monitor command" depends on !SPL_BUILD diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index de068e9..3155340 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -4,6 +4,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_LD4=y ++S:CONFIG_DCC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index f4ddf5f..7ea4e6e 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -4,6 +4,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_PRO4=y ++S:CONFIG_DCC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index ee14382..ddf210c 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -4,6 +4,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_SLD8=y ++S:CONFIG_DCC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y diff --git a/include/configs/ph1_ld4.h b/include/configs/ph1_ld4.h index 73a95e6..a3e4f96 100644 --- a/include/configs/ph1_ld4.h +++ b/include/configs/ph1_ld4.h @@ -9,21 +9,6 @@ #define __PH1_XXX_H
/* - * Support Card Select - * - * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. - * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. - * CPLD is re-programmed for ARIMA board compatibility. - * No define - No support card. - */ - -#if 0 -#define CONFIG_PFC_MICRO_SUPPORT_CARD -#else -#define CONFIG_DCC_MICRO_SUPPORT_CARD -#endif - -/* * Serial Configuration * SoC UART : enable CONFIG_UNIPHIER_SERIAL * On-board UART: enable CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/ph1_pro4.h b/include/configs/ph1_pro4.h index 7780030..15849ba 100644 --- a/include/configs/ph1_pro4.h +++ b/include/configs/ph1_pro4.h @@ -9,21 +9,6 @@ #define __PH1_XXX_H
/* - * Support Card Select - * - * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. - * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. - * CPLD is re-programmed for ARIMA board compatibility. - * No define - No support card. - */ - -#if 0 -#define CONFIG_PFC_MICRO_SUPPORT_CARD -#else -#define CONFIG_DCC_MICRO_SUPPORT_CARD -#endif - -/* * Serial Configuration * SoC UART : enable CONFIG_UNIPHIER_SERIAL * On-board UART: enable CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/ph1_sld8.h b/include/configs/ph1_sld8.h index e2f1102..e64d902 100644 --- a/include/configs/ph1_sld8.h +++ b/include/configs/ph1_sld8.h @@ -9,21 +9,6 @@ #define __PH1_XXX_H
/* - * Support Card Select - * - * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. - * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. - * CPLD is re-programmed for ARIMA board compatibility. - * No define - No support card. - */ - -#if 0 -#define CONFIG_PFC_MICRO_SUPPORT_CARD -#else -#define CONFIG_DCC_MICRO_SUPPORT_CARD -#endif - -/* * Serial Configuration * SoC UART : enable CONFIG_UNIPHIER_SERIAL * On-board UART: enable CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier-common.h index 31ab470..224c335 100644 --- a/include/configs/uniphier-common.h +++ b/include/configs/uniphier-common.h @@ -10,12 +10,6 @@ #ifndef __CONFIG_UNIPHIER_COMMON_H__ #define __CONFIG_UNIPHIER_COMMON_H__
-#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) && \ - defined(CONFIG_DCC_MICRO_SUPPORT_CARD) -# error "Both CONFIG_PFC_MICRO_SUPPORT_CARD and CONFIG_DCC_MICRO_SUPPORT_CARD \ -are defined. Select only one of them." -#endif - /* * Support card address map */
Some configurations have been moved to Kconfig and the difference among the config headers of UniPhier SoC variants is getting smaller and smaller. Now is a good time to merge them into a single file.
