[PATCH] video: Remove ati_radeon_fb
This driver is currently unused. Remove.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/video/Makefile | 1 - drivers/video/ati_ids.h | 211 ---- drivers/video/ati_radeon_fb.c | 761 ------------- drivers/video/ati_radeon_fb.h | 282 ----- include/radeon.h | 1988 --------------------------------- 5 files changed, 3243 deletions(-) delete mode 100644 drivers/video/ati_ids.h delete mode 100644 drivers/video/ati_radeon_fb.c delete mode 100644 drivers/video/ati_radeon_fb.h delete mode 100644 include/radeon.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 7ae0ab2b35c3..f6d07b343f0a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -25,7 +25,6 @@ obj-${CONFIG_VIDEO_STM32} += stm32/ obj-${CONFIG_VIDEO_TEGRA124} += tegra124/ obj-y += ti/
-obj-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o videomodes.o obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o diff --git a/drivers/video/ati_ids.h b/drivers/video/ati_ids.h deleted file mode 100644 index 3e72a7dd4c0d..000000000000 --- a/drivers/video/ati_ids.h +++ /dev/null @@ -1,211 +0,0 @@ -/* - * ATI PCI IDs from XFree86, kept here to make sync'ing with - * XFree much simpler. Currently, this list is only used by - * radeonfb - */ - -#define PCI_CHIP_RV380_3150 0x3150 -#define PCI_CHIP_RV380_3151 0x3151 -#define PCI_CHIP_RV380_3152 0x3152 -#define PCI_CHIP_RV380_3153 0x3153 -#define PCI_CHIP_RV380_3154 0x3154 -#define PCI_CHIP_RV380_3156 0x3156 -#define PCI_CHIP_RV380_3E50 0x3E50 -#define PCI_CHIP_RV380_3E51 0x3E51 -#define PCI_CHIP_RV380_3E52 0x3E52 -#define PCI_CHIP_RV380_3E53 0x3E53 -#define PCI_CHIP_RV380_3E54 0x3E54 -#define PCI_CHIP_RV380_3E56 0x3E56 -#define PCI_CHIP_RS100_4136 0x4136 -#define PCI_CHIP_RS200_4137 0x4137 -#define PCI_CHIP_R300_AD 0x4144 -#define PCI_CHIP_R300_AE 0x4145 -#define PCI_CHIP_R300_AF 0x4146 -#define PCI_CHIP_R300_AG 0x4147 -#define PCI_CHIP_R350_AH 0x4148 -#define PCI_CHIP_R350_AI 0x4149 -#define PCI_CHIP_R350_AJ 0x414A -#define PCI_CHIP_R350_AK 0x414B -#define PCI_CHIP_RV350_AP 0x4150 -#define PCI_CHIP_RV350_AQ 0x4151 -#define PCI_CHIP_RV360_AR 0x4152 -#define PCI_CHIP_RV350_AS 0x4153 -#define PCI_CHIP_RV350_AT 0x4154 -#define PCI_CHIP_RV350_AV 0x4156 -#define PCI_CHIP_MACH32 0x4158 -#define PCI_CHIP_RS250_4237 0x4237 -#define PCI_CHIP_R200_BB 0x4242 -#define PCI_CHIP_R200_BC 0x4243 -#define PCI_CHIP_RS100_4336 0x4336 -#define PCI_CHIP_RS200_4337 0x4337 -#define PCI_CHIP_MACH64CT 0x4354 -#define PCI_CHIP_MACH64CX 0x4358 -#define PCI_CHIP_RS250_4437 0x4437 -#define PCI_CHIP_MACH64ET 0x4554 -#define PCI_CHIP_MACH64GB 0x4742 -#define PCI_CHIP_MACH64GD 0x4744 -#define PCI_CHIP_MACH64GI 0x4749 -#define PCI_CHIP_MACH64GL 0x474C -#define PCI_CHIP_MACH64GM 0x474D -#define PCI_CHIP_MACH64GN 0x474E -#define PCI_CHIP_MACH64GO 0x474F -#define PCI_CHIP_MACH64GP 0x4750 -#define PCI_CHIP_MACH64GQ 0x4751 -#define PCI_CHIP_MACH64GR 0x4752 -#define PCI_CHIP_MACH64GS 0x4753 -#define PCI_CHIP_MACH64GT 0x4754 -#define PCI_CHIP_MACH64GU 0x4755 -#define PCI_CHIP_MACH64GV 0x4756 -#define PCI_CHIP_MACH64GW 0x4757 -#define PCI_CHIP_MACH64GX 0x4758 -#define PCI_CHIP_MACH64GY 0x4759 -#define PCI_CHIP_MACH64GZ 0x475A -#define PCI_CHIP_RV250_Id 0x4964 -#define PCI_CHIP_RV250_Ie 0x4965 -#define PCI_CHIP_RV250_If 0x4966 -#define PCI_CHIP_RV250_Ig 0x4967 -#define PCI_CHIP_R420_JH 0x4A48 -#define PCI_CHIP_R420_JI 0x4A49 -#define PCI_CHIP_R420_JJ 0x4A4A -#define PCI_CHIP_R420_JK 0x4A4B -#define PCI_CHIP_R420_JL 0x4A4C -#define PCI_CHIP_R420_JM 0x4A4D -#define PCI_CHIP_R420_JN 0x4A4E -#define PCI_CHIP_R420_JP 0x4A50 -#define PCI_CHIP_MACH64LB 0x4C42 -#define PCI_CHIP_MACH64LD 0x4C44 -#define PCI_CHIP_RAGE128LE 0x4C45 -#define PCI_CHIP_RAGE128LF 0x4C46 -#define PCI_CHIP_MACH64LG 0x4C47 -#define PCI_CHIP_MACH64LI 0x4C49 -#define PCI_CHIP_MACH64LM 0x4C4D -#define PCI_CHIP_MACH64LN 0x4C4E -#define PCI_CHIP_MACH64LP 0x4C50 -#define PCI_CHIP_MACH64LQ 0x4C51 -#define PCI_CHIP_MACH64LR 0x4C52 -#define PCI_CHIP_MACH64LS 0x4C53 -#define PCI_CHIP_MACH64LT 0x4C54 -#define PCI_CHIP_RADEON_LW 0x4C57 -#define PCI_CHIP_RADEON_LX 0x4C58 -#define PCI_CHIP_RADEON_LY 0x4C59 -#define PCI_CHIP_RADEON_LZ 0x4C5A -#define PCI_CHIP_RV250_Ld 0x4C64 -#define PCI_CHIP_RV250_Le 0x4C65 -#define PCI_CHIP_RV250_Lf 0x4C66 -#define PCI_CHIP_RV250_Lg 0x4C67 -#define PCI_CHIP_RV250_Ln 0x4C6E -#define PCI_CHIP_RAGE128MF 0x4D46 -#define PCI_CHIP_RAGE128ML 0x4D4C -#define PCI_CHIP_R300_ND 0x4E44 -#define PCI_CHIP_R300_NE 0x4E45 -#define PCI_CHIP_R300_NF 0x4E46 -#define PCI_CHIP_R300_NG 0x4E47 -#define PCI_CHIP_R350_NH 0x4E48 -#define PCI_CHIP_R350_NI 0x4E49 -#define PCI_CHIP_R360_NJ 0x4E4A -#define PCI_CHIP_R350_NK 0x4E4B -#define PCI_CHIP_RV350_NP 0x4E50 -#define PCI_CHIP_RV350_NQ 0x4E51 -#define PCI_CHIP_RV350_NR 0x4E52 -#define PCI_CHIP_RV350_NS 0x4E53 -#define PCI_CHIP_RV350_NT 0x4E54 -#define PCI_CHIP_RV350_NV 0x4E56 -#define PCI_CHIP_RAGE128PA 0x5041 -#define PCI_CHIP_RAGE128PB 0x5042 -#define PCI_CHIP_RAGE128PC 0x5043 -#define PCI_CHIP_RAGE128PD 0x5044 -#define PCI_CHIP_RAGE128PE 0x5045 -#define PCI_CHIP_RAGE128PF 0x5046 -#define PCI_CHIP_RAGE128PG 0x5047 -#define PCI_CHIP_RAGE128PH 0x5048 -#define PCI_CHIP_RAGE128PI 0x5049 -#define PCI_CHIP_RAGE128PJ 0x504A -#define PCI_CHIP_RAGE128PK 0x504B -#define PCI_CHIP_RAGE128PL 0x504C -#define PCI_CHIP_RAGE128PM 0x504D -#define PCI_CHIP_RAGE128PN 0x504E -#define PCI_CHIP_RAGE128PO 0x504F -#define PCI_CHIP_RAGE128PP 0x5050 -#define PCI_CHIP_RAGE128PQ 0x5051 -#define PCI_CHIP_RAGE128PR 0x5052 -#define PCI_CHIP_RAGE128PS 0x5053 -#define PCI_CHIP_RAGE128PT 0x5054 -#define PCI_CHIP_RAGE128PU 0x5055 -#define PCI_CHIP_RAGE128PV 0x5056 -#define PCI_CHIP_RAGE128PW 0x5057 -#define PCI_CHIP_RAGE128PX 0x5058 -#define PCI_CHIP_RADEON_QD 0x5144 -#define PCI_CHIP_RADEON_QE 0x5145 -#define PCI_CHIP_RADEON_QF 0x5146 -#define PCI_CHIP_RADEON_QG 0x5147 -#define PCI_CHIP_R200_QH 0x5148 -#define PCI_CHIP_R200_QI 0x5149 -#define PCI_CHIP_R200_QJ 0x514A -#define PCI_CHIP_R200_QK 0x514B -#define PCI_CHIP_R200_QL 0x514C -#define PCI_CHIP_R200_QM 0x514D -#define PCI_CHIP_R200_QN 0x514E -#define PCI_CHIP_R200_QO 0x514F -#define PCI_CHIP_RV200_QW 0x5157 -#define PCI_CHIP_RV200_QX 0x5158 -#define PCI_CHIP_RV100_QY 0x5159 -#define PCI_CHIP_RV100_QZ 0x515A -#define PCI_CHIP_RN50 0x515E -#define PCI_CHIP_RAGE128RE 0x5245 -#define PCI_CHIP_RAGE128RF 0x5246 -#define PCI_CHIP_RAGE128RG 0x5247 -#define PCI_CHIP_RAGE128RK 0x524B -#define PCI_CHIP_RAGE128RL 0x524C -#define PCI_CHIP_RAGE128SE 0x5345 -#define PCI_CHIP_RAGE128SF 0x5346 -#define PCI_CHIP_RAGE128SG 0x5347 -#define PCI_CHIP_RAGE128SH 0x5348 -#define PCI_CHIP_RAGE128SK 0x534B -#define PCI_CHIP_RAGE128SL 0x534C -#define PCI_CHIP_RAGE128SM 0x534D -#define PCI_CHIP_RAGE128SN 0x534E -#define PCI_CHIP_RAGE128TF 0x5446 -#define PCI_CHIP_RAGE128TL 0x544C -#define PCI_CHIP_RAGE128TR 0x5452 -#define PCI_CHIP_RAGE128TS 0x5453 -#define PCI_CHIP_RAGE128TT 0x5454 -#define PCI_CHIP_RAGE128TU 0x5455 -#define PCI_CHIP_RV370_5460 0x5460 -#define PCI_CHIP_RV370_5461 0x5461 -#define PCI_CHIP_RV370_5462 0x5462 -#define PCI_CHIP_RV370_5463 0x5463 -#define PCI_CHIP_RV370_5464 0x5464 -#define PCI_CHIP_RV370_5465 0x5465 -#define PCI_CHIP_RV370_5466 0x5466 -#define PCI_CHIP_RV370_5467 0x5467 -#define PCI_CHIP_R423_UH 0x5548 -#define PCI_CHIP_R423_UI 0x5549 -#define PCI_CHIP_R423_UJ 0x554A -#define PCI_CHIP_R423_UK 0x554B -#define PCI_CHIP_R423_UQ 0x5551 -#define PCI_CHIP_R423_UR 0x5552 -#define PCI_CHIP_R423_UT 0x5554 -#define PCI_CHIP_MACH64VT 0x5654 -#define PCI_CHIP_MACH64VU 0x5655 -#define PCI_CHIP_MACH64VV 0x5656 -#define PCI_CHIP_RS300_5834 0x5834 -#define PCI_CHIP_RS300_5835 0x5835 -#define PCI_CHIP_RS300_5836 0x5836 -#define PCI_CHIP_RS300_5837 0x5837 -#define PCI_CHIP_RV370_5B60 0x5B60 -#define PCI_CHIP_RV370_5B61 0x5B61 -#define PCI_CHIP_RV370_5B62 0x5B62 -#define PCI_CHIP_RV370_5B63 0x5B63 -#define PCI_CHIP_RV370_5B64 0x5B64 -#define PCI_CHIP_RV370_5B65 0x5B65 -#define PCI_CHIP_RV370_5B66 0x5B66 -#define PCI_CHIP_RV370_5B67 0x5B67 -#define PCI_CHIP_RV280_5960 0x5960 -#define PCI_CHIP_RV280_5961 0x5961 -#define PCI_CHIP_RV280_5962 0x5962 -#define PCI_CHIP_RV280_5964 0x5964 -#define PCI_CHIP_RV280_5C61 0x5C61 -#define PCI_CHIP_RV280_5C63 0x5C63 -#define PCI_CHIP_R423_5D57 0x5D57 -#define PCI_CHIP_RS350_7834 0x7834 -#define PCI_CHIP_RS350_7835 0x7835 diff --git a/drivers/video/ati_radeon_fb.c b/drivers/video/ati_radeon_fb.c deleted file mode 100644 index 383666781cce..000000000000 --- a/drivers/video/ati_radeon_fb.c +++ /dev/null @@ -1,761 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * ATI Radeon Video card Framebuffer driver. - * - * Copyright 2007 Freescale Semiconductor, Inc. - * Zhang Wei wei.zhang@freescale.com - * Jason Jin jason.jin@freescale.com - * - * Some codes of this file is partly ported from Linux kernel - * ATI video framebuffer driver. - * - * Now the driver is tested on below ATI chips: - * 9200 - * X300 - * X700 - */ - -#include <common.h> -#include <linux/delay.h> - -#include <command.h> -#include <bios_emul.h> -#include <env.h> -#include <pci.h> -#include <asm/processor.h> -#include <linux/errno.h> -#include <asm/io.h> -#include <malloc.h> -#include <video_fb.h> -#include "videomodes.h" - -#include <radeon.h> -#include "ati_ids.h" -#include "ati_radeon_fb.h" - -#undef DEBUG - -#ifdef DEBUG -#define DPRINT(x...) printf(x) -#else -#define DPRINT(x...) do{}while(0) -#endif - -#define MAX_MAPPED_VRAM (2048*2048*4) -#define MIN_MAPPED_VRAM (1024*768*1) - -#define RADEON_BUFFER_ALIGN 0x00000fff -#define SURF_UPPER_BOUND(x,y,bpp) (((((x) * (((y) + 15) & ~15) * (bpp)/8) + RADEON_BUFFER_ALIGN) \ - & ~RADEON_BUFFER_ALIGN) - 1) -#define RADEON_CRT_PITCH(width, bpp) ((((width) * (bpp) + ((bpp) * 8 - 1)) / ((bpp) * 8)) | \ - ((((width) * (bpp) + ((bpp) * 8 - 1)) / ((bpp) * 8)) << 16)) - -#define CRTC_H_TOTAL_DISP_VAL(htotal, hdisp) \ - (((((htotal) / 8) - 1) & 0x3ff) | (((((hdisp) / 8) - 1) & 0x1ff) << 16)) -#define CRTC_HSYNC_STRT_WID_VAL(hsync_srtr, hsync_wid) \ - (((hsync_srtr) & 0x1fff) | (((hsync_wid) & 0x3f) << 16)) -#define CRTC_V_TOTAL_DISP_VAL(vtotal, vdisp) \ - ((((vtotal) - 1) & 0xffff) | (((vdisp) - 1) << 16)) -#define CRTC_VSYNC_STRT_WID_VAL(vsync_srtr, vsync_wid) \ - ((((vsync_srtr) - 1) & 0xfff) | (((vsync_wid) & 0x1f) << 16)) - -/*#define PCI_VENDOR_ID_ATI*/ -#define PCI_CHIP_RV280_5960 0x5960 -#define PCI_CHIP_RV280_5961 0x5961 -#define PCI_CHIP_RV280_5962 0x5962 -#define PCI_CHIP_RV280_5964 0x5964 -#define PCI_CHIP_RV280_5C63 0x5C63 -#define PCI_CHIP_RV370_5B60 0x5B60 -#define PCI_CHIP_RV380_5657 0x5657 -#define PCI_CHIP_R420_554d 0x554d - -static struct pci_device_id ati_radeon_pci_ids[] = { - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV280_5960}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV280_5961}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV280_5962}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV280_5964}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV280_5C63}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV370_5B60}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_RV380_5657}, - {PCI_VENDOR_ID_ATI, PCI_CHIP_R420_554d}, - {0, 0} -}; - -static u16 ati_radeon_id_family_table[][2] = { - {PCI_CHIP_RV280_5960, CHIP_FAMILY_RV280}, - {PCI_CHIP_RV280_5961, CHIP_FAMILY_RV280}, - {PCI_CHIP_RV280_5962, CHIP_FAMILY_RV280}, - {PCI_CHIP_RV280_5964, CHIP_FAMILY_RV280}, - {PCI_CHIP_RV280_5C63, CHIP_FAMILY_RV280}, - {PCI_CHIP_RV370_5B60, CHIP_FAMILY_RV380}, - {PCI_CHIP_RV380_5657, CHIP_FAMILY_RV380}, - {PCI_CHIP_R420_554d, CHIP_FAMILY_R420}, - {0, 0} -}; - -u16 get_radeon_id_family(u16 device) -{ - int i; - for (i=0; ati_radeon_id_family_table[0][i]; i+=2) - if (ati_radeon_id_family_table[0][i] == device) - return ati_radeon_id_family_table[0][i + 1]; - return 0; -} - -struct radeonfb_info *rinfo; - -static void radeon_identify_vram(struct radeonfb_info *rinfo) -{ - u32 tmp; - - /* framebuffer size */ - if ((rinfo->family == CHIP_FAMILY_RS100) || - (rinfo->family == CHIP_FAMILY_RS200) || - (rinfo->family == CHIP_FAMILY_RS300)) { - u32 tom = INREG(NB_TOM); - tmp = ((((tom >> 16) - (tom & 0xffff) + 1) << 6) * 1024); - - radeon_fifo_wait(6); - OUTREG(MC_FB_LOCATION, tom); - OUTREG(DISPLAY_BASE_ADDR, (tom & 0xffff) << 16); - OUTREG(CRTC2_DISPLAY_BASE_ADDR, (tom & 0xffff) << 16); - OUTREG(OV0_BASE_ADDR, (tom & 0xffff) << 16); - - /* This is supposed to fix the crtc2 noise problem. */ - OUTREG(GRPH2_BUFFER_CNTL, INREG(GRPH2_BUFFER_CNTL) & ~0x7f0000); - - if ((rinfo->family == CHIP_FAMILY_RS100) || - (rinfo->family == CHIP_FAMILY_RS200)) { - /* This is to workaround the asic bug for RMX, some versions - of BIOS dosen't have this register initialized correctly. - */ - OUTREGP(CRTC_MORE_CNTL, CRTC_H_CUTOFF_ACTIVE_EN, - ~CRTC_H_CUTOFF_ACTIVE_EN); - } - } else { - tmp = INREG(CONFIG_MEMSIZE); - } - - /* mem size is bits [28:0], mask off the rest */ - rinfo->video_ram = tmp & CONFIG_MEMSIZE_MASK; - - /* - * Hack to get around some busted production M6's - * reporting no ram - */ - if (rinfo->video_ram == 0) { - switch (rinfo->pdev.device) { - case PCI_CHIP_RADEON_LY: - case PCI_CHIP_RADEON_LZ: - rinfo->video_ram = 8192 * 1024; - break; - default: - break; - } - } - - /* - * Now try to identify VRAM type - */ - if ((rinfo->family >= CHIP_FAMILY_R300) || - (INREG(MEM_SDRAM_MODE_REG) & (1<<30))) - rinfo->vram_ddr = 1; - else - rinfo->vram_ddr = 0; - - tmp = INREG(MEM_CNTL); - if (IS_R300_VARIANT(rinfo)) { - tmp &= R300_MEM_NUM_CHANNELS_MASK; - switch (tmp) { - case 0: rinfo->vram_width = 64; break; - case 1: rinfo->vram_width = 128; break; - case 2: rinfo->vram_width = 256; break; - default: rinfo->vram_width = 128; break; - } - } else if ((rinfo->family == CHIP_FAMILY_RV100) || - (rinfo->family == CHIP_FAMILY_RS100) || - (rinfo->family == CHIP_FAMILY_RS200)){ - if (tmp & RV100_MEM_HALF_MODE) - rinfo->vram_width = 32; - else - rinfo->vram_width = 64; - } else { - if (tmp & MEM_NUM_CHANNELS_MASK) - rinfo->vram_width = 128; - else - rinfo->vram_width = 64; - } - - /* This may not be correct, as some cards can have half of channel disabled - * ToDo: identify these cases - */ - - DPRINT("radeonfb: Found %dk of %s %d bits wide videoram\n", - rinfo->video_ram / 1024, - rinfo->vram_ddr ? "DDR" : "SDRAM", - rinfo->vram_width); - -} - -static void radeon_write_pll_regs(struct radeonfb_info *rinfo, struct radeon_regs *mode) -{ - int i; - - radeon_fifo_wait(20); - -#if 0 - /* Workaround from XFree */ - if (rinfo->is_mobility) { - /* A temporal workaround for the occational blanking on certain laptop - * panels. This appears to related to the PLL divider registers - * (fail to lock?). It occurs even when all dividers are the same - * with their old settings. In this case we really don't need to - * fiddle with PLL registers. By doing this we can avoid the blanking - * problem with some panels. - */ - if ((mode->ppll_ref_div == (INPLL(PPLL_REF_DIV) & PPLL_REF_DIV_MASK)) && - (mode->ppll_div_3 == (INPLL(PPLL_DIV_3) & - (PPLL_POST3_DIV_MASK | PPLL_FB3_DIV_MASK)))) { - /* We still have to force a switch to selected PPLL div thanks to - * an XFree86 driver bug which will switch it away in some cases - * even when using UseFDev */ - OUTREGP(CLOCK_CNTL_INDEX, - mode->clk_cntl_index & PPLL_DIV_SEL_MASK, - ~PPLL_DIV_SEL_MASK); - radeon_pll_errata_after_index(rinfo); - radeon_pll_errata_after_data(rinfo); - return; - } - } -#endif - if(rinfo->pdev.device == PCI_CHIP_RV370_5B60) return; - - /* Swich VCKL clock input to CPUCLK so it stays fed while PPLL updates*/ - OUTPLLP(VCLK_ECP_CNTL, VCLK_SRC_SEL_CPUCLK, ~VCLK_SRC_SEL_MASK); - - /* Reset PPLL & enable atomic update */ - OUTPLLP(PPLL_CNTL, - PPLL_RESET | PPLL_ATOMIC_UPDATE_EN | PPLL_VGA_ATOMIC_UPDATE_EN, - ~(PPLL_RESET | PPLL_ATOMIC_UPDATE_EN | PPLL_VGA_ATOMIC_UPDATE_EN)); - - /* Switch to selected PPLL divider */ - OUTREGP(CLOCK_CNTL_INDEX, - mode->clk_cntl_index & PPLL_DIV_SEL_MASK, - ~PPLL_DIV_SEL_MASK); - - /* Set PPLL ref. div */ - if (rinfo->family == CHIP_FAMILY_R300 || - rinfo->family == CHIP_FAMILY_RS300 || - rinfo->family == CHIP_FAMILY_R350 || - rinfo->family == CHIP_FAMILY_RV350) { - if (mode->ppll_ref_div & R300_PPLL_REF_DIV_ACC_MASK) { - /* When restoring console mode, use saved PPLL_REF_DIV - * setting. - */ - OUTPLLP(PPLL_REF_DIV, mode->ppll_ref_div, 0); - } else { - /* R300 uses ref_div_acc field as real ref divider */ - OUTPLLP(PPLL_REF_DIV, - (mode->ppll_ref_div << R300_PPLL_REF_DIV_ACC_SHIFT), - ~R300_PPLL_REF_DIV_ACC_MASK); - } - } else - OUTPLLP(PPLL_REF_DIV, mode->ppll_ref_div, ~PPLL_REF_DIV_MASK); - - /* Set PPLL divider 3 & post divider*/ - OUTPLLP(PPLL_DIV_3, mode->ppll_div_3, ~PPLL_FB3_DIV_MASK); - OUTPLLP(PPLL_DIV_3, mode->ppll_div_3, ~PPLL_POST3_DIV_MASK); - - /* Write update */ - while (INPLL(PPLL_REF_DIV) & PPLL_ATOMIC_UPDATE_R) - ; - OUTPLLP(PPLL_REF_DIV, PPLL_ATOMIC_UPDATE_W, ~PPLL_ATOMIC_UPDATE_W); - - /* Wait read update complete */ - /* FIXME: Certain revisions of R300 can't recover here. Not sure of - the cause yet, but this workaround will mask the problem for now. - Other chips usually will pass at the very first test, so the - workaround shouldn't have any effect on them. */ - for (i = 0; (i < 10000 && INPLL(PPLL_REF_DIV) & PPLL_ATOMIC_UPDATE_R); i++) - ; - - OUTPLL(HTOTAL_CNTL, 0); - - /* Clear reset & atomic update */ - OUTPLLP(PPLL_CNTL, 0, - ~(PPLL_RESET | PPLL_SLEEP | PPLL_ATOMIC_UPDATE_EN | PPLL_VGA_ATOMIC_UPDATE_EN)); - - /* We may want some locking ... oh well */ - udelay(5000); - - /* Switch back VCLK source to PPLL */ - OUTPLLP(VCLK_ECP_CNTL, VCLK_SRC_SEL_PPLLCLK, ~VCLK_SRC_SEL_MASK); -} - -typedef struct { - u16 reg; - u32 val; -} reg_val; - -#if 0 /* unused ? -> scheduled for removal */ -/* these common regs are cleared before mode setting so they do not - * interfere with anything - */ -static reg_val common_regs[] = { - { OVR_CLR, 0 }, - { OVR_WID_LEFT_RIGHT, 0 }, - { OVR_WID_TOP_BOTTOM, 0 }, - { OV0_SCALE_CNTL, 0 }, - { SUBPIC_CNTL, 0 }, - { VIPH_CONTROL, 0 }, - { I2C_CNTL_1, 0 }, - { GEN_INT_CNTL, 0 }, - { CAP0_TRIG_CNTL, 0 }, - { CAP1_TRIG_CNTL, 0 }, -}; -#endif /* 0 */ - -void radeon_setmode(void) -{ - struct radeon_regs *mode = malloc(sizeof(struct radeon_regs)); - - mode->crtc_gen_cntl = 0x03000200; - mode->crtc_ext_cntl = 0x00008048; - mode->dac_cntl = 0xff002100; - mode->crtc_h_total_disp = 0x4f0063; - mode->crtc_h_sync_strt_wid = 0x8c02a2; - mode->crtc_v_total_disp = 0x01df020c; - mode->crtc_v_sync_strt_wid = 0x8201ea; - mode->crtc_pitch = 0x00500050; - - OUTREG(CRTC_GEN_CNTL, mode->crtc_gen_cntl); - OUTREGP(CRTC_EXT_CNTL, mode->crtc_ext_cntl, - ~(CRTC_HSYNC_DIS | CRTC_VSYNC_DIS | CRTC_DISPLAY_DIS)); - OUTREGP(DAC_CNTL, mode->dac_cntl, DAC_RANGE_CNTL | DAC_BLANKING); - OUTREG(CRTC_H_TOTAL_DISP, mode->crtc_h_total_disp); - OUTREG(CRTC_H_SYNC_STRT_WID, mode->crtc_h_sync_strt_wid); - OUTREG(CRTC_V_TOTAL_DISP, mode->crtc_v_total_disp); - OUTREG(CRTC_V_SYNC_STRT_WID, mode->crtc_v_sync_strt_wid); - OUTREG(CRTC_OFFSET, 0); - OUTREG(CRTC_OFFSET_CNTL, 0); - OUTREG(CRTC_PITCH, mode->crtc_pitch); - - mode->clk_cntl_index = 0x300; - mode->ppll_ref_div = 0xc; - mode->ppll_div_3 = 0x00030059; - - radeon_write_pll_regs(rinfo, mode); -} - -static void set_pal(void) -{ - int idx, val = 0; - - for (idx = 0; idx < 256; idx++) { - OUTREG8(PALETTE_INDEX, idx); - OUTREG(PALETTE_DATA, val); - val += 0x00010101; - } -} - -void radeon_setmode_9200(int vesa_idx, int bpp) -{ - struct radeon_regs *mode = malloc(sizeof(struct radeon_regs)); - - mode->crtc_gen_cntl = CRTC_EN | CRTC_EXT_DISP_EN; - mode->crtc_ext_cntl = VGA_ATI_LINEAR | XCRT_CNT_EN | CRTC_CRT_ON; - mode->dac_cntl = DAC_MASK_ALL | DAC_VGA_ADR_EN | DAC_8BIT_EN; - mode->crtc_offset_cntl = CRTC_OFFSET_CNTL__CRTC_TILE_EN; - - switch (bpp) { - case 24: - mode->crtc_gen_cntl |= 0x6 << 8; /* x888 */ -#if defined(__BIG_ENDIAN) - mode->surface_cntl = NONSURF_AP0_SWP_32BPP | NONSURF_AP1_SWP_32BPP; - mode->surf_info[0] = NONSURF_AP0_SWP_32BPP | NONSURF_AP1_SWP_32BPP; -#endif - break; - case 16: - mode->crtc_gen_cntl |= 0x4 << 8; /* 565 */ -#if defined(__BIG_ENDIAN) - mode->surface_cntl = NONSURF_AP0_SWP_16BPP | NONSURF_AP1_SWP_16BPP; - mode->surf_info[0] = NONSURF_AP0_SWP_16BPP | NONSURF_AP1_SWP_16BPP; -#endif - break; - default: - mode->crtc_gen_cntl |= 0x2 << 8; /* palette */ - mode->surface_cntl = 0x00000000; - break; - } - - switch (vesa_idx) { - case RES_MODE_1280x1024: - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(1688,1280); - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(1066,1024); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(1025,3); -#if defined(CONFIG_RADEON_VREFRESH_75HZ) - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(1288,18); - mode->ppll_div_3 = 0x00010078; -#else /* default @ 60 Hz */ - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(1320,14); - mode->ppll_div_3 = 0x00010060; -#endif - /* - * for this mode pitch expands to the same value for 32, 16 and 8 bpp, - * so we set it here once only. - */ - mode->crtc_pitch = RADEON_CRT_PITCH(1280,32); - switch (bpp) { - case 24: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (1280 * 4 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1280,1024,32); - break; - case 16: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (1280 * 2 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1280,1024,16); - break; - default: /* 8 bpp */ - mode->surf_info[0] = R200_SURF_TILE_COLOR_MACRO | (1280 * 1 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1280,1024,8); - break; - } - break; - case RES_MODE_1024x768: -#if defined(CONFIG_RADEON_VREFRESH_75HZ) - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(1312,1024); - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(1032,12); - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(800,768); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(769,3); - mode->ppll_div_3 = 0x0002008c; -#else /* @ 60 Hz */ - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(1344,1024); - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(1040,17) | CRTC_H_SYNC_POL; - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(806,768); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(771,6) | CRTC_V_SYNC_POL; - mode->ppll_div_3 = 0x00020074; -#endif - /* also same pitch value for 32, 16 and 8 bpp */ - mode->crtc_pitch = RADEON_CRT_PITCH(1024,32); - switch (bpp) { - case 24: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (1024 * 4 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1024,768,32); - break; - case 16: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (1024 * 2 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1024,768,16); - break; - default: /* 8 bpp */ - mode->surf_info[0] = R200_SURF_TILE_COLOR_MACRO | (1024 * 1 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1024,768,8); - break; - } - break; - case RES_MODE_800x600: - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(1056,800); -#if defined(CONFIG_RADEON_VREFRESH_75HZ) - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(808,10); - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(625,600); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(601,3); - mode->ppll_div_3 = 0x000300b0; -#else /* @ 60 Hz */ - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(832,16); - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(628,600); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(601,4); - mode->ppll_div_3 = 0x0003008e; -#endif - switch (bpp) { - case 24: - mode->crtc_pitch = RADEON_CRT_PITCH(832,32); - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (832 * 4 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(832,600,32); - break; - case 16: - mode->crtc_pitch = RADEON_CRT_PITCH(896,16); - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (896 * 2 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(896,600,16); - break; - default: /* 8 bpp */ - mode->crtc_pitch = RADEON_CRT_PITCH(1024,8); - mode->surf_info[0] = R200_SURF_TILE_COLOR_MACRO | (1024 * 1 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(1024,600,8); - break; - } - break; - default: /* RES_MODE_640x480 */ -#if defined(CONFIG_RADEON_VREFRESH_75HZ) - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(840,640); - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(648,8) | CRTC_H_SYNC_POL; - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(500,480); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(481,3) | CRTC_V_SYNC_POL; - mode->ppll_div_3 = 0x00030070; -#else /* @ 60 Hz */ - mode->crtc_h_total_disp = CRTC_H_TOTAL_DISP_VAL(800,640); - mode->crtc_h_sync_strt_wid = CRTC_HSYNC_STRT_WID_VAL(674,12) | CRTC_H_SYNC_POL; - mode->crtc_v_total_disp = CRTC_V_TOTAL_DISP_VAL(525,480); - mode->crtc_v_sync_strt_wid = CRTC_VSYNC_STRT_WID_VAL(491,2) | CRTC_V_SYNC_POL; - mode->ppll_div_3 = 0x00030059; -#endif - /* also same pitch value for 32, 16 and 8 bpp */ - mode->crtc_pitch = RADEON_CRT_PITCH(640,32); - switch (bpp) { - case 24: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (640 * 4 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(640,480,32); - break; - case 16: - mode->surf_info[0] |= R200_SURF_TILE_COLOR_MACRO | (640 * 2 / 16); - mode->surf_upper_bound[0] = SURF_UPPER_BOUND(640,480,16); - break; - default: /* 8 bpp */ - mode->crtc_offset_cntl = 0x00000000; - break; - } - break; - } - - OUTREG(CRTC_GEN_CNTL, mode->crtc_gen_cntl | CRTC_DISP_REQ_EN_B); - OUTREGP(CRTC_EXT_CNTL, mode->crtc_ext_cntl, - (CRTC_HSYNC_DIS | CRTC_VSYNC_DIS | CRTC_DISPLAY_DIS)); - OUTREGP(DAC_CNTL, mode->dac_cntl, DAC_RANGE_CNTL | DAC_BLANKING); - OUTREG(CRTC_H_TOTAL_DISP, mode->crtc_h_total_disp); - OUTREG(CRTC_H_SYNC_STRT_WID, mode->crtc_h_sync_strt_wid); - OUTREG(CRTC_V_TOTAL_DISP, mode->crtc_v_total_disp); - OUTREG(CRTC_V_SYNC_STRT_WID, mode->crtc_v_sync_strt_wid); - OUTREG(CRTC_OFFSET, 0); - OUTREG(CRTC_OFFSET_CNTL, mode->crtc_offset_cntl); - OUTREG(CRTC_PITCH, mode->crtc_pitch); - OUTREG(CRTC_GEN_CNTL, mode->crtc_gen_cntl); - - mode->clk_cntl_index = 0x300; - mode->ppll_ref_div = 0xc; - - radeon_write_pll_regs(rinfo, mode); - - OUTREGP(CRTC_EXT_CNTL, mode->crtc_ext_cntl, - ~(CRTC_HSYNC_DIS | CRTC_VSYNC_DIS | CRTC_DISPLAY_DIS)); - OUTREG(SURFACE0_INFO, mode->surf_info[0]); - OUTREG(SURFACE0_LOWER_BOUND, 0); - OUTREG(SURFACE0_UPPER_BOUND, mode->surf_upper_bound[0]); - OUTREG(SURFACE_CNTL, mode->surface_cntl); - - if (bpp > 8) - set_pal(); - - free(mode); -} - -#include "../bios_emulator/include/biosemu.h" - -int radeon_probe(struct radeonfb_info *rinfo) -{ - pci_dev_t pdev; - u16 did; - - pdev = pci_find_devices(ati_radeon_pci_ids, 0); - - if (pdev != -1) { - pci_read_config_word(pdev, PCI_DEVICE_ID, &did); - printf("ATI Radeon video card (%04x, %04x) found @(%d:%d:%d)\n", - PCI_VENDOR_ID_ATI, did, (pdev >> 16) & 0xff, - (pdev >> 11) & 0x1f, (pdev >> 8) & 0x7); - - strcpy(rinfo->name, "ATI Radeon"); - rinfo->pdev.vendor = PCI_VENDOR_ID_ATI; - rinfo->pdev.device = did; - rinfo->family = get_radeon_id_family(rinfo->pdev.device); - pci_read_config_dword(pdev, PCI_BASE_ADDRESS_0, - &rinfo->fb_base_bus); - pci_read_config_dword(pdev, PCI_BASE_ADDRESS_2, - &rinfo->mmio_base_bus); - rinfo->fb_base_bus &= 0xfffff000; - rinfo->mmio_base_bus &= ~0x04; - - rinfo->mmio_base = pci_bus_to_virt(pdev, rinfo->mmio_base_bus, - PCI_REGION_MEM, 0, MAP_NOCACHE); - DPRINT("rinfo->mmio_base = 0x%p bus=0x%x\n", - rinfo->mmio_base, rinfo->mmio_base_bus); - rinfo->fb_local_base = INREG(MC_FB_LOCATION) << 16; - DPRINT("rinfo->fb_local_base = 0x%x\n",rinfo->fb_local_base); - /* PostBIOS with x86 emulater */ - if (!BootVideoCardBIOS(pdev, NULL, 0)) - return -1; - - /* - * Check for errata - * (These will be added in the future for the chipfamily - * R300, RV200, RS200, RV100, RS100.) - */ - - /* Get VRAM size and type */ - radeon_identify_vram(rinfo); - - rinfo->mapped_vram = min_t(unsigned long, MAX_MAPPED_VRAM, - rinfo->video_ram); - rinfo->fb_base = pci_bus_to_virt(pdev, rinfo->fb_base_bus, - PCI_REGION_MEM, 0, MAP_NOCACHE); - DPRINT("Radeon: framebuffer base address 0x%08x, " - "bus address 0x%08x\n" - "MMIO base address 0x%08x, bus address 0x%08x, " - "framebuffer local base 0x%08x.\n ", - (u32)rinfo->fb_base, rinfo->fb_base_bus, - (u32)rinfo->mmio_base, rinfo->mmio_base_bus, - rinfo->fb_local_base); - return 0; - } - return -1; -} - -/* - * The Graphic Device - */ -GraphicDevice ctfb; - -#define CURSOR_SIZE 0x1000 /* in KByte for HW Cursor */ -#define PATTERN_ADR (pGD->dprBase + CURSOR_SIZE) /* pattern Memory after Cursor Memory */ -#define PATTERN_SIZE 8*8*4 /* 4 Bytes per Pixel 8 x 8 Pixel */ -#define ACCELMEMORY (CURSOR_SIZE + PATTERN_SIZE) /* reserved Memory for BITBlt and hw cursor */ - -void *video_hw_init(void) -{ - GraphicDevice *pGD = (GraphicDevice *) & ctfb; - u32 *vm; - char *penv; - unsigned long t1, hsynch, vsynch; - int bits_per_pixel, i, tmp, vesa_idx = 0, videomode; - struct ctfb_res_modes *res_mode; - struct ctfb_res_modes var_mode; - - rinfo = malloc(sizeof(struct radeonfb_info)); - - printf("Video: "); - if(radeon_probe(rinfo)) { - printf("No radeon video card found!