[PATCH] sandbox: Fix pinmux warnings with non-test devicetrees
The sandbox pinmux driver is used in the non-test devicetree as well as the test one. I didn't realize this when I modified the driver for tests, and so broke the regular use case (which only resulted in warnings). First, making the pinmux and the UART group available in all boot phases to avoid ENODEV errors. Then, convert the pin groups and functions to the new style, adding onewire group as well.
Fixes: 7f0f1806e3a ("test: pinmux: Add test for pin muxing") Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/sandbox/dts/sandbox.dtsi | 14 ++++++++------ drivers/pinctrl/pinctrl-sandbox.c | 4 +++- include/dt-bindings/pinctrl/sandbox-pinmux.h | 1 + 3 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index c93ce712894..06ba4f031fa 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -231,23 +231,25 @@ };
pinctrl { + bootph-all; compatible = "sandbox,pinctrl"; status = "okay";
pinctrl_i2c0: i2c0 { - groups = "i2c"; - function = "i2c"; + groups = "I2C_UART"; + function = "I2C"; bias-pull-up; };
pinctrl_serial0: uart0 { - groups = "serial_a"; - function = "serial"; + bootph-all; + groups = "I2C_UART"; + function = "UART"; };
pinctrl_onewire0: onewire0 { - groups = "w1"; - function = "w1"; + pins = "P8"; + function = "ONEWIRE"; bias-pull-up; }; }; diff --git a/drivers/pinctrl/pinctrl-sandbox.c b/drivers/pinctrl/pinctrl-sandbox.c index a5d056643a0..f6921b56ceb 100644 --- a/drivers/pinctrl/pinctrl-sandbox.c +++ b/drivers/pinctrl/pinctrl-sandbox.c @@ -42,7 +42,7 @@ static const char * const sandbox_pins_muxing[][2] = { { "GPIO0", "SPI CS0" }, { "GPIO1", "SPI CS1" }, { "GPIO2", "PWM0" }, - { "GPIO3", "PWM1" }, + { "GPIO3", "ONEWIRE" }, };
#define SANDBOX_GROUP_I2C_UART 0 @@ -63,6 +63,7 @@ static const char * const sandbox_functions[] = { FUNC(GPIO), FUNC(CS), FUNC(PWM), + FUNC(ONEWIRE), #undef FUNC };
@@ -166,6 +167,7 @@ static int sandbox_pinmux_set(struct udevice *dev, unsigned pin_selector, break; case SANDBOX_PINMUX_CS: case SANDBOX_PINMUX_PWM: + case SANDBOX_PINMUX_ONEWIRE: mux = BIT(pin_selector); break; default: diff --git a/include/dt-bindings/pinctrl/sandbox-pinmux.h b/include/dt-bindings/pinctrl/sandbox-pinmux.h index 891af072e52..21c5a1762ab 100644 --- a/include/dt-bindings/pinctrl/sandbox-pinmux.h +++ b/include/dt-bindings/pinctrl/sandbox-pinmux.h @@ -13,6 +13,7 @@ #define SANDBOX_PINMUX_GPIO 4 #define SANDBOX_PINMUX_CS 5 #define SANDBOX_PINMUX_PWM 6 +#define SANDBOX_PINMUX_ONEWIRE 7
#define SANDBOX_PINMUX(pin, func) ((func) << 16 | (pin))
Hi Sean,
Reviewed-by: Simon Glass sjg@chromium.org Fixes: https://source.denx.de/u-boot/u-boot/-/issues/2
Please feel free to take over that issue if you can and add a patchwork link to this.
Regards, SImon
Fixes: 7f0f1806e3a ("test: pinmux: Add test for pin muxing") Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
This introduces failure to build on sandbox_spl and sandbox_vpl.
Sean Anderson
