[PATCH 1/2] video: add guards around 16bpp/32bbp code
Many boards use only single depth configuration, for such boards there is some unused code in video and console uclass routines. Add guards to avoid dead code.
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/video/vidconsole-uclass.c | 6 ++++++ drivers/video/video-uclass.c | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index af88588904..c690eceeaa 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -116,6 +116,7 @@ static void vidconsole_newline(struct udevice *dev) video_sync(dev->parent, false); }
+#if CONFIG_IS_ENABLED(VIDEO_BPP16) || CONFIG_IS_ENABLED(VIDEO_BPP32) static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0x00, 0x00 }, /* black */ { 0xc0, 0x00, 0x00 }, /* red */ @@ -134,18 +135,23 @@ static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0xff, 0xff }, /* bright cyan */ { 0xff, 0xff, 0xff }, /* white */ }; +#endif
u32 vid_console_color(struct video_priv *priv, unsigned int idx) { switch (priv->bpix) { +#if CONFIG_IS_ENABLED(VIDEO_BPP16) case VIDEO_BPP16: return ((colors[idx].r >> 3) << 11) | ((colors[idx].g >> 2) << 5) | ((colors[idx].b >> 3) << 0); +#endif +#if CONFIG_IS_ENABLED(VIDEO_BPP32) case VIDEO_BPP32: return (colors[idx].r << 16) | (colors[idx].g << 8) | (colors[idx].b << 0); +#endif default: /* * For unknown bit arrangements just support diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index f660c5205e..5ea7568fa4 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -92,6 +92,7 @@ int video_clear(struct udevice *dev) struct video_priv *priv = dev_get_uclass_priv(dev);
switch (priv->bpix) { +#ifdef CONFIG_VIDEO_BPP16 case VIDEO_BPP16: { u16 *ppix = priv->fb; u16 *end = priv->fb + priv->fb_size; @@ -100,6 +101,8 @@ int video_clear(struct udevice *dev) *ppix++ = priv->colour_bg; break; } +#endif +#ifdef CONFIG_VIDEO_BPP32 case VIDEO_BPP32: { u32 *ppix = priv->fb; u32 *end = priv->fb + priv->fb_size; @@ -108,6 +111,7 @@ int video_clear(struct udevice *dev) *ppix++ = priv->colour_bg; break; } +#endif default: memset(priv->fb, priv->colour_bg, priv->fb_size); break;
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Also adjust defconfigs of DM_VIDEO enabled boards to select actually used BPP values.
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/apalis_imx6_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/chromebit_mickey_defconfig | 2 ++ configs/chromebook_jerry_defconfig | 2 ++ configs/chromebook_minnie_defconfig | 2 ++ configs/chromebook_speedy_defconfig | 2 ++ configs/colibri-imx6ull_defconfig | 3 +++ configs/colibri_imx6_defconfig | 1 + configs/colibri_imx7_defconfig | 3 +++ configs/colibri_imx7_emmc_defconfig | 3 +++ configs/colibri_t20_defconfig | 2 ++ configs/colibri_vf_defconfig | 1 + configs/evb-px30_defconfig | 3 +++ configs/evb-rk3288_defconfig | 2 ++ configs/evb-rk3399_defconfig | 2 ++ configs/firefly-rk3288_defconfig | 2 ++ configs/gazerbeam_defconfig | 3 +++ configs/ge_bx50v3_defconfig | 1 + configs/gurnard_defconfig | 2 ++ configs/harmony_defconfig | 2 ++ configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/libretech-ac_defconfig | 1 + configs/libretech-cc_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/medcom-wide_defconfig | 2 ++ configs/miqi-rk3288_defconfig | 2 ++ configs/mx53cx9020_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 3 +++ configs/mx6ul_9x9_evk_defconfig | 3 +++ configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/paz00_defconfig | 2 ++ configs/peach-pi_defconfig | 2 ++ configs/peach-pit_defconfig | 2 ++ configs/pico-dwarf-imx7d_defconfig | 3 +++ configs/pico-hobbit-imx7d_defconfig | 3 +++ configs/pico-imx7d_bl33_defconfig | 3 +++ configs/pico-imx7d_defconfig | 3 +++ configs/pico-nymph-imx7d_defconfig | 3 +++ configs/pico-pi-imx7d_defconfig | 3 +++ configs/pm9261_defconfig | 2 ++ configs/pm9263_defconfig | 2 ++ configs/puma-rk3399_defconfig | 2 ++ configs/rock2_defconfig | 2 ++ configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 3 +++ configs/sama5d3xek_nandflash_defconfig | 3 +++ configs/sama5d3xek_spiflash_defconfig | 3 +++ configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/seaboard_defconfig | 2 ++ configs/sei510_defconfig | 1 + configs/sei610_defconfig | 1 + configs/snow_defconfig | 2 ++ configs/spring_defconfig | 2 ++ configs/stm32f746-disco_defconfig | 3 +++ configs/stm32f769-disco_defconfig | 3 +++ configs/stm32mp15_basic_defconfig | 3 +++ configs/stm32mp15_optee_defconfig | 3 +++ configs/stm32mp15_trusted_defconfig | 3 +++ configs/tec_defconfig | 2 ++ configs/theadorable_debug_defconfig | 1 + configs/tinker-s-rk3288_defconfig | 2 ++ configs/ventana_defconfig | 2 ++ configs/vyasa-rk3288_defconfig | 2 ++ configs/wandboard_defconfig | 1 + drivers/video/Kconfig | 8 ++++---- drivers/video/console_normal.c | 10 +++++----- 105 files changed, 180 insertions(+), 9 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 92a249f317..0d11ab53d6 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -87,6 +87,7 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 8b3a8f1aab..23304080e2 