\n"); - return NULL; - } - - tmp = 0; - - videomode = CONFIG_SYS_DEFAULT_VIDEO_MODE; - /* get video mode via environment */ - penv = env_get("videomode"); - if (penv) { - /* deceide if it is a string */ - if (penv[0] <= '9') { - videomode = (int)hextoul(penv, NULL); - tmp = 1; - } - } else { - tmp = 1; - } - if (tmp) { - /* parameter are vesa modes */ - /* search params */ - for (i = 0; i < VESA_MODES_COUNT; i++) { - if (vesa_modes[i].vesanr == videomode) - break; - } - if (i == VESA_MODES_COUNT) { - printf ("no VESA Mode found, switching to mode 0x%x ", CONFIG_SYS_DEFAULT_VIDEO_MODE); - i = 0; - } - res_mode = (struct ctfb_res_modes *) &res_mode_init[vesa_modes[i].resindex]; - bits_per_pixel = vesa_modes[i].bits_per_pixel; - vesa_idx = vesa_modes[i].resindex; - } else { - res_mode = (struct ctfb_res_modes *) &var_mode; - bits_per_pixel = video_get_params (res_mode, penv); - } - - /* calculate hsynch and vsynch freq (info only) */ - t1 = (res_mode->left_margin + res_mode->xres + - res_mode->right_margin + res_mode->hsync_len) / 8; - t1 *= 8; - t1 *= res_mode->pixclock; - t1 /= 1000; - hsynch = 1000000000L / t1; - t1 *= (res_mode->upper_margin + res_mode->yres + - res_mode->lower_margin + res_mode->vsync_len); - t1 /= 1000; - vsynch = 1000000000L / t1; - - /* fill in Graphic device struct */ - sprintf (pGD->modeIdent, "%dx%dx%d %ldkHz %ldHz", res_mode->xres, - res_mode->yres, bits_per_pixel, (hsynch / 1000), - (vsynch / 1000)); - printf ("%s\n", pGD->modeIdent); - pGD->winSizeX = res_mode->xres; - pGD->winSizeY = res_mode->yres; - pGD->plnSizeX = res_mode->xres; - pGD->plnSizeY = res_mode->yres; - - switch (bits_per_pixel) { - case 24: - pGD->gdfBytesPP = 4; - pGD->gdfIndex = GDF_32BIT_X888RGB; - if (res_mode->xres == 800) { - pGD->winSizeX = 832; - pGD->plnSizeX = 832; - } - break; - case 16: - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_16BIT_565RGB; - if (res_mode->xres == 800) { - pGD->winSizeX = 896; - pGD->plnSizeX = 896; - } - break; - default: - if (res_mode->xres == 800) { - pGD->winSizeX = 1024; - pGD->plnSizeX = 1024; - } - pGD->gdfBytesPP = 1; - pGD->gdfIndex = GDF__8BIT_INDEX; - break; - } - - pGD->isaBase = CONFIG_SYS_ISA_IO_BASE_ADDRESS; - pGD->pciBase = (unsigned int)rinfo->fb_base; - pGD->frameAdrs = (unsigned int)rinfo->fb_base; - pGD->memSize = 64 * 1024 * 1024; - - /* Cursor Start Address */ - pGD->dprBase = (pGD->winSizeX * pGD->winSizeY * pGD->gdfBytesPP) + - (unsigned int)rinfo->fb_base; - if ((pGD->dprBase & 0x0fff) != 0) { - /* allign it */ - pGD->dprBase &= 0xfffff000; - pGD->dprBase += 0x00001000; - } - DPRINT ("Cursor Start %x Pattern Start %x\n", pGD->dprBase, - PATTERN_ADR); - pGD->vprBase = (unsigned int)rinfo->fb_base; /* Dummy */ - pGD->cprBase = (unsigned int)rinfo->fb_base; /* Dummy */ - /* set up Hardware */ - - /* Clear video memory (only visible screen area) */ - i = pGD->winSizeX * pGD->winSizeY * pGD->gdfBytesPP / 4; - vm = (unsigned int *) pGD->pciBase; - while (i--) - *vm++ = 0; - /*SetDrawingEngine (bits_per_pixel);*/ - - if (rinfo->family == CHIP_FAMILY_RV280) - radeon_setmode_9200(vesa_idx, bits_per_pixel); - else - radeon_setmode(); - - return ((void *) pGD); -} - -void video_set_lut (unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ) -{ - OUTREG(PALETTE_INDEX, index); - OUTREG(PALETTE_DATA, (r << 16) | (g << 8) | b); -} diff --git a/drivers/video/ati_radeon_fb.h b/drivers/video/ati_radeon_fb.h deleted file mode 100644 index 9dd638bb9e45..000000000000 --- a/drivers/video/ati_radeon_fb.h +++ /dev/null @@ -1,282 +0,0 @@ -#ifndef __ATI_RADEON_FB_H -#define __ATI_RADEON_FB_H - -/*************************************************************** - * Most of the definitions here are adapted right from XFree86 * - ***************************************************************/ - -/* - * Chip families. Must fit in the low 16 bits of a long word - */ -enum radeon_family { - CHIP_FAMILY_UNKNOW, - CHIP_FAMILY_LEGACY, - CHIP_FAMILY_RADEON, - CHIP_FAMILY_RV100, - CHIP_FAMILY_RS100, /* U1 (IGP320M) or A3 (IGP320)*/ - CHIP_FAMILY_RV200, - CHIP_FAMILY_RS200, /* U2 (IGP330M/340M/350M) or A4 (IGP330/340/345/350), - RS250 (IGP 7000) */ - CHIP_FAMILY_R200, - CHIP_FAMILY_RV250, - CHIP_FAMILY_RS300, /* Radeon 9000 IGP */ - CHIP_FAMILY_RV280, - CHIP_FAMILY_R300, - CHIP_FAMILY_R350, - CHIP_FAMILY_RV350, - CHIP_FAMILY_RV380, /* RV370/RV380/M22/M24 */ - CHIP_FAMILY_R420, /* R420/R423/M18 */ - CHIP_FAMILY_LAST, -}; - -#define IS_RV100_VARIANT(rinfo) (((rinfo)->family == CHIP_FAMILY_RV100) || \ - ((rinfo)->family == CHIP_FAMILY_RV200) || \ - ((rinfo)->family == CHIP_FAMILY_RS100) || \ - ((rinfo)->family == CHIP_FAMILY_RS200) || \ - ((rinfo)->family == CHIP_FAMILY_RV250) || \ - ((rinfo)->family == CHIP_FAMILY_RV280) || \ - ((rinfo)->family == CHIP_FAMILY_RS300)) - -#define IS_R300_VARIANT(rinfo) (((rinfo)->family == CHIP_FAMILY_R300) || \ - ((rinfo)->family == CHIP_FAMILY_RV350) || \ - ((rinfo)->family == CHIP_FAMILY_R350) || \ - ((rinfo)->family == CHIP_FAMILY_RV380) || \ - ((rinfo)->family == CHIP_FAMILY_R420)) - -struct radeonfb_info { - char name[20]; - - struct pci_device_id pdev; - u16 family; - - u32 fb_base_bus; - u32 mmio_base_bus; - - void *mmio_base; - void *fb_base; - - u32 video_ram; - u32 mapped_vram; - int vram_width; - int vram_ddr; - - u32 fb_local_base; -}; - -#define INREG8(addr) readb((rinfo->mmio_base)+addr) -#define OUTREG8(addr,val) writeb(val, (rinfo->mmio_base)+addr) -#define INREG16(addr) readw((rinfo->mmio_base)+addr) -#define OUTREG16(addr,val) writew(val, (rinfo->mmio_base)+addr) -#define INREG(addr) readl((rinfo->mmio_base)+addr) -#define OUTREG(addr,val) writel(val, (rinfo->mmio_base)+addr) - -static inline void _OUTREGP(struct radeonfb_info *rinfo, u32 addr, - u32 val, u32 mask) -{ - unsigned int tmp; - - tmp = INREG(addr); - tmp &= (mask); - tmp |= (val); - OUTREG(addr, tmp); -} - -#define OUTREGP(addr,val,mask) _OUTREGP(rinfo, addr, val,mask) - -/* - * 2D Engine helper routines - */ -static inline void radeon_engine_flush (struct radeonfb_info *rinfo) -{ - int i; - - /* initiate flush */ - OUTREGP(RB2D_DSTCACHE_CTLSTAT, RB2D_DC_FLUSH_ALL, - ~RB2D_DC_FLUSH_ALL); - - for (i=0; i < 2000000; i++) { - if (!(INREG(RB2D_DSTCACHE_CTLSTAT) & RB2D_DC_BUSY)) - return; - udelay(1); - } - printf("radeonfb: Flush Timeout !\n"); -} - -static inline void _radeon_fifo_wait(struct radeonfb_info *rinfo, int entries) -{ - int i; - - for (i=0; i<2000000; i++) { - if ((INREG(RBBM_STATUS) & 0x7f) >= entries) - return; - udelay(1); - } - printf("radeonfb: FIFO Timeout !\n"); -} - -static inline void _radeon_engine_idle(struct radeonfb_info *rinfo) -{ - int i; - - /* ensure FIFO is empty before waiting for idle */ - _radeon_fifo_wait (rinfo, 64); - - for (i=0; i<2000000; i++) { - if (((INREG(RBBM_STATUS) & GUI_ACTIVE)) == 0) { - radeon_engine_flush (rinfo); - return; - } - udelay(1); - } - printf("radeonfb: Idle Timeout !\n"); -} - -#define radeon_engine_idle() _radeon_engine_idle(rinfo) -#define radeon_fifo_wait(entries) _radeon_fifo_wait(rinfo,entries) -#define radeon_msleep(ms) _radeon_msleep(rinfo,ms) - -/* - * This structure contains the various registers manipulated by this - * driver for setting or restoring a mode. It's mostly copied from - * XFree's RADEONSaveRec structure. A few chip settings might still be - * tweaked without beeing reflected or saved in these registers though - */ -struct radeon_regs { - /* Common registers */ - u32 ovr_clr; - u32 ovr_wid_left_right; - u32 ovr_wid_top_bottom; - u32 ov0_scale_cntl; - u32 mpp_tb_config; - u32 mpp_gp_config; - u32 subpic_cntl; - u32 viph_control; - u32 i2c_cntl_1; - u32 gen_int_cntl; - u32 cap0_trig_cntl; - u32 cap1_trig_cntl; - u32 bus_cntl; - u32 surface_cntl; - u32 bios_5_scratch; - - /* Other registers to save for VT switches or driver load/unload */ - u32 dp_datatype; - u32 rbbm_soft_reset; - u32 clock_cntl_index; - u32 amcgpio_en_reg; - u32 amcgpio_mask; - - /* Surface/tiling registers */ - u32 surf_lower_bound[8]; - u32 surf_upper_bound[8]; - u32 surf_info[8]; - - /* CRTC registers */ - u32 crtc_gen_cntl; - u32 crtc_ext_cntl; - u32 dac_cntl; - u32 crtc_h_total_disp; - u32 crtc_h_sync_strt_wid; - u32 crtc_v_total_disp; - u32 crtc_v_sync_strt_wid; - u32 crtc_offset; - u32 crtc_offset_cntl; - u32 crtc_pitch; - u32 disp_merge_cntl; - u32 grph_buffer_cntl; - u32 crtc_more_cntl; - - /* CRTC2 registers */ - u32 crtc2_gen_cntl; - u32 dac2_cntl; - u32 disp_output_cntl; - u32 disp_hw_debug; - u32 disp2_merge_cntl; - u32 grph2_buffer_cntl; - u32 crtc2_h_total_disp; - u32 crtc2_h_sync_strt_wid; - u32 crtc2_v_total_disp; - u32 crtc2_v_sync_strt_wid; - u32 crtc2_offset; - u32 crtc2_offset_cntl; - u32 crtc2_pitch; - - /* Flat panel regs */ - u32 fp_crtc_h_total_disp; - u32 fp_crtc_v_total_disp; - u32 fp_gen_cntl; - u32 fp2_gen_cntl; - u32 fp_h_sync_strt_wid; - u32 fp2_h_sync_strt_wid; - u32 fp_horz_stretch; - u32 fp_panel_cntl; - u32 fp_v_sync_strt_wid; - u32 fp2_v_sync_strt_wid; - u32 fp_vert_stretch; - u32 lvds_gen_cntl; - u32 lvds_pll_cntl; - u32 tmds_crc; - u32 tmds_transmitter_cntl; - - /* Computed values for PLL */ - u32 dot_clock_freq; - int feedback_div; - int post_div; - - /* PLL registers */ - u32 ppll_div_3; - u32 ppll_ref_div; - u32 vclk_ecp_cntl; - u32 clk_cntl_index; - - /* Computed values for PLL2 */ - u32 dot_clock_freq_2; - int feedback_div_2; - int post_div_2; - - /* PLL2 registers */ - u32 p2pll_ref_div; - u32 p2pll_div_0; - u32 htotal_cntl2; - - /* Palette */ - int palette_valid; -}; - -static inline u32 __INPLL(struct radeonfb_info *rinfo, u32 addr) -{ - u32 data; - - OUTREG8(CLOCK_CNTL_INDEX, addr & 0x0000003f); - /* radeon_pll_errata_after_index(rinfo); */ - data = INREG(CLOCK_CNTL_DATA); - /* radeon_pll_errata_after_data(rinfo); */ - return data; -} - -static inline void __OUTPLL(struct radeonfb_info *rinfo, unsigned int index, - u32 val) -{ - - OUTREG8(CLOCK_CNTL_INDEX, (index & 0x0000003f) | 0x00000080); - /* radeon_pll_errata_after_index(rinfo); */ - OUTREG(CLOCK_CNTL_DATA, val); - /* radeon_pll_errata_after_data(rinfo); */ -} - -static inline void __OUTPLLP(struct radeonfb_info *rinfo, unsigned int index, - u32 val, u32 mask) -{ - unsigned int tmp; - - tmp = __INPLL(rinfo, index); - tmp &= (mask); - tmp |= (val); - __OUTPLL(rinfo, index, tmp); -} - -#define INPLL(addr) __INPLL(rinfo, addr) -#define OUTPLL(index, val) __OUTPLL(rinfo, index, val) -#define OUTPLLP(index, val, mask) __OUTPLLP(rinfo, index, val, mask) - -#endif diff --git a/include/radeon.h b/include/radeon.h deleted file mode 100644 index da6c26bbe3bf..000000000000 --- a/include/radeon.h +++ /dev/null @@ -1,1988 +0,0 @@ -#ifndef _RADEON_H -#define _RADEON_H - - -#define RADEON_REGSIZE 0x4000 - - -#define MM_INDEX 0x0000 -#define MM_DATA 0x0004 -#define BUS_CNTL 0x0030 -#define HI_STAT 0x004C -#define BUS_CNTL1 0x0034 -#define I2C_CNTL_1 0x0094 -#define CONFIG_CNTL 0x00E0 -#define CONFIG_MEMSIZE 0x00F8 -#define CONFIG_APER_0_BASE 0x0100 -#define CONFIG_APER_1_BASE 0x0104 -#define CONFIG_APER_SIZE 0x0108 -#define CONFIG_REG_1_BASE 0x010C -#define CONFIG_REG_APER_SIZE 0x0110 -#define PAD_AGPINPUT_DELAY 0x0164 -#define PAD_CTLR_STRENGTH 0x0168 -#define PAD_CTLR_UPDATE 0x016C -#define PAD_CTLR_MISC 0x0aa0 -#define AGP_CNTL 0x0174 -#define BM_STATUS 0x0160 -#define CAP0_TRIG_CNTL 0x0950 -#define CAP1_TRIG_CNTL 0x09c0 -#define VIPH_CONTROL 0x0C40 -#define VENDOR_ID 0x0F00 -#define DEVICE_ID 0x0F02 -#define COMMAND 0x0F04 -#define STATUS 0x0F06 -#define REVISION_ID 0x0F08 -#define REGPROG_INF 0x0F09 -#define SUB_CLASS 0x0F0A -#define BASE_CODE 0x0F0B -#define CACHE_LINE 0x0F0C -#define LATENCY 0x0F0D -#define HEADER 0x0F0E -#define BIST 0x0F0F -#define REG_MEM_BASE 0x0F10 -#define REG_IO_BASE 0x0F14 -#define REG_REG_BASE 0x0F18 -#define ADAPTER_ID 0x0F2C -#define BIOS_ROM 0x0F30 -#define CAPABILITIES_PTR 0x0F34 -#define INTERRUPT_LINE 0x0F3C -#define INTERRUPT_PIN 0x0F3D -#define MIN_GRANT 0x0F3E -#define MAX_LATENCY 0x0F3F -#define ADAPTER_ID_W 0x0F4C -#define PMI_CAP_ID 0x0F50 -#define PMI_NXT_CAP_PTR 0x0F51 -#define PMI_PMC_REG 0x0F52 -#define PM_STATUS 0x0F54 -#define PMI_DATA 0x0F57 -#define AGP_CAP_ID 0x0F58 -#define AGP_STATUS 0x0F5C -#define AGP_COMMAND 0x0F60 -#define AIC_CTRL 0x01D0 -#define AIC_STAT 0x01D4 -#define AIC_PT_BASE 0x01D8 -#define AIC_LO_ADDR 0x01DC -#define AIC_HI_ADDR 0x01E0 -#define AIC_TLB_ADDR 0x01E4 -#define AIC_TLB_DATA 0x01E8 -#define DAC_CNTL 0x0058 -#define DAC_CNTL2 0x007c -#define CRTC_GEN_CNTL 0x0050 -#define MEM_CNTL 0x0140 -#define MC_CNTL 0x0140 -#define EXT_MEM_CNTL 0x0144 -#define MC_TIMING_CNTL 0x0144 -#define MC_AGP_LOCATION 0x014C -#define MEM_IO_CNTL_A0 0x0178 -#define MEM_REFRESH_CNTL 0x0178 -#define MEM_INIT_LATENCY_TIMER 0x0154 -#define MC_INIT_GFX_LAT_TIMER 0x0154 -#define MEM_SDRAM_MODE_REG 0x0158 -#define AGP_BASE 0x0170 -#define MEM_IO_CNTL_A1 0x017C -#define MC_READ_CNTL_AB 0x017C -#define MEM_IO_CNTL_B0 0x0180 -#define MC_INIT_MISC_LAT_TIMER 0x0180 -#define MEM_IO_CNTL_B1 0x0184 -#define MC_IOPAD_CNTL 0x0184 -#define MC_DEBUG 0x0188 -#define MC_STATUS 0x0150 -#define MEM_IO_OE_CNTL 0x018C -#define MC_CHIP_IO_OE_CNTL_AB 0x018C -#define MC_FB_LOCATION 0x0148 -/* #define MC_FB_LOCATION 0x0188 */ -#define HOST_PATH_CNTL 0x0130 -#define MEM_VGA_WP_SEL 0x0038 -#define MEM_VGA_RP_SEL 0x003C -#define HDP_DEBUG 0x0138 -#define SW_SEMAPHORE 0x013C -#define CRTC2_GEN_CNTL 0x03f8 -#define CRTC2_DISPLAY_BASE_ADDR 0x033c -#define SURFACE_CNTL 0x0B00 -#define SURFACE0_LOWER_BOUND 0x0B04 -#define SURFACE1_LOWER_BOUND 0x0B14 -#define SURFACE2_LOWER_BOUND 0x0B24 -#define SURFACE3_LOWER_BOUND 0x0B34 -#define SURFACE4_LOWER_BOUND 0x0B44 -#define SURFACE5_LOWER_BOUND 0x0B54 -#define SURFACE6_LOWER_BOUND 0x0B64 -#define SURFACE7_LOWER_BOUND 0x0B74 -#define SURFACE0_UPPER_BOUND 0x0B08 -#define SURFACE1_UPPER_BOUND 0x0B18 -#define SURFACE2_UPPER_BOUND 0x0B28 -#define SURFACE3_UPPER_BOUND 0x0B38 -#define SURFACE4_UPPER_BOUND 0x0B48 -#define SURFACE5_UPPER_BOUND 0x0B58 -#define SURFACE6_UPPER_BOUND 0x0B68 -#define SURFACE7_UPPER_BOUND 0x0B78 -#define SURFACE0_INFO 0x0B0C -#define SURFACE1_INFO 0x0B1C -#define SURFACE2_INFO 0x0B2C -#define SURFACE3_INFO 0x0B3C -#define SURFACE4_INFO 0x0B4C -#define SURFACE5_INFO 0x0B5C -#define SURFACE6_INFO 0x0B6C -#define SURFACE7_INFO 0x0B7C -#define SURFACE_ACCESS_FLAGS 0x0BF8 -#define SURFACE_ACCESS_CLR 0x0BFC -#define GEN_INT_CNTL 0x0040 -#define GEN_INT_STATUS 0x0044 -#define CRTC_EXT_CNTL 0x0054 -#define RB3D_CNTL 0x1C3C -#define WAIT_UNTIL 0x1720 -#define ISYNC_CNTL 0x1724 -#define RBBM_GUICNTL 0x172C -#define RBBM_STATUS 0x0E40 -#define RBBM_STATUS_alt_1 0x1740 -#define RBBM_CNTL 0x00EC -#define RBBM_CNTL_alt_1 0x0E44 -#define RBBM_SOFT_RESET 0x00F0 -#define RBBM_SOFT_RESET_alt_1 0x0E48 -#define NQWAIT_UNTIL 0x0E50 -#define RBBM_DEBUG 0x0E6C -#define RBBM_CMDFIFO_ADDR 0x0E70 -#define RBBM_CMDFIFO_DATAL 0x0E74 -#define RBBM_CMDFIFO_DATAH 0x0E78 -#define RBBM_CMDFIFO_STAT 0x0E7C -#define CRTC_STATUS 0x005C -#define GPIO_VGA_DDC 0x0060 -#define GPIO_DVI_DDC 0x0064 -#define GPIO_MONID 0x0068 -#define GPIO_CRT2_DDC 0x006c -#define PALETTE_INDEX 0x00B0 -#define PALETTE_DATA 0x00B4 -#define PALETTE_30_DATA 0x00B8 -#define CRTC_H_TOTAL_DISP 0x0200 -#define CRTC_H_SYNC_STRT_WID 0x0204 -#define CRTC_H_SYNC_POL (1 << 23) -#define CRTC_V_TOTAL_DISP 0x0208 -#define CRTC_V_SYNC_STRT_WID 0x020C -#define CRTC_V_SYNC_POL (1 << 23) -#define CRTC_VLINE_CRNT_VLINE 0x0210 -#define CRTC_CRNT_FRAME 0x0214 -#define CRTC_GUI_TRIG_VLINE 0x0218 -#define CRTC_DEBUG 0x021C -#define CRTC_OFFSET_RIGHT 0x0220 -#define CRTC_OFFSET 0x0224 -#define CRTC_OFFSET_CNTL 0x0228 -#define CRTC_PITCH 0x022C -#define OVR_CLR 0x0230 -#define OVR_WID_LEFT_RIGHT 0x0234 -#define OVR_WID_TOP_BOTTOM 0x0238 -#define DISPLAY_BASE_ADDR 0x023C -#define SNAPSHOT_VH_COUNTS 0x0240 -#define SNAPSHOT_F_COUNT 0x0244 -#define N_VIF_COUNT 0x0248 -#define SNAPSHOT_VIF_COUNT 0x024C -#define FP_CRTC_H_TOTAL_DISP 0x0250 -#define FP_CRTC_V_TOTAL_DISP 0x0254 -#define CRT_CRTC_H_SYNC_STRT_WID 0x0258 -#define CRT_CRTC_V_SYNC_STRT_WID 0x025C -#define CUR_OFFSET 0x0260 -#define CUR_HORZ_VERT_POSN 0x0264 -#define CUR_HORZ_VERT_OFF 0x0268 -#define CUR_CLR0 0x026C -#define CUR_CLR1 0x0270 -#define FP_HORZ_VERT_ACTIVE 0x0278 -#define CRTC_MORE_CNTL 0x027C -#define CRTC_H_CUTOFF_ACTIVE_EN (1<<4) -#define CRTC_V_CUTOFF_ACTIVE_EN (1<<5) -#define DAC_EXT_CNTL 0x0280 -#define FP_GEN_CNTL 0x0284 -#define FP_HORZ_STRETCH 0x028C -#define FP_VERT_STRETCH 0x0290 -#define FP_H_SYNC_STRT_WID 0x02C4 -#define FP_V_SYNC_STRT_WID 0x02C8 -#define AUX_WINDOW_HORZ_CNTL 0x02D8 -#define AUX_WINDOW_VERT_CNTL 0x02DC -/* #define DDA_CONFIG 0x02e0 */ -/* #define DDA_ON_OFF 0x02e4 */ -#define DVI_I2C_CNTL_1 0x02e4 -#define GRPH_BUFFER_CNTL 0x02F0 -#define GRPH2_BUFFER_CNTL 0x03F0 -#define VGA_BUFFER_CNTL 0x02F4 -#define OV0_Y_X_START 0x0400 -#define OV0_Y_X_END 0x0404 -#define OV0_PIPELINE_CNTL 0x0408 -#define OV0_REG_LOAD_CNTL 0x0410 -#define OV0_SCALE_CNTL 0x0420 -#define OV0_V_INC 0x0424 -#define OV0_P1_V_ACCUM_INIT 0x0428 -#define OV0_P23_V_ACCUM_INIT 0x042C -#define OV0_P1_BLANK_LINES_AT_TOP 