[U-Boot-Users] [PATCH 1/1] NE2000: Fix regresssion introduced by e710185aae90 on non AX88796
Move non-inlied functions into specific drivers file Set get_prom as weak
Coding Style Cleanup
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Vlad Lungu vlad@comsys.ro --- drivers/net/Makefile | 5 +- drivers/net/ax88796.c | 156 +++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ax88796.h | 134 -------------------------------------- drivers/net/ne2000.c | 94 ++++++++++++++++++++++++++- drivers/net/ne2000.h | 87 +------------------------- drivers/net/ne2000_base.h | 1 - 6 files changed, 252 insertions(+), 225 deletions(-) create mode 100644 drivers/net/ax88796.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d5e413b..4131aad 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,7 +42,10 @@ COBJS-y += lan91c96.o COBJS-y += macb.o COBJS-y += mcffec.o COBJS-y += natsemi.o -COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o +ifeq ($(CONFIG_DRIVER_NE2000),y) +COBJS-y += ne2000.o +COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o +endif COBJS-y += netarm_eth.o COBJS-y += netconsole.o COBJS-y += ns7520_eth.o diff --git a/drivers/net/ax88796.c b/drivers/net/ax88796.c new file mode 100644 index 0000000..39cd101 --- /dev/null +++ b/drivers/net/ax88796.c @@ -0,0 +1,156 @@ +/* + * (c) 2007 Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#include <common.h> +#include "ax88796.h" + +/* + * Set 1 bit data + */ +static void ax88796_bitset(u32 bit) +{ + /* DATA1 */ + if( bit ) + EEDI_HIGH; + else + EEDI_LOW; + + EECLK_LOW; + udelay(1000); + EECLK_HIGH; + udelay(1000); + EEDI_LOW; +} + +/* + * Get 1 bit data + */ +static u8 ax88796_bitget(void) +{ + u8 bit; + + EECLK_LOW; + udelay(1000); + /* DATA */ + bit = EEDO; + EECLK_HIGH; + udelay(1000); + + return bit; +} + +/* + * Send COMMAND to EEPROM + */ +static void ax88796_eep_cmd(u8 cmd) +{ + ax88796_bitset(BIT_DUMMY); + switch(cmd){ + case MAC_EEP_READ: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(0); + break; + + case MAC_EEP_WRITE: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(1); + break; + + case MAC_EEP_ERACE: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(1); + break; + + case MAC_EEP_EWEN: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + + case MAC_EEP_EWDS: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + default: + break; + } +} + +static void ax88796_eep_setaddr(u16 addr) +{ + int i ; + + for( i = 7 ; i >= 0 ; i-- ) + ax88796_bitset(addr & (1 << i)); +} + +/* + * Get data from EEPROM + */ +static u16 ax88796_eep_getdata(void) +{ + ushort data = 0; + int i; + + ax88796_bitget(); /* DUMMY */ + for( i = 0 ; i < 16 ; i++ ){ + data <<= 1; + data |= ax88796_bitget(); + } + return data; +} + +static void ax88796_mac_read(u8 *buff) +{ + int i ; + u16 data; + u16 addr = 0; + + for( i = 0 ; i < 3; i++ ) + { + EECS_HIGH; + EEDI_LOW; + udelay(1000); + /* READ COMMAND */ + ax88796_eep_cmd(MAC_EEP_READ); + /* ADDRESS */ + ax88796_eep_setaddr(addr++); + /* GET DATA */ + data = ax88796_eep_getdata(); + *buff++ = (uchar)(data & 0xff); + *buff++ = (uchar)((data >> 8) & 0xff); + EECLK_LOW; + EEDI_LOW; + EECS_LOW; + } +} + +int get_prom(u8* mac_addr) +{ + u8 prom[32]; + int i; + + ax88796_mac_read(prom); + for (i = 0; i < 6; i++){ + mac_addr[i] = prom[i]; + } + return 1; +} diff --git a/drivers/net/ax88796.h b/drivers/net/ax88796.h index 069ae80..aa342cb 100644 --- a/drivers/net/ax88796.h +++ b/drivers/net/ax88796.h @@ -79,139 +79,5 @@ #endif
-/* - * Set 1 bit data - */ -static void ax88796_bitset(u32 bit) -{ - /* DATA1 */ - if( bit ) - EEDI_HIGH; - else - EEDI_LOW; - - EECLK_LOW; - udelay(1000); - EECLK_HIGH; - udelay(1000); - EEDI_LOW; -} - -/* - * Get 1 bit data - */ -static u8 ax88796_bitget(void) -{ - u8 bit; - - EECLK_LOW; - udelay(1000); - /* DATA */ - bit = EEDO; - EECLK_HIGH; - udelay(1000); - - return bit; -} - -/* - * Send COMMAND to EEPROM - */ -static void ax88796_eep_cmd(u8 cmd) -{ - ax88796_bitset(BIT_DUMMY); - switch(cmd){ - case MAC_EEP_READ: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(0); - break; - - case MAC_EEP_WRITE: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(1); - break; - - case MAC_EEP_ERACE: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(1); - break; - - case MAC_EEP_EWEN: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - - case MAC_EEP_EWDS: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - default: - break; - } -} - -static void ax88796_eep_setaddr(u16 addr) -{ - int i ; - for( i = 7 ; i >= 0 ; i-- ) - ax88796_bitset(addr & (1 << i)); -} - -/* - * Get data from EEPROM - */ -static u16 ax88796_eep_getdata(void) -{ - ushort data = 0; - int i; - - ax88796_bitget(); /* DUMMY */ - for( i = 0 ; i < 16 ; i++ ){ - data <<= 1; - data |= ax88796_bitget(); - } - return data; -} - -static void ax88796_mac_read(u8 *buff) -{ - int i ; - u16 data, addr = 0; - - for( i = 0 ; i < 3; i++ ) - { - EECS_HIGH; - EEDI_LOW; - udelay(1000); - /* READ COMMAND */ - ax88796_eep_cmd(MAC_EEP_READ); - /* ADDRESS */ - ax88796_eep_setaddr(addr++); - /* GET DATA */ - data = ax88796_eep_getdata(); - *buff++ = (uchar)(data & 0xff); - *buff++ = (uchar)((data >> 8) & 0xff); - EECLK_LOW; - EEDI_LOW; - EECS_LOW; - } -} - -int get_prom(u8* mac_addr) -{ - u8 prom[32]; - int i; - - ax88796_mac_read(prom); - for (i = 0; i < 6; i++){ - mac_addr[i] = prom[i]; - } - return 1; -}
#endif /* __DRIVERS_AX88796L_H__ */ diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index 568dad7..3f32693 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -126,6 +126,9 @@ dp83902a_init(void) { dp83902a_priv_data_t *dp = &nic; u8* base; +#if defined(NE2000_BASIC_INIT) + int i; +#endif
DEBUG_FUNCTION();
@@ -755,8 +758,6 @@ static hw_info_t hw_info[] = {
#define NR_INFO (sizeof(hw_info)/sizeof(hw_info_t))
-static hw_info_t default_info = { 0, 0, 0, 0, 0 }; - u8 dev_addr[6];
#define PCNET_CMD 0x00 @@ -764,6 +765,93 @@ u8 dev_addr[6]; #define PCNET_RESET 0x1f /* Issue a read to reset, a write to clear. */ #define PCNET_MISC 0x18 /* For IBM CCAE and Socket EA cards */
+static void pcnet_reset_8390(void) +{ + int i, r; + + PRINTK("nic base is %lx\n", nic_base); + + n2k_outb(E8390_NODMA + E8390_PAGE0+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); + + n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); + + for (i = 0; i < 100; i++) { + if ((r = (n2k_inb(EN0_ISR) & ENISR_RESET)) != 0) + break; + PRINTK("got %x in reset\n", r); + udelay(100); + } + n2k_outb(ENISR_RESET, EN0_ISR); /* Ack intr. */ + + if (i == 100) + printf("pcnet_reset_8390() did not complete.\n"); +} /* pcnet_reset_8390 */ + +int get_prom(u8* mac_addr) __attribute__ ((weak, alias ("__get_prom"))); +int __get_prom(u8* mac_addr) +{ + u8 prom[32]; + int i, j; + struct { + u_char value, offset; + } program_seq[] = { + {E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD}, /* Select page 0*/ + {0x48, EN0_DCFG}, /* Set byte-wide (0x48) access. */ + {0x00, EN0_RCNTLO}, /* Clear the count regs. */ + {0x00, EN0_RCNTHI}, + {0x00, EN0_IMR}, /* Mask completion irq. */ + {0xFF, EN0_ISR}, + {E8390_RXOFF, EN0_RXCR}, /* 0x20 Set to monitor */ + {E8390_TXOFF, EN0_TXCR}, /* 0x02 and loopback mode. */ + {32, EN0_RCNTLO}, + {0x00, EN0_RCNTHI}, + {0x00, EN0_RSARLO}, /* DMA starting at 0x0000. */ + {0x00, EN0_RSARHI}, + {E8390_RREAD+E8390_START, E8390_CMD}, + }; + + PRINTK ("trying to get MAC via prom reading\n"); + + pcnet_reset_8390 (); + + mdelay (10); + + for (i = 0; i < sizeof (program_seq) / sizeof (program_seq[0]); i++) + n2k_outb (program_seq[i].value, program_seq[i].offset); + + PRINTK ("PROM:"); + for (i = 0; i < 32; i++) { + prom[i] = n2k_inb (PCNET_DATAPORT); + PRINTK (" %02x", prom[i]); + } + PRINTK ("\n"); + for (i = 0; i < NR_INFO; i++) { + if ((prom[0] == hw_info[i].a0) && + (prom[2] == hw_info[i].a1) && + (prom[4] == hw_info[i].a2)) { + PRINTK ("matched board %d\n", i); + break; + } + } + if ((i < NR_INFO) || ((prom[28] == 0x57) && (prom[30] == 0x57))) { + PRINTK ("on exit i is %d/%ld\n", i, NR_INFO); + PRINTK ("MAC address is "); + for (j = 0; j < 6; j++) { + mac_addr[j] = prom[j << 1]; + PRINTK ("%02x:", mac_addr[i]); + } + PRINTK ("\n"); + return (i < NR_INFO) ? i : 0; + } + return 0; +} + u32 nic_base;
/* U-boot specific routines */ @@ -790,7 +878,7 @@ void uboot_push_tx_done(int key, int val) { }
int eth_init(bd_t *bd) { - static hw_info_t * r; + int r; char ethaddr[20];
PRINTK("### eth_init\n"); diff --git a/drivers/net/ne2000.h b/drivers/net/ne2000.h index 6049482..2cde6be 100644 --- a/drivers/net/ne2000.h +++ b/drivers/net/ne2000.h @@ -81,6 +81,7 @@ are GPL, so this is, of course, GPL.