arch/arm/cpu/armv7/uniphier/Kconfig | 4 +- include/configs/ph1_ld4.h | 38 ------------------ include/configs/ph1_pro4.h | 38 ------------------ include/configs/ph1_sld8.h | 40 ------------------- include/configs/{uniphier-common.h => uniphier.h} | 47 +++++++++++++++++++++++ 5 files changed, 48 insertions(+), 119 deletions(-) delete mode 100644 include/configs/ph1_ld4.h delete mode 100644 include/configs/ph1_pro4.h delete mode 100644 include/configs/ph1_sld8.h rename include/configs/{uniphier-common.h => uniphier.h} (86%)
diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/cpu/armv7/uniphier/Kconfig index 1d96db2..9760299 100644 --- a/arch/arm/cpu/armv7/uniphier/Kconfig +++ b/arch/arm/cpu/armv7/uniphier/Kconfig @@ -5,9 +5,7 @@ config SYS_SOC default "uniphier"
config SYS_CONFIG_NAME - default "ph1_pro4" if MACH_PH1_PRO4 - default "ph1_ld4" if MACH_PH1_LD4 - default "ph1_sld8" if MACH_PH1_SLD8 + default "uniphier"
config UNIPHIER_SMP bool diff --git a/include/configs/ph1_ld4.h b/include/configs/ph1_ld4.h deleted file mode 100644 index a3e4f96..0000000 --- a/include/configs/ph1_ld4.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __PH1_XXX_H -#define __PH1_XXX_H - -/* - * Serial Configuration - * SoC UART : enable CONFIG_UNIPHIER_SERIAL - * On-board UART: enable CONFIG_SYS_NS16550_SERIAL - */ -#if 0 -#define CONFIG_SYS_NS16550_SERIAL -#endif - -#define CONFIG_SMC911X - -#define CONFIG_DDR_NUM_CH0 1 -#define CONFIG_DDR_NUM_CH1 1 - -/* - * Memory Size & Mapping - */ -/* Physical start address of SDRAM */ -#define CONFIG_SDRAM0_BASE 0x80000000 -#define CONFIG_SDRAM0_SIZE 0x10000000 -#define CONFIG_SDRAM1_BASE 0x90000000 -#define CONFIG_SDRAM1_SIZE 0x10000000 - -#define CONFIG_SPL_TEXT_BASE 0x40000 - -#include "uniphier-common.h" - -#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_pro4.h b/include/configs/ph1_pro4.h deleted file mode 100644 index 15849ba..0000000 --- a/include/configs/ph1_pro4.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __PH1_XXX_H -#define __PH1_XXX_H - -/* - * Serial Configuration - * SoC UART : enable CONFIG_UNIPHIER_SERIAL - * On-board UART: enable CONFIG_SYS_NS16550_SERIAL - */ -#if 0 -#define CONFIG_SYS_NS16550_SERIAL -#endif - -#define CONFIG_SMC911X - -#define CONFIG_DDR_NUM_CH0 2 -#define CONFIG_DDR_NUM_CH1 2 - -/* - * Memory Size & Mapping - */ -/* Physical start address of SDRAM */ -#define CONFIG_SDRAM0_BASE 0x80000000 -#define CONFIG_SDRAM0_SIZE 0x20000000 -#define CONFIG_SDRAM1_BASE 0xa0000000 -#define CONFIG_SDRAM1_SIZE 0x20000000 - -#define CONFIG_SPL_TEXT_BASE 0x100000 - -#include "uniphier-common.h" - -#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_sld8.h b/include/configs/ph1_sld8.h deleted file mode 100644 index e64d902..0000000 --- a/include/configs/ph1_sld8.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __PH1_XXX_H -#define __PH1_XXX_H - -/* - * Serial Configuration - * SoC UART : enable CONFIG_UNIPHIER_SERIAL - * On-board UART: enable CONFIG_SYS_NS16550_SERIAL - */ -#if 0 -#define CONFIG_SYS_NS16550_SERIAL -#endif - -#define CONFIG_SMC911X - -#define CONFIG_DDR_NUM_CH0 1 -#define CONFIG_DDR_NUM_CH1 1 - -/* #define CONFIG_DDR_STANDARD */ - -/* - * Memory Size & Mapping - */ -/* Physical start address of SDRAM */ -#define CONFIG_SDRAM0_BASE 0x80000000 -#define CONFIG_SDRAM0_SIZE 0x10000000 -#define CONFIG_SDRAM1_BASE 0x90000000 -#define CONFIG_SDRAM1_SIZE 0x10000000 - -#define CONFIG_SPL_TEXT_BASE 0x40000 - -#include "uniphier-common.h" - -#endif /* __PH1_XXX_H */ diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier.h similarity index 86% rename from include/configs/uniphier-common.h rename to include/configs/uniphier.h index 224c335..733e6fa 100644 --- a/include/configs/uniphier-common.h +++ b/include/configs/uniphier.h @@ -10,6 +10,39 @@ #ifndef __CONFIG_UNIPHIER_COMMON_H__ #define __CONFIG_UNIPHIER_COMMON_H__