0x0430 -#define OV0_P23_BLANK_LINES_AT_TOP 0x0434 -#define OV0_BASE_ADDR 0x043C -#define OV0_VID_BUF0_BASE_ADRS 0x0440 -#define OV0_VID_BUF1_BASE_ADRS 0x0444 -#define OV0_VID_BUF2_BASE_ADRS 0x0448 -#define OV0_VID_BUF3_BASE_ADRS 0x044C -#define OV0_VID_BUF4_BASE_ADRS 0x0450 -#define OV0_VID_BUF5_BASE_ADRS 0x0454 -#define OV0_VID_BUF_PITCH0_VALUE 0x0460 -#define OV0_VID_BUF_PITCH1_VALUE 0x0464 -#define OV0_AUTO_FLIP_CNTRL 0x0470 -#define OV0_DEINTERLACE_PATTERN 0x0474 -#define OV0_SUBMIT_HISTORY 0x0478 -#define OV0_H_INC 0x0480 -#define OV0_STEP_BY 0x0484 -#define OV0_P1_H_ACCUM_INIT 0x0488 -#define OV0_P23_H_ACCUM_INIT 0x048C -#define OV0_P1_X_START_END 0x0494 -#define OV0_P2_X_START_END 0x0498 -#define OV0_P3_X_START_END 0x049C -#define OV0_FILTER_CNTL 0x04A0 -#define OV0_FOUR_TAP_COEF_0 0x04B0 -#define OV0_FOUR_TAP_COEF_1 0x04B4 -#define OV0_FOUR_TAP_COEF_2 0x04B8 -#define OV0_FOUR_TAP_COEF_3 0x04BC -#define OV0_FOUR_TAP_COEF_4 0x04C0 -#define OV0_FLAG_CNTRL 0x04DC -#define OV0_SLICE_CNTL 0x04E0 -#define OV0_VID_KEY_CLR_LOW 0x04E4 -#define OV0_VID_KEY_CLR_HIGH 0x04E8 -#define OV0_GRPH_KEY_CLR_LOW 0x04EC -#define OV0_GRPH_KEY_CLR_HIGH 0x04F0 -#define OV0_KEY_CNTL 0x04F4 -#define OV0_TEST 0x04F8 -#define SUBPIC_CNTL 0x0540 -#define SUBPIC_DEFCOLCON 0x0544 -#define SUBPIC_Y_X_START 0x054C -#define SUBPIC_Y_X_END 0x0550 -#define SUBPIC_V_INC 0x0554 -#define SUBPIC_H_INC 0x0558 -#define SUBPIC_BUF0_OFFSET 0x055C -#define SUBPIC_BUF1_OFFSET 0x0560 -#define SUBPIC_LC0_OFFSET 0x0564 -#define SUBPIC_LC1_OFFSET 0x0568 -#define SUBPIC_PITCH 0x056C -#define SUBPIC_BTN_HLI_COLCON 0x0570 -#define SUBPIC_BTN_HLI_Y_X_START 0x0574 -#define SUBPIC_BTN_HLI_Y_X_END 0x0578 -#define SUBPIC_PALETTE_INDEX 0x057C -#define SUBPIC_PALETTE_DATA 0x0580 -#define SUBPIC_H_ACCUM_INIT 0x0584 -#define SUBPIC_V_ACCUM_INIT 0x0588 -#define DISP_MISC_CNTL 0x0D00 -#define DAC_MACRO_CNTL 0x0D04 -#define DISP_PWR_MAN 0x0D08 -#define DISP_TEST_DEBUG_CNTL 0x0D10 -#define DISP_HW_DEBUG 0x0D14 -#define DAC_CRC_SIG1 0x0D18 -#define DAC_CRC_SIG2 0x0D1C -#define OV0_LIN_TRANS_A 0x0D20 -#define OV0_LIN_TRANS_B 0x0D24 -#define OV0_LIN_TRANS_C 0x0D28 -#define OV0_LIN_TRANS_D 0x0D2C -#define OV0_LIN_TRANS_E 0x0D30 -#define OV0_LIN_TRANS_F 0x0D34 -#define OV0_GAMMA_0_F 0x0D40 -#define OV0_GAMMA_10_1F 0x0D44 -#define OV0_GAMMA_20_3F 0x0D48 -#define OV0_GAMMA_40_7F 0x0D4C -#define OV0_GAMMA_380_3BF 0x0D50 -#define OV0_GAMMA_3C0_3FF 0x0D54 -#define DISP_MERGE_CNTL 0x0D60 -#define DISP_OUTPUT_CNTL 0x0D64 -#define DISP_LIN_TRANS_GRPH_A 0x0D80 -#define DISP_LIN_TRANS_GRPH_B 0x0D84 -#define DISP_LIN_TRANS_GRPH_C 0x0D88 -#define DISP_LIN_TRANS_GRPH_D 0x0D8C -#define DISP_LIN_TRANS_GRPH_E 0x0D90 -#define DISP_LIN_TRANS_GRPH_F 0x0D94 -#define DISP_LIN_TRANS_VID_A 0x0D98 -#define DISP_LIN_TRANS_VID_B 0x0D9C -#define DISP_LIN_TRANS_VID_C 0x0DA0 -#define DISP_LIN_TRANS_VID_D 0x0DA4 -#define DISP_LIN_TRANS_VID_E 0x0DA8 -#define DISP_LIN_TRANS_VID_F 0x0DAC -#define RMX_HORZ_FILTER_0TAP_COEF 0x0DB0 -#define RMX_HORZ_FILTER_1TAP_COEF 0x0DB4 -#define RMX_HORZ_FILTER_2TAP_COEF 0x0DB8 -#define RMX_HORZ_PHASE 0x0DBC -#define DAC_EMBEDDED_SYNC_CNTL 0x0DC0 -#define DAC_BROAD_PULSE 0x0DC4 -#define DAC_SKEW_CLKS 0x0DC8 -#define DAC_INCR 0x0DCC -#define DAC_NEG_SYNC_LEVEL 0x0DD0 -#define DAC_POS_SYNC_LEVEL 0x0DD4 -#define DAC_BLANK_LEVEL 0x0DD8 -#define CLOCK_CNTL_INDEX 0x0008 -#define CLOCK_CNTL_DATA 0x000C -#define CP_RB_CNTL 0x0704 -#define CP_RB_BASE 0x0700 -#define CP_RB_RPTR_ADDR 0x070C -#define CP_RB_RPTR 0x0710 -#define CP_RB_WPTR 0x0714 -#define CP_RB_WPTR_DELAY 0x0718 -#define CP_IB_BASE 0x0738 -#define CP_IB_BUFSZ 0x073C -#define SCRATCH_REG0 0x15E0 -#define GUI_SCRATCH_REG0 0x15E0 -#define SCRATCH_REG1 0x15E4 -#define GUI_SCRATCH_REG1 0x15E4 -#define SCRATCH_REG2 0x15E8 -#define GUI_SCRATCH_REG2 0x15E8 -#define SCRATCH_REG3 0x15EC -#define GUI_SCRATCH_REG3 0x15EC -#define SCRATCH_REG4 0x15F0 -#define GUI_SCRATCH_REG4 0x15F0 -#define SCRATCH_REG5 0x15F4 -#define GUI_SCRATCH_REG5 0x15F4 -#define SCRATCH_UMSK 0x0770 -#define SCRATCH_ADDR 0x0774 -#define DP_BRUSH_FRGD_CLR 0x147C -#define DP_BRUSH_BKGD_CLR 0x1478 -#define DST_LINE_START 0x1600 -#define DST_LINE_END 0x1604 -#define SRC_OFFSET 0x15AC -#define SRC_PITCH 0x15B0 -#define SRC_TILE 0x1704 -#define SRC_PITCH_OFFSET 0x1428 -#define SRC_X 0x1414 -#define SRC_Y 0x1418 -#define SRC_X_Y 0x1590 -#define SRC_Y_X 0x1434 -#define DST_Y_X 0x1438 -#define DST_WIDTH_HEIGHT 0x1598 -#define DST_HEIGHT_WIDTH 0x143c -#define DST_OFFSET 0x1404 -#define SRC_CLUT_ADDRESS 0x1780 -#define SRC_CLUT_DATA 0x1784 -#define SRC_CLUT_DATA_RD 0x1788 -#define HOST_DATA0 0x17C0 -#define HOST_DATA1 0x17C4 -#define HOST_DATA2 0x17C8 -#define HOST_DATA3 0x17CC -#define HOST_DATA4 0x17D0 -#define HOST_DATA5 0x17D4 -#define HOST_DATA6 0x17D8 -#define HOST_DATA7 0x17DC -#define HOST_DATA_LAST 0x17E0 -#define DP_SRC_ENDIAN 0x15D4 -#define DP_SRC_FRGD_CLR 0x15D8 -#define DP_SRC_BKGD_CLR 0x15DC -#define SC_LEFT 0x1640 -#define SC_RIGHT 0x1644 -#define SC_TOP 0x1648 -#define SC_BOTTOM 0x164C -#define SRC_SC_RIGHT 0x1654 -#define SRC_SC_BOTTOM 0x165C -#define DP_CNTL 0x16C0 -#define DP_CNTL_XDIR_YDIR_YMAJOR 0x16D0 -#define DP_DATATYPE 0x16C4 -#define DP_MIX 0x16C8 -#define DP_WRITE_MSK 0x16CC -#define DP_XOP 0x17F8 -#define CLR_CMP_CLR_SRC 0x15C4 -#define CLR_CMP_CLR_DST 0x15C8 -#define CLR_CMP_CNTL 0x15C0 -#define CLR_CMP_MSK 0x15CC -#define DSTCACHE_MODE 0x1710 -#define DSTCACHE_CTLSTAT 0x1714 -#define DEFAULT_PITCH_OFFSET 0x16E0 -#define DEFAULT_SC_BOTTOM_RIGHT 0x16E8 -#define DEFAULT_SC_TOP_LEFT 0x16EC -#define SRC_PITCH_OFFSET 0x1428 -#define DST_PITCH_OFFSET 0x142C -#define DP_GUI_MASTER_CNTL 0x146C -#define SC_TOP_LEFT 0x16EC -#define SC_BOTTOM_RIGHT 0x16F0 -#define SRC_SC_BOTTOM_RIGHT 0x16F4 -#define RB2D_DSTCACHE_MODE 0x3428 -#define RB2D_DSTCACHE_CTLSTAT 0x342C -#define LVDS_GEN_CNTL 0x02d0 -#define LVDS_PLL_CNTL 0x02d4 -#define FP2_GEN_CNTL 0x0288 -#define TMDS_CNTL 0x0294 -#define TMDS_CRC 0x02a0 -#define TMDS_TRANSMITTER_CNTL 0x02a4 -#define MPP_TB_CONFIG 0x01c0 -#define PAMAC0_DLY_CNTL 0x0a94 -#define PAMAC1_DLY_CNTL 0x0a98 -#define PAMAC2_DLY_CNTL 0x0a9c -#define FW_CNTL 0x0118 -#define FCP_CNTL 0x0910 -#define VGA_DDA_ON_OFF 0x02ec -#define TV_MASTER_CNTL 0x0800 - -/* #define BASE_CODE 0x0f0b */ -#define BIOS_0_SCRATCH 0x0010 -#define BIOS_1_SCRATCH 0x0014 -#define BIOS_2_SCRATCH 0x0018 -#define BIOS_3_SCRATCH 0x001c -#define BIOS_4_SCRATCH 0x0020 -#define BIOS_5_SCRATCH 0x0024 -#define BIOS_6_SCRATCH 0x0028 -#define BIOS_7_SCRATCH 0x002c - -#define HDP_SOFT_RESET (1 << 26) - -#define TV_DAC_CNTL 0x088c -#define GPIOPAD_MASK 0x0198 -#define GPIOPAD_A 0x019c -#define GPIOPAD_EN 0x01a0 -#define GPIOPAD_Y 0x01a4 -#define ZV_LCDPAD_MASK 0x01a8 -#define ZV_LCDPAD_A 0x01ac -#define ZV_LCDPAD_EN 0x01b0 -#define ZV_LCDPAD_Y 0x01b4 - -/* PLL Registers */ -#define CLK_PIN_CNTL 0x0001 -#define PPLL_CNTL 0x0002 -#define PPLL_REF_DIV 0x0003 -#define PPLL_DIV_0 0x0004 -#define PPLL_DIV_1 0x0005 -#define PPLL_DIV_2 0x0006 -#define PPLL_DIV_3 0x0007 -#define VCLK_ECP_CNTL 0x0008 -#define HTOTAL_CNTL 0x0009 -#define M_SPLL_REF_FB_DIV 0x000a -#define AGP_PLL_CNTL 0x000b -#define SPLL_CNTL 0x000c -#define SCLK_CNTL 0x000d -#define MPLL_CNTL 0x000e -#define MDLL_CKO 0x000f -#define MDLL_RDCKA 0x0010 -#define MCLK_CNTL 0x0012 -#define AGP_PLL_CNTL 0x000b -#define PLL_TEST_CNTL 0x0013 -#define CLK_PWRMGT_CNTL 0x0014 -#define PLL_PWRMGT_CNTL 0x0015 -#define MCLK_MISC 0x001f -#define P2PLL_CNTL 0x002a -#define P2PLL_REF_DIV 0x002b -#define PIXCLKS_CNTL 0x002d -#define SCLK_MORE_CNTL 0x0035 - -/* MCLK_CNTL bit constants */ -#define FORCEON_MCLKA (1 << 16) -#define FORCEON_MCLKB (1 << 17) -#define FORCEON_YCLKA (1 << 18) -#define FORCEON_YCLKB (1 << 19) -#define FORCEON_MC (1 << 20) -#define FORCEON_AIC (1 << 21) - -/* SCLK_CNTL bit constants */ -#define DYN_STOP_LAT_MASK 0x00007ff8 -#define CP_MAX_DYN_STOP_LAT 0x0008 -#define SCLK_FORCEON_MASK 0xffff8000 - -/* SCLK_MORE_CNTL bit constants */ -#define SCLK_MORE_FORCEON 0x0700 - -/* BUS_CNTL bit constants */ -#define BUS_DBL_RESYNC 0x00000001 -#define BUS_MSTR_RESET 0x00000002 -#define BUS_FLUSH_BUF 0x00000004 -#define BUS_STOP_REQ_DIS 0x00000008 -#define BUS_ROTATION_DIS 0x00000010 -#define BUS_MASTER_DIS 0x00000040 -#define BUS_ROM_WRT_EN 0x00000080 -#define BUS_DIS_ROM 0x00001000 -#define BUS_PCI_READ_RETRY_EN 0x00002000 -#define BUS_AGP_AD_STEPPING_EN 0x00004000 -#define BUS_PCI_WRT_RETRY_EN 0x00008000 -#define BUS_MSTR_RD_MULT 0x00100000 -#define BUS_MSTR_RD_LINE 0x00200000 -#define BUS_SUSPEND 0x00400000 -#define LAT_16X 0x00800000 -#define BUS_RD_DISCARD_EN 0x01000000 -#define BUS_RD_ABORT_EN 0x02000000 -#define BUS_MSTR_WS 0x04000000 -#define BUS_PARKING_DIS 0x08000000 -#define BUS_MSTR_DISCONNECT_EN 0x10000000 -#define BUS_WRT_BURST 0x20000000 -#define BUS_READ_BURST 0x40000000 -#define BUS_RDY_READ_DLY 0x80000000 - -/* PIXCLKS_CNTL */ -#define PIX2CLK_SRC_SEL_MASK 0x03 -#define PIX2CLK_SRC_SEL_CPUCLK 0x00 -#define PIX2CLK_SRC_SEL_PSCANCLK 0x01 -#define PIX2CLK_SRC_SEL_BYTECLK 0x02 -#define PIX2CLK_SRC_SEL_P2PLLCLK 0x03 -#define PIX2CLK_ALWAYS_ONb (1<<6) -#define PIX2CLK_DAC_ALWAYS_ONb (1<<7) -#define PIXCLK_TV_SRC_SEL (1 << 8) -#define PIXCLK_LVDS_ALWAYS_ONb (1 << 14) -#define PIXCLK_TMDS_ALWAYS_ONb (1 << 15) - - -/* CLOCK_CNTL_INDEX bit constants */ -#define PLL_WR_EN 0x00000080 - -/* CONFIG_CNTL bit constants */ -#define CONFIG_SYS_VGA_RAM_EN 0x00000100 -#define CONFIG_SYS_ATI_REV_ID_MASK (0xf << 16) -#define CONFIG_SYS_ATI_REV_A11 (0 << 16) -#define CONFIG_SYS_ATI_REV_A12 (1 << 16) -#define CONFIG_SYS_ATI_REV_A13 (2 << 16) - -/* CRTC_EXT_CNTL bit constants */ -#define VGA_ATI_LINEAR 0x00000008 -#define VGA_128KAP_PAGING 0x00000010 -#define XCRT_CNT_EN (1 << 6) -#define CRTC_HSYNC_DIS (1 << 8) -#define CRTC_VSYNC_DIS (1 << 9) -#define CRTC_DISPLAY_DIS (1 << 10) -#define CRTC_CRT_ON (1 << 15) - - -/* DSTCACHE_CTLSTAT bit constants */ -#define RB2D_DC_FLUSH (3 << 0) -#define RB2D_DC_FLUSH_ALL 0xf -#define RB2D_DC_BUSY (1 << 31) - - -/* CRTC_GEN_CNTL bit constants */ -#define CRTC_DBL_SCAN_EN 0x00000001 -#define CRTC_CUR_EN 0x00010000 -#define CRTC_INTERLACE_EN (1 << 1) -#define CRTC_BYPASS_LUT_EN (1 << 14) -#define CRTC_EXT_DISP_EN (1 << 24) -#define CRTC_EN (1 << 25) -#define CRTC_DISP_REQ_EN_B (1 << 26) - -/* CRTC_STATUS bit constants */ -#define CRTC_VBLANK 0x00000001 - -/* CRTC2_GEN_CNTL bit constants */ -#define CRT2_ON (1 << 7) -#define CRTC2_DISPLAY_DIS (1 << 23) -#define CRTC2_EN (1 << 25) -#define CRTC2_DISP_REQ_EN_B (1 << 26) - -/* CUR_OFFSET, CUR_HORZ_VERT_POSN, CUR_HORZ_VERT_OFF bit constants */ -#define CUR_LOCK 0x80000000 - -/* GPIO bit constants */ -#define GPIO_A_0 (1 << 0) -#define GPIO_A_1 (1 << 1) -#define GPIO_Y_0 (1 << 8) -#define GPIO_Y_1 (1 << 9) -#define GPIO_EN_0 (1 << 16) -#define GPIO_EN_1 (1 << 17) -#define GPIO_MASK_0 (1 << 24) -#define GPIO_MASK_1 (1 << 25) -#define VGA_DDC_DATA_OUTPUT GPIO_A_0 -#define VGA_DDC_CLK_OUTPUT GPIO_A_1 -#define VGA_DDC_DATA_INPUT GPIO_Y_0 -#define VGA_DDC_CLK_INPUT GPIO_Y_1 -#define VGA_DDC_DATA_OUT_EN GPIO_EN_0 -#define VGA_DDC_CLK_OUT_EN GPIO_EN_1 - - -/* FP bit constants */ -#define FP_CRTC_H_TOTAL_MASK 000003ff -#define FP_CRTC_H_DISP_MASK 0x01ff0000 -#define FP_CRTC_V_TOTAL_MASK 0x00000fff -#define FP_CRTC_V_DISP_MASK 0x0fff0000 -#define FP_H_SYNC_STRT_CHAR_MASK 0x00001ff8 -#define FP_H_SYNC_WID_MASK 0x003f0000 -#define FP_V_SYNC_STRT_MASK 0x00000fff -#define FP_V_SYNC_WID_MASK 0x001f0000 -#define FP_CRTC_H_TOTAL_SHIFT 0x00000000 -#define FP_CRTC_H_DISP_SHIFT 0x00000010 -#define FP_CRTC_V_TOTAL_SHIFT 0x00000000 -#define FP_CRTC_V_DISP_SHIFT 0x00000010 -#define FP_H_SYNC_STRT_CHAR_SHIFT 0x00000003 -#define FP_H_SYNC_WID_SHIFT 0x00000010 -#define FP_V_SYNC_STRT_SHIFT 0x00000000 -#define FP_V_SYNC_WID_SHIFT 0x00000010 - -/* FP_GEN_CNTL bit constants */ -#define FP_FPON (1 << 0) -#define FP_TMDS_EN (1 << 2) -#define FP_PANEL_FORMAT (1 << 3) -#define FP_EN_TMDS (1 << 7) -#define FP_DETECT_SENSE (1 << 8) -#define R200_FP_SOURCE_SEL_MASK (3 << 10) -#define R200_FP_SOURCE_SEL_CRTC1 (0 << 10) -#define R200_FP_SOURCE_SEL_CRTC2 (1 << 10) -#define R200_FP_SOURCE_SEL_RMX (2 << 10) -#define R200_FP_SOURCE_SEL_TRANS (3 << 10) -#define FP_SEL_CRTC1 (0 << 13) -#define FP_SEL_CRTC2 (1 << 13) -#define FP_USE_VGA_HSYNC (1 << 14) -#define FP_CRTC_DONT_SHADOW_HPAR (1 << 15) -#define FP_CRTC_DONT_SHADOW_VPAR (1 << 16) -#define FP_CRTC_DONT_SHADOW_HEND (1 << 17) -#define FP_CRTC_USE_SHADOW_VEND (1 << 18) -#define FP_RMX_HVSYNC_CONTROL_EN (1 << 20) -#define FP_DFP_SYNC_SEL (1 << 21) -#define FP_CRTC_LOCK_8DOT (1 << 22) -#define FP_CRT_SYNC_SEL (1 << 23) -#define FP_USE_SHADOW_EN (1 << 24) -#define FP_CRT_SYNC_ALT (1 << 26) - -/* FP2_GEN_CNTL bit constants */ -#define FP2_BLANK_EN (1 << 1) -#define FP2_ON (1 << 2) -#define FP2_PANEL_FORMAT (1 << 3) -#define FP2_SOURCE_SEL_MASK (3 << 10) -#define FP2_SOURCE_SEL_CRTC2 (1 << 10) -#define FP2_SRC_SEL_MASK (3 << 13) -#define FP2_SRC_SEL_CRTC2 (1 << 13) -#define FP2_FP_POL (1 << 16) -#define FP2_LP_POL (1 << 17) -#define FP2_SCK_POL (1 << 18) -#define FP2_LCD_CNTL_MASK (7 << 19) -#define FP2_PAD_FLOP_EN (1 << 22) -#define FP2_CRC_EN (1 << 23) -#define FP2_CRC_READ_EN (1 << 24) -#define FP2_DV0_EN (1 << 25) -#define FP2_DV0_RATE_SEL_SDR (1 << 26) - - -/* LVDS_GEN_CNTL bit constants */ -#define LVDS_ON (1 << 0) -#define LVDS_DISPLAY_DIS (1 << 1) -#define LVDS_PANEL_TYPE (1 << 2) -#define LVDS_PANEL_FORMAT (1 << 3) -#define LVDS_EN (1 << 7) -#define LVDS_BL_MOD_LEVEL_MASK 0x0000ff00 -#define LVDS_BL_MOD_LEVEL_SHIFT 8 -#define LVDS_BL_MOD_EN (1 << 16) -#define LVDS_DIGON (1 << 18) -#define LVDS_BLON (1 << 19) -#define LVDS_SEL_CRTC2 (1 << 23) -#define LVDS_STATE_MASK \ - (LVDS_ON | LVDS_DISPLAY_DIS | LVDS_BL_MOD_LEVEL_MASK | LVDS_BLON) - -/* LVDS_PLL_CNTL bit constatns */ -#define HSYNC_DELAY_SHIFT 0x1c -#define HSYNC_DELAY_MASK (0xf << 0x1c) - -/* TMDS_TRANSMITTER_CNTL bit constants */ -#define TMDS_PLL_EN (1 << 0) -#define TMDS_PLLRST (1 << 1) -#define TMDS_RAN_PAT_RST (1 << 7) -#define TMDS_ICHCSEL (1 << 28) - -/* FP_HORZ_STRETCH bit constants */ -#define HORZ_STRETCH_RATIO_MASK 0xffff -#define HORZ_STRETCH_RATIO_MAX 4096 -#define HORZ_PANEL_SIZE (0x1ff << 16) -#define HORZ_PANEL_SHIFT 16 -#define HORZ_STRETCH_PIXREP (0 << 25) -#define HORZ_STRETCH_BLEND (1 << 26) -#define HORZ_STRETCH_ENABLE (1 << 25) -#define HORZ_AUTO_RATIO (1 << 27) -#define HORZ_FP_LOOP_STRETCH (0x7 << 28) -#define HORZ_AUTO_RATIO_INC (1 << 31) - - -/* FP_VERT_STRETCH bit constants */ -#define VERT_STRETCH_RATIO_MASK 0xfff -#define VERT_STRETCH_RATIO_MAX 4096 -#define VERT_PANEL_SIZE (0xfff << 12) -#define VERT_PANEL_SHIFT 12 -#define VERT_STRETCH_LINREP (0 << 26) -#define VERT_STRETCH_BLEND (1 << 26) -#define VERT_STRETCH_ENABLE (1 << 25) -#define VERT_AUTO_RATIO_EN (1 << 27) -#define VERT_FP_LOOP_STRETCH (0x7 << 28) -#define VERT_STRETCH_RESERVED 0xf1000000 - -/* DAC_CNTL bit constants */ -#define DAC_8BIT_EN 0x00000100 -#define DAC_4BPP_PIX_ORDER 0x00000200 -#define DAC_CRC_EN 0x00080000 -#define DAC_MASK_ALL (0xff << 24) -#define DAC_PDWN (1 << 15) -#define DAC_EXPAND_MODE (1 << 14) -#define DAC_VGA_ADR_EN (1 << 13) -#define DAC_RANGE_CNTL (3 << 0) -#define DAC_RANGE_CNTL_MASK 0x03 -#define DAC_BLANKING (1 << 2) -#define DAC_CMP_EN (1 << 3) -#define DAC_CMP_OUTPUT (1 << 7) - -/* DAC_CNTL2 bit constants */ -#define DAC2_EXPAND_MODE (1 << 14) -#define DAC2_CMP_EN (1 << 7) -#define DAC2_PALETTE_ACCESS_CNTL (1 << 5) - -/* DAC_EXT_CNTL bit constants */ -#define DAC_FORCE_BLANK_OFF_EN (1 << 4) -#define DAC_FORCE_DATA_EN (1 << 5) -#define DAC_FORCE_DATA_SEL_MASK (3 << 6) -#define DAC_FORCE_DATA_MASK 0x0003ff00 -#define DAC_FORCE_DATA_SHIFT 8 - -/* GEN_RESET_CNTL bit constants */ -#define SOFT_RESET_GUI 0x00000001 -#define SOFT_RESET_VCLK 0x00000100 -#define SOFT_RESET_PCLK 0x00000200 -#define SOFT_RESET_ECP 0x00000400 -#define SOFT_RESET_DISPENG_XCLK 0x00000800 - -/* MEM_CNTL bit constants */ -#define MEM_CTLR_STATUS_IDLE 0x00000000 -#define MEM_CTLR_STATUS_BUSY 0x00100000 -#define MEM_SEQNCR_STATUS_IDLE 0x00000000 -#define MEM_SEQNCR_STATUS_BUSY 0x00200000 -#define MEM_ARBITER_STATUS_IDLE 0x00000000 -#define MEM_ARBITER_STATUS_BUSY 0x00400000 -#define MEM_REQ_UNLOCK 0x00000000 -#define MEM_REQ_LOCK 0x00800000 -#define MEM_NUM_CHANNELS_MASK 0x00000001 -#define MEM_USE_B_CH_ONLY 0x00000002 -#define RV100_MEM_HALF_MODE 0x00000008 -#define R300_MEM_NUM_CHANNELS_MASK 0x00000003 -#define R300_MEM_USE_CD_CH_ONLY 0x00000004 - - -/* RBBM_SOFT_RESET bit constants */ -#define SOFT_RESET_CP (1 << 0) -#define SOFT_RESET_HI (1 << 1) -#define SOFT_RESET_SE (1 << 2) -#define SOFT_RESET_RE (1 << 3) -#define SOFT_RESET_PP (1 << 4) -#define SOFT_RESET_E2 (1 << 5) -#define SOFT_RESET_RB (1 << 6) -#define SOFT_RESET_HDP (1 << 7) - -/* SURFACE_CNTL bit consants */ -#define SURF_TRANSLATION_DIS (1 << 8) -#define NONSURF_AP0_SWP_16BPP (1 << 20) -#define NONSURF_AP0_SWP_32BPP (1 << 21) -#define NONSURF_AP1_SWP_16BPP (1 << 22) -#define NONSURF_AP1_SWP_32BPP (1 << 23) - -#define R200_SURF_TILE_COLOR_MACRO (1 << 16) - -/* DEFAULT_SC_BOTTOM_RIGHT bit constants */ -#define DEFAULT_SC_RIGHT_MAX (0x1fff << 0) -#define DEFAULT_SC_BOTTOM_MAX (0x1fff << 16) - -/* MM_INDEX bit constants */ -#define MM_APER 0x80000000 - -/* CLR_CMP_CNTL bit constants */ -#define COMPARE_SRC_FALSE 0x00000000 -#define COMPARE_SRC_TRUE 0x00000001 -#define COMPARE_SRC_NOT_EQUAL 0x00000004 -#define COMPARE_SRC_EQUAL 0x00000005 -#define COMPARE_SRC_EQUAL_FLIP 0x00000007 -#define COMPARE_DST_FALSE 0x00000000 -#define COMPARE_DST_TRUE 0x00000100 -#define COMPARE_DST_NOT_EQUAL 0x00000400 -#define COMPARE_DST_EQUAL 0x00000500 -#define COMPARE_DESTINATION 0x00000000 -#define COMPARE_SOURCE 0x01000000 -#define COMPARE_SRC_AND_DST 0x02000000 - - -/* DP_CNTL bit constants */ -#define DST_X_RIGHT_TO_LEFT 0x00000000 -#define DST_X_LEFT_TO_RIGHT 0x00000001 -#define DST_Y_BOTTOM_TO_TOP 0x00000000 -#define DST_Y_TOP_TO_BOTTOM 0x00000002 -#define DST_X_MAJOR 0x00000000 -#define DST_Y_MAJOR 0x00000004 -#define DST_X_TILE 0x00000008 -#define DST_Y_TILE 0x00000010 -#define DST_LAST_PEL 0x00000020 -#define DST_TRAIL_X_RIGHT_TO_LEFT 0x00000000 -#define DST_TRAIL_X_LEFT_TO_RIGHT 0x00000040 -#define DST_TRAP_FILL_RIGHT_TO_LEFT 0x00000000 -#define DST_TRAP_FILL_LEFT_TO_RIGHT 0x00000080 -#define DST_BRES_SIGN 0x00000100 -#define DST_HOST_BIG_ENDIAN_EN 0x00000200 -#define DST_POLYLINE_NONLAST 0x00008000 -#define DST_RASTER_STALL 0x00010000 -#define DST_POLY_EDGE 0x00040000 - - -/* DP_CNTL_YDIR_XDIR_YMAJOR bit constants (short version of DP_CNTL) */ -#define DST_X_MAJOR_S 0x00000000 -#define DST_Y_MAJOR_S 0x00000001 -#define DST_Y_BOTTOM_TO_TOP_S 0x00000000 -#define DST_Y_TOP_TO_BOTTOM_S 0x00008000 -#define DST_X_RIGHT_TO_LEFT_S 0x00000000 -#define DST_X_LEFT_TO_RIGHT_S 0x80000000 - - -/* DP_DATATYPE bit constants */ -#define DST_8BPP 0x00000002 -#define DST_15BPP 0x00000003 -#define DST_16BPP 0x00000004 -#define DST_24BPP 0x00000005 -#define DST_32BPP 0x00000006 -#define DST_8BPP_RGB332 0x00000007 -#define DST_8BPP_Y8 0x00000008 -#define DST_8BPP_RGB8 0x00000009 -#define DST_16BPP_VYUY422 0x0000000b -#define DST_16BPP_YVYU422 0x0000000c -#define DST_32BPP_AYUV444 0x0000000e -#define DST_16BPP_ARGB4444 0x0000000f -#define BRUSH_SOLIDCOLOR 0x00000d00 -#define SRC_MONO 0x00000000 -#define SRC_MONO_LBKGD 0x00010000 -#define SRC_DSTCOLOR 0x00030000 -#define BYTE_ORDER_MSB_TO_LSB 0x00000000 -#define BYTE_ORDER_LSB_TO_MSB 0x40000000 -#define DP_CONVERSION_TEMP 0x80000000 -#define HOST_BIG_ENDIAN_EN (1 << 29) - - -/* DP_GUI_MASTER_CNTL bit constants */ -#define GMC_SRC_PITCH_OFFSET_DEFAULT 0x00000000 -#define GMC_SRC_PITCH_OFFSET_LEAVE 0x00000001 -#define GMC_DST_PITCH_OFFSET_DEFAULT 0x00000000 -#define GMC_DST_PITCH_OFFSET_LEAVE 0x00000002 -#define GMC_SRC_CLIP_DEFAULT 0x00000000 -#define GMC_SRC_CLIP_LEAVE 0x00000004 -#define GMC_DST_CLIP_DEFAULT 0x00000000 -#define GMC_DST_CLIP_LEAVE 0x00000008 -#define GMC_BRUSH_8x8MONO 0x00000000 -#define GMC_BRUSH_8x8MONO_LBKGD 0x00000010 -#define GMC_BRUSH_8x1MONO 0x00000020 -#define GMC_BRUSH_8x1MONO_LBKGD 0x00000030 -#define GMC_BRUSH_1x8MONO 0x00000040 -#define GMC_BRUSH_1x8MONO_LBKGD 0x00000050 -#define GMC_BRUSH_32x1MONO 0x00000060 -#define GMC_BRUSH_32x1MONO_LBKGD 0x00000070 -#define GMC_BRUSH_32x32MONO 0x00000080 -#define GMC_BRUSH_32x32MONO_LBKGD 0x00000090 -#define GMC_BRUSH_8x8COLOR 0x000000a0 -#define GMC_BRUSH_8x1COLOR 0x000000b0 -#define GMC_BRUSH_1x8COLOR 0x000000c0 -#define GMC_BRUSH_SOLID_COLOR 0x000000d0 -#define GMC_DST_8BPP 0x00000200 -#define GMC_DST_15BPP 0x00000300 -#define GMC_DST_16BPP 0x00000400 -#define GMC_DST_24BPP 0x00000500 -#define GMC_DST_32BPP 0x00000600 -#define GMC_DST_8BPP_RGB332 0x00000700 -#define GMC_DST_8BPP_Y8 0x00000800 -#define GMC_DST_8BPP_RGB8 0x00000900 -#define GMC_DST_16BPP_VYUY422 0x00000b00 -#define GMC_DST_16BPP_YVYU422 0x00000c00 -#define GMC_DST_32BPP_AYUV444 0x00000e00 -#define GMC_DST_16BPP_ARGB4444 0x00000f00 -#define GMC_SRC_MONO 0x00000000 -#define GMC_SRC_MONO_LBKGD 0x00001000 -#define GMC_SRC_DSTCOLOR 0x00003000 -#define GMC_BYTE_ORDER_MSB_TO_LSB 0x00000000 -#define GMC_BYTE_ORDER_LSB_TO_MSB 0x00004000 -#define GMC_DP_CONVERSION_TEMP_9300 0x00008000 -#define GMC_DP_CONVERSION_TEMP_6500 0x00000000 -#define GMC_DP_SRC_RECT 0x02000000 -#define GMC_DP_SRC_HOST 0x03000000 -#define GMC_DP_SRC_HOST_BYTEALIGN 0x04000000 -#define GMC_3D_FCN_EN_CLR 0x00000000 -#define GMC_3D_FCN_EN_SET 0x08000000 -#define GMC_DST_CLR_CMP_FCN_LEAVE 0x00000000 -#define GMC_DST_CLR_CMP_FCN_CLEAR 0x10000000 -#define GMC_AUX_CLIP_LEAVE 0x00000000 -#define GMC_AUX_CLIP_CLEAR 0x20000000 -#define GMC_WRITE_MASK_LEAVE 0x00000000 -#define GMC_WRITE_MASK_SET 0x40000000 -#define GMC_CLR_CMP_CNTL_DIS (1 << 28) -#define GMC_SRC_DATATYPE_COLOR (3 << 12) -#define ROP3_S 0x00cc0000 -#define ROP3_SRCCOPY 0x00cc0000 -#define ROP3_P 0x00f00000 -#define ROP3_PATCOPY 0x00f00000 -#define DP_SRC_SOURCE_MASK (7 << 24) -#define GMC_BRUSH_NONE (15 << 4) -#define DP_SRC_SOURCE_MEMORY (2 << 24) -#define GMC_BRUSH_SOLIDCOLOR 0x000000d0 - -/* DP_MIX bit constants */ -#define DP_SRC_RECT 0x00000200 -#define DP_SRC_HOST 0x00000300 -#define DP_SRC_HOST_BYTEALIGN 0x00000400 - -/* MPLL_CNTL bit constants */ -#define MPLL_RESET 0x00000001 - -/* MDLL_CKO bit constants */ -#define MCKOA_SLEEP 0x00000001 -#define MCKOA_RESET 0x00000002 -#define MCKOA_REF_SKEW_MASK 0x00000700 -#define MCKOA_FB_SKEW_MASK 0x00007000 - -/* MDLL_RDCKA bit constants */ -#define MRDCKA0_SLEEP 0x00000001 -#define MRDCKA0_RESET 0x00000002 -#define MRDCKA1_SLEEP 0x00010000 -#define MRDCKA1_RESET 0x00020000 - -/* VCLK_ECP_CNTL constants */ -#define VCLK_SRC_SEL_MASK 0x03 -#define VCLK_SRC_SEL_CPUCLK 0x00 -#define VCLK_SRC_SEL_PSCANCLK 0x01 -#define VCLK_SRC_SEL_BYTECLK 0x02 -#define VCLK_SRC_SEL_PPLLCLK 0x03 -#define PIXCLK_ALWAYS_ONb 0x00000040 -#define PIXCLK_DAC_ALWAYS_ONb 0x00000080 - -/* BUS_CNTL1 constants */ -#define BUS_CNTL1_MOBILE_PLATFORM_SEL_MASK 0x0c000000 -#define BUS_CNTL1_MOBILE_PLATFORM_SEL_SHIFT 26 -#define BUS_CNTL1_AGPCLK_VALID 0x80000000 - -/* PLL_PWRMGT_CNTL constants */ -#define PLL_PWRMGT_CNTL_SPLL_TURNOFF 0x00000002 -#define PLL_PWRMGT_CNTL_PPLL_TURNOFF 0x00000004 -#define PLL_PWRMGT_CNTL_P2PLL_TURNOFF 0x00000008 -#define PLL_PWRMGT_CNTL_TVPLL_TURNOFF 0x00000010 -#define PLL_PWRMGT_CNTL_MOBILE_SU 0x00010000 -#define PLL_PWRMGT_CNTL_SU_SCLK_USE_BCLK 0x00020000 -#define PLL_PWRMGT_CNTL_SU_MCLK_USE_BCLK 0x00040000 - -/* TV_DAC_CNTL constants */ -#define TV_DAC_CNTL_BGSLEEP 0x00000040 -#define TV_DAC_CNTL_DETECT 0x00000010 -#define TV_DAC_CNTL_BGADJ_MASK 0x000f0000 -#define TV_DAC_CNTL_DACADJ_MASK 0x00f00000 -#define TV_DAC_CNTL_BGADJ__SHIFT 16 -#define TV_DAC_CNTL_DACADJ__SHIFT 20 -#define TV_DAC_CNTL_RDACPD 0x01000000 -#define TV_DAC_CNTL_GDACPD 0x02000000 -#define TV_DAC_CNTL_BDACPD 0x04000000 - -/* DISP_MISC_CNTL constants */ -#define DISP_MISC_CNTL_SOFT_RESET_GRPH_PP (1 << 0) -#define DISP_MISC_CNTL_SOFT_RESET_SUBPIC_PP (1 << 1) -#define DISP_MISC_CNTL_SOFT_RESET_OV0_PP (1 << 2) -#define DISP_MISC_CNTL_SOFT_RESET_GRPH_SCLK (1 << 4) -#define DISP_MISC_CNTL_SOFT_RESET_SUBPIC_SCLK (1 << 5) -#define DISP_MISC_CNTL_SOFT_RESET_OV0_SCLK (1 << 6) -#define DISP_MISC_CNTL_SOFT_RESET_GRPH2_PP (1 << 12) -#define DISP_MISC_CNTL_SOFT_RESET_GRPH2_SCLK (1 << 15) -#define DISP_MISC_CNTL_SOFT_RESET_LVDS (1 << 16) -#define DISP_MISC_CNTL_SOFT_RESET_TMDS (1 << 17) -#define DISP_MISC_CNTL_SOFT_RESET_DIG_TMDS (1 << 18) -#define DISP_MISC_CNTL_SOFT_RESET_TV (1 << 19) - -/* DISP_PWR_MAN constants */ -#define DISP_PWR_MAN_DISP_PWR_MAN_D3_CRTC_EN (1 << 0) -#define DISP_PWR_MAN_DISP2_PWR_MAN_D3_CRTC2_EN (1 << 4) -#define DISP_PWR_MAN_DISP_D3_RST (1 << 16) -#define DISP_PWR_MAN_DISP_D3_REG_RST (1 << 17) -#define DISP_PWR_MAN_DISP_D3_GRPH_RST (1 << 18) -#define DISP_PWR_MAN_DISP_D3_SUBPIC_RST (1 << 19) -#define DISP_PWR_MAN_DISP_D3_OV0_RST (1 << 20) -#define DISP_PWR_MAN_DISP_D1D2_GRPH_RST (1 << 21) -#define DISP_PWR_MAN_DISP_D1D2_SUBPIC_RST (1 << 22) -#define DISP_PWR_MAN_DISP_D1D2_OV0_RST (1 << 23) -#define DISP_PWR_MAN_DIG_TMDS_ENABLE_RST (1 << 24) -#define DISP_PWR_MAN_TV_ENABLE_RST (1 << 25) -#define DISP_PWR_MAN_AUTO_PWRUP_EN (1 << 26) - -/* masks */ - -#define CONFIG_MEMSIZE_MASK 0x1f000000 -#define MEM_CFG_TYPE 0x40000000 -#define DST_OFFSET_MASK 0x003fffff -#define DST_PITCH_MASK 0x3fc00000 -#define DEFAULT_TILE_MASK 0xc0000000 -#define PPLL_DIV_SEL_MASK 0x00000300 -#define PPLL_RESET 0x00000001 -#define PPLL_SLEEP 0x00000002 -#define PPLL_ATOMIC_UPDATE_EN 0x00010000 -#define PPLL_REF_DIV_MASK 0x000003ff -#define PPLL_FB3_DIV_MASK 0x000007ff -#define PPLL_POST3_DIV_MASK 0x00070000 -#define PPLL_ATOMIC_UPDATE_R 0x00008000 -#define PPLL_ATOMIC_UPDATE_W 0x00008000 -#define PPLL_VGA_ATOMIC_UPDATE_EN 0x00020000 -#define R300_PPLL_REF_DIV_ACC_MASK (0x3ff << 18) -#define R300_PPLL_REF_DIV_ACC_SHIFT 18 - -#define GUI_ACTIVE 0x80000000 - - -#define MC_IND_INDEX 0x01F8 -#define MC_IND_DATA 0x01FC - -/* PAD_CTLR_STRENGTH */ -#define PAD_MANUAL_OVERRIDE 0x80000000 - -/* pllCLK_PIN_CNTL */ -#define CLK_PIN_CNTL__OSC_EN_MASK 0x00000001L -#define CLK_PIN_CNTL__OSC_EN 0x00000001L -#define CLK_PIN_CNTL__XTL_LOW_GAIN_MASK 0x00000004L -#define CLK_PIN_CNTL__XTL_LOW_GAIN 0x00000004L -#define CLK_PIN_CNTL__DONT_USE_XTALIN_MASK 0x00000010L -#define CLK_PIN_CNTL__DONT_USE_XTALIN 0x00000010L -#define CLK_PIN_CNTL__SLOW_CLOCK_SOURCE_MASK 0x00000020L -#define CLK_PIN_CNTL__SLOW_CLOCK_SOURCE 0x00000020L -#define CLK_PIN_CNTL__CG_CLK_TO_OUTPIN_MASK 0x00000800L -#define CLK_PIN_CNTL__CG_CLK_TO_OUTPIN 0x00000800L -#define CLK_PIN_CNTL__CG_COUNT_UP_TO_OUTPIN_MASK 0x00001000L -#define CLK_PIN_CNTL__CG_COUNT_UP_TO_OUTPIN 0x00001000L -#define CLK_PIN_CNTL__ACCESS_REGS_IN_SUSPEND_MASK 0x00002000L -#define CLK_PIN_CNTL__ACCESS_REGS_IN_SUSPEND 0x00002000L -#define CLK_PIN_CNTL__CG_SPARE_MASK 0x00004000L -#define CLK_PIN_CNTL__CG_SPARE 0x00004000L -#define CLK_PIN_CNTL__SCLK_DYN_START_CNTL_MASK 0x00008000L -#define CLK_PIN_CNTL__SCLK_DYN_START_CNTL 0x00008000L -#define CLK_PIN_CNTL__CP_CLK_RUNNING_MASK 0x00010000L -#define CLK_PIN_CNTL__CP_CLK_RUNNING 0x00010000L -#define CLK_PIN_CNTL__CG_SPARE_RD_MASK 0x00060000L -#define CLK_PIN_CNTL__XTALIN_ALWAYS_ONb_MASK 0x00080000L -#define CLK_PIN_CNTL__XTALIN_ALWAYS_ONb 0x00080000L -#define CLK_PIN_CNTL__PWRSEQ_DELAY_MASK 0xff000000L - -/* pllCLK_PWRMGT_CNTL */ -#define CLK_PWRMGT_CNTL__MPLL_PWRMGT_OFF__SHIFT 0x00000000 -#define CLK_PWRMGT_CNTL__SPLL_PWRMGT_OFF__SHIFT 0x00000001 -#define CLK_PWRMGT_CNTL__PPLL_PWRMGT_OFF__SHIFT 0x00000002 -#define CLK_PWRMGT_CNTL__P2PLL_PWRMGT_OFF__SHIFT 0x00000003 -#define CLK_PWRMGT_CNTL__MCLK_TURNOFF__SHIFT 0x00000004 -#define CLK_PWRMGT_CNTL__SCLK_TURNOFF__SHIFT 0x00000005 -#define CLK_PWRMGT_CNTL__PCLK_TURNOFF__SHIFT 0x00000006 -#define CLK_PWRMGT_CNTL__P2CLK_TURNOFF__SHIFT 0x00000007 -#define CLK_PWRMGT_CNTL__MC_CH_MODE__SHIFT 0x00000008 -#define CLK_PWRMGT_CNTL__TEST_MODE__SHIFT 0x00000009 -#define CLK_PWRMGT_CNTL__GLOBAL_PMAN_EN__SHIFT 0x0000000a -#define CLK_PWRMGT_CNTL__ENGINE_DYNCLK_MODE__SHIFT 0x0000000c -#define CLK_PWRMGT_CNTL__ACTIVE_HILO_LAT__SHIFT 0x0000000d -#define CLK_PWRMGT_CNTL__DISP_DYN_STOP_LAT__SHIFT 0x0000000f -#define CLK_PWRMGT_CNTL__MC_BUSY__SHIFT 0x00000010 -#define CLK_PWRMGT_CNTL__MC_INT_CNTL__SHIFT 0x00000011 -#define CLK_PWRMGT_CNTL__MC_SWITCH__SHIFT 0x00000012 -#define CLK_PWRMGT_CNTL__DLL_READY__SHIFT 0x00000013 -#define CLK_PWRMGT_CNTL__DISP_PM__SHIFT 0x00000014 -#define CLK_PWRMGT_CNTL__DYN_STOP_MODE__SHIFT 0x00000015 -#define CLK_PWRMGT_CNTL__CG_NO1_DEBUG__SHIFT 0x00000018 -#define CLK_PWRMGT_CNTL__TVPLL_PWRMGT_OFF__SHIFT 0x0000001e -#define CLK_PWRMGT_CNTL__TVCLK_TURNOFF__SHIFT 0x0000001f - -/* pllP2PLL_CNTL */ -#define P2PLL_CNTL__P2PLL_RESET_MASK 0x00000001L -#define P2PLL_CNTL__P2PLL_RESET 0x00000001L -#define P2PLL_CNTL__P2PLL_SLEEP_MASK 0x00000002L -#define P2PLL_CNTL__P2PLL_SLEEP 0x00000002L -#define P2PLL_CNTL__P2PLL_TST_EN_MASK 0x00000004L -#define P2PLL_CNTL__P2PLL_TST_EN 0x00000004L -#define P2PLL_CNTL__P2PLL_REFCLK_SEL_MASK 0x00000010L -#define P2PLL_CNTL__P2PLL_REFCLK_SEL 0x00000010L -#define P2PLL_CNTL__P2PLL_FBCLK_SEL_MASK 0x00000020L -#define P2PLL_CNTL__P2PLL_FBCLK_SEL 0x00000020L -#define P2PLL_CNTL__P2PLL_TCPOFF_MASK 0x00000040L -#define P2PLL_CNTL__P2PLL_TCPOFF 0x00000040L -#define P2PLL_CNTL__P2PLL_TVCOMAX_MASK 0x00000080L -#define P2PLL_CNTL__P2PLL_TVCOMAX 0x00000080L -#define P2PLL_CNTL__P2PLL_PCP_MASK 0x00000700L -#define P2PLL_CNTL__P2PLL_PVG_MASK 0x00003800L -#define P2PLL_CNTL__P2PLL_PDC_MASK 0x0000c000L -#define P2PLL_CNTL__P2PLL_ATOMIC_UPDATE_EN_MASK 0x00010000L -#define P2PLL_CNTL__P2PLL_ATOMIC_UPDATE_EN 0x00010000L -#define P2PLL_CNTL__P2PLL_ATOMIC_UPDATE_SYNC_MASK 0x00040000L -#define P2PLL_CNTL__P2PLL_ATOMIC_UPDATE_SYNC 0x00040000L -#define P2PLL_CNTL__P2PLL_DISABLE_AUTO_RESET_MASK 0x00080000L -#define P2PLL_CNTL__P2PLL_DISABLE_AUTO_RESET 0x00080000L - -/* pllPIXCLKS_CNTL */ -#define PIXCLKS_CNTL__PIX2CLK_SRC_SEL__SHIFT 0x00000000 -#define PIXCLKS_CNTL__PIX2CLK_INVERT__SHIFT 0x00000004 -#define PIXCLKS_CNTL__PIX2CLK_SRC_INVERT__SHIFT 0x00000005 -#define PIXCLKS_CNTL__PIX2CLK_ALWAYS_ONb__SHIFT 0x00000006 -#define PIXCLKS_CNTL__PIX2CLK_DAC_ALWAYS_ONb__SHIFT 0x00000007 -#define PIXCLKS_CNTL__PIXCLK_TV_SRC_SEL__SHIFT 0x00000008 -#define PIXCLKS_CNTL__PIXCLK_BLEND_ALWAYS_ONb__SHIFT 0x0000000b -#define PIXCLKS_CNTL__PIXCLK_GV_ALWAYS_ONb__SHIFT 0x0000000c -#define PIXCLKS_CNTL__PIXCLK_DIG_TMDS_ALWAYS_ONb__SHIFT 0x0000000d -#define PIXCLKS_CNTL__PIXCLK_LVDS_ALWAYS_ONb__SHIFT 0x0000000e -#define PIXCLKS_CNTL__PIXCLK_TMDS_ALWAYS_ONb__SHIFT 0x0000000f - - -/* pllPIXCLKS_CNTL */ -#define PIXCLKS_CNTL__PIX2CLK_SRC_SEL_MASK 0x00000003L -#define