#define DP_DATA 0x10 #define START_PG 0x50 /* First page of TX buffer */ +#define START_PG2 0x48 #define STOP_PG 0x80 /* Last page +1 of RX ring */
#define RX_START 0x50 @@ -90,90 +91,4 @@ are GPL, so this is, of course, GPL. #define DP_OUT(_b_, _o_, _d_) *( (vu_char *) ((_b_)+(_o_))) = (_d_) #define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_char *) ((_b_))) #define DP_OUT_DATA(_b_, _d_) *( (vu_char *) ((_b_))) = (_d_) - -static void pcnet_reset_8390(void) -{ - int i, r; - - PRINTK("nic base is %lx\n", nic_base); - - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - - n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); - - for (i = 0; i < 100; i++) { - if ((r = (n2k_inb(EN0_ISR) & ENISR_RESET)) != 0) - break; - PRINTK("got %x in reset\n", r); - udelay(100); - } - n2k_outb(ENISR_RESET, EN0_ISR); /* Ack intr. */ - - if (i == 100) - printf("pcnet_reset_8390() did not complete.\n"); -} /* pcnet_reset_8390 */ - -int get_prom(u8* mac_addr) -{ - u8 prom[32]; - int i, j; - struct { - u_char value, offset; - } program_seq[] = { - {E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD}, /* Select page 0*/ - {0x48, EN0_DCFG}, /* Set byte-wide (0x48) access. */ - {0x00, EN0_RCNTLO}, /* Clear the count regs. */ - {0x00, EN0_RCNTHI}, - {0x00, EN0_IMR}, /* Mask completion irq. */ - {0xFF, EN0_ISR}, - {E8390_RXOFF, EN0_RXCR}, /* 0x20 Set to monitor */ - {E8390_TXOFF, EN0_TXCR}, /* 0x02 and loopback mode. */ - {32, EN0_RCNTLO}, - {0x00, EN0_RCNTHI}, - {0x00, EN0_RSARLO}, /* DMA starting at 0x0000. */ - {0x00, EN0_RSARHI}, - {E8390_RREAD+E8390_START, E8390_CMD}, - }; - - PRINTK ("trying to get MAC via prom reading\n"); - - pcnet_reset_8390 (); - - mdelay (10); - - for (i = 0; i < sizeof (program_seq) / sizeof (program_seq[0]); i++) - n2k_outb (program_seq[i].value, program_seq[i].offset); - - PRINTK ("PROM:"); - for (i = 0; i < 32; i++) { - prom[i] = n2k_inb (PCNET_DATAPORT); - PRINTK (" %02x", prom[i]); - } - PRINTK ("\n"); - for (i = 0; i < NR_INFO; i++) { - if ((prom[0] == hw_info[i].a0) && - (prom[2] == hw_info[i].a1) && - (prom[4] == hw_info[i].a2)) { - PRINTK ("matched board %d\n", i); - break; - } - } - if ((i < NR_INFO) || ((prom[28] == 0x57) && (prom[30] == 0x57))) { - PRINTK ("on exit i is %d/%ld\n", i, NR_INFO); - PRINTK ("MAC address is "); - for (j = 0; j < 6; j++) { - mac_addr[j] = prom[j << 1]; - PRINTK ("%02x:", mac_addr[i]); - } - PRINTK ("\n"); - return (i < NR_INFO) ? i : 0; - } - return NULL; -} #endif /* __DRIVERS_NE2000_H__ */ diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h index 990d748..948b290 100644 --- a/drivers/net/ne2000_base.h +++ b/drivers/net/ne2000_base.h @@ -122,7 +122,6 @@ typedef struct dp83902a_priv_data { /* * Some forward declarations */ -int get_prom( u8* mac_addr); static void dp83902a_poll(void);
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- Fix coding style in drivers/net/ax88796.h too
drivers/net/ax88796.h | 46 ++-- drivers/net/ne2000.c | 276 ++++++++++++---------- drivers/net/ne2000.h | 30 ++-- drivers/net/ne2000_base.h | 567 +++++++++++++++++++++++---------------------- 4 files changed, 474 insertions(+), 445 deletions(-) rewrite drivers/net/ne2000_base.h (65%)
diff --git a/drivers/net/ax88796.h b/drivers/net/ax88796.h index 069ae80..0e6f8a2 100644 --- a/drivers/net/ax88796.h +++ b/drivers/net/ax88796.h @@ -23,24 +23,24 @@ #ifndef __DRIVERS_AX88796L_H__ #define __DRIVERS_AX88796L_H__
-#define DP_DATA (0x10 << 1) -#define START_PG 0x40 /* First page of TX buffer */ -#define START_PG2 0x48 -#define STOP_PG 0x80 /* Last page +1 of RX ring */ -#define TX_PAGES 12 -#define RX_START (START_PG+TX_PAGES) -#define RX_END STOP_PG +#define DP_DATA (0x10 << 1) +#define START_PG 0x40 /* First page of TX buffer */ +#define START_PG2 0x48 +#define STOP_PG 0x80 /* Last page +1 of RX ring */ +#define TX_PAGES 12 +#define RX_START (START_PG+TX_PAGES) +#define RX_END STOP_PG
#define AX88796L_BASE_ADDRESS CONFIG_DRIVER_NE2000_BASE -#define AX88796L_BYTE_ACCESS 0x00001000 -#define AX88796L_OFFSET 0x00000400 -#define AX88796L_ADDRESS_BYTE AX88796L_BASE_ADDRESS + \ +#define AX88796L_BYTE_ACCESS 0x00001000 +#define AX88796L_OFFSET 0x00000400 +#define AX88796L_ADDRESS_BYTE AX88796L_BASE_ADDRESS + \ AX88796L_BYTE_ACCESS + AX88796L_OFFSET -#define AX88796L_REG_MEMR AX88796L_ADDRESS_BYTE + (0x14<<1) -#define AX88796L_REG_CR AX88796L_ADDRESS_BYTE + (0x00<<1) +#define AX88796L_REG_MEMR AX88796L_ADDRESS_BYTE + (0x14<<1) +#define AX88796L_REG_CR AX88796L_ADDRESS_BYTE + (0x00<<1)
#define AX88796L_CR (*(vu_short *)(AX88796L_REG_CR)) -#define AX88796L_MEMR (*(vu_short *)(AX88796L_REG_MEMR)) +#define AX88796L_MEMR (*(vu_short *)(AX88796L_REG_MEMR))
#define EECS_HIGH (AX88796L_MEMR |= 0x10) #define EECS_LOW (AX88796L_MEMR &= 0xef) @@ -53,7 +53,7 @@ #define PAGE0_SET (AX88796L_CR &= 0x3f) #define PAGE1_SET (AX88796L_CR = (AX88796L_CR & 0x3f) | 0x40)
-#define BIT_DUMMY 0 +#define BIT_DUMMY 0 #define MAC_EEP_READ 1 #define MAC_EEP_WRITE 2 #define MAC_EEP_ERACE 3 @@ -62,20 +62,20 @@
/* R7780MP Specific code */ #if defined(CONFIG_R7780MP) -#define ISA_OFFSET 0x1400 -#define DP_IN(_b_, _o_, _d_) (_d_) = \ +#define ISA_OFFSET 0x1400 +#define DP_IN(_b_, _o_, _d_) (_d_) = \ *( (vu_short *) ((_b_) + ((_o_) * 2) + ISA_OFFSET)) #define DP_OUT(_b_, _o_, _d_) \ *((vu_short *)((_b_) + ((_o_) * 2) + ISA_OFFSET)) = (_d_) -#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_short *) ((_b_) + ISA_OFFSET)) -#define DP_OUT_DATA(_b_, _d_) *( (vu_short *) ((_b_)+ISA_OFFSET)) = (_d_) +#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_short *) ((_b_) + ISA_OFFSET)) +#define DP_OUT_DATA(_b_, _d_) *( (vu_short *) ((_b_)+ISA_OFFSET)) = (_d_) #else /* Please change for your target boards */ -#define ISA_OFFSET 0x0000 -#define DP_IN(_b_, _o_, _d_) (_d_) = *( (vu_short *)((_b_)+(_o_ )+ISA_OFFSET)) -#define DP_OUT(_b_, _o_, _d_) *((vu_short *)((_b_)+(_o_)+ISA_OFFSET)) = (_d_) -#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_short *) ((_b_)+ISA_OFFSET)) -#define DP_OUT_DATA(_b_, _d_) *( (vu_short *) ((_b_)+ISA_OFFSET)) = (_d_) +#define ISA_OFFSET 0x0000 +#define DP_IN(_b_, _o_, _d_) (_d_) = *( (vu_short *)((_b_)+(_o_ )+ISA_OFFSET)) +#define DP_OUT(_b_, _o_, _d_) *((vu_short *)((_b_)+(_o_)+ISA_OFFSET)) = (_d_) +#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_short *) ((_b_)+ISA_OFFSET)) +#define DP_OUT_DATA(_b_, _d_) *( (vu_short *) ((_b_)+ISA_OFFSET)) = (_d_) #endif
diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index 99baeea..d09da78 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -1,5 +1,5 @@ /* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com +Ported to U-Boot by Christian Pellegrin chri@ascensit.com
Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world @@ -57,13 +57,13 @@ and are covered by the appropriate copyright disclaimers included herein. ========================================================================== #####DESCRIPTIONBEGIN####
-Author(s): gthomas -Contributors: gthomas, jskov, rsandifo -Date: 2001-06-13 +Author(s): gthomas +Contributors: gthomas, jskov, rsandifo +Date: 2001-06-13 Purpose: Description:
-FIXME: Will fail if pinged with large packets (1520 bytes) +FIXME: Will fail if pinged with large packets (1520 bytes) Add promisc config Add SNMP
@@ -77,24 +77,26 @@ Add SNMP #include <net.h> #include <malloc.h>