+#if defined(CONFIG_MACH_PH1_PRO4) +#define CONFIG_DDR_NUM_CH0 2 +#define CONFIG_DDR_NUM_CH1 2 + +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x20000000 +#define CONFIG_SDRAM1_BASE 0xa0000000 +#define CONFIG_SDRAM1_SIZE 0x20000000 +#endif + +#if defined(CONFIG_MACH_PH1_LD4) +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 +#endif + +#if defined(CONFIG_MACH_PH1_SLD8) +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 +#endif + /* * Support card address map */ @@ -34,6 +67,13 @@ #define CONFIG_SYS_NS16550_REG_SIZE -2 #endif
+/* TODO: move to Kconfig and device tree */ +#if 0 +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SMC911X + #define CONFIG_SMC911X_BASE CONFIG_SUPPORT_CARD_ETHER_BASE #define CONFIG_SMC911X_32_BIT
@@ -226,6 +266,13 @@
#define CONFIG_SYS_TEXT_BASE 0x84000000
+#if defined(CONFIG_MACH_PH1_LD4) || defined(CONFIG_MACH_PH1_SLD8) +#define CONFIG_SPL_TEXT_BASE 0x00040000 +#endif +#if defined(CONFIG_MACH_PH1_PRO4) +#define CONFIG_SPL_TEXT_BASE 0x00100000 +#endif + #define CONFIG_BOARD_POSTCLK_INIT
#ifndef CONFIG_SPL_BUILD
Add I2C controller and NAND controller devices. Fix indentation too.
arch/arm/dts/uniphier-ph1-ld4-ref.dts | 23 +++++++++--- arch/arm/dts/uniphier-ph1-ld4.dtsi | 40 ++++++++++++++++++++- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 26 +++++++++++--- arch/arm/dts/uniphier-ph1-pro4.dtsi | 64 +++++++++++++++++++++++++++++++++- arch/arm/dts/uniphier-ph1-sld8-ref.dts | 23 +++++++++--- arch/arm/dts/uniphier-ph1-sld8.dtsi | 40 ++++++++++++++++++++- 6 files changed, 201 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/uniphier-ph1-ld4-ref.dts b/arch/arm/dts/uniphier-ph1-ld4-ref.dts index f01189c..5d63a9a 100644 --- a/arch/arm/dts/uniphier-ph1-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld4-ref.dts @@ -23,20 +23,35 @@ bootargs = "console=ttyPS0,115200 earlyprintk"; stdout-path = &uart0; }; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + }; };
&uart0 { - status = "okay"; + status = "okay"; };
&uart1 { - status = "okay"; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + eeprom { + compatible = "i2c-eeprom"; + reg = <0x50>; + }; };
&usb0 { - status = "okay"; + status = "okay"; };
&usb1 { - status = "okay"; + status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 80074c5..8c217b8 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -13,8 +13,8 @@ compatible = "panasonic,ph1-ld4";
cpus { - #size-cells = <0>; #address-cells = <1>; + #size-cells = <0>;
cpu@0 { device_type = "cpu"; @@ -57,6 +57,38 @@ clock-frequency = <36864000>; };
+ i2c0: i2c@58400000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58400000 0x40>; + status = "disabled"; + }; + + i2c1: i2c@58480000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58480000 0x40>; + status = "disabled"; + }; + + i2c2: i2c@58500000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58500000 0x40>; + status = "disabled"; + }; + + i2c3: i2c@58580000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58580000 0x40>; + status = "disabled"; + }; + usb0: usb@5a800100 { compatible = "panasonic,uniphier-ehci", "usb-ehci"; status = "disabled"; @@ -74,5 +106,11 @@ status = "disabled"; reg = <0x5a820100 0x100>; }; + + nand: nand@68000000 { + compatible = "denali,denali-nand-dt"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + reg-names = "nand_data", "denali_reg"; + }; }; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index 52fa81f..dab01da 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -23,20 +23,38 @@ bootargs = "console=ttyPS0,115200 earlyprintk"; stdout-path = &uart0; }; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + }; };
