[PATCH 1/3] clk: imx: Add ECSPI to iMX8MN
Add ECSPI clock entries to iMX8MN clock driver. Only make those entries available in case SPI support in U-Boot is enabled at all to conserve space, esp. in SPL.
Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- drivers/clk/imx/clk-imx8mn.c | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index e29d902544c..e398d7de02a 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -105,6 +105,20 @@ static const char *imx8mn_usdhc1_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sy static const char *imx8mn_usdhc2_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", "audio_pll2_out", "sys_pll1_100m", };
+#if CONFIG_IS_ENABLED(DM_SPI) +static const char *imx8mn_ecspi1_sels[] = {"osc_24m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *imx8mn_ecspi2_sels[] = {"osc_24m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *imx8mn_ecspi3_sels[] = {"osc_24m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; +#endif + static const char *imx8mn_i2c1_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", };
@@ -440,6 +454,21 @@ static int imx8mn_clk_probe(struct udevice *dev) base + 0x40a0, 0)); #endif
+#if CONFIG_IS_ENABLED(DM_SPI) + clk_dm(IMX8MN_CLK_ECSPI1, + imx8m_clk_composite("ecspi1", imx8mn_ecspi1_sels, base + 0xb280)); + clk_dm(IMX8MN_CLK_ECSPI2, + imx8m_clk_composite("ecspi2", imx8mn_ecspi2_sels, base + 0xb300)); + clk_dm(IMX8MN_CLK_ECSPI3, + imx8m_clk_composite("ecspi3", imx8mn_ecspi3_sels, base + 0xc180)); + clk_dm(IMX8MN_CLK_ECSPI1_ROOT, + imx_clk_gate4("ecspi1_root_clk", "ecspi1", base + 0x4070, 0)); + clk_dm(IMX8MN_CLK_ECSPI2_ROOT, + imx_clk_gate4("ecspi2_root_clk", "ecspi2", base + 0x4080, 0)); + clk_dm(IMX8MN_CLK_ECSPI3_ROOT, + imx_clk_gate4("ecspi3_root_clk", "ecspi3", base + 0x4090, 0)); +#endif + return 0; }
The CSPI/ECSPI register bits do not differ between newer SoCs, instead of having multiple copies of the same thing for each iMX SoC, define the bits in the driver.
Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx25/imx-regs.h | 30 --------- arch/arm/include/asm/arch-mx31/imx-regs.h | 31 --------- arch/arm/include/asm/arch-mx35/imx-regs.h | 30 --------- arch/arm/include/asm/arch-mx5/imx-regs.h | 36 ----------- arch/arm/include/asm/arch-mx6/imx-regs.h | 36 ----------- arch/arm/include/asm/arch-mx7/imx-regs.h | 37 ----------- drivers/spi/mxc_spi.c | 76 +++++++++++++++++++++++ 7 files changed, 76 insertions(+), 200 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 5d0974f3283..57809697c1a 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -269,18 +269,6 @@ struct epit_regs { u32 cnr; /* Counter register */ };
-/* CSPI registers */ -struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 intr; - u32 dma; - u32 stat; - u32 period; - u32 test; -}; - #endif
#define ARCH_MXC @@ -508,24 +496,6 @@ struct cspi_regs { /* * CSPI register definitions */ -#define MXC_CSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_SMC (1 << 3) -#define MXC_CSPICTRL_POL (1 << 4) -#define MXC_CSPICTRL_PHA (1 << 5) -#define MXC_CSPICTRL_SSCTL (1 << 6) -#define MXC_CSPICTRL_SSPOL (1 << 7) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 4 - #define MXC_SPI_BASE_ADDRESSES \ IMX_CSPI1_BASE, \ IMX_CSPI2_BASE, \ diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 9e271d6ea2e..566db549ec6 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -39,17 +39,6 @@ struct clock_control_regs { u32 pdr2; };
-struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 intr; - u32 dma; - u32 stat; - u32 period; - u32 test; -}; - /* IIM control registers */ struct iim_regs { u32 iim_stat; @@ -889,26 +878,6 @@ struct esdc_regs { /* * CSPI register definitions */ -#define MXC_CSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_SMC (1 << 3) -#define MXC_CSPICTRL_POL (1 << 4) -#define MXC_CSPICTRL_PHA (1 << 5) -#define MXC_CSPICTRL_SSCTL (1 << 6) -#define MXC_CSPICTRL_SSPOL (1 << 7) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) -#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) -#define MXC_CSPICTRL_TC (1 << 8) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPICTRL_MAXBITS 0x1f - -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 4 - - #define