-#define mdelay(n) udelay((n)*1000) +#define mdelay(n) udelay((n)*1000) /* forward definition of function used for the uboot interface */ void uboot_push_packet_len(int len); void uboot_push_tx_done(int key, int val);
/* - ------------------------------------------------------------------------ - Debugging details - - Set to perms of: - 0 disables all debug output - 1 for process debug output - 2 for added data IO output: get_reg, put_reg - 4 for packet allocation/free output - 8 for only startup status, so we can tell we're installed OK -*/ -/*#define DEBUG 0xf*/ + * Debugging details + * + * Set to perms of: + * 0 disables all debug output + * 1 for process debug output + * 2 for added data IO output: get_reg, put_reg + * 4 for packet allocation/free output + * 8 for only startup status, so we can tell we're installed OK + */ +#if 0 +#define DEBUG 0xf +#else #define DEBUG 0 +#endif
#if DEBUG & 1 #define DEBUG_FUNCTION() do { printf("%s\n", __FUNCTION__); } while (0) @@ -128,27 +130,28 @@ dp83902a_init(void) DEBUG_FUNCTION();
base = dp->base; - if (!base) return false; /* No device found */ + if (!base) + return false; /* No device found */
DEBUG_LINE();
#if defined(NE2000_BASIC_INIT) /* AX88796L doesn't need */ /* Prepare ESA */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ /* Use the address from the serial EEPROM */ for (i = 0; i < 6; i++) DP_IN(base, DP_P1_PAR0+i, dp->esa[i]); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */
printf("NE2000 - %s ESA: %02x:%02x:%02x:%02x:%02x:%02x\n", - "eeprom", - dp->esa[0], - dp->esa[1], - dp->esa[2], - dp->esa[3], - dp->esa[4], - dp->esa[5] ); + "eeprom", + dp->esa[0], + dp->esa[1], + dp->esa[2], + dp->esa[3], + dp->esa[4], + dp->esa[5] );
#endif /* NE2000_BASIC_INIT */ return true; @@ -162,7 +165,7 @@ dp83902a_stop(void)
DEBUG_FUNCTION();
- DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ + DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ DP_OUT(base, DP_IMR, 0x00); /* Disable all interrupts */
@@ -170,11 +173,11 @@ dp83902a_stop(void) }
/* - This function is called to "start up" the interface. It may be called - multiple times, even when the hardware is already running. It will be - called whenever something "hardware oriented" changes and should leave - the hardware ready to send/receive packets. -*/ + * This function is called to "start up" the interface. It may be called + * multiple times, even when the hardware is already running. It will be + * called whenever something "hardware oriented" changes and should leave + * the hardware ready to send/receive packets. + */ static void dp83902a_start(u8 * enaddr) { @@ -196,16 +199,16 @@ dp83902a_start(u8 * enaddr) dp->tx_started = false; dp->running = true; DP_OUT(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); /* Receive ring boundary */ + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ DP_OUT(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ - dp->rx_next = dp->rx_buf_start-1; + dp->rx_next = dp->rx_buf_start - 1; dp->running = true; DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ DP_OUT(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ - DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ + DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ dp->running = true; - for (i = 0; i < ETHER_ADDR_LEN; i++) { + for (i = 0; i < ETHER_ADDR_LEN; i++) { /* FIXME */ /*((vu_short*)( base + ((DP_P1_PAR0 + i) * 2) + * 0x1400)) = enaddr[i];*/ @@ -214,15 +217,15 @@ dp83902a_start(u8 * enaddr) /* Enable and start device */ DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); DP_OUT(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ - DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ + DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ dp->running = true; }
/* - This routine is called to start the transmitter. It is split out from the - data handling routine so it may be called either when data becomes first - available or when an Tx interrupt occurs -*/ + * This routine is called to start the transmitter. It is split out from the + * data handling routine so it may be called either when data becomes first + * available or when an Tx interrupt occurs + */
static void dp83902a_start_xmit(int start_page, int len) @@ -249,9 +252,9 @@ dp83902a_start_xmit(int start_page, int len) }
/* - This routine is called to send data to the hardware. It is known a-priori - that there is free buffer space (dp->tx_next). -*/ + * This routine is called to send data to the hardware. It is known a-priori + * that there is free buffer space (dp->tx_next). + */ static void dp83902a_send(u8 *data, int total_len, u32 key) { @@ -265,7 +268,8 @@ dp83902a_send(u8 *data, int total_len, u32 key) DEBUG_FUNCTION();
len = pkt_len = total_len; - if (pkt_len < IEEE_8023_MIN_FRAME) pkt_len = IEEE_8023_MIN_FRAME; + if (pkt_len < IEEE_8023_MIN_FRAME) + pkt_len = IEEE_8023_MIN_FRAME;
start_page = dp->tx_next; if (dp->tx_next == dp->tx_buf1) { @@ -284,17 +288,19 @@ dp83902a_send(u8 *data, int total_len, u32 key) printf("TX prep page %d len %d\n", start_page, pkt_len); #endif
- DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ + DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ { - /* Dummy read. The manual sez something slightly different, */ - /* but the code is extended a bit to do what Hitachi's monitor */ - /* does (i.e., also read data). */ + /* + * Dummy read. The manual sez something slightly different, + * but the code is extended a bit to do what Hitachi's monitor + * does (i.e., also read data). + */
u16 tmp; int len = 1;
- DP_OUT(base, DP_RSAL, 0x100-len); - DP_OUT(base, DP_RSAH, (start_page-1) & 0xff); + DP_OUT(base, DP_RSAL, 0x100 - len); + DP_OUT(base, DP_RSAH, (start_page - 1) & 0xff); DP_OUT(base, DP_RBCL, len); DP_OUT(base, DP_RBCH, 0); DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); @@ -302,8 +308,10 @@ dp83902a_send(u8 *data, int total_len, u32 key) }
#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* Stall for a bit before continuing to work around random data */ - /* corruption problems on some platforms. */ + /* + * Stall for a bit before continuing to work around random data + * corruption problems on some platforms. + */ CYGACC_CALL_IF_DELAY_US(1); #endif
@@ -336,16 +344,18 @@ dp83902a_send(u8 *data, int total_len, u32 key) printf(" + %d bytes of padding\n", pkt_len - total_len); #endif /* Padding to 802.3 length was required */ - for (i = total_len; i < pkt_len;) { + for (i = total_len; i < pkt_len;) { i++; DP_OUT_DATA(dp->data, 0); } }
#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* After last data write, delay for a bit before accessing the */ - /* device again, or we may get random data corruption in the last */ - /* datum (on some platforms). */ + /* + * After last data write, delay for a bit before accessing the + * device again, or we may get random data corruption in the last + * datum (on some platforms). + */ CYGACC_CALL_IF_DELAY_US(1); #endif
@@ -360,21 +370,21 @@ dp83902a_send(u8 *data, int total_len, u32 key) /* Start transmit if not already going */ if (!dp->tx_started) { if (start_page == dp->tx1) { - dp->tx_int = 1; /* Expecting interrupt from BUF1 */ + dp->tx_int = 1; /* Expecting interrupt from BUF1 */ } else { - dp->tx_int = 2; /* Expecting interrupt from BUF2 */ + dp->tx_int = 2; /* Expecting interrupt from BUF2 */ } dp83902a_start_xmit(start_page, pkt_len); } }