&usb1 { - status = "okay"; + status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index dd84269..debe9cb 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -13,8 +13,8 @@ compatible = "panasonic,ph1-pro4";
cpu@0 { device_type = "cpu"; @@ -63,6 +63,62 @@ clock-frequency = <73728000>; };
+ i2c0: i2c@58780000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58780000 0x80>; + status = "disabled"; + }; + + i2c1: i2c@58781000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58781000 0x80>; + status = "disabled"; + }; + + i2c2: i2c@58782000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58782000 0x80>; + status = "disabled"; + }; + + i2c3: i2c@58783000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58783000 0x80>; + status = "disabled"; + }; + + i2c4: i2c@58784000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58784000 0x80>; + status = "disabled"; + }; + + i2c5: i2c@58785000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58785000 0x80>; + status = "disabled"; + }; + + i2c6: i2c@58786000 { + compatible = "panasonic,uniphier-fi2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58786000 0x80>; + status = "disabled"; + }; + usb0: usb@5a800100 { compatible = "panasonic,uniphier-ehci", "usb-ehci"; status = "disabled"; @@ -74,5 +130,11 @@ status = "disabled"; reg = <0x5a810100 0x100>; }; + + nand: nand@68000000 { + compatible = "denali,denali-nand-dt"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + reg-names = "nand_data", "denali_reg"; + }; }; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8-ref.dts b/arch/arm/dts/uniphier-ph1-sld8-ref.dts index ac73aad..6a08b68 100644 --- a/arch/arm/dts/uniphier-ph1-sld8-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld8-ref.dts @@ -23,20 +23,35 @@ bootargs = "console=ttyPS0,115200 earlyprintk"; stdout-path = &uart0; }; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + }; };
&usb1 { - status = "okay"; + status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 43a39f5..e80ed02 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -13,8 +13,8 @@ compatible = "panasonic,ph1-sld8";
cpu@0 { device_type = "cpu"; @@ -57,6 +57,38 @@ clock-frequency = <80000000>; };
arch/arm/dts/Makefile | 1 + arch/arm/dts/uniphier-ph1-sld3-ref.dts | 57 ++++++++++++++++ arch/arm/dts/uniphier-ph1-sld3.dtsi | 121 +++++++++++++++++++++++++++++++++ 3 files changed, 179 insertions(+) create mode 100644 arch/arm/dts/uniphier-ph1-sld3-ref.dts create mode 100644 arch/arm/dts/uniphier-ph1-sld3.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 01df9a9..187d58c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -33,6 +33,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra124-jetson-tk1.dtb \ tegra124-venice2.dtb dtb-$(CONFIG_ARCH_UNIPHIER) += \ + uniphier-ph1-sld3-ref.dtb \ uniphier-ph1-pro4-ref.dtb \ uniphier-ph1-ld4-ref.dtb \ uniphier-ph1-sld8-ref.dtb diff --git a/arch/arm/dts/uniphier-ph1-sld3-ref.dts b/arch/arm/dts/uniphier-ph1-sld3-ref.dts new file mode 100644 index 0000000..cb255d2 --- /dev/null +++ b/arch/arm/dts/uniphier-ph1-sld3-ref.dts @@ -0,0 +1,57 @@ +/* + * Device Tree Source for UniPhier PH1-sLD3 Reference Board + * + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "uniphier-ph1-sld3.dtsi" + +/ { + model = "Panasonic UniPhier PH1-sLD3 Reference Board"; + compatible = "panasonic,ph1-sld3-ref", "panasonic,ph1-sld3"; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + chosen { + bootargs = "console=ttyPS0,115200 earlyprintk"; + stdout-path = &uart0; + }; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + }; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + eeprom { + compatible = "i2c-eeprom"; + reg = <0x50>; + }; +}; + +&usb0 { + status = "okay"; +}; + +&usb1 { + status = "okay"; +}; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi new file mode 100644 index 0000000..23b6767 --- /dev/null +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -0,0 +1,121 @@ +/* + * Device Tree Source for UniPhier PH1-sLD3 SoC + * + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + compatible = "panasonic,ph1-sld3"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <1>; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + uart0: serial@54006800 { + compatible = "panasonic,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x20>; + clock-frequency = <36864000>; + }; + + uart1: serial@54006900 { + compatible = "panasonic,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x20>; + clock-frequency = <36864000>; + }; + + uart2: serial@54006a00 { + compatible = "panasonic,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x20>; + clock-frequency = <36864000>; + }; + + i2c0: i2c@58400000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58400000 0x40>; + status = "disabled"; + }; + + i2c1: i2c@58480000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58480000 0x40>; + status = "disabled"; + }; + + i2c2: i2c@58500000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58500000 0x40>; + status = "disabled"; + }; + + i2c3: i2c@58580000 { + compatible = "panasonic,uniphier-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x58580000 0x40>; + status = "disabled"; + }; + + usb0: usb@5a800100 { + compatible = "panasonic,uniphier-ehci", "usb-ehci"; + status = "disabled"; + reg = <0x5a800100 0x100>; + }; + + usb1: usb@5a810100 { + compatible = "panasonic,uniphier-ehci", "usb-ehci"; + status = "disabled"; + reg = <0x5a810100 0x100>; + }; + + usb2: usb@5a820100 { + compatible = "panasonic,uniphier-ehci", "usb-ehci"; + status = "disabled"; + reg = <0x5a820100 0x100>; + }; + + usb3: usb@5a830100 { + compatible = "panasonic,uniphier-ehci", "usb-ehci"; + status = "disabled"; + reg = <0x5a830100 0x100>; + }; + + nand: nand@f8000000 { + compatible = "denali,denali-nand-dt"; + reg = <0xf8000000 0x20>, <0xf8100000 0x1000>; + reg-names = "nand_data", "denali_reg"; + }; + }; +};
0x20000000-0x2fffffff: assigned to ARM mpcore (sLD3 only) 0xf0000000-0xffffffff: assigned to Denali NAND controller (sLD3 only)
arch/arm/cpu/armv7/uniphier/init_page_table.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/uniphier/init_page_table.c b/arch/arm/cpu/armv7/uniphier/init_page_table.c index d273835..a0d10a9 100644 --- a/arch/arm/cpu/armv7/uniphier/init_page_table.c +++ b/arch/arm/cpu/armv7/uniphier/init_page_table.c @@ -28,7 +28,12 @@ #define IS_SSC(x) ((IS_SPL_TEXT_AREA(x)) || \ (IS_INIT_STACK_AREA(x))) #define IS_EXT(x) ((x) < 0x100) -#define IS_REG(x) (0x500 <= (x) && (x) < 0x700) + +/* 0x20000000-0x2fffffff, 0xf0000000-0xffffffff are only used by PH1-sLD3 */ +#define IS_REG(x) (0x200 <= (x) && (x) < 0x300) || \ + (0x500 <= (x) && (x) < 0x700) || \ + (0xf00 <= (x)) + #define IS_DDR(x) (0x800 <= (x) && (x) < 0xf00)
#define MMU_FLAGS(x) (IS_SSC(x)) ? SSC : \
Some UniPhier boards are equipped with an expansion slot that some optional SRAM/NOR-flash cards can be attached to. So, run-time detection of the number of flash banks would be more user-friendly.
Until this commit, UniPhier boards have achieved this by (ab)using board_flash_wp_on() because the boot failed if flash_size got zero. This problem was solved by the previous commit.
Now it is possible to throw away such a tricky workaround.