MXC_SPI_BASE_ADDRESSES \ 0x43fa4000, \ 0x50010000, \ diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index 8ee0754c8e5..35090047c70 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -170,24 +170,6 @@ /* * CSPI register definitions */ -#define MXC_CSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_SMC (1 << 3) -#define MXC_CSPICTRL_POL (1 << 4) -#define MXC_CSPICTRL_PHA (1 << 5) -#define MXC_CSPICTRL_SSCTL (1 << 6) -#define MXC_CSPICTRL_SSPOL (1 << 7) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 4 - #define MXC_SPI_BASE_ADDRESSES \ 0x43fa4000, \ 0x50010000, @@ -280,18 +262,6 @@ struct gpt_regs { u32 counter; /* counter */ };
-/* CSPI registers */ -struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 intr; - u32 dma; - u32 stat; - u32 period; - u32 test; -}; - struct esdc_regs { u32 esdctl0; u32 esdcfg0; diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 3d1cc683228..2731b7fb59b 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -204,30 +204,6 @@ /* * CSPI register definitions */ -#define MXC_ECSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_MODE_MASK (0xf << 4) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) -#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) -#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 32 - -/* Bit position inside CTRL register to be associated with SS */ -#define MXC_CSPICTRL_CHAN 18 - -/* Bit position inside CON register to be associated with SS */ -#define MXC_CSPICON_PHA 0 /* SCLK phase control */ -#define MXC_CSPICON_POL 4 /* SCLK polarity */ -#define MXC_CSPICON_SSPOL 12 /* SS polarity */ -#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ #define MXC_SPI_BASE_ADDRESSES \ CSPI1_BASE_ADDR, \ CSPI2_BASE_ADDR, \ @@ -476,18 +452,6 @@ struct srtc_regs { u32 hpienr; /* 0x38 */ };
-/* CSPI registers */ -struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 cfg; - u32 intr; - u32 dma; - u32 stat; - u32 period; -}; - struct iim_regs { u32 stat; u32 statm; diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index ccd48e83055..a8a5bf7a575 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -668,46 +668,10 @@ struct gpc { #define IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0 (IOMUXC_GPR2_MODE_ENABLED_DI0<<IOMUXC_GPR2_LVDS_CH0_MODE_OFFSET) #define IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI1 (IOMUXC_GPR2_MODE_ENABLED_DI1<<IOMUXC_GPR2_LVDS_CH0_MODE_OFFSET)
-/* ECSPI registers */ -struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 cfg; - u32 intr; - u32 dma; - u32 stat; - u32 period; -}; - /* * CSPI register definitions */ -#define MXC_ECSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_MODE_MASK (0xf << 4) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) -#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) -#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 32 #define SPI_MAX_NUM 4 - -/* Bit position inside CTRL register to be associated with SS */ -#define MXC_CSPICTRL_CHAN 18 - -/* Bit position inside CON register to be associated with SS */ -#define MXC_CSPICON_PHA 0 /* SCLK phase control */ -#define MXC_CSPICON_POL 4 /* SCLK polarity */ -#define MXC_CSPICON_SSPOL 12 /* SS polarity */ -#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ #if defined(CONFIG_MX6SLL) || defined(CONFIG_MX6SL) || \ defined(CONFIG_MX6DL) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define MXC_SPI_BASE_ADDRESSES \ diff --git a/arch/arm/include/asm/arch-mx7/imx-regs.h b/arch/arm/include/asm/arch-mx7/imx-regs.h index f37419c07f1..5cab12f30d8 100644 --- a/arch/arm/include/asm/arch-mx7/imx-regs.h +++ b/arch/arm/include/asm/arch-mx7/imx-regs.h @@ -842,46 +842,9 @@ struct iomuxc_gpr_base_regs { u32 gpr[23]; /* 0x000 */ };