/* - This function is called when a packet has been received. It's job is - to prepare to unload the packet from the hardware. Once the length of - the packet is known, the upper layer of the driver can be told. When - the upper layer is ready to unload the packet, the internal function - 'dp83902a_recv' will be called to actually fetch it from the hardware. -*/ + * This function is called when a packet has been received. It's job is + * to prepare to unload the packet from the hardware. Once the length of + * the packet is known, the upper layer of the driver can be told. When + * the upper layer is ready to unload the packet, the internal function + * 'dp83902a_recv' will be called to actually fetch it from the hardware. + */ static void dp83902a_RxEvent(void) { @@ -407,9 +417,9 @@ dp83902a_RxEvent(void) DP_OUT(base, DP_RSAH, pkt); if (dp->rx_next == pkt) { if (cur == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, cur-1); /* Update pointer */ + DP_OUT(base, DP_BNDRY, cur - 1); /* Update pointer */ return; } dp->rx_next = pkt; @@ -420,13 +430,13 @@ dp83902a_RxEvent(void) #endif
/* read header (get data size)*/ - for (i = 0; i < sizeof(rcv_hdr);) { + for (i = 0; i < sizeof(rcv_hdr);) { DP_IN_DATA(dp->data, rcv_hdr[i++]); }
#if DEBUG & 5 printf("rx hdr %02x %02x %02x %02x\n", - rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); + rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); #endif len = ((rcv_hdr[3] << 8) | rcv_hdr[2]) - sizeof(rcv_hdr);
@@ -434,19 +444,19 @@ dp83902a_RxEvent(void) uboot_push_packet_len(len);
if (rcv_hdr[1] == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, rcv_hdr[1]-1); /* Update pointer */ + DP_OUT(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ } }
/* - This function is called as a result of the "eth_drv_recv()" call above. - It's job is to actually fetch data for a packet from the hardware once - memory buffers have been allocated for the packet. Note that the buffers - may come in pieces, using a scatter-gather list. This allows for more - efficient processing in the upper layers of the stack. -*/ + * This function is called as a result of the "eth_drv_recv()" call above. + * It's job is to actually fetch data for a packet from the hardware once + * memory buffers have been allocated for the packet. Note that the buffers + * may come in pieces, using a scatter-gather list. This allows for more + * efficient processing in the upper layers of the stack. + */ static void dp83902a_recv(u8 *data, int len) { @@ -478,7 +488,7 @@ dp83902a_recv(u8 *data, int len) #endif
saved = false; - for (i = 0; i < 1; i++) { + for (i = 0; i < 1; i++) { if (data) { mlen = len; #if DEBUG & 4 @@ -545,8 +555,10 @@ dp83902a_TxEvent(void) uboot_push_tx_done(key, 0); }
-/* Read the tally counters to clear them. Called in response to a CNT */ -/* interrupt. */ +/* + * Read the tally counters to clear them. Called in response to a CNT + * interrupt. + */ static void dp83902a_ClearCounters(void) { @@ -560,8 +572,10 @@ dp83902a_ClearCounters(void) DP_OUT(base, DP_ISR, DP_ISR_CNT); }
-/* Deal with an overflow condition. This code follows the procedure set */ -/* out in section 7.0 of the datasheet. */ +/* + * Deal with an overflow condition. This code follows the procedure set + * out in section 7.0 of the datasheet. + */ static void dp83902a_Overflow(void) { @@ -581,9 +595,11 @@ dp83902a_Overflow(void) DP_OUT(base, DP_TCR, DP_TCR_LOCAL); DP_OUT(base, DP_CR, DP_CR_START | DP_CR_NODMA);
- /* Read in as many packets as we can and acknowledge any and receive */ - /* interrupts. Since the buffer has overflowed, a receive event of */ - /* some kind will have occured. */ + /* + * Read in as many packets as we can and acknowledge any and receive + * interrupts. Since the buffer has overflowed, a receive event of + * some kind will have occured. + */ dp83902a_RxEvent(); DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE);
@@ -591,8 +607,10 @@ dp83902a_Overflow(void) DP_OUT(base, DP_ISR, DP_ISR_OFLW); DP_OUT(base, DP_TCR, DP_TCR_NORMAL);
- /* If a transmit command was issued, but no transmit event has occured, */ - /* restart it here. */ + /* + * If a transmit command was issued, but no transmit event has occured, + * restart it here. + */ DP_IN(base, DP_ISR, isr); if (dp->tx_started && !(isr & (DP_ISR_TxP|DP_ISR_TxE))) { DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); @@ -609,25 +627,33 @@ dp83902a_poll(void) DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); DP_IN(base, DP_ISR, isr); while (0 != isr) { - /* The CNT interrupt triggers when the MSB of one of the error */ - /* counters is set. We don't much care about these counters, but */ - /* we should read their values to reset them. */ + /* + * The CNT interrupt triggers when the MSB of one of the error + * counters is set. We don't much care about these counters, but + * we should read their values to reset them. + */ if (isr & DP_ISR_CNT) { dp83902a_ClearCounters(); } - /* Check for overflow. It's a special case, since there's a */ - /* particular procedure that must be followed to get back into */ - /* a running state.a */ + /* + * Check for overflow. It's a special case, since there's a + * particular procedure that must be followed to get back into + * a running state.a + */ if (isr & DP_ISR_OFLW) { dp83902a_Overflow(); } else { - /* Other kinds of interrupts can be acknowledged simply by */ - /* clearing the relevant bits of the ISR. Do that now, then */ - /* handle the interrupts we care about. */ - DP_OUT(base, DP_ISR, isr); /* Clear set bits */ + /* + * Other kinds of interrupts can be acknowledged simply by + * clearing the relevant bits of the ISR. Do that now, then + * handle the interrupts we care about. + */ + DP_OUT(base, DP_ISR, isr); /* Clear set bits */ if (!dp->running) break; /* Is this necessary? */ - /* Check for tx_started on TX event since these may happen */ - /* spuriously it seems. */ + /* + * Check for tx_started on TX event since these may happen + * spuriously it seems. + */ if (isr & (DP_ISR_TxP|DP_ISR_TxE) && dp->tx_started) { dp83902a_TxEvent(); } @@ -658,8 +684,8 @@ typedef struct hw_info_t { #define HAS_MII 0x40 #define USE_SHMEM 0x80 /* autodetected */
-#define AM79C9XX_HOME_PHY 0x00006B90 /* HomePNA PHY */ -#define AM79C9XX_ETH_PHY 0x00006B70 /* 10baseT PHY */ +#define AM79C9XX_HOME_PHY 0x00006B90 /* HomePNA PHY */ +#define AM79C9XX_ETH_PHY 0x00006B70 /* 10baseT PHY */ #define MII_PHYID_REV_MASK 0xfffffff0 #define MII_PHYID_REG1 0x02 #define MII_PHYID_REG2 0x03 @@ -669,7 +695,7 @@ static hw_info_t hw_info[] = { { /* Allied Telesis LA-PCM */ 0x0ff0, 0x00, 0x00, 0xf4, 0 }, { /* APEX MultiCard */ 0x03f4, 0x00, 0x20, 0xe5, 0 }, { /* ASANTE FriendlyNet */ 0x4910, 0x00, 0x00, 0x94, - DELAY_OUTPUT | HAS_IBM_MISC }, + DELAY_OUTPUT | HAS_IBM_MISC }, { /* Danpex EN-6200P2 */ 0x0110, 0x00, 0x40, 0xc7, 0 }, { /* DataTrek NetCard */ 0x0ff0, 0x00, 0x20, 0xe8, 0 }, { /* Dayna CommuniCard E */ 0x0110, 0x00, 0x80, 0x19, 0 }, @@ -677,48 +703,48 @@ static hw_info_t hw_info[] = { { /* EP-210 Ethernet */ 0x0110, 0x00, 0x40, 0x33, 0 }, { /* EP4000 Ethernet */ 0x01c0, 0x00, 0x00, 0xb4, 0 }, { /* Epson EEN10B */ 0x0ff0, 0x00, 0x00, 0x48, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* ELECOM Laneed LD-CDWA */ 0xb8, 0x08, 0x00, 0x42, 0 }, { /* Hypertec Ethernet */ 0x01c0, 0x00, 0x40, 0x4c, 0 }, { /* IBM CCAE */ 0x0ff0, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM CCAE */ 0x0ff0, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM CCAE */ 0x0ff0, 0x00, 0x06, 0x29, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM FME */ 0x0374, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM FME */ 0x0374, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kansai KLA-PCM/T */ 0x0ff0, 0x00, 0x60, 0x87, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x08, 0x00, 0x17, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x00, 0xc0, 0xa8, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x00, 0xa0, 0xb0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0198, 0x00, 0x20, 0xe0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* I-O DATA PCLA/T */ 0x0ff0, 0x00, 0xa0, 0xb0, 0 }, { /* Katron PE-520 */ 0x0110, 0x00, 0x40, 0xf6, 0 }, { /* Kingston KNE-PCM/x */ 0x0ff0, 0x00, 0xc0, 0xf0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kingston KNE-PCM/x */ 0x0ff0, 0xe2, 0x0c, 0x0f, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kingston KNE-PC2 */ 0x0180, 0x00, 0xc0, 0xf0, 0 }, { /* Maxtech PCN2000 */ 0x5000, 0x00, 0x00, 0xe8, 0 }, { /* NDC Instant-Link */ 0x003a, 0x00, 0x80, 0xc6, 0 }, { /* NE2000 Compatible */ 0x0ff0, 0x00, 0xa0, 0x0c, 0 }, { /* Network General Sniffer */ 0x0ff0, 0x00, 0x00, 0x65, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Panasonic VEL211 */ 0x0ff0, 0x00, 0x80, 0x45, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* PreMax PE-200 */ 0x07f0, 0x00, 0x20, 0xe0, 0 }, { /* RPTI EP400 */ 0x0110, 0x00, 0x40, 0x95, 0 }, { /* SCM Ethernet */ 0x0ff0, 0x00, 0x20, 0xcb, 0 }, { /* Socket EA */ 0x4000, 0x00, 0xc0, 0x1b, - DELAY_OUTPUT | HAS_MISC_REG | USE_BIG_BUF }, + DELAY_OUTPUT | HAS_MISC_REG | USE_BIG_BUF }, { /* Socket LP-E CF+ */ 0x01c0, 0x00, 0xc0, 0x1b, 0 }, { /* SuperSocket RE450T */ 0x0110, 0x00, 0xe0, 0x98, 0 }, { /* Volktek NPL-402CT */ 0x0060, 0x00, 0x40, 0x05, 0 }, @@ -744,11 +770,11 @@ u32 nic_base; static u8 *pbuf = NULL;
static int pkey = -1; -static int initialized=0; +static int initialized = 0;
void uboot_push_packet_len(int len) { PRINTK("pushed len = %d\n", len); - if (len>=2000) { + if (len >= 2000) { printf("NE2000: packet too big\n"); return; } @@ -779,7 +805,7 @@ int eth_init(bd_t *bd) {
#ifdef CONFIG_DRIVER_NE2000_CCR { - vu_char *p = (vu_char *) CONFIG_DRIVER_NE2000_CCR; + vu_char *p = (vu_char *) CONFIG_DRIVER_NE2000_CCR;
PRINTK("CCR before is %x\n", *p); *p = CONFIG_DRIVER_NE2000_VAL; @@ -811,7 +837,7 @@ int eth_init(bd_t *bd) { return -1;
dp83902a_start(dev_addr); - initialized=1; + initialized = 1;
return 0; } @@ -821,7 +847,7 @@ void eth_halt() { PRINTK("### eth_halt\n"); if(initialized) dp83902a_stop(); - initialized=0; + initialized = 0; }
int eth_rx() { diff --git a/drivers/net/ne2000.h b/drivers/net/ne2000.h index d324a00..6049482 100644 --- a/drivers/net/ne2000.h +++ b/drivers/net/ne2000.h @@ -1,5 +1,5 @@ /* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com +Ported to U-Boot by Christian Pellegrin chri@ascensit.com
Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world @@ -7,9 +7,9 @@ are GPL, so this is, of course, GPL.
- dev/dp83902a.h + dev/dp83902a.h
- National Semiconductor DP83902a ethernet chip + National Semiconductor DP83902a ethernet chip
========================================================================== ####ECOSGPLCOPYRIGHTBEGIN#### @@ -57,9 +57,9 @@ are GPL, so this is, of course, GPL. ========================================================================== #####DESCRIPTIONBEGIN####
- Author(s): gthomas - Contributors: gthomas, jskov - Date: 2001-06-13 + Author(s): gthomas + Contributors: gthomas, jskov + Date: 2001-06-13 Purpose: Description:
@@ -79,17 +79,17 @@ are GPL, so this is, of course, GPL. /* Enable NE2000 basic init function */ #define NE2000_BASIC_INIT
-#define DP_DATA 0x10 -#define START_PG 0x50 /* First page of TX buffer */ -#define STOP_PG 0x80 /* Last page +1 of RX ring */ +#define DP_DATA 0x10 +#define START_PG 0x50 /* First page of TX buffer */ +#define STOP_PG 0x80 /* Last page +1 of RX ring */
-#define RX_START 0x50 -#define RX_END 0x80 +#define RX_START 0x50 +#define RX_END 0x80
-#define DP_IN(_b_, _o_, _d_) (_d_) = *( (vu_char *) ((_b_)+(_o_))) -#define DP_OUT(_b_, _o_, _d_) *( (vu_char *) ((_b_)+(_o_))) = (_d_) -#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_char *) ((_b_))) -#define DP_OUT_DATA(_b_, _d_) *( (vu_char *) ((_b_))) = (_d_) +#define DP_IN(_b_, _o_, _d_) (_d_) = *( (vu_char *) ((_b_)+(_o_))) +#define DP_OUT(_b_, _o_, _d_) *( (vu_char *) ((_b_)+(_o_))) = (_d_) +#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_char *) ((_b_))) +#define DP_OUT_DATA(_b_, _d_) *( (vu_char *) ((_b_))) = (_d_)
static void pcnet_reset_8390(void) { diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h dissimilarity index 65% index 1badf62..990d748 100644 --- a/drivers/net/ne2000_base.h +++ b/drivers/net/ne2000_base.h @@ -1,282 +1,285 @@ -/* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - - -========================================================================== - - dev/dp83902a.h - - National Semiconductor DP83902a ethernet chip - -========================================================================== -####ECOSGPLCOPYRIGHTBEGIN#### - ------------------------------------------- - This file is part of eCos, the Embedded Configurable Operating System. - Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. - - eCos is free software; you can redistribute it and/or modify it under - the terms of the GNU General Public License as published by the Free - Software Foundation; either version 2 or (at your option) any later version. - - eCos is distributed in the hope that it will be useful, but WITHOUT ANY - WARRANTY; without even the implied warranty of MERCHANTABILITY or - FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License - for more details. - - You should have received a copy of the GNU General Public License along - with eCos; if not, write to the Free Software Foundation, Inc., - 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. - - As a special exception, if other files instantiate templates or use macros - or inline functions from this file, or you compile this file and link it - with other works to produce a work based on this file, this file does not - by itself cause the resulting work to be covered by the GNU General Public - License. However the source code for this file must still be made available - in accordance with section (3) of the GNU General Public License. - - This exception does not invalidate any other reasons why a work based on - this file might be covered by the GNU General Public License. - - Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. - at http://sources.redhat.com/ecos/ecos-license/ - ------------------------------------------- -####ECOSGPLCOPYRIGHTEND#### -####BSDCOPYRIGHTBEGIN#### - - ------------------------------------------- - - Portions of this software may have been derived from OpenBSD or other sources, - and are covered by the appropriate copyright disclaimers included herein. - - ------------------------------------------- - -####BSDCOPYRIGHTEND#### -========================================================================== -#####DESCRIPTIONBEGIN#### - - Author(s): gthomas - Contributors: gthomas, jskov - Date: 2001-06-13 - Purpose: - Description: - -####DESCRIPTIONEND#### - -========================================================================== - -*/ - -/* - ------------------------------------------------------------------------ - Macros for accessing DP registers - These can be overridden by the platform header -*/ - -#define bool int - -#define false 0 -#define true 1 - -/* timeout for tx/rx in s */ -#define TOUT 5 -/* Ether MAC address size */ -#define ETHER_ADDR_LEN 6 - - -#define CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA 1 -#define CYGACC_CALL_IF_DELAY_US(X) udelay(X) - -/* H/W infomation struct */ -typedef struct hw_info_t { - u32 offset; - u8 a0, a1, a2; - u32 flags; -} hw_info_t; - -typedef struct dp83902a_priv_data { - u8* base; - u8* data; - u8* reset; - int tx_next; /* First free Tx page */ - int tx_int; /* Expecting interrupt from this buffer */ - int rx_next; /* First free Rx page */ - int tx1, tx2; /* Page numbers for Tx buffers */ - u32 tx1_key, tx2_key; /* Used to ack when packet sent */ - int tx1_len, tx2_len; - bool tx_started, running, hardwired_esa; - u8 esa[6]; - void* plf_priv; - - /* Buffer allocation */ - int tx_buf1, tx_buf2; - int rx_buf_start, rx_buf_end; -} dp83902a_priv_data_t; - -/* - ------------------------------------------------------------------------ - Some forward declarations -*/ -int get_prom( u8* mac_addr); -static void dp83902a_poll(void); - -/* ------------------------------------------------------------------------ */ -/* Register offsets */ - -#define DP_CR 0x00 -#define DP_CLDA0 0x01 -#define DP_PSTART 0x01 /* write */ -#define DP_CLDA1 0x02 -#define DP_PSTOP 0x02 /* write */ -#define DP_BNDRY 0x03 -#define DP_TSR 0x04 -#define DP_TPSR 0x04 /* write */ -#define DP_NCR 0x05 -#define DP_TBCL 0x05 /* write */ -#define DP_FIFO 0x06 -#define DP_TBCH 0x06 /* write */ -#define DP_ISR 0x07 -#define DP_CRDA0 0x08 -#define DP_RSAL 0x08 /* write */ -#define DP_CRDA1 0x09 -#define DP_RSAH 0x09 /* write */ -#define DP_RBCL 0x0a /* write */ -#define DP_RBCH 0x0b /* write */ -#define DP_RSR 0x0c -#define DP_RCR 0x0c /* write */ -#define DP_FER 0x0d -#define DP_TCR 0x0d /* write */ -#define DP_CER 0x0e -#define DP_DCR 0x0e /* write */ -#define DP_MISSED 0x0f -#define DP_IMR 0x0f /* write */ -#define DP_DATAPORT 0x10 /* "eprom" data port */ - -#define DP_P1_CR 0x00 -#define DP_P1_PAR0 0x01 -#define DP_P1_PAR1 0x02 -#define DP_P1_PAR2 0x03 -#define DP_P1_PAR3 0x04 -#define DP_P1_PAR4 0x05 -#define DP_P1_PAR5 0x06 -#define DP_P1_CURP 0x07 -#define DP_P1_MAR0 0x08 -#define DP_P1_MAR1 0x09 -#define DP_P1_MAR2 0x0a -#define DP_P1_MAR3 0x0b -#define DP_P1_MAR4 0x0c -#define DP_P1_MAR5 0x0d -#define DP_P1_MAR6 0x0e -#define DP_P1_MAR7 0x0f - -#define DP_P2_CR 0x00 -#define DP_P2_PSTART 0x01 -#define DP_P2_CLDA0 0x01 /* write */ -#define DP_P2_PSTOP 0x02 -#define DP_P2_CLDA1 0x02 /* write */ -#define DP_P2_RNPP 0x03 -#define DP_P2_TPSR 0x04 -#define DP_P2_LNPP 0x05 -#define DP_P2_ACH 0x06 -#define DP_P2_ACL 0x07 -#define DP_P2_RCR 0x0c -#define DP_P2_TCR 0x0d -#define DP_P2_DCR 0x0e -#define DP_P2_IMR 0x0f - -/* Command register - common to all pages */ - -#define DP_CR_STOP 0x01 /* Stop: software reset */ -#define DP_CR_START 0x02 /* Start: initialize device */ -#define DP_CR_TXPKT 0x04 /* Transmit packet */ -#define DP_CR_RDMA 0x08 /* Read DMA (recv data from device) */ -#define DP_CR_WDMA 0x10 /* Write DMA (send data to device) */ -#define DP_CR_SEND 0x18 /* Send packet */ -#define DP_CR_NODMA 0x20 /* Remote (or no) DMA */ -#define DP_CR_PAGE0 0x00 /* Page select */ -#define DP_CR_PAGE1 0x40 -#define DP_CR_PAGE2 0x80 -#define DP_CR_PAGEMSK 0x3F /* Used to mask out page bits */ - -/* Data configuration register */ - -#define DP_DCR_WTS 0x01 /* 1=16 bit word transfers */ -#define DP_DCR_BOS 0x02 /* 1=Little Endian */ -#define DP_DCR_LAS 0x04 /* 1=Single 32 bit DMA mode */ -#define DP_DCR_LS 0x08 /* 1=normal mode, 0=loopback */ -#define DP_DCR_ARM 0x10 /* 0=no send command (program I/O) */ -#define DP_DCR_FIFO_1 0x00 /* FIFO threshold */ -#define DP_DCR_FIFO_2 0x20 -#define DP_DCR_FIFO_4 0x40 -#define DP_DCR_FIFO_6 0x60 - -#define DP_DCR_INIT (DP_DCR_LS|DP_DCR_FIFO_4) - -/* Interrupt status register */ - -#define DP_ISR_RxP 0x01 /* Packet received */ -#define DP_ISR_TxP 0x02 /* Packet transmitted */ -#define DP_ISR_RxE 0x04 /* Receive error */ -#define DP_ISR_TxE 0x08 /* Transmit error */ -#define DP_ISR_OFLW 0x10 /* Receive overflow */ -#define DP_ISR_CNT 0x20 /* Tally counters need emptying */ -#define DP_ISR_RDC 0x40 /* Remote DMA complete */ -#define DP_ISR_RESET 0x80 /* Device has reset (shutdown, error) */ - -/* Interrupt mask register */ - -#define DP_IMR_RxP 0x01 /* Packet received */ -#define DP_IMR_TxP 0x02 /* Packet transmitted */ -#define DP_IMR_RxE 0x04 /* Receive error */ -#define DP_IMR_TxE 0x08 /* Transmit error */ -#define DP_IMR_OFLW 0x10 /* Receive overflow */ -#define DP_IMR_CNT 0x20 /* Tall counters need emptying */ -#define DP_IMR_RDC 0x40 /* Remote DMA complete */ - -#define DP_IMR_All 0x3F /* Everything but remote DMA */ - -/* Receiver control register */ - -#define DP_RCR_SEP 0x01 /* Save bad(error) packets */ -#define DP_RCR_AR 0x02 /* Accept runt packets */ -#define DP_RCR_AB 0x04 /* Accept broadcast packets */ -#define DP_RCR_AM 0x08 /* Accept multicast packets */ -#define DP_RCR_PROM 0x10 /* Promiscuous mode */ -#define DP_RCR_MON 0x20 /* Monitor mode - 1=accept no packets */ - -/* Receiver status register */ - -#define DP_RSR_RxP 0x01 /* Packet received */ -#define DP_RSR_CRC 0x02 /* CRC error */ -#define DP_RSR_FRAME 0x04 /* Framing error */ -#define DP_RSR_FO 0x08 /* FIFO overrun */ -#define DP_RSR_MISS 0x10 /* Missed packet */ -#define DP_RSR_PHY 0x20 /* 0=pad match, 1=mad match */ -#define DP_RSR_DIS 0x40 /* Receiver disabled */ -#define DP_RSR_DFR 0x80 /* Receiver processing deferred */ - -/* Transmitter control register */ - -#define DP_TCR_NOCRC 0x01 /* 1=inhibit CRC */ -#define DP_TCR_NORMAL 0x00 /* Normal transmitter operation */ -#define DP_TCR_LOCAL 0x02 /* Internal NIC loopback */ -#define DP_TCR_INLOOP 0x04 /* Full internal loopback */ -#define DP_TCR_OUTLOOP 0x08 /* External loopback */ -#define DP_TCR_ATD 0x10 /* Auto transmit disable */ -#define DP_TCR_OFFSET 0x20 /* Collision offset adjust */ - -/* Transmit status register */ - -#define DP_TSR_TxP 0x01 /* Packet transmitted */ -#define DP_TSR_COL 0x04 /* Collision (at least one) */ -#define DP_TSR_ABT 0x08 /* Aborted because of too many collisions */ -#define DP_TSR_CRS 0x10 /* Lost carrier */ -#define DP_TSR_FU 0x20 /* FIFO underrun */ -#define DP_TSR_CDH 0x40 /* Collision Detect Heartbeat */ -#define DP_TSR_OWC 0x80 /* Collision outside normal window */ - -#define IEEE_8023_MAX_FRAME 1518 /* Largest possible ethernet frame */ -#define IEEE_8023_MIN_FRAME 64 /* Smallest possible ethernet frame */ +/* +Ported to U-Boot by Christian Pellegrin chri@ascensit.com + +Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and +eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world +are GPL, so this is, of course, GPL. + + +========================================================================== + + dev/dp83902a.h + + National Semiconductor DP83902a ethernet chip + +========================================================================== +####ECOSGPLCOPYRIGHTBEGIN#### + ------------------------------------------- + This file is part of eCos, the Embedded Configurable Operating System. + Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. + + eCos is free software; you can redistribute it and/or modify it under + the terms of the GNU General Public License as published by the Free + Software Foundation; either version 2 or (at your option) any later version. + + eCos is distributed in the hope that it will be useful, but WITHOUT ANY + WARRANTY; without even the implied warranty of MERCHANTABILITY or + FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + for more details. + + You should have received a copy of the GNU General Public License along + with eCos; if not, write to the Free Software Foundation, Inc., + 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. + + As a special exception, if other files instantiate templates or use macros + or inline functions from this file, or you compile this file and link it + with other works to produce a work based on this file, this file does not + by itself cause the resulting work to be covered by the GNU General Public + License. However the source code for this file must still be made available + in accordance with section (3) of the GNU General Public License. + + This exception does not invalidate any other reasons why a work based on + this file might be covered by the GNU General Public License. + + Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. + at http://sources.redhat.com/ecos/ecos-license/ + ------------------------------------------- +####ECOSGPLCOPYRIGHTEND#### +####BSDCOPYRIGHTBEGIN#### + + ------------------------------------------- + + Portions of this software may have been derived from OpenBSD or other sources, + and are covered by the appropriate copyright disclaimers included herein. + + ------------------------------------------- + +####BSDCOPYRIGHTEND#### +========================================================================== +#####DESCRIPTIONBEGIN#### + + Author(s): gthomas + Contributors: gthomas, jskov + Date: 2001-06-13 + Purpose: + Description: + +####DESCRIPTIONEND#### + +========================================================================== + +*/ + +/* + ------------------------------------------------------------------------ + Macros for accessing DP registers + These can be overridden by the platform header +*/ + +#ifndef __NE2000_BASE_H__ +#define __NE2000_BASE_H__ + +#define bool int + +#define false 0 +#define true 1 + +/* timeout for tx/rx in s */ +#define TOUT 5 +/* Ether MAC address size */ +#define ETHER_ADDR_LEN 6 + + +#define CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA 1 +#define CYGACC_CALL_IF_DELAY_US(X) udelay(X) + +/* H/W infomation struct */ +typedef struct hw_info_t { + u32 offset; + u8 a0, a1, a2; + u32 flags; +} hw_info_t; + +typedef struct dp83902a_priv_data { + u8* base; + u8* data; + u8* reset; + int tx_next; /* First free Tx page */ + int tx_int; /* Expecting interrupt from this buffer */ + int rx_next; /* First free Rx page */ + int tx1, tx2; /* Page numbers for Tx buffers */ + u32 tx1_key, tx2_key; /* Used to ack when packet sent */ + int tx1_len, tx2_len; + bool tx_started, running, hardwired_esa; + u8 esa[6]; + void* plf_priv; + + /* Buffer allocation */ + int tx_buf1, tx_buf2; + int rx_buf_start, rx_buf_end; +} dp83902a_priv_data_t; + +/* + * Some forward declarations + */ +int get_prom( u8* mac_addr); +static void dp83902a_poll(void); + +/* ------------------------------------------------------------------------ */ +/* Register offsets */ + +#define DP_CR 0x00 +#define DP_CLDA0 0x01 +#define DP_PSTART 0x01 /* write */ +#define DP_CLDA1 0x02 +#define DP_PSTOP 0x02 /* write */ +#define DP_BNDRY 0x03 +#define DP_TSR 0x04 +#define DP_TPSR 0x04 /* write */ +#define DP_NCR 0x05 +#define DP_TBCL 0x05 /* write */ +#define DP_FIFO 0x06 +#define DP_TBCH 0x06 /* write */ +#define DP_ISR 0x07 +#define DP_CRDA0 0x08 +#define DP_RSAL 0x08 /* write */ +#define DP_CRDA1 0x09 +#define DP_RSAH 0x09 /* write */ +#define DP_RBCL 0x0a /* write */ +#define DP_RBCH 0x0b /* write */ +#define DP_RSR 0x0c +#define DP_RCR 0x0c /* write */ +#define DP_FER 0x0d +#define DP_TCR 0x0d /* write */ +#define DP_CER 0x0e +#define DP_DCR 0x0e /* write */ +#define DP_MISSED 0x0f +#define DP_IMR 0x0f /* write */ +#define DP_DATAPORT 0x10 /* "eprom" data port */ + +#define DP_P1_CR 0x00 +#define DP_P1_PAR0 0x01 +#define DP_P1_PAR1 0x02 +#define DP_P1_PAR2 0x03 +#define DP_P1_PAR3 0x04 +#define DP_P1_PAR4 0x05 +#define DP_P1_PAR5 0x06 +#define DP_P1_CURP 0x07 +#define DP_P1_MAR0 0x08 +#define DP_P1_MAR1 0x09 +#define DP_P1_MAR2 0x0a +#define DP_P1_MAR3 0x0b +#define DP_P1_MAR4 0x0c +#define DP_P1_MAR5 0x0d +#define DP_P1_MAR6 0x0e +#define DP_P1_MAR7 0x0f + +#define DP_P2_CR 0x00 +#define DP_P2_PSTART 0x01 +#define DP_P2_CLDA0 0x01 /* write */ +#define DP_P2_PSTOP 0x02 +#define DP_P2_CLDA1 0x02 /* write */ +#define DP_P2_RNPP 0x03 +#define DP_P2_TPSR 0x04 +#define DP_P2_LNPP 0x05 +#define DP_P2_ACH 0x06 +#define DP_P2_ACL 0x07 +#define DP_P2_RCR 0x0c +#define DP_P2_TCR 0x0d +#define DP_P2_DCR 0x0e +#define DP_P2_IMR 0x0f + +/* Command register - common to all pages */ + +#define DP_CR_STOP 0x01 /* Stop: software reset */ +#define DP_CR_START 0x02 /* Start: initialize device */ +#define DP_CR_TXPKT 0x04 /* Transmit packet */ +#define DP_CR_RDMA 0x08 /* Read DMA (recv data from device) */ +#define DP_CR_WDMA 0x10 /* Write DMA (send data to device) */ +#define DP_CR_SEND 0x18 /* Send packet */ +#define DP_CR_NODMA 0x20 /* Remote (or no) DMA */ +#define DP_CR_PAGE0 0x00 /* Page select */ +#define DP_CR_PAGE1 0x40 +#define DP_CR_PAGE2 0x80 +#define DP_CR_PAGEMSK 0x3F /* Used to mask out page bits */ + +/* Data configuration register */ + +#define DP_DCR_WTS 0x01 /* 1=16 bit word transfers */ +#define DP_DCR_BOS 0x02 /* 1=Little Endian */ +#define DP_DCR_LAS 0x04 /* 1=Single 32 bit DMA mode */ +#define DP_DCR_LS 0x08 /* 1=normal mode, 0=loopback */ +#define DP_DCR_ARM 0x10 /* 0=no send command (program I/O) */ +#define DP_DCR_FIFO_1 0x00 /* FIFO threshold */ +#define DP_DCR_FIFO_2 0x20 +#define DP_DCR_FIFO_4 0x40 +#define DP_DCR_FIFO_6 0x60 + +#define DP_DCR_INIT (DP_DCR_LS|DP_DCR_FIFO_4) + +/* Interrupt status register */ + +#define DP_ISR_RxP 0x01 /* Packet received */ +#define DP_ISR_TxP 0x02 /* Packet transmitted */ +#define DP_ISR_RxE 0x04 /* Receive error */ +#define DP_ISR_TxE 0x08 /* Transmit error */ +#define DP_ISR_OFLW 0x10 /* Receive overflow */ +#define DP_ISR_CNT 0x20 /* Tally counters need emptying */ +#define DP_ISR_RDC 0x40 /* Remote DMA complete */ +#define DP_ISR_RESET 0x80 /* Device has reset (shutdown, error) */ + +/* Interrupt mask register */ + +#define DP_IMR_RxP 0x01 /* Packet received */ +#define DP_IMR_TxP 0x02 /* Packet transmitted */ +#define DP_IMR_RxE 0x04 /* Receive error */ +#define DP_IMR_TxE 0x08 /* Transmit error */ +#define DP_IMR_OFLW 0x10 /* Receive overflow */ +#define DP_IMR_CNT 0x20 /* Tall counters need emptying */ +#define DP_IMR_RDC 0x40 /* Remote DMA complete */ + +#define DP_IMR_All 0x3F /* Everything but remote DMA */ + +/* Receiver control register */ + +#define DP_RCR_SEP 0x01 /* Save bad(error) packets */ +#define DP_RCR_AR 0x02 /* Accept runt packets */ +#define DP_RCR_AB 