This commit enables CONFIG_SYS_MAX_FLASH_BANKS_DETECT and refactors NOR-flash detection code.
arch/arm/cpu/armv7/uniphier/Makefile | 1 + arch/arm/cpu/armv7/uniphier/board_early_init_r.c | 15 +++ arch/arm/cpu/armv7/uniphier/support_card.c | 125 +++++++++++++++-------- arch/arm/include/asm/arch-uniphier/board.h | 7 ++ include/configs/uniphier.h | 13 +-- 5 files changed, 110 insertions(+), 51 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/board_early_init_r.c
diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/cpu/armv7/uniphier/Makefile index 0f64d25..4a7b8a9 100644 --- a/arch/arm/cpu/armv7/uniphier/Makefile +++ b/arch/arm/cpu/armv7/uniphier/Makefile @@ -11,6 +11,7 @@ obj-y += cache_uniphier.o obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o obj-y += dram_init.o obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-$(CONFIG_BOARD_EARLY_INIT_R) += board_early_init_r.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o obj-$(CONFIG_UNIPHIER_SMP) += smp.o obj-$(CONFIG_CMD_PINMON) += cmd_pinmon.o diff --git a/arch/arm/cpu/armv7/uniphier/board_early_init_r.c b/arch/arm/cpu/armv7/uniphier/board_early_init_r.c new file mode 100644 index 0000000..cb7e04f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_early_init_r.c @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int board_early_init_r(void) +{ + uniphier_board_late_init(); + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/support_card.c b/arch/arm/cpu/armv7/uniphier/support_card.c index 40d4940..419012e 100644 --- a/arch/arm/cpu/armv7/uniphier/support_card.c +++ b/arch/arm/cpu/armv7/uniphier/support_card.c @@ -83,6 +83,12 @@ static int support_card_show_revision(void) } #endif
+int check_support_card(void) +{ + printf("SC: Micro Support Card "); + return support_card_show_revision(); +} + void support_card_init(void) { /* @@ -94,12 +100,6 @@ void support_card_init(void) support_card_reset_deassert(); }
-int check_support_card(void) -{ - printf("SC: Micro Support Card "); - return support_card_show_revision(); -} - #if defined(CONFIG_SMC911X) #include <netdev.h>
@@ -112,18 +112,14 @@ int board_eth_init(bd_t *bis) #if !defined(CONFIG_SYS_NO_FLASH)
#include <mtd/cfi_flash.h> +#include <asm/arch/sbc-regs.h>
-#if CONFIG_SYS_MAX_FLASH_BANKS > 1 -static phys_addr_t flash_banks_list[CONFIG_SYS_MAX_FLASH_BANKS] = - CONFIG_SYS_FLASH_BANKS_LIST; +struct memory_bank { + phys_addr_t base; + unsigned long size; +};
-phys_addr_t cfi_flash_bank_addr(int i) -{ - return flash_banks_list[i]; -} -#endif - -int mem_is_flash(phys_addr_t base) +static int mem_is_flash(const struct memory_bank *mem) { const int loop = 128; u32 *scratch_addr; @@ -131,8 +127,9 @@ int mem_is_flash(phys_addr_t base) int ret = 1; int i;
- scratch_addr = map_physmem(base + 0x01e00000, - sizeof(u32) * loop, MAP_NOCACHE); + /* just in case, use the tail of the memory bank */ + scratch_addr = map_physmem(mem->base + mem->size - sizeof(u32) * loop, + sizeof(u32) * loop, MAP_NOCACHE);
for (i = 0; i < loop; i++, scratch_addr++) { saved_value = readl(scratch_addr); @@ -150,31 +147,79 @@ int mem_is_flash(phys_addr_t base) return ret; }
-int board_flash_wp_on(void) +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) + /* {address, size} */ +static const struct memory_bank memory_banks_boot_swap_off[] = { + {0x02000000, 0x01f00000}, +}; + +static const struct memory_bank memory_banks_boot_swap_on[] = { + {0x00000000, 0x01f00000}, +}; +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +static const struct memory_bank memory_banks_boot_swap_off[] = { + {0x04000000, 0x04000000}, +}; + +static const struct memory_bank memory_banks_boot_swap_on[] = { + {0x00000000, 0x04000000}, + {0x04000000, 0x04000000}, +}; +#endif + +static const struct memory_bank +*flash_banks_list[CONFIG_SYS_MAX_FLASH_BANKS_DETECT]; + +phys_addr_t cfi_flash_bank_addr(int i) { - int i; - int ret = 1; + return flash_banks_list[i]->base; +}
