[PATCH] riscv: Fix setting no-map in reserved memory nodes
The no-map property is wrongly skipped if a no-map reserved memory node follows one without that property. Fix this by not remembering the absence of a no-map property across loop iterations.
Fixes: d4ea649f179a ("riscv: Provide a mechanism to fix DT for reserved memory") Signed-off-by: Samuel Holland samuel@sholland.org ---
arch/riscv/lib/fdt_fixup.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index f636b284497..61cf8935269 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -31,7 +31,6 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) fdt_addr_t addr; fdt_size_t size; int offset, node, err, rmem_offset; - bool nomap = true; char basename[32] = {0}; int bname_len; int max_len = sizeof(basename); @@ -81,9 +80,7 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) log_err("failed to add reserved memory: %d\n", err); return err; } - if (!fdt_getprop(src, node, "no-map", NULL)) - nomap = false; - if (nomap) { + if (fdt_getprop(src, node, "no-map", NULL)) { rmem_offset = fdt_node_offset_by_phandle(dst, phandle); fdt_setprop_empty(dst, rmem_offset, "no-map"); }
nomap = false;
if (nomap) {
-- 2.31.1
Thanks for catching it.
Reviewed-by: Atish Patra atish.patra@wdc.com
Atish Patra
Bin Meng
Samuel Holland