PIXCLKS_CNTL__PIX2CLK_INVERT 0x00000010L -#define PIXCLKS_CNTL__PIX2CLK_SRC_INVERT 0x00000020L -#define PIXCLKS_CNTL__PIX2CLK_ALWAYS_ONb 0x00000040L -#define PIXCLKS_CNTL__PIX2CLK_DAC_ALWAYS_ONb 0x00000080L -#define PIXCLKS_CNTL__PIXCLK_TV_SRC_SEL 0x00000100L -#define PIXCLKS_CNTL__PIXCLK_BLEND_ALWAYS_ONb 0x00000800L -#define PIXCLKS_CNTL__PIXCLK_GV_ALWAYS_ONb 0x00001000L -#define PIXCLKS_CNTL__PIXCLK_DIG_TMDS_ALWAYS_ONb 0x00002000L -#define PIXCLKS_CNTL__PIXCLK_LVDS_ALWAYS_ONb 0x00004000L -#define PIXCLKS_CNTL__PIXCLK_TMDS_ALWAYS_ONb 0x00008000L -#define PIXCLKS_CNTL__DISP_TVOUT_PIXCLK_TV_ALWAYS_ONb (1 << 9) -#define PIXCLKS_CNTL__R300_DVOCLK_ALWAYS_ONb (1 << 10) -#define PIXCLKS_CNTL__R300_PIXCLK_DVO_ALWAYS_ONb (1 << 13) -#define PIXCLKS_CNTL__R300_PIXCLK_TRANS_ALWAYS_ONb (1 << 16) -#define PIXCLKS_CNTL__R300_PIXCLK_TVO_ALWAYS_ONb (1 << 17) -#define PIXCLKS_CNTL__R300_P2G2CLK_ALWAYS_ONb (1 << 18) -#define PIXCLKS_CNTL__R300_P2G2CLK_DAC_ALWAYS_ONb (1 << 19) -#define PIXCLKS_CNTL__R300_DISP_DAC_PIXCLK_DAC2_BLANK_OFF (1 << 23) - - -/* pllP2PLL_DIV_0 */ -#define P2PLL_DIV_0__P2PLL_FB_DIV_MASK 0x000007ffL -#define P2PLL_DIV_0__P2PLL_ATOMIC_UPDATE_W_MASK 0x00008000L -#define P2PLL_DIV_0__P2PLL_ATOMIC_UPDATE_W 0x00008000L -#define P2PLL_DIV_0__P2PLL_ATOMIC_UPDATE_R_MASK 0x00008000L -#define P2PLL_DIV_0__P2PLL_ATOMIC_UPDATE_R 0x00008000L -#define P2PLL_DIV_0__P2PLL_POST_DIV_MASK 0x00070000L - -/* pllSCLK_CNTL */ -#define SCLK_CNTL__SCLK_SRC_SEL_MASK 0x00000007L -#define SCLK_CNTL__CP_MAX_DYN_STOP_LAT 0x00000008L -#define SCLK_CNTL__HDP_MAX_DYN_STOP_LAT 0x00000010L -#define SCLK_CNTL__TV_MAX_DYN_STOP_LAT 0x00000020L -#define SCLK_CNTL__E2_MAX_DYN_STOP_LAT 0x00000040L -#define SCLK_CNTL__SE_MAX_DYN_STOP_LAT 0x00000080L -#define SCLK_CNTL__IDCT_MAX_DYN_STOP_LAT 0x00000100L -#define SCLK_CNTL__VIP_MAX_DYN_STOP_LAT 0x00000200L -#define SCLK_CNTL__RE_MAX_DYN_STOP_LAT 0x00000400L -#define SCLK_CNTL__PB_MAX_DYN_STOP_LAT 0x00000800L -#define SCLK_CNTL__TAM_MAX_DYN_STOP_LAT 0x00001000L -#define SCLK_CNTL__TDM_MAX_DYN_STOP_LAT 0x00002000L -#define SCLK_CNTL__RB_MAX_DYN_STOP_LAT 0x00004000L -#define SCLK_CNTL__DYN_STOP_LAT_MASK 0x00007ff8 -#define SCLK_CNTL__FORCE_DISP2 0x00008000L -#define SCLK_CNTL__FORCE_CP 0x00010000L -#define SCLK_CNTL__FORCE_HDP 0x00020000L -#define SCLK_CNTL__FORCE_DISP1 0x00040000L -#define SCLK_CNTL__FORCE_TOP 0x00080000L -#define SCLK_CNTL__FORCE_E2 0x00100000L -#define SCLK_CNTL__FORCE_SE 0x00200000L -#define SCLK_CNTL__FORCE_IDCT 0x00400000L -#define SCLK_CNTL__FORCE_VIP 0x00800000L -#define SCLK_CNTL__FORCE_RE 0x01000000L -#define SCLK_CNTL__FORCE_PB 0x02000000L -#define SCLK_CNTL__FORCE_TAM 0x04000000L -#define SCLK_CNTL__FORCE_TDM 0x08000000L -#define SCLK_CNTL__FORCE_RB 0x10000000L -#define SCLK_CNTL__FORCE_TV_SCLK 0x20000000L -#define SCLK_CNTL__FORCE_SUBPIC 0x40000000L -#define SCLK_CNTL__FORCE_OV0 0x80000000L -#define SCLK_CNTL__R300_FORCE_VAP (1<<21) -#define SCLK_CNTL__R300_FORCE_SR (1<<25) -#define SCLK_CNTL__R300_FORCE_PX (1<<26) -#define SCLK_CNTL__R300_FORCE_TX (1<<27) -#define SCLK_CNTL__R300_FORCE_US (1<<28) -#define SCLK_CNTL__R300_FORCE_SU (1<<30) -#define SCLK_CNTL__FORCEON_MASK 0xffff8000L - -/* pllSCLK_CNTL2 */ -#define SCLK_CNTL2__R300_TCL_MAX_DYN_STOP_LAT (1<<10) -#define SCLK_CNTL2__R300_GA_MAX_DYN_STOP_LAT (1<<11) -#define SCLK_CNTL2__R300_CBA_MAX_DYN_STOP_LAT (1<<12) -#define SCLK_CNTL2__R300_FORCE_TCL (1<<13) -#define SCLK_CNTL2__R300_FORCE_CBA (1<<14) -#define SCLK_CNTL2__R300_FORCE_GA (1<<15) - -/* SCLK_MORE_CNTL */ -#define SCLK_MORE_CNTL__DISPREGS_MAX_DYN_STOP_LAT 0x00000001L -#define SCLK_MORE_CNTL__MC_GUI_MAX_DYN_STOP_LAT 0x00000002L -#define SCLK_MORE_CNTL__MC_HOST_MAX_DYN_STOP_LAT 0x00000004L -#define SCLK_MORE_CNTL__FORCE_DISPREGS 0x00000100L -#define SCLK_MORE_CNTL__FORCE_MC_GUI 0x00000200L -#define SCLK_MORE_CNTL__FORCE_MC_HOST 0x00000400L -#define SCLK_MORE_CNTL__STOP_SCLK_EN 0x00001000L -#define SCLK_MORE_CNTL__STOP_SCLK_A 0x00002000L -#define SCLK_MORE_CNTL__STOP_SCLK_B 0x00004000L -#define SCLK_MORE_CNTL__STOP_SCLK_C 0x00008000L -#define SCLK_MORE_CNTL__HALF_SPEED_SCLK 0x00010000L -#define SCLK_MORE_CNTL__IO_CG_VOLTAGE_DROP 0x00020000L -#define SCLK_MORE_CNTL__TVFB_SOFT_RESET 0x00040000L -#define SCLK_MORE_CNTL__VOLTAGE_DROP_SYNC 0x00080000L -#define SCLK_MORE_CNTL__IDLE_DELAY_HALF_SCLK 0x00400000L -#define SCLK_MORE_CNTL__AGP_BUSY_HALF_SCLK 0x00800000L -#define SCLK_MORE_CNTL__CG_SPARE_RD_C_MASK 0xff000000L -#define SCLK_MORE_CNTL__FORCEON 0x00000700L - -/* MCLK_CNTL */ -#define MCLK_CNTL__MCLKA_SRC_SEL_MASK 0x00000007L -#define MCLK_CNTL__YCLKA_SRC_SEL_MASK 0x00000070L -#define MCLK_CNTL__MCLKB_SRC_SEL_MASK 0x00000700L -#define MCLK_CNTL__YCLKB_SRC_SEL_MASK 0x00007000L -#define MCLK_CNTL__FORCE_MCLKA_MASK 0x00010000L -#define MCLK_CNTL__FORCE_MCLKA 0x00010000L -#define MCLK_CNTL__FORCE_MCLKB_MASK 0x00020000L -#define MCLK_CNTL__FORCE_MCLKB 0x00020000L -#define MCLK_CNTL__FORCE_YCLKA_MASK 0x00040000L -#define MCLK_CNTL__FORCE_YCLKA 0x00040000L -#define MCLK_CNTL__FORCE_YCLKB_MASK 0x00080000L -#define MCLK_CNTL__FORCE_YCLKB 0x00080000L -#define MCLK_CNTL__FORCE_MC_MASK 0x00100000L -#define MCLK_CNTL__FORCE_MC 0x00100000L -#define MCLK_CNTL__FORCE_AIC_MASK 0x00200000L -#define MCLK_CNTL__FORCE_AIC 0x00200000L -#define MCLK_CNTL__MRDCKA0_SOUTSEL_MASK 0x03000000L -#define MCLK_CNTL__MRDCKA1_SOUTSEL_MASK 0x0c000000L -#define MCLK_CNTL__MRDCKB0_SOUTSEL_MASK 0x30000000L -#define MCLK_CNTL__MRDCKB1_SOUTSEL_MASK 0xc0000000L -#define MCLK_CNTL__R300_DISABLE_MC_MCLKA (1 << 21) -#define MCLK_CNTL__R300_DISABLE_MC_MCLKB (1 << 21) - -/* MCLK_MISC */ -#define MCLK_MISC__SCLK_SOURCED_FROM_MPLL_SEL_MASK 0x00000003L -#define MCLK_MISC__MCLK_FROM_SPLL_DIV_SEL_MASK 0x00000004L -#define MCLK_MISC__MCLK_FROM_SPLL_DIV_SEL 0x00000004L -#define MCLK_MISC__ENABLE_SCLK_FROM_MPLL_MASK 0x00000008L -#define MCLK_MISC__ENABLE_SCLK_FROM_MPLL 0x00000008L -#define MCLK_MISC__MPLL_MODEA_MODEC_HW_SEL_EN_MASK 0x00000010L -#define MCLK_MISC__MPLL_MODEA_MODEC_HW_SEL_EN 0x00000010L -#define MCLK_MISC__DLL_READY_LAT_MASK 0x00000100L -#define MCLK_MISC__DLL_READY_LAT 0x00000100L -#define MCLK_MISC__MC_MCLK_MAX_DYN_STOP_LAT_MASK 0x00001000L -#define MCLK_MISC__MC_MCLK_MAX_DYN_STOP_LAT 0x00001000L -#define MCLK_MISC__IO_MCLK_MAX_DYN_STOP_LAT_MASK 0x00002000L -#define MCLK_MISC__IO_MCLK_MAX_DYN_STOP_LAT 0x00002000L -#define MCLK_MISC__MC_MCLK_DYN_ENABLE_MASK 0x00004000L -#define MCLK_MISC__MC_MCLK_DYN_ENABLE 0x00004000L -#define MCLK_MISC__IO_MCLK_DYN_ENABLE_MASK 0x00008000L -#define MCLK_MISC__IO_MCLK_DYN_ENABLE 0x00008000L -#define MCLK_MISC__CGM_CLK_TO_OUTPIN_MASK 0x00010000L -#define MCLK_MISC__CGM_CLK_TO_OUTPIN 0x00010000L -#define MCLK_MISC__CLK_OR_COUNT_SEL_MASK 0x00020000L -#define MCLK_MISC__CLK_OR_COUNT_SEL 0x00020000L -#define MCLK_MISC__EN_MCLK_TRISTATE_IN_SUSPEND_MASK 0x00040000L -#define MCLK_MISC__EN_MCLK_TRISTATE_IN_SUSPEND 0x00040000L -#define MCLK_MISC__CGM_SPARE_RD_MASK 0x00300000L -#define MCLK_MISC__CGM_SPARE_A_RD_MASK 0x00c00000L -#define MCLK_MISC__TCLK_TO_YCLKB_EN_MASK 0x01000000L -#define MCLK_MISC__TCLK_TO_YCLKB_EN 0x01000000L -#define MCLK_MISC__CGM_SPARE_A_MASK 0x0e000000L - -/* VCLK_ECP_CNTL */ -#define VCLK_ECP_CNTL__VCLK_SRC_SEL_MASK 0x00000003L -#define VCLK_ECP_CNTL__VCLK_INVERT 0x00000010L -#define VCLK_ECP_CNTL__PIXCLK_SRC_INVERT 0x00000020L -#define VCLK_ECP_CNTL__PIXCLK_ALWAYS_ONb 0x00000040L -#define VCLK_ECP_CNTL__PIXCLK_DAC_ALWAYS_ONb 0x00000080L -#define VCLK_ECP_CNTL__ECP_DIV_MASK 0x00000300L -#define VCLK_ECP_CNTL__ECP_FORCE_ON 0x00040000L -#define VCLK_ECP_CNTL__SUBCLK_FORCE_ON 0x00080000L -#define VCLK_ECP_CNTL__R300_DISP_DAC_PIXCLK_DAC_BLANK_OFF (1<<23) - -/* PLL_PWRMGT_CNTL */ -#define PLL_PWRMGT_CNTL__MPLL_TURNOFF_MASK 0x00000001L -#define PLL_PWRMGT_CNTL__MPLL_TURNOFF 0x00000001L -#define PLL_PWRMGT_CNTL__SPLL_TURNOFF_MASK 0x00000002L -#define PLL_PWRMGT_CNTL__SPLL_TURNOFF 0x00000002L -#define PLL_PWRMGT_CNTL__PPLL_TURNOFF_MASK 0x00000004L -#define PLL_PWRMGT_CNTL__PPLL_TURNOFF 0x00000004L -#define PLL_PWRMGT_CNTL__P2PLL_TURNOFF_MASK 0x00000008L -#define PLL_PWRMGT_CNTL__P2PLL_TURNOFF 0x00000008L -#define PLL_PWRMGT_CNTL__TVPLL_TURNOFF_MASK 0x00000010L -#define PLL_PWRMGT_CNTL__TVPLL_TURNOFF 0x00000010L -#define PLL_PWRMGT_CNTL__AGPCLK_DYN_STOP_LAT_MASK 0x000001e0L -#define PLL_PWRMGT_CNTL__APM_POWER_STATE_MASK 0x00000600L -#define PLL_PWRMGT_CNTL__APM_PWRSTATE_RD_MASK 0x00001800L -#define PLL_PWRMGT_CNTL__PM_MODE_SEL_MASK 0x00002000L -#define PLL_PWRMGT_CNTL__PM_MODE_SEL 0x00002000L -#define PLL_PWRMGT_CNTL__EN_PWRSEQ_DONE_COND_MASK 0x00004000L -#define PLL_PWRMGT_CNTL__EN_PWRSEQ_DONE_COND 0x00004000L -#define PLL_PWRMGT_CNTL__EN_DISP_PARKED_COND_MASK 0x00008000L -#define PLL_PWRMGT_CNTL__EN_DISP_PARKED_COND 0x00008000L -#define PLL_PWRMGT_CNTL__MOBILE_SU_MASK 0x00010000L -#define PLL_PWRMGT_CNTL__MOBILE_SU 0x00010000L -#define PLL_PWRMGT_CNTL__SU_SCLK_USE_BCLK_MASK 0x00020000L -#define PLL_PWRMGT_CNTL__SU_SCLK_USE_BCLK 0x00020000L -#define PLL_PWRMGT_CNTL__SU_MCLK_USE_BCLK_MASK 0x00040000L -#define PLL_PWRMGT_CNTL__SU_MCLK_USE_BCLK 0x00040000L -#define PLL_PWRMGT_CNTL__SU_SUSTAIN_DISABLE_MASK 0x00080000L -#define PLL_PWRMGT_CNTL__SU_SUSTAIN_DISABLE 0x00080000L -#define PLL_PWRMGT_CNTL__TCL_BYPASS_DISABLE_MASK 0x00100000L -#define PLL_PWRMGT_CNTL__TCL_BYPASS_DISABLE 0x00100000L -#define PLL_PWRMGT_CNTL__TCL_CLOCK_CTIVE_RD_MASK 0x00200000L -#define PLL_PWRMGT_CNTL__TCL_CLOCK_ACTIVE_RD 0x00200000L -#define PLL_PWRMGT_CNTL__CG_NO2_DEBUG_MASK 0xff000000L - -/* CLK_PWRMGT_CNTL */ -#define CLK_PWRMGT_CNTL__MPLL_PWRMGT_OFF_MASK 0x00000001L -#define CLK_PWRMGT_CNTL__MPLL_PWRMGT_OFF 0x00000001L -#define CLK_PWRMGT_CNTL__SPLL_PWRMGT_OFF_MASK 0x00000002L -#define CLK_PWRMGT_CNTL__SPLL_PWRMGT_OFF 0x00000002L -#define CLK_PWRMGT_CNTL__PPLL_PWRMGT_OFF_MASK 0x00000004L -#define CLK_PWRMGT_CNTL__PPLL_PWRMGT_OFF 0x00000004L -#define CLK_PWRMGT_CNTL__P2PLL_PWRMGT_OFF_MASK 0x00000008L -#define CLK_PWRMGT_CNTL__P2PLL_PWRMGT_OFF 0x00000008L -#define CLK_PWRMGT_CNTL__MCLK_TURNOFF_MASK 0x00000010L -#define CLK_PWRMGT_CNTL__MCLK_TURNOFF 0x00000010L -#define CLK_PWRMGT_CNTL__SCLK_TURNOFF_MASK 0x00000020L -#define CLK_PWRMGT_CNTL__SCLK_TURNOFF 0x00000020L -#define CLK_PWRMGT_CNTL__PCLK_TURNOFF_MASK 0x00000040L -#define CLK_PWRMGT_CNTL__PCLK_TURNOFF 0x00000040L -#define CLK_PWRMGT_CNTL__P2CLK_TURNOFF_MASK 0x00000080L -#define CLK_PWRMGT_CNTL__P2CLK_TURNOFF 0x00000080L -#define CLK_PWRMGT_CNTL__MC_CH_MODE_MASK 0x00000100L -#define CLK_PWRMGT_CNTL__MC_CH_MODE 0x00000100L -#define CLK_PWRMGT_CNTL__TEST_MODE_MASK 0x00000200L -#define CLK_PWRMGT_CNTL__TEST_MODE 0x00000200L -#define CLK_PWRMGT_CNTL__GLOBAL_PMAN_EN_MASK 0x00000400L -#define CLK_PWRMGT_CNTL__GLOBAL_PMAN_EN 0x00000400L -#define CLK_PWRMGT_CNTL__ENGINE_DYNCLK_MODE_MASK 0x00001000L -#define CLK_PWRMGT_CNTL__ENGINE_DYNCLK_MODE 0x00001000L -#define CLK_PWRMGT_CNTL__ACTIVE_HILO_LAT_MASK 0x00006000L -#define CLK_PWRMGT_CNTL__DISP_DYN_STOP_LAT_MASK 0x00008000L -#define CLK_PWRMGT_CNTL__DISP_DYN_STOP_LAT 0x00008000L -#define CLK_PWRMGT_CNTL__MC_BUSY_MASK 0x00010000L -#define CLK_PWRMGT_CNTL__MC_BUSY 0x00010000L -#define CLK_PWRMGT_CNTL__MC_INT_CNTL_MASK 0x00020000L -#define CLK_PWRMGT_CNTL__MC_INT_CNTL 0x00020000L -#define CLK_PWRMGT_CNTL__MC_SWITCH_MASK 0x00040000L -#define CLK_PWRMGT_CNTL__MC_SWITCH 0x00040000L -#define CLK_PWRMGT_CNTL__DLL_READY_MASK 0x00080000L -#define CLK_PWRMGT_CNTL__DLL_READY 0x00080000L -#define CLK_PWRMGT_CNTL__DISP_PM_MASK 0x00100000L -#define CLK_PWRMGT_CNTL__DISP_PM 0x00100000L -#define CLK_PWRMGT_CNTL__DYN_STOP_MODE_MASK 0x00e00000L -#define CLK_PWRMGT_CNTL__CG_NO1_DEBUG_MASK 0x3f000000L -#define CLK_PWRMGT_CNTL__TVPLL_PWRMGT_OFF_MASK 0x40000000L -#define CLK_PWRMGT_CNTL__TVPLL_PWRMGT_OFF 0x40000000L -#define CLK_PWRMGT_CNTL__TVCLK_TURNOFF_MASK 0x80000000L -#define CLK_PWRMGT_CNTL__TVCLK_TURNOFF 0x80000000L - -/* BUS_CNTL1 */ -#define BUS_CNTL1__PMI_IO_DISABLE_MASK 0x00000001L -#define BUS_CNTL1__PMI_IO_DISABLE 0x00000001L -#define BUS_CNTL1__PMI_MEM_DISABLE_MASK 0x00000002L -#define BUS_CNTL1__PMI_MEM_DISABLE 0x00000002L -#define BUS_CNTL1__PMI_BM_DISABLE_MASK 0x00000004L -#define BUS_CNTL1__PMI_BM_DISABLE 0x00000004L -#define BUS_CNTL1__PMI_INT_DISABLE_MASK 0x00000008L -#define BUS_CNTL1__PMI_INT_DISABLE 0x00000008L -#define BUS_CNTL1__BUS2_IMMEDIATE_PMI_DISABLE_MASK 0x00000020L -#define BUS_CNTL1__BUS2_IMMEDIATE_PMI_DISABLE 0x00000020L -#define BUS_CNTL1__BUS2_VGA_REG_COHERENCY_DIS_MASK 0x00000100L -#define BUS_CNTL1__BUS2_VGA_REG_COHERENCY_DIS 0x00000100L -#define BUS_CNTL1__BUS2_VGA_MEM_COHERENCY_DIS_MASK 0x00000200L -#define BUS_CNTL1__BUS2_VGA_MEM_COHERENCY_DIS 0x00000200L -#define BUS_CNTL1__BUS2_HDP_REG_COHERENCY_DIS_MASK 0x00000400L -#define BUS_CNTL1__BUS2_HDP_REG_COHERENCY_DIS 0x00000400L -#define BUS_CNTL1__BUS2_GUI_INITIATOR_COHERENCY_DIS_MASK 0x00000800L -#define BUS_CNTL1__BUS2_GUI_INITIATOR_COHERENCY_DIS 0x00000800L -#define BUS_CNTL1__MOBILE_PLATFORM_SEL_MASK 0x0c000000L -#define BUS_CNTL1__SEND_SBA_LATENCY_MASK 0x70000000L -#define BUS_CNTL1__AGPCLK_VALID_MASK 0x80000000L -#define BUS_CNTL1__AGPCLK_VALID 0x80000000L - -/* BUS_CNTL1 */ -#define BUS_CNTL1__PMI_IO_DISABLE__SHIFT 0x00000000 -#define BUS_CNTL1__PMI_MEM_DISABLE__SHIFT 0x00000001 -#define BUS_CNTL1__PMI_BM_DISABLE__SHIFT 0x00000002 -#define BUS_CNTL1__PMI_INT_DISABLE__SHIFT 0x00000003 -#define BUS_CNTL1__BUS2_IMMEDIATE_PMI_DISABLE__SHIFT 0x00000005 -#define BUS_CNTL1__BUS2_VGA_REG_COHERENCY_DIS__SHIFT 0x00000008 -#define BUS_CNTL1__BUS2_VGA_MEM_COHERENCY_DIS__SHIFT 0x00000009 -#define BUS_CNTL1__BUS2_HDP_REG_COHERENCY_DIS__SHIFT 0x0000000a -#define BUS_CNTL1__BUS2_GUI_INITIATOR_COHERENCY_DIS__SHIFT 0x0000000b -#define BUS_CNTL1__MOBILE_PLATFORM_SEL__SHIFT 0x0000001a -#define BUS_CNTL1__SEND_SBA_LATENCY__SHIFT 0x0000001c -#define BUS_CNTL1__AGPCLK_VALID__SHIFT 0x0000001f - -/* CRTC_OFFSET_CNTL */ -#define CRTC_OFFSET_CNTL__CRTC_TILE_LINE_MASK 0x0000000fL -#define CRTC_OFFSET_CNTL__CRTC_TILE_LINE_RIGHT_MASK 0x000000f0L -#define CRTC_OFFSET_CNTL__CRTC_TILE_EN_RIGHT_MASK 0x00004000L -#define CRTC_OFFSET_CNTL__CRTC_TILE_EN_RIGHT 0x00004000L -#define CRTC_OFFSET_CNTL__CRTC_TILE_EN_MASK 0x00008000L -#define CRTC_OFFSET_CNTL__CRTC_TILE_EN 0x00008000L -#define CRTC_OFFSET_CNTL__CRTC_OFFSET_FLIP_CNTL_MASK 0x00010000L -#define CRTC_OFFSET_CNTL__CRTC_OFFSET_FLIP_CNTL 0x00010000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_OFFSET_EN_MASK 0x00020000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_OFFSET_EN 0x00020000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_SYNC_EN_MASK 0x000c0000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_SYNC_OUT_EN_MASK 0x00100000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_SYNC_OUT_EN 0x00100000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_SYNC_MASK 0x00200000L -#define CRTC_OFFSET_CNTL__CRTC_STEREO_SYNC 0x00200000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET_LEFT_EN_MASK 0x10000000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET_LEFT_EN 0x10000000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET_RIGHT_EN_MASK 0x20000000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET_RIGHT_EN 0x20000000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET_MASK 0x40000000L -#define CRTC_OFFSET_CNTL__CRTC_GUI_TRIG_OFFSET 0x40000000L -#define CRTC_OFFSET_CNTL__CRTC_OFFSET_LOCK_MASK 0x80000000L -#define CRTC_OFFSET_CNTL__CRTC_OFFSET_LOCK 0x80000000L - -/* CRTC_GEN_CNTL */ -#define CRTC_GEN_CNTL__CRTC_DBL_SCAN_EN_MASK 0x00000001L -#define CRTC_GEN_CNTL__CRTC_DBL_SCAN_EN 0x00000001L -#define CRTC_GEN_CNTL__CRTC_INTERLACE_EN_MASK 0x00000002L -#define CRTC_GEN_CNTL__CRTC_INTERLACE_EN 0x00000002L -#define CRTC_GEN_CNTL__CRTC_C_SYNC_EN_MASK 0x00000010L -#define CRTC_GEN_CNTL__CRTC_C_SYNC_EN 0x00000010L -#define CRTC_GEN_CNTL__CRTC_PIX_WIDTH_MASK 0x00000f00L -#define CRTC_GEN_CNTL__CRTC_ICON_EN_MASK 0x00008000L -#define CRTC_GEN_CNTL__CRTC_ICON_EN 0x00008000L -#define CRTC_GEN_CNTL__CRTC_CUR_EN_MASK 0x00010000L -#define CRTC_GEN_CNTL__CRTC_CUR_EN 0x00010000L -#define CRTC_GEN_CNTL__CRTC_VSTAT_MODE_MASK 0x00060000L -#define CRTC_GEN_CNTL__CRTC_CUR_MODE_MASK 0x00700000L -#define CRTC_GEN_CNTL__CRTC_EXT_DISP_EN_MASK 0x01000000L -#define CRTC_GEN_CNTL__CRTC_EXT_DISP_EN 0x01000000L -#define CRTC_GEN_CNTL__CRTC_EN_MASK 0x02000000L -#define CRTC_GEN_CNTL__CRTC_EN 0x02000000L -#define CRTC_GEN_CNTL__CRTC_DISP_REQ_EN_B_MASK 0x04000000L -#define CRTC_GEN_CNTL__CRTC_DISP_REQ_EN_B 0x04000000L - -/* CRTC2_GEN_CNTL */ -#define CRTC2_GEN_CNTL__CRTC2_DBL_SCAN_EN_MASK 0x00000001L -#define CRTC2_GEN_CNTL__CRTC2_DBL_SCAN_EN 0x00000001L -#define CRTC2_GEN_CNTL__CRTC2_INTERLACE_EN_MASK 0x00000002L -#define CRTC2_GEN_CNTL__CRTC2_INTERLACE_EN 0x00000002L -#define CRTC2_GEN_CNTL__CRTC2_SYNC_TRISTATE_MASK 0x00000010L -#define CRTC2_GEN_CNTL__CRTC2_SYNC_TRISTATE 0x00000010L -#define CRTC2_GEN_CNTL__CRTC2_HSYNC_TRISTATE_MASK 0x00000020L -#define CRTC2_GEN_CNTL__CRTC2_HSYNC_TRISTATE 0x00000020L -#define CRTC2_GEN_CNTL__CRTC2_VSYNC_TRISTATE_MASK 0x00000040L -#define CRTC2_GEN_CNTL__CRTC2_VSYNC_TRISTATE 0x00000040L -#define CRTC2_GEN_CNTL__CRT2_ON_MASK 0x00000080L -#define CRTC2_GEN_CNTL__CRT2_ON 0x00000080L -#define CRTC2_GEN_CNTL__CRTC2_PIX_WIDTH_MASK 0x00000f00L -#define CRTC2_GEN_CNTL__CRTC2_ICON_EN_MASK 0x00008000L -#define CRTC2_GEN_CNTL__CRTC2_ICON_EN 0x00008000L -#define CRTC2_GEN_CNTL__CRTC2_CUR_EN_MASK 0x00010000L -#define CRTC2_GEN_CNTL__CRTC2_CUR_EN 0x00010000L -#define CRTC2_GEN_CNTL__CRTC2_CUR_MODE_MASK 0x00700000L -#define CRTC2_GEN_CNTL__CRTC2_DISPLAY_DIS_MASK 0x00800000L -#define CRTC2_GEN_CNTL__CRTC2_DISPLAY_DIS 0x00800000L -#define CRTC2_GEN_CNTL__CRTC2_EN_MASK 0x02000000L -#define CRTC2_GEN_CNTL__CRTC2_EN 0x02000000L -#define CRTC2_GEN_CNTL__CRTC2_DISP_REQ_EN_B_MASK 0x04000000L -#define CRTC2_GEN_CNTL__CRTC2_DISP_REQ_EN_B 0x04000000L -#define CRTC2_GEN_CNTL__CRTC2_C_SYNC_EN_MASK 0x08000000L -#define CRTC2_GEN_CNTL__CRTC2_C_SYNC_EN 0x08000000L -#define CRTC2_GEN_CNTL__CRTC2_HSYNC_DIS_MASK 0x10000000L -#define CRTC2_GEN_CNTL__CRTC2_HSYNC_DIS 0x10000000L -#define CRTC2_GEN_CNTL__CRTC2_VSYNC_DIS_MASK 0x20000000L -#define CRTC2_GEN_CNTL__CRTC2_VSYNC_DIS 0x20000000L - -/* AGP_CNTL */ -#define AGP_CNTL__MAX_IDLE_CLK_MASK 0x000000ffL -#define AGP_CNTL__HOLD_RD_FIFO_MASK 0x00000100L -#define AGP_CNTL__HOLD_RD_FIFO 0x00000100L -#define AGP_CNTL__HOLD_RQ_FIFO_MASK 0x00000200L -#define AGP_CNTL__HOLD_RQ_FIFO 0x00000200L -#define AGP_CNTL__EN_2X_STBB_MASK 0x00000400L -#define AGP_CNTL__EN_2X_STBB 0x00000400L -#define AGP_CNTL__FORCE_FULL_SBA_MASK 0x00000800L -#define AGP_CNTL__FORCE_FULL_SBA 0x00000800L -#define AGP_CNTL__SBA_DIS_MASK 0x00001000L -#define AGP_CNTL__SBA_DIS 0x00001000L -#define AGP_CNTL__AGP_REV_ID_MASK 0x00002000L -#define AGP_CNTL__AGP_REV_ID 0x00002000L -#define AGP_CNTL__REG_CRIPPLE_AGP4X_MASK 0x00004000L -#define AGP_CNTL__REG_CRIPPLE_AGP4X 0x00004000L -#define AGP_CNTL__REG_CRIPPLE_AGP2X4X_MASK 0x00008000L -#define AGP_CNTL__REG_CRIPPLE_AGP2X4X 0x00008000L -#define AGP_CNTL__FORCE_INT_VREF_MASK 0x00010000L -#define AGP_CNTL__FORCE_INT_VREF 0x00010000L -#define AGP_CNTL__PENDING_SLOTS_VAL_MASK 0x00060000L -#define AGP_CNTL__PENDING_SLOTS_SEL_MASK 0x00080000L -#define AGP_CNTL__PENDING_SLOTS_SEL 0x00080000L -#define AGP_CNTL__EN_EXTENDED_AD_STB_2X_MASK 0x00100000L -#define AGP_CNTL__EN_EXTENDED_AD_STB_2X 0x00100000L -#define AGP_CNTL__DIS_QUEUED_GNT_FIX_MASK 0x00200000L -#define AGP_CNTL__DIS_QUEUED_GNT_FIX 0x00200000L -#define AGP_CNTL__EN_RDATA2X4X_MULTIRESET_MASK 0x00400000L -#define AGP_CNTL__EN_RDATA2X4X_MULTIRESET 0x00400000L -#define AGP_CNTL__EN_RBFCALM_MASK 0x00800000L -#define AGP_CNTL__EN_RBFCALM 0x00800000L -#define AGP_CNTL__FORCE_EXT_VREF_MASK 0x01000000L -#define AGP_CNTL__FORCE_EXT_VREF 0x01000000L -#define AGP_CNTL__DIS_RBF_MASK 0x02000000L -#define AGP_CNTL__DIS_RBF 0x02000000L -#define AGP_CNTL__DELAY_FIRST_SBA_EN_MASK 0x04000000L -#define AGP_CNTL__DELAY_FIRST_SBA_EN 0x04000000L -#define AGP_CNTL__DELAY_FIRST_SBA_VAL_MASK 0x38000000L -#define AGP_CNTL__AGP_MISC_MASK 0xc0000000L - -/* AGP_CNTL */ -#define AGP_CNTL__MAX_IDLE_CLK__SHIFT 0x00000000 -#define AGP_CNTL__HOLD_RD_FIFO__SHIFT 0x00000008 -#define AGP_CNTL__HOLD_RQ_FIFO__SHIFT 0x00000009 -#define AGP_CNTL__EN_2X_STBB__SHIFT 0x0000000a -#define AGP_CNTL__FORCE_FULL_SBA__SHIFT 0x0000000b -#define AGP_CNTL__SBA_DIS__SHIFT 0x0000000c -#define AGP_CNTL__AGP_REV_ID__SHIFT 0x0000000d -#define AGP_CNTL__REG_CRIPPLE_AGP4X__SHIFT 0x0000000e -#define AGP_CNTL__REG_CRIPPLE_AGP2X4X__SHIFT 0x0000000f -#define AGP_CNTL__FORCE_INT_VREF__SHIFT 0x00000010 -#define AGP_CNTL__PENDING_SLOTS_VAL__SHIFT 0x00000011 -#define AGP_CNTL__PENDING_SLOTS_SEL__SHIFT 0x00000013 -#define AGP_CNTL__EN_EXTENDED_AD_STB_2X__SHIFT 0x00000014 -#define AGP_CNTL__DIS_QUEUED_GNT_FIX__SHIFT 0x00000015 -#define AGP_CNTL__EN_RDATA2X4X_MULTIRESET__SHIFT 0x00000016 -#define AGP_CNTL__EN_RBFCALM__SHIFT 0x00000017 -#define AGP_CNTL__FORCE_EXT_VREF__SHIFT 0x00000018 -#define AGP_CNTL__DIS_RBF__SHIFT 0x00000019 -#define AGP_CNTL__DELAY_FIRST_SBA_EN__SHIFT 0x0000001a -#define AGP_CNTL__DELAY_FIRST_SBA_VAL__SHIFT 0x0000001b -#define AGP_CNTL__AGP_MISC__SHIFT 0x0000001e - -/* DISP_MISC_CNTL */ -#define DISP_MISC_CNTL__SOFT_RESET_GRPH_PP_MASK 0x00000001L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH_PP 0x00000001L -#define DISP_MISC_CNTL__SOFT_RESET_SUBPIC_PP_MASK 0x00000002L -#define DISP_MISC_CNTL__SOFT_RESET_SUBPIC_PP 0x00000002L -#define DISP_MISC_CNTL__SOFT_RESET_OV0_PP_MASK 0x00000004L -#define DISP_MISC_CNTL__SOFT_RESET_OV0_PP 0x00000004L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH_SCLK_MASK 0x00000010L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH_SCLK 0x00000010L -#define DISP_MISC_CNTL__SOFT_RESET_SUBPIC_SCLK_MASK 0x00000020L -#define DISP_MISC_CNTL__SOFT_RESET_SUBPIC_SCLK 0x00000020L -#define DISP_MISC_CNTL__SOFT_RESET_OV0_SCLK_MASK 0x00000040L -#define DISP_MISC_CNTL__SOFT_RESET_OV0_SCLK 0x00000040L -#define DISP_MISC_CNTL__SYNC_STRENGTH_MASK 0x00000300L -#define DISP_MISC_CNTL__SYNC_PAD_FLOP_EN_MASK 0x00000400L -#define DISP_MISC_CNTL__SYNC_PAD_FLOP_EN 0x00000400L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH2_PP_MASK 0x00001000L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH2_PP 0x00001000L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH2_SCLK_MASK 0x00008000L -#define DISP_MISC_CNTL__SOFT_RESET_GRPH2_SCLK 0x00008000L -#define DISP_MISC_CNTL__SOFT_RESET_LVDS_MASK 0x00010000L -#define DISP_MISC_CNTL__SOFT_RESET_LVDS 0x00010000L -#define DISP_MISC_CNTL__SOFT_RESET_TMDS_MASK 0x00020000L -#define DISP_MISC_CNTL__SOFT_RESET_TMDS 0x00020000L -#define DISP_MISC_CNTL__SOFT_RESET_DIG_TMDS_MASK 0x00040000L -#define DISP_MISC_CNTL__SOFT_RESET_DIG_TMDS 0x00040000L -#define DISP_MISC_CNTL__SOFT_RESET_TV_MASK 0x00080000L -#define DISP_MISC_CNTL__SOFT_RESET_TV 0x00080000L -#define DISP_MISC_CNTL__PALETTE2_MEM_RD_MARGIN_MASK 0x00f00000L -#define DISP_MISC_CNTL__PALETTE_MEM_RD_MARGIN_MASK 0x0f000000L -#define DISP_MISC_CNTL__RMX_BUF_MEM_RD_MARGIN_MASK 0xf0000000L - -/* DISP_PWR_MAN */ -#define DISP_PWR_MAN__DISP_PWR_MAN_D3_CRTC_EN_MASK 0x00000001L -#define DISP_PWR_MAN__DISP_PWR_MAN_D3_CRTC_EN 0x00000001L -#define DISP_PWR_MAN__DISP2_PWR_MAN_D3_CRTC2_EN_MASK 0x00000010L -#define DISP_PWR_MAN__DISP2_PWR_MAN_D3_CRTC2_EN 0x00000010L -#define DISP_PWR_MAN__DISP_PWR_MAN_DPMS_MASK 0x00000300L -#define DISP_PWR_MAN__DISP_D3_RST_MASK 0x00010000L -#define DISP_PWR_MAN__DISP_D3_RST 0x00010000L -#define DISP_PWR_MAN__DISP_D3_REG_RST_MASK 0x00020000L -#define DISP_PWR_MAN__DISP_D3_REG_RST 0x00020000L -#define DISP_PWR_MAN__DISP_D3_GRPH_RST_MASK 0x00040000L -#define DISP_PWR_MAN__DISP_D3_GRPH_RST 0x00040000L -#define DISP_PWR_MAN__DISP_D3_SUBPIC_RST_MASK 0x00080000L -#define DISP_PWR_MAN__DISP_D3_SUBPIC_RST 0x00080000L -#define DISP_PWR_MAN__DISP_D3_OV0_RST_MASK 0x00100000L -#define DISP_PWR_MAN__DISP_D3_OV0_RST 0x00100000L -#define DISP_PWR_MAN__DISP_D1D2_GRPH_RST_MASK 0x00200000L -#define DISP_PWR_MAN__DISP_D1D2_GRPH_RST 0x00200000L -#define DISP_PWR_MAN__DISP_D1D2_SUBPIC_RST_MASK 0x00400000L -#define DISP_PWR_MAN__DISP_D1D2_SUBPIC_RST 0x00400000L -#define DISP_PWR_MAN__DISP_D1D2_OV0_RST_MASK 0x00800000L -#define DISP_PWR_MAN__DISP_D1D2_OV0_RST 0x00800000L -#define DISP_PWR_MAN__DIG_TMDS_ENABLE_RST_MASK 0x01000000L -#define DISP_PWR_MAN__DIG_TMDS_ENABLE_RST 0x01000000L -#define DISP_PWR_MAN__TV_ENABLE_RST_MASK 0x02000000L -#define DISP_PWR_MAN__TV_ENABLE_RST 0x02000000L -#define DISP_PWR_MAN__AUTO_PWRUP_EN_MASK 0x04000000L -#define DISP_PWR_MAN__AUTO_PWRUP_EN 0x04000000L - -/* MC_IND_INDEX */ -#define MC_IND_INDEX__MC_IND_ADDR_MASK 0x0000001fL -#define MC_IND_INDEX__MC_IND_WR_EN_MASK 0x00000100L -#define MC_IND_INDEX__MC_IND_WR_EN 0x00000100L - -/* MC_IND_DATA */ -#define MC_IND_DATA__MC_IND_DATA_MASK 0xffffffffL - -/* MC_CHP_IO_CNTL_A1 */ -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_CKA__SHIFT 0x00000000 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_AA__SHIFT 0x00000001 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQMA__SHIFT 0x00000002 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQSA__SHIFT 0x00000003 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_CKA__SHIFT 0x00000004 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_AA__SHIFT 0x00000005 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQMA__SHIFT 0x00000006 -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQSA__SHIFT 0x00000007 -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_AA__SHIFT 0x00000008 -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQMA__SHIFT 0x00000009 -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQSA__SHIFT 0x0000000a -#define MC_CHP_IO_CNTL_A1__MEM_IO_MODEA__SHIFT 0x0000000c -#define MC_CHP_IO_CNTL_A1__MEM_REC_CKA__SHIFT 0x0000000e -#define MC_CHP_IO_CNTL_A1__MEM_REC_AA__SHIFT 0x00000010 -#define MC_CHP_IO_CNTL_A1__MEM_REC_DQMA__SHIFT 0x00000012 -#define MC_CHP_IO_CNTL_A1__MEM_REC_DQSA__SHIFT 0x00000014 -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_PHASEA__SHIFT 0x00000016 -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_CENTERA__SHIFT 0x00000017 -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_ENA__SHIFT 0x00000018 -#define MC_CHP_IO_CNTL_A1__MEM_CLK_SELA__SHIFT 0x0000001a -#define MC_CHP_IO_CNTL_A1__MEM_CLK_INVA__SHIFT 0x0000001c -#define MC_CHP_IO_CNTL_A1__MEM_DATA_ENIMP_A__SHIFT 0x0000001e -#define MC_CHP_IO_CNTL_A1__MEM_CNTL_ENIMP_A__SHIFT 0x0000001f - -/* MC_CHP_IO_CNTL_B1 */ -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_CKB__SHIFT 0x00000000 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_AB__SHIFT 0x00000001 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQMB__SHIFT 0x00000002 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQSB__SHIFT 0x00000003 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_CKB__SHIFT 0x00000004 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_AB__SHIFT 0x00000005 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQMB__SHIFT 0x00000006 -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQSB__SHIFT 0x00000007 -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_AB__SHIFT 0x00000008 -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQMB__SHIFT 0x00000009 -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQSB__SHIFT 0x0000000a -#define MC_CHP_IO_CNTL_B1__MEM_IO_MODEB__SHIFT 0x0000000c -#define MC_CHP_IO_CNTL_B1__MEM_REC_CKB__SHIFT 0x0000000e -#define MC_CHP_IO_CNTL_B1__MEM_REC_AB__SHIFT 0x00000010 -#define MC_CHP_IO_CNTL_B1__MEM_REC_DQMB__SHIFT 0x00000012 -#define MC_CHP_IO_CNTL_B1__MEM_REC_DQSB__SHIFT 0x00000014 -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_PHASEB__SHIFT 0x00000016 -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_CENTERB__SHIFT 0x00000017 -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_ENB__SHIFT 0x00000018 -#define MC_CHP_IO_CNTL_B1__MEM_CLK_SELB__SHIFT 0x0000001a -#define MC_CHP_IO_CNTL_B1__MEM_CLK_INVB__SHIFT 0x0000001c -#define MC_CHP_IO_CNTL_B1__MEM_DATA_ENIMP_B__SHIFT 0x0000001e -#define MC_CHP_IO_CNTL_B1__MEM_CNTL_ENIMP_B__SHIFT 0x0000001f - -/* MC_CHP_IO_CNTL_A1 */ -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_CKA_MASK 0x00000001L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_CKA 0x00000001L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_AA_MASK 0x00000002L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_AA 0x00000002L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQMA_MASK 0x00000004L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQMA 0x00000004L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQSA_MASK 0x00000008L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWN_DQSA 0x00000008L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_CKA_MASK 0x00000010L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_CKA 0x00000010L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_AA_MASK 0x00000020L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_AA 0x00000020L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQMA_MASK 0x00000040L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQMA 0x00000040L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQSA_MASK 0x00000080L -#define MC_CHP_IO_CNTL_A1__MEM_SLEWP_DQSA 0x00000080L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_AA_MASK 0x00000100L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_AA 0x00000100L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQMA_MASK 0x00000200L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQMA 0x00000200L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQSA_MASK 0x00000400L -#define MC_CHP_IO_CNTL_A1__MEM_PREAMP_DQSA 0x00000400L -#define MC_CHP_IO_CNTL_A1__MEM_IO_MODEA_MASK 0x00003000L -#define MC_CHP_IO_CNTL_A1__MEM_REC_CKA_MASK 0x0000c000L -#define MC_CHP_IO_CNTL_A1__MEM_REC_AA_MASK 0x00030000L -#define MC_CHP_IO_CNTL_A1__MEM_REC_DQMA_MASK 0x000c0000L -#define MC_CHP_IO_CNTL_A1__MEM_REC_DQSA_MASK 0x00300000L -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_PHASEA_MASK 0x00400000L -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_PHASEA 0x00400000L -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_CENTERA_MASK 0x00800000L -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_CENTERA 0x00800000L -#define MC_CHP_IO_CNTL_A1__MEM_SYNC_ENA_MASK 0x03000000L -#define MC_CHP_IO_CNTL_A1__MEM_CLK_SELA_MASK 0x0c000000L -#define MC_CHP_IO_CNTL_A1__MEM_CLK_INVA_MASK 0x10000000L -#define MC_CHP_IO_CNTL_A1__MEM_CLK_INVA 0x10000000L -#define MC_CHP_IO_CNTL_A1__MEM_DATA_ENIMP_A_MASK 0x40000000L -#define MC_CHP_IO_CNTL_A1__MEM_DATA_ENIMP_A 0x40000000L -#define MC_CHP_IO_CNTL_A1__MEM_CNTL_ENIMP_A_MASK 0x80000000L -#define MC_CHP_IO_CNTL_A1__MEM_CNTL_ENIMP_A 0x80000000L - -/* MC_CHP_IO_CNTL_B1 */ -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_CKB_MASK 0x00000001L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_CKB 0x00000001L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_AB_MASK 0x00000002L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_AB 0x00000002L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQMB_MASK 0x00000004L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQMB 0x00000004L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQSB_MASK 0x00000008L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWN_DQSB 0x00000008L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_CKB_MASK 0x00000010L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_CKB 0x00000010L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_AB_MASK 0x00000020L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_AB 0x00000020L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQMB_MASK 0x00000040L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQMB 0x00000040L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQSB_MASK 0x00000080L -#define MC_CHP_IO_CNTL_B1__MEM_SLEWP_DQSB 0x00000080L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_AB_MASK 0x00000100L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_AB 0x00000100L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQMB_MASK 0x00000200L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQMB 0x00000200L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQSB_MASK 0x00000400L -#define MC_CHP_IO_CNTL_B1__MEM_PREAMP_DQSB 0x00000400L -#define MC_CHP_IO_CNTL_B1__MEM_IO_MODEB_MASK 0x00003000L -#define MC_CHP_IO_CNTL_B1__MEM_REC_CKB_MASK 0x0000c000L -#define MC_CHP_IO_CNTL_B1__MEM_REC_AB_MASK 0x00030000L -#define MC_CHP_IO_CNTL_B1__MEM_REC_DQMB_MASK 0x000c0000L -#define MC_CHP_IO_CNTL_B1__MEM_REC_DQSB_MASK 0x00300000L -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_PHASEB_MASK 0x00400000L -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_PHASEB 0x00400000L -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_CENTERB_MASK 0x00800000L -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_CENTERB 0x00800000L -#define MC_CHP_IO_CNTL_B1__MEM_SYNC_ENB_MASK 0x03000000L -#define MC_CHP_IO_CNTL_B1__MEM_CLK_SELB_MASK 0x0c000000L -#define MC_CHP_IO_CNTL_B1__MEM_CLK_INVB_MASK 0x10000000L -#define MC_CHP_IO_CNTL_B1__MEM_CLK_INVB 0x10000000L -#define MC_CHP_IO_CNTL_B1__MEM_DATA_ENIMP_B_MASK 0x40000000L -#define MC_CHP_IO_CNTL_B1__MEM_DATA_ENIMP_B 0x40000000L -#define MC_CHP_IO_CNTL_B1__MEM_CNTL_ENIMP_B_MASK 0x80000000L -#define MC_CHP_IO_CNTL_B1__MEM_CNTL_ENIMP_B 0x80000000L - -/* MEM_SDRAM_MODE_REG */ -#define MEM_SDRAM_MODE_REG__MEM_MODE_REG_MASK 0x00007fffL -#define MEM_SDRAM_MODE_REG__MEM_WR_LATENCY_MASK 0x000f0000L -#define MEM_SDRAM_MODE_REG__MEM_CAS_LATENCY_MASK 0x00700000L -#define MEM_SDRAM_MODE_REG__MEM_CMD_LATENCY_MASK 0x00800000L -#define MEM_SDRAM_MODE_REG__MEM_CMD_LATENCY 0x00800000L -#define MEM_SDRAM_MODE_REG__MEM_STR_LATENCY_MASK 0x01000000L -#define MEM_SDRAM_MODE_REG__MEM_STR_LATENCY 0x01000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_CMD_MASK 0x02000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_CMD 0x02000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_DATA_MASK 0x04000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_DATA 0x04000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_STR_MASK 0x08000000L -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_STR 0x08000000L -#define MEM_SDRAM_MODE_REG__MC_INIT_COMPLETE_MASK 0x10000000L -#define MEM_SDRAM_MODE_REG__MC_INIT_COMPLETE 0x10000000L -#define MEM_SDRAM_MODE_REG__MEM_DDR_DLL_MASK 0x20000000L -#define MEM_SDRAM_MODE_REG__MEM_DDR_DLL 0x20000000L -#define MEM_SDRAM_MODE_REG__MEM_CFG_TYPE_MASK 0x40000000L -#define MEM_SDRAM_MODE_REG__MEM_CFG_TYPE 0x40000000L -#define MEM_SDRAM_MODE_REG__MEM_SDRAM_RESET_MASK 0x80000000L -#define MEM_SDRAM_MODE_REG__MEM_SDRAM_RESET 0x80000000L - -/* MEM_SDRAM_MODE_REG */ -#define MEM_SDRAM_MODE_REG__MEM_MODE_REG__SHIFT 0x00000000 -#define MEM_SDRAM_MODE_REG__MEM_WR_LATENCY__SHIFT 0x00000010 -#define MEM_SDRAM_MODE_REG__MEM_CAS_LATENCY__SHIFT 0x00000014 -#define MEM_SDRAM_MODE_REG__MEM_CMD_LATENCY__SHIFT 0x00000017 -#define MEM_SDRAM_MODE_REG__MEM_STR_LATENCY__SHIFT 0x00000018 -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_CMD__SHIFT 0x00000019 -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_DATA__SHIFT 0x0000001a -#define MEM_SDRAM_MODE_REG__MEM_FALL_OUT_STR__SHIFT 0x0000001b -#define MEM_SDRAM_MODE_REG__MC_INIT_COMPLETE__SHIFT 0x0000001c -#define MEM_SDRAM_MODE_REG__MEM_DDR_DLL__SHIFT 0x0000001d -#define MEM_SDRAM_MODE_REG__MEM_CFG_TYPE__SHIFT 0x0000001e -#define MEM_SDRAM_MODE_REG__MEM_SDRAM_RESET__SHIFT 0x0000001f - -/* MEM_REFRESH_CNTL */ -#define MEM_REFRESH_CNTL__MEM_REFRESH_RATE_MASK 0x000000ffL -#define MEM_REFRESH_CNTL__MEM_REFRESH_DIS_MASK 0x00000100L -#define MEM_REFRESH_CNTL__MEM_REFRESH_DIS 0x00000100L -#define MEM_REFRESH_CNTL__MEM_DYNAMIC_CKE_MASK 0x00000200L -#define MEM_REFRESH_CNTL__MEM_DYNAMIC_CKE 0x00000200L -#define MEM_REFRESH_CNTL__MEM_TRFC_MASK 0x0000f000L -#define MEM_REFRESH_CNTL__MEM_CLKA0_ENABLE_MASK 0x00010000L -#define MEM_REFRESH_CNTL__MEM_CLKA0_ENABLE 0x00010000L -#define MEM_REFRESH_CNTL__MEM_CLKA0b_ENABLE_MASK 0x00020000L -#define MEM_REFRESH_CNTL__MEM_CLKA0b_ENABLE 0x00020000L -#define MEM_REFRESH_CNTL__MEM_CLKA1_ENABLE_MASK 0x00040000L -#define MEM_REFRESH_CNTL__MEM_CLKA1_ENABLE 0x00040000L -#define MEM_REFRESH_CNTL__MEM_CLKA1b_ENABLE_MASK 0x00080000L -#define MEM_REFRESH_CNTL__MEM_CLKA1b_ENABLE 0x00080000L -#define MEM_REFRESH_CNTL__MEM_CLKAFB_ENABLE_MASK 0x00100000L -#define MEM_REFRESH_CNTL__MEM_CLKAFB_ENABLE 0x00100000L -#define MEM_REFRESH_CNTL__DLL_FB_SLCT_CKA_MASK 0x00c00000L -#define MEM_REFRESH_CNTL__MEM_CLKB0_ENABLE_MASK 0x01000000L -#define MEM_REFRESH_CNTL__MEM_CLKB0_ENABLE 0x01000000L -#define MEM_REFRESH_CNTL__MEM_CLKB0b_ENABLE_MASK 0x02000000L -#define MEM_REFRESH_CNTL__MEM_CLKB0b_ENABLE 0x02000000L -#define MEM_REFRESH_CNTL__MEM_CLKB1_ENABLE_MASK 0x04000000L -#define MEM_REFRESH_CNTL__MEM_CLKB1_ENABLE 0x04000000L -#define MEM_REFRESH_CNTL__MEM_CLKB1b_ENABLE_MASK 0x08000000L -#define MEM_REFRESH_CNTL__MEM_CLKB1b_ENABLE 0x08000000L -#define MEM_REFRESH_CNTL__MEM_CLKBFB_ENABLE_MASK 0x10000000L -#define MEM_REFRESH_CNTL__MEM_CLKBFB_ENABLE 0x10000000L -#define MEM_REFRESH_CNTL__DLL_FB_SLCT_CKB_MASK 0xc0000000L - -/* MC_STATUS */ -#define MC_STATUS__MEM_PWRUP_COMPL_A_MASK 0x00000001L -#define MC_STATUS__MEM_PWRUP_COMPL_A 0x00000001L -#define MC_STATUS__MEM_PWRUP_COMPL_B_MASK 0x00000002L -#define MC_STATUS__MEM_PWRUP_COMPL_B 0x00000002L -#define MC_STATUS__MC_IDLE_MASK 0x00000004L -#define MC_STATUS__MC_IDLE 0x00000004L -#define MC_STATUS__IMP_N_VALUE_R_BACK_MASK 0x00000078L -#define MC_STATUS__IMP_P_VALUE_R_BACK_MASK 0x00000780L -#define MC_STATUS__TEST_OUT_R_BACK_MASK 0x00000800L -#define MC_STATUS__TEST_OUT_R_BACK 0x00000800L -#define MC_STATUS__DUMMY_OUT_R_BACK_MASK 0x00001000L -#define MC_STATUS__DUMMY_OUT_R_BACK 0x00001000L -#define MC_STATUS__IMP_N_VALUE_A_R_BACK_MASK 0x0001e000L -#define MC_STATUS__IMP_P_VALUE_A_R_BACK_MASK 0x001e0000L -#define MC_STATUS__IMP_N_VALUE_CK_R_BACK_MASK 0x01e00000L -#define MC_STATUS__IMP_P_VALUE_CK_R_BACK_MASK 0x1e000000L - -/* MDLL_CKO */ -#define MDLL_CKO__MCKOA_SLEEP_MASK 0x00000001L -#define MDLL_CKO__MCKOA_SLEEP 0x00000001L -#define MDLL_CKO__MCKOA_RESET_MASK 0x00000002L -#define MDLL_CKO__MCKOA_RESET 0x00000002L -#define MDLL_CKO__MCKOA_RANGE_MASK 0x0000000cL -#define MDLL_CKO__ERSTA_SOUTSEL_MASK 0x00000030L -#define MDLL_CKO__MCKOA_FB_SEL_MASK 0x000000c0L -#define MDLL_CKO__MCKOA_REF_SKEW_MASK 0x00000700L -#define MDLL_CKO__MCKOA_FB_SKEW_MASK 0x00007000L -#define MDLL_CKO__MCKOA_BP_SEL_MASK 0x00008000L -#define MDLL_CKO__MCKOA_BP_SEL 0x00008000L -#define MDLL_CKO__MCKOB_SLEEP_MASK 0x00010000L -#define MDLL_CKO__MCKOB_SLEEP 0x00010000L -#define MDLL_CKO__MCKOB_RESET_MASK 0x00020000L -#define MDLL_CKO__MCKOB_RESET 0x00020000L -#define MDLL_CKO__MCKOB_RANGE_MASK 0x000c0000L -#define MDLL_CKO__ERSTB_SOUTSEL_MASK 0x00300000L -#define MDLL_CKO__MCKOB_FB_SEL_MASK 0x00c00000L -#define MDLL_CKO__MCKOB_REF_SKEW_MASK 0x07000000L -#define MDLL_CKO__MCKOB_FB_SKEW_MASK 0x70000000L -#define MDLL_CKO__MCKOB_BP_SEL_MASK 0x80000000L -#define MDLL_CKO__MCKOB_BP_SEL 0x80000000L - -/* MDLL_RDCKA */ -#define MDLL_RDCKA__MRDCKA0_SLEEP_MASK 0x00000001L -#define MDLL_RDCKA__MRDCKA0_SLEEP 0x00000001L -#define MDLL_RDCKA__MRDCKA0_RESET_MASK 0x00000002L -#define MDLL_RDCKA__MRDCKA0_RESET 0x00000002L -#define MDLL_RDCKA__MRDCKA0_RANGE_MASK 0x0000000cL -#define MDLL_RDCKA__MRDCKA0_REF_SEL_MASK 0x00000030L -#define MDLL_RDCKA__MRDCKA0_FB_SEL_MASK 0x000000c0L -#define MDLL_RDCKA__MRDCKA0_REF_SKEW_MASK 0x00000700L -#define MDLL_RDCKA__MRDCKA0_SINSEL_MASK 0x00000800L -#define MDLL_RDCKA__MRDCKA0_SINSEL 0x00000800L -#define MDLL_RDCKA__MRDCKA0_FB_SKEW_MASK 0x00007000L -#define MDLL_RDCKA__MRDCKA0_BP_SEL_MASK 0x00008000L -#define MDLL_RDCKA__MRDCKA0_BP_SEL 0x00008000L -#define MDLL_RDCKA__MRDCKA1_SLEEP_MASK 0x00010000L -#define MDLL_RDCKA__MRDCKA1_SLEEP 0x00010000L -#define MDLL_RDCKA__MRDCKA1_RESET_MASK 0x00020000L -#define MDLL_RDCKA__MRDCKA1_RESET 0x00020000L -#define MDLL_RDCKA__MRDCKA1_RANGE_MASK 0x000c0000L -#define MDLL_RDCKA__MRDCKA1_REF_SEL_MASK 0x00300000L -#define MDLL_RDCKA__MRDCKA1_FB_SEL_MASK 0x00c00000L -#define MDLL_RDCKA__MRDCKA1_REF_SKEW_MASK 0x07000000L -#define MDLL_RDCKA__MRDCKA1_SINSEL_MASK 0x08000000L -#define MDLL_RDCKA__MRDCKA1_SINSEL 0x08000000L -#define MDLL_RDCKA__MRDCKA1_FB_SKEW_MASK 0x70000000L -#define MDLL_RDCKA__MRDCKA1_BP_SEL_MASK 0x80000000L -#define MDLL_RDCKA__MRDCKA1_BP_SEL 0x80000000L - -/* MDLL_RDCKB */ -#define MDLL_RDCKB__MRDCKB0_SLEEP_MASK 0x00000001L -#define MDLL_RDCKB__MRDCKB0_SLEEP 0x00000001L -#define MDLL_RDCKB__MRDCKB0_RESET_MASK 0x00000002L -#define MDLL_RDCKB__MRDCKB0_RESET 0x00000002L -#define MDLL_RDCKB__MRDCKB0_RANGE_MASK 0x0000000cL -#define MDLL_RDCKB__MRDCKB0_REF_SEL_MASK 0x00000030L -#define MDLL_RDCKB__MRDCKB0_FB_SEL_MASK 0x000000c0L -#define MDLL_RDCKB__MRDCKB0_REF_SKEW_MASK 0x00000700L -#define MDLL_RDCKB__MRDCKB0_SINSEL_MASK 0x00000800L -#define MDLL_RDCKB__MRDCKB0_SINSEL 0x00000800L -#define MDLL_RDCKB__MRDCKB0_FB_SKEW_MASK 0x00007000L -#define MDLL_RDCKB__MRDCKB0_BP_SEL_MASK 0x00008000L -#define MDLL_RDCKB__MRDCKB0_BP_SEL 0x00008000L -#define MDLL_RDCKB__MRDCKB1_SLEEP_MASK 0x00010000L -#define MDLL_RDCKB__MRDCKB1_SLEEP 0x00010000L -#define MDLL_RDCKB__MRDCKB1_RESET_MASK 0x00020000L -#define MDLL_RDCKB__MRDCKB1_RESET 0x00020000L -#define MDLL_RDCKB__MRDCKB1_RANGE_MASK 0x000c0000L -#define MDLL_RDCKB__MRDCKB1_REF_SEL_MASK 0x00300000L -#define MDLL_RDCKB__MRDCKB1_FB_SEL_MASK 0x00c00000L -#define MDLL_RDCKB__MRDCKB1_REF_SKEW_MASK 0x07000000L -#define MDLL_RDCKB__MRDCKB1_SINSEL_MASK 0x08000000L -#define MDLL_RDCKB__MRDCKB1_SINSEL 0x08000000L -#define MDLL_RDCKB__MRDCKB1_FB_SKEW_MASK 0x70000000L -#define MDLL_RDCKB__MRDCKB1_BP_SEL_MASK 0x80000000L -#define MDLL_RDCKB__MRDCKB1_BP_SEL 0x80000000L - -#define MDLL_R300_RDCK__MRDCKA_SLEEP 0x00000001L -#define MDLL_R300_RDCK__MRDCKA_RESET 0x00000002L -#define MDLL_R300_RDCK__MRDCKB_SLEEP 0x00000004L -#define MDLL_R300_RDCK__MRDCKB_RESET 0x00000008L -#define MDLL_R300_RDCK__MRDCKC_SLEEP 0x00000010L -#define MDLL_R300_RDCK__MRDCKC_RESET 0x00000020L -#define MDLL_R300_RDCK__MRDCKD_SLEEP 0x00000040L -#define MDLL_R300_RDCK__MRDCKD_RESET 0x00000080L - -#define pllCLK_PIN_CNTL 0x0001 -#define pllPPLL_CNTL 0x0002 -#define pllPPLL_REF_DIV 0x0003 -#define pllPPLL_DIV_0 0x0004 -#define pllPPLL_DIV_1 0x0005 -#define pllPPLL_DIV_2 0x0006 -#define pllPPLL_DIV_3 0x0007 -#define pllVCLK_ECP_CNTL 0x0008 -#define pllHTOTAL_CNTL 0x0009 -#define pllM_SPLL_REF_FB_DIV 0x000A -#define pllAGP_PLL_CNTL 0x000B -#define pllSPLL_CNTL 0x000C -#define pllSCLK_CNTL 0x000D -#define pllMPLL_CNTL 0x000E -#define pllMDLL_CKO 0x000F -#define pllMDLL_RDCKA 0x0010 -#define pllMDLL_RDCKB 0x0011 -#define pllMCLK_CNTL 0x0012 -#define pllPLL_TEST_CNTL 0x0013 -#define pllCLK_PWRMGT_CNTL 0x0014 -#define pllPLL_PWRMGT_CNTL 0x0015 -#define pllCG_TEST_MACRO_RW_WRITE 0x0016 -#define pllCG_TEST_MACRO_RW_READ 0x0017 -#define pllCG_TEST_MACRO_RW_DATA 0x0018 -#define pllCG_TEST_MACRO_RW_CNTL 0x0019 -#define pllDISP_TEST_MACRO_RW_WRITE 0x001A -#define pllDISP_TEST_MACRO_RW_READ 0x001B -#define pllDISP_TEST_MACRO_RW_DATA 0x001C -#define pllDISP_TEST_MACRO_RW_CNTL 0x001D -#define pllSCLK_CNTL2 0x001E -#define pllMCLK_MISC 0x001F -#define pllTV_PLL_FINE_CNTL 0x0020 -#define pllTV_PLL_CNTL 0x0021 -#define pllTV_PLL_CNTL1 0x0022 -#define pllTV_DTO_INCREMENTS 0x0023 -#define pllSPLL_AUX_CNTL 0x0024 -#define pllMPLL_AUX_CNTL 0x0025 -#define pllP2PLL_CNTL 0x002A -#define pllP2PLL_REF_DIV 0x002B -#define pllP2PLL_DIV_0 0x002C -#define pllPIXCLKS_CNTL 0x002D -#define pllHTOTAL2_CNTL 0x002E -#define pllSSPLL_CNTL 0x0030 -#define pllSSPLL_REF_DIV 0x0031 -#define pllSSPLL_DIV_0 0x0032 -#define pllSS_INT_CNTL 0x0033 -#define pllSS_TST_CNTL 0x0034 -#define pllSCLK_MORE_CNTL 0x0035 - -#define ixMC_PERF_CNTL 0x0000 -#define ixMC_PERF_SEL 0x0001 -#define ixMC_PERF_REGION_0 0x0002 -#define ixMC_PERF_REGION_1 0x0003 -#define ixMC_PERF_COUNT_0 0x0004 -#define ixMC_PERF_COUNT_1 0x0005 -#define ixMC_PERF_COUNT_2 0x0006 -#define ixMC_PERF_COUNT_3 0x0007 -#define ixMC_PERF_COUNT_MEMCH_A 0x0008 -#define ixMC_PERF_COUNT_MEMCH_B 0x0009 -#define ixMC_IMP_CNTL 0x000A -#define ixMC_CHP_IO_CNTL_A0 0x000B -#define ixMC_CHP_IO_CNTL_A1 0x000C -#define ixMC_CHP_IO_CNTL_B0 0x000D -#define ixMC_CHP_IO_CNTL_B1 0x000E -#define ixMC_IMP_CNTL_0 0x000F -#define ixTC_MISMATCH_1 0x0010 -#define ixTC_MISMATCH_2 0x0011 -#define ixMC_BIST_CTRL 0x0012 -#define ixREG_COLLAR_WRITE 0x0013 -#define ixREG_COLLAR_READ 0x0014 -#define ixR300_MC_IMP_CNTL 0x0018 -#define ixR300_MC_CHP_IO_CNTL_A0 0x0019 -#define ixR300_MC_CHP_IO_CNTL_A1 0x001a -#define ixR300_MC_CHP_IO_CNTL_B0 0x001b -#define ixR300_MC_CHP_IO_CNTL_B1 0x001c -#define ixR300_MC_CHP_IO_CNTL_C0 0x001d -#define ixR300_MC_CHP_IO_CNTL_C1 0x001e -#define ixR300_MC_CHP_IO_CNTL_D0 0x001f -#define ixR300_MC_CHP_IO_CNTL_D1 0x0020 -#define ixR300_MC_IMP_CNTL_0 0x0021 -#define ixR300_MC_ELPIDA_CNTL 0x0022 -#define ixR300_MC_CHP_IO_OE_CNTL_CD 0x0023 -#define ixR300_MC_READ_CNTL_CD 0x0024 -#define ixR300_MC_MC_INIT_WR_LAT_TIMER 0x0025 -#define ixR300_MC_DEBUG_CNTL 0x0026 -#define ixR300_MC_BIST_CNTL_0 0x0028 -#define ixR300_MC_BIST_CNTL_1 0x0029 -#define ixR300_MC_BIST_CNTL_2 0x002a -#define ixR300_MC_BIST_CNTL_3 0x002b -#define ixR300_MC_BIST_CNTL_4 0x002c -#define ixR300_MC_BIST_CNTL_5 0x002d -#define ixR300_MC_IMP_STATUS 0x002e -#define ixR300_MC_DLL_CNTL 0x002f -#define NB_TOM 0x15C - -#endif /* _RADEON_H */
On Fri, Aug 20, 2021 at 3:08 AM Tom Rini trini@konsulko.com wrote:
This driver is currently unused. Remove.
Signed-off-by: Tom Rini trini@konsulko.com
drivers/video/Makefile | 1 - drivers/video/ati_ids.h | 211 ---- drivers/video/ati_radeon_fb.c | 761 ------------- drivers/video/ati_radeon_fb.h | 282 ----- include/radeon.h | 1988 --------------------------------- 5 files changed, 3243 deletions(-) delete mode 100644 drivers/video/ati_ids.h delete mode 100644 drivers/video/ati_radeon_fb.c delete mode 100644 drivers/video/ati_radeon_fb.h delete mode 100644 include/radeon.h
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