- for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - if (mem_is_flash(cfi_flash_bank_addr(i))) { - /* - * We found at least one flash. - * We need to return 0 and call flash_init(). - */ - ret = 0; - } -#if CONFIG_SYS_MAX_FLASH_BANKS > 1 - else { - /* - * We might have a SRAM here. - * To prevent SRAM data from being destroyed, - * we set dummy address (SDRAM). - */ - flash_banks_list[i] = 0x80000000 + 0x10000 * i; +unsigned long cfi_flash_bank_size(int i) +{ + return flash_banks_list[i]->size; +} + +static void detect_num_flash_banks(void) +{ + const struct memory_bank *memory_bank, *end; + + cfi_flash_num_flash_banks = 0; + + if (boot_is_swapped()) { + memory_bank = memory_banks_boot_swap_on; + end = memory_bank + ARRAY_SIZE(memory_banks_boot_swap_on); + } else { + memory_bank = memory_banks_boot_swap_off; + end = memory_bank + ARRAY_SIZE(memory_banks_boot_swap_off); + } + + for (; memory_bank < end; memory_bank++) { + if (cfi_flash_num_flash_banks >= + CONFIG_SYS_MAX_FLASH_BANKS_DETECT) + break; + + if (mem_is_flash(memory_bank)) { + flash_banks_list[cfi_flash_num_flash_banks] = + memory_bank; + + debug("flash bank found: base = 0x%lx, size = 0x%lx\n", + memory_bank->base, memory_bank->size); + cfi_flash_num_flash_banks++; } -#endif }
- return ret; + debug("number of flash banks: %d\n", cfi_flash_num_flash_banks); +} +#else /* ONFIG_SYS_NO_FLASH */ +void detect_num_flash_banks(void) +{ +}; +#endif /* ONFIG_SYS_NO_FLASH */ + +void support_card_late_init(void) +{ + detect_num_flash_banks(); } -#endif diff --git a/arch/arm/include/asm/arch-uniphier/board.h b/arch/arm/include/asm/arch-uniphier/board.h index e6ba4e4..e3cba5b 100644 --- a/arch/arm/include/asm/arch-uniphier/board.h +++ b/arch/arm/include/asm/arch-uniphier/board.h @@ -12,10 +12,12 @@ defined(CONFIG_DCC_MICRO_SUPPORT_CARD) void support_card_reset(void); void support_card_init(void); +void support_card_late_init(void); int check_support_card(void); #else #define support_card_reset() do {} while (0) #define support_card_init() do {} while (0) +#define support_card_late_init() do {} while (0) static inline int check_support_card(void) { return 0; @@ -32,4 +34,9 @@ static inline void uniphier_board_init(void) support_card_init(); }
+static inline void uniphier_board_late_init(void) +{ + support_card_late_init(); +} + #endif /* ARCH_BOARD_H */ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 733e6fa..dd022fb 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -92,6 +92,7 @@
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) @@ -121,17 +122,7 @@
#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) -# define CONFIG_SYS_MAX_FLASH_BANKS 1 -# define CONFIG_SYS_FLASH_BANKS_LIST {0x00000000} -# define CONFIG_SYS_FLASH_BANKS_SIZES {0x02000000} -#endif - -#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) -# define CONFIG_SYS_MAX_FLASH_BANKS 1 -# define CONFIG_SYS_FLASH_BANKS_LIST {0x04000000} -# define CONFIG_SYS_FLASH_BANKS_SIZES {0x04000000} -#endif +#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 2
/* serial console configuration */ #define CONFIG_BAUDRATE 115200
2014-12-06 0:03 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
-- 1.9.1
Series, applied to u-boot-uniphier/master.
Masahiro YAMADA
Masahiro Yamada
