[U-Boot] [PATCH] arch: powerpc: Remove unused dts frequency fixup for lbc_clk
lbc_clk is used to fixup dts as "bus frequency". It is not being used by Linux IFC and eLBC driver.
So remove unused "bus frqeuency" fix-up of devicre tree.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- arch/powerpc/cpu/mpc85xx/fdt.c | 4 ---- arch/powerpc/cpu/mpc86xx/fdt.c | 7 ------- 2 files changed, 11 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index ced216c..047c972 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -626,10 +626,6 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_prop_u32(blob, "device_type", "soc", 4, "bus-frequency", bd->bi_busfreq, 1);
- do_fixup_by_compat_u32(blob, "fsl,pq3-localbus", - "bus-frequency", gd->arch.lbc_clk, 1); - do_fixup_by_compat_u32(blob, "fsl,elbc", - "bus-frequency", gd->arch.lbc_clk, 1); #ifdef CONFIG_QE ft_qe_setup(blob); ft_fixup_qe_snum(blob); diff --git a/arch/powerpc/cpu/mpc86xx/fdt.c b/arch/powerpc/cpu/mpc86xx/fdt.c index dd99155..5f9ad6b 100644 --- a/arch/powerpc/cpu/mpc86xx/fdt.c +++ b/arch/powerpc/cpu/mpc86xx/fdt.c @@ -30,13 +30,6 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_prop_u32(blob, "device_type", "soc", 4, "bus-frequency", bd->bi_busfreq, 1);
-#if defined(CONFIG_MPC8641) - do_fixup_by_compat_u32(blob, "fsl,mpc8641-localbus", - "bus-frequency", gd->arch.lbc_clk, 1); -#endif - do_fixup_by_compat_u32(blob, "fsl,elbc", - "bus-frequency", gd->arch.lbc_clk, 1); - fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
#if defined(CONFIG_HAS_ETH0) || defined(CONFIG_HAS_ETH1) \
Applied to u-boot-mpc85xx master, awaiting upstream. Thanks.
York
Prabhakar Kushwaha
york sun
