[U-Boot] [PATCH] SPL: do not use fix value for u-boot size
If an u-boot image is not found, SPL thinks to load a bare u-boot.bin image with a maximum size of 200KB. Use CONFIG_SYS_MONITOR_LEN instead.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tom Rini trini@ti.com ---
Note: this is based on Tom's series "ARM: SPL: Make more generic, merge DaVinci and OMAP"
Tested with V2 version on a MX35.
common/spl/spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 7d15460..827ff1c 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -100,7 +100,11 @@ void spl_parse_image_header(const struct image_header *header) debug("mkimage signature not found - ih_magic = %x\n", header->ih_magic); /* Let's assume U-Boot will not be more than 200 KB */ +#ifdef CONFIG_SYS_MONITOR_LEN + spl_image.size = CONFIG_SYS_MONITOR_LEN; +#else spl_image.size = 200 * 1024; +#endif spl_image.entry_point = CONFIG_SYS_TEXT_BASE; spl_image.load_addr = CONFIG_SYS_TEXT_BASE; spl_image.os = IH_OS_U_BOOT;
Yes, I noticed this 200 KiB setting as well. But it seems that this ".size" variable is not referenced at all. Or am I missing something? If this is correct, then we should probably remove setting it completely.
What do you think?
Thanks, Stefan
Hi Stefan,
Your are missing something:
drivers/mmc/spl_mmc.c:
55 /* convert size to sectors - round up */ 56 image_size_sectors = (spl_image.size + MMCSD_SECTOR_SIZE - 1) / 57 MMCSD_SECTOR_SIZE;
And I have an example where only a part of u-boot is copied.
Cheers, Stefano
Hi Stefano,
Ahh, I see. Thanks.
I would prefer the following approach then, to move the #ifdef out of the C code:
#ifndef CONFIG_SYS_MONITOR_LEN #define CONFIG_SYS_MONITOR_LEN (200 * 1024) #endif
and then use CONFIG_SYS_MONITOR_LEN unconditionally.
Thanks, Stefan
On 23/08/2012 11:28, Stefan Roese wrote:
Hi Stefano,
Ahh, I see. Thanks.
Fine with me - I will fix in V2.
Regards, Stefano
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tom Rini trini@ti.com CC: Stefan Roese stefan.roese@gmail.com ---
Changes:
- move the #ifdef out of the C code (Stefan Roese)
common/spl/spl.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 7d15460..d9e4b62 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -36,6 +36,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifndef CONFIG_SYS_MONITOR_LEN +#define CONFIG_SYS_MONITOR_LEN (200 * 1024) +#endif + u32* boot_params_ptr = NULL; struct spl_image_info spl_image;
@@ -100,7 +104,7 @@ void spl_parse_image_header(const struct image_header *header) debug("mkimage signature not found - ih_magic = %x\n", header->ih_magic); /* Let's assume U-Boot will not be more than 200 KB */ - spl_image.size = 200 * 1024; + spl_image.size = CONFIG_SYS_MONITOR_LEN; spl_image.entry_point = CONFIG_SYS_TEXT_BASE; spl_image.load_addr = CONFIG_SYS_TEXT_BASE; spl_image.os = IH_OS_U_BOOT;
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Looks good, I'll take this for my v4.
Stefan Roese
Stefano Babic