0x04 /* Accept broadcast packets */ +#define DP_RCR_AM 0x08 /* Accept multicast packets */ +#define DP_RCR_PROM 0x10 /* Promiscuous mode */ +#define DP_RCR_MON 0x20 /* Monitor mode - 1=accept no packets */ + +/* Receiver status register */ + +#define DP_RSR_RxP 0x01 /* Packet received */ +#define DP_RSR_CRC 0x02 /* CRC error */ +#define DP_RSR_FRAME 0x04 /* Framing error */ +#define DP_RSR_FO 0x08 /* FIFO overrun */ +#define DP_RSR_MISS 0x10 /* Missed packet */ +#define DP_RSR_PHY 0x20 /* 0=pad match, 1=mad match */ +#define DP_RSR_DIS 0x40 /* Receiver disabled */ +#define DP_RSR_DFR 0x80 /* Receiver processing deferred */ + +/* Transmitter control register */ + +#define DP_TCR_NOCRC 0x01 /* 1=inhibit CRC */ +#define DP_TCR_NORMAL 0x00 /* Normal transmitter operation */ +#define DP_TCR_LOCAL 0x02 /* Internal NIC loopback */ +#define DP_TCR_INLOOP 0x04 /* Full internal loopback */ +#define DP_TCR_OUTLOOP 0x08 /* External loopback */ +#define DP_TCR_ATD 0x10 /* Auto transmit disable */ +#define DP_TCR_OFFSET 0x20 /* Collision offset adjust */ + +/* Transmit status register */ + +#define DP_TSR_TxP 0x01 /* Packet transmitted */ +#define DP_TSR_COL 0x04 /* Collision (at least one) */ +#define DP_TSR_ABT 0x08 /* Aborted because of too many collisions */ +#define DP_TSR_CRS 0x10 /* Lost carrier */ +#define DP_TSR_FU 0x20 /* FIFO underrun */ +#define DP_TSR_CDH 0x40 /* Collision Detect Heartbeat */ +#define DP_TSR_OWC 0x80 /* Collision outside normal window */ + +#define IEEE_8023_MAX_FRAME 1518 /* Largest possible ethernet frame */ +#define IEEE_8023_MIN_FRAME 64 /* Smallest possible ethernet frame */ +#endif /* __NE2000_BASE_H__ */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Vlad Lungu vlad@comsys.ro --- Fix comment
drivers/net/Makefile | 5 +- drivers/net/ax88796.c | 156 +++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ax88796.h | 136 --------------------------------------- drivers/net/ne2000.c | 94 ++++++++++++++++++++++++++- drivers/net/ne2000.h | 87 +------------------------- drivers/net/ne2000_base.h | 1 - 6 files changed, 252 insertions(+), 227 deletions(-) create mode 100644 drivers/net/ax88796.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d5e413b..4131aad 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,7 +42,10 @@ COBJS-y += lan91c96.o COBJS-y += macb.o COBJS-y += mcffec.o COBJS-y += natsemi.o -COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o +ifeq ($(CONFIG_DRIVER_NE2000),y) +COBJS-y += ne2000.o +COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o +endif COBJS-y += netarm_eth.o COBJS-y += netconsole.o COBJS-y += ns7520_eth.o diff --git a/drivers/net/ax88796.c b/drivers/net/ax88796.c new file mode 100644 index 0000000..39cd101 --- /dev/null +++ b/drivers/net/ax88796.c @@ -0,0 +1,156 @@ +/* + * (c) 2007 Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#include <common.h> +#include "ax88796.h" + +/* + * Set 1 bit data + */ +static void ax88796_bitset(u32 bit) +{ + /* DATA1 */ + if( bit ) + EEDI_HIGH; + else + EEDI_LOW; + + EECLK_LOW; + udelay(1000); + EECLK_HIGH; + udelay(1000); + EEDI_LOW; +} + +/* + * Get 1 bit data + */ +static u8 ax88796_bitget(void) +{ + u8 bit; + + EECLK_LOW; + udelay(1000); + /* DATA */ + bit = EEDO; + EECLK_HIGH; + udelay(1000); + + return bit; +} + +/* + * Send COMMAND to EEPROM + */ +static void ax88796_eep_cmd(u8 cmd) +{ + ax88796_bitset(BIT_DUMMY); + switch(cmd){ + case MAC_EEP_READ: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(0); + break; + + case MAC_EEP_WRITE: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(1); + break; + + case MAC_EEP_ERACE: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(1); + break; + + case MAC_EEP_EWEN: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + + case MAC_EEP_EWDS: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + default: + break; + } +} + +static void ax88796_eep_setaddr(u16 addr) +{ + int i ; + + for( i = 7 ; i >= 0 ; i-- ) + ax88796_bitset(addr & (1 << i)); +} + +/* + * Get data from EEPROM + */ +static u16 ax88796_eep_getdata(void) +{ + ushort data = 0; + int i; + + ax88796_bitget(); /* DUMMY */ + for( i = 0 ; i < 16 ; i++ ){ + data <<= 1; + data |= ax88796_bitget(); + } + return data; +} + +static void ax88796_mac_read(u8 *buff) +{ + int i ; + u16 data; + u16 addr = 0; + + for( i = 0 ; i < 3; i++ ) + { + EECS_HIGH; + EEDI_LOW; + udelay(1000); + /* READ COMMAND */ + ax88796_eep_cmd(MAC_EEP_READ); + /* ADDRESS */ + ax88796_eep_setaddr(addr++); + /* GET DATA */ + data = ax88796_eep_getdata(); + *buff++ = (uchar)(data & 0xff); + *buff++ = (uchar)((data >> 8) & 0xff); + EECLK_LOW; + EEDI_LOW; + EECS_LOW; + } +} + +int get_prom(u8* mac_addr) +{ + u8 prom[32]; + int i; + + ax88796_mac_read(prom); + for (i = 0; i < 6; i++){ + mac_addr[i] = prom[i]; + } + return 1; +} diff --git a/drivers/net/ax88796.h b/drivers/net/ax88796.h index 0e6f8a2..43a1639 100644 --- a/drivers/net/ax88796.h +++ b/drivers/net/ax88796.h @@ -78,140 +78,4 @@ #define DP_OUT_DATA(_b_, _d_) *( (vu_short *) ((_b_)+ISA_OFFSET)) = (_d_) #endif
- -/* - * Set 1 bit data - */ -static void ax88796_bitset(u32 bit) -{ - /* DATA1 */ - if( bit ) - EEDI_HIGH; - else - EEDI_LOW; - - EECLK_LOW; - udelay(1000); - EECLK_HIGH; - udelay(1000); - EEDI_LOW; -} - -/* - * Get 1 bit data - */ -static u8 ax88796_bitget(void) -{ - u8 bit; - - EECLK_LOW; - udelay(1000); - /* DATA */ - bit = EEDO; - EECLK_HIGH; - udelay(1000); - - return bit; -} - -/* - * Send COMMAND to EEPROM - */ -static void ax88796_eep_cmd(u8 cmd) -{ - ax88796_bitset(BIT_DUMMY); - switch(cmd){ - case MAC_EEP_READ: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(0); - break; - - case MAC_EEP_WRITE: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(1); - break; - - case MAC_EEP_ERACE: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(1); - break; - - case MAC_EEP_EWEN: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - - case MAC_EEP_EWDS: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - default: - break; - } -} - -static void ax88796_eep_setaddr(u16 addr) -{ - int i ; - for( i = 7 ; i >= 0 ; i-- ) - ax88796_bitset(addr & (1 << i)); -} - -/* - * Get data from EEPROM - */ -static u16 ax88796_eep_getdata(void) -{ - ushort data = 0; - int i; - - ax88796_bitget(); /* DUMMY */ - for( i = 0 ; i < 16 ; i++ ){ - data <<= 1; - data |= ax88796_bitget(); - } - return data; -} - -static void ax88796_mac_read(u8 *buff) -{ - int i ; - u16 data, addr = 0; - - for( i = 0 ; i < 3; i++ ) - { - EECS_HIGH; - EEDI_LOW; - udelay(1000); - /* READ COMMAND */ - ax88796_eep_cmd(MAC_EEP_READ); - /* ADDRESS */ - ax88796_eep_setaddr(addr++); - /* GET DATA */ - data = ax88796_eep_getdata(); - *buff++ = (uchar)(data & 0xff); - *buff++ = (uchar)((data >> 8) & 0xff); - EECLK_LOW; - EEDI_LOW; - EECS_LOW; - } -} - -int get_prom(u8* mac_addr) -{ - u8 prom[32]; - int i; - - ax88796_mac_read(prom); - for (i = 0; i < 6; i++){ - mac_addr[i] = prom[i]; - } - return 1; -} - #endif /* __DRIVERS_AX88796L_H__ */ diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index d09da78..2da57b6 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -126,6 +126,9 @@ dp83902a_init(void) { dp83902a_priv_data_t *dp = &nic; u8* base; +#if defined(NE2000_BASIC_INIT) + int i; +#endif
DEBUG_FUNCTION();
In message 1209016637-10264-1-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied, thanks.