-/* ECSPI registers */ -struct cspi_regs { - u32 rxdata; - u32 txdata; - u32 ctrl; - u32 cfg; - u32 intr; - u32 dma; - u32 stat; - u32 period; -}; - /* * CSPI register definitions */ -#define MXC_ECSPI -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_MODE_MASK (0xf << 4) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) -#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) -#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 32 - -/* Bit position inside CTRL register to be associated with SS */ -#define MXC_CSPICTRL_CHAN 18 - -/* Bit position inside CON register to be associated with SS */ -#define MXC_CSPICON_PHA 0 /* SCLK phase control */ -#define MXC_CSPICON_POL 4 /* SCLK polarity */ -#define MXC_CSPICON_SSPOL 12 /* SS polarity */ -#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ - #define MXC_SPI_BASE_ADDRESSES \ ECSPI1_BASE_ADDR, \ ECSPI2_BASE_ADDR, \ diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index e90a06a66de..849808fb916 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -20,6 +20,82 @@
DECLARE_GLOBAL_DATA_PTR;
+/* MX35 and older is CSPI */ +#if defined(CONFIG_MX25) || defined(CONFIG_MX31) || defined(CONFIG_MX35) +#define MXC_CSPI +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 intr; + u32 dma; + u32 stat; + u32 period; + u32 test; +}; + +#define MXC_CSPICTRL_EN BIT(0) +#define MXC_CSPICTRL_MODE BIT(1) +#define MXC_CSPICTRL_XCH BIT(2) +#define MXC_CSPICTRL_SMC BIT(3) +#define MXC_CSPICTRL_POL BIT(4) +#define MXC_CSPICTRL_PHA BIT(5) +#define MXC_CSPICTRL_SSCTL BIT(6) +#define MXC_CSPICTRL_SSPOL BIT(7) +#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_RXOVF BIT(6) +#define MXC_CSPIPERIOD_32KHZ BIT(15) +#define MAX_SPI_BYTES 4 +#if defined(CONFIG_MX25) || defined(CONFIG_MX35) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_TC BIT(7) +#define MXC_CSPICTRL_MAXBITS 0xfff +#else /* MX31 */ +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) +#define MXC_CSPICTRL_TC BIT(8) +#define MXC_CSPICTRL_MAXBITS 0x1f +#endif + +#else /* MX51 and newer is ECSPI */ +#define MXC_ECSPI +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 cfg; + u32 intr; + u32 dma; + u32 stat; + u32 period; +}; + +#define MXC_CSPICTRL_EN BIT(0) +#define MXC_CSPICTRL_MODE BIT(1) +#define MXC_CSPICTRL_XCH BIT(2) +#define MXC_CSPICTRL_MODE_MASK (0xf << 4) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC BIT(7) +#define MXC_CSPICTRL_RXOVF BIT(6) +#define MXC_CSPIPERIOD_32KHZ BIT(15) +#define MAX_SPI_BYTES 32 + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_PHA 0 /* SCLK phase control */ +#define MXC_CSPICON_POL 4 /* SCLK polarity */ +#define MXC_CSPICON_SSPOL 12 /* SS polarity */ +#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ +#endif + #ifdef CONFIG_MX27 /* i.MX27 has a completely wrong register layout and register definitions in the * datasheet, the correct one is in the Freescale's Linux driver */
The CSPI/ECSPI register bits do not differ between newer SoCs, instead of having multiple copies of the same thing for each iMX SoC, define the bits in the driver. Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
In case the clock framework is enabled, enable the SPI controller clock and obtain max frequency from the clock framework.
Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de --- drivers/spi/mxc_spi.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 849808fb916..3377200d24f 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <log.h> #include <malloc.h> @@ -617,8 +618,19 @@ static int mxc_spi_probe(struct udevice *bus) if (mxcs->base == FDT_ADDR_T_NONE) return -ENODEV;
+#if CONFIG_IS_ENABLED(CLK) + struct clk clk; + ret = clk_get_by_index(bus, 0, &clk); + if (ret) + return ret; + + clk_enable(&clk); + + mxcs->max_hz = clk_get_rate(&clk); +#else mxcs->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", 20000000); +#endif
return 0; }
In case the clock framework is enabled, enable the SPI controller clock and obtain max frequency from the clock framework. Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de
Subject: [PATCH 1/3] clk: imx: Add ECSPI to iMX8MN
"sys_pll3_out",
"sys_pll3_out",
"sys_pll3_out",
"sys_pll2_250m", "audio_pll2_out", }; #endif
- clk_dm(IMX8MN_CLK_ECSPI1,
0xb280));
- clk_dm(IMX8MN_CLK_ECSPI2,
0xb300));
- clk_dm(IMX8MN_CLK_ECSPI3,
0xc180));
- clk_dm(IMX8MN_CLK_ECSPI1_ROOT,
- clk_dm(IMX8MN_CLK_ECSPI2_ROOT,
- clk_dm(IMX8MN_CLK_ECSPI3_ROOT,
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.29.2
Add ECSPI clock entries to iMX8MN clock driver. Only make those entries available in case SPI support in U-Boot is enabled at all to conserve space, esp. in SPL. Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com
Peng Fan
sbabic@denx.de