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -69,4 +69,5 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 8672bf8300..a934298dcb 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -66,4 +66,5 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 4fe10bf289..8a38da57a7 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -67,4 +67,5 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index edb792ef6a..f0ece6a073 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -68,4 +68,5 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index a0b1c8d87e..87b88e22d3 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -92,6 +92,8 @@ CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 7ba0c9566a..d13c52dee7 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -97,6 +97,8 @@ CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 46e1c183a2..13a09e60be 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -97,6 +97,8 @@ CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_EDP=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 34cf727abc..65e07964cd 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -92,6 +92,8 @@ CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index aa0ec63ae6..48d14f28c3 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -85,5 +85,8 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 534873b28a..bc5d5bf6a2 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -85,6 +85,7 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index bd5474e83d..29ddd7d3e9 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -81,5 +81,8 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index 4fe1e360d0..ac2fa0e1e4 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -76,5 +76,8 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 36d2a44d2b..56e993dd10 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -66,6 +66,8 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 33c8ca53c5..c73c364377 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -91,6 +91,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/evb-px30_defconfig b/configs/evb-px30_defconfig index 521c82095f..d83cc6f4db 100644 --- a/configs/evb-px30_defconfig +++ b/configs/evb-px30_defconfig @@ -98,6 +98,9 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_LCD=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 05c43a07e7..1fa4054f5d 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -74,6 +74,8 @@ CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_VIDEO_ROCKCHIP_MAX_YRES=1200 diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 82e5d8196c..8b8cdc5109 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -54,6 +54,8 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_VIDEO_ROCKCHIP_MAX_YRES=1200 diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 6c2c84aa6b..0c0a51c54f 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -81,6 +81,8 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index f2907c72ae..683fc225c0 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -193,6 +193,9 @@ CONFIG_TPM_ATMEL_TWI=y CONFIG_TPM_AUTH_SESSIONS=y # CONFIG_TPM_V2 is not set CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_LOGICORE_DP_TX=y CONFIG_OSD=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index ffeefb3707..6b2d6c173a 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_VIDEO_IPUV3=y CONFIG_WATCHDOG_TIMEOUT_MSECS=6000 CONFIG_IMX_WATCHDOG=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 64395d374a..048afed65a 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -40,4 +40,6 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y CONFIG_CMD_DHRYSTONE=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 000345cdd5..11800dadae 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -55,5 +55,7 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index d8f8857b07..38561259ad 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -56,5 +56,6 @@ CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 2e313bdb82..a3e2e16c84 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -57,5 +57,6 @@ CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index db9188adaf..e9251d36e6 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -72,6 +72,7 @@ CONFIG_DEBUG_UART_MXC=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_IMX_WATCHDOG=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 2e313bdb82..a3e2e16c84 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -57,5 +57,6 @@ CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index ad99e1e5dc..05b0290a90 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -70,6 +70,7 @@ CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_MESON=y CONFIG_VIDEO_DT_SIMPLEFB=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index 8976d7f1f4..36debe7736 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -52,6 +52,7 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_MESON=y CONFIG_VIDEO_DT_SIMPLEFB=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 7ee004d610..9efdef614f 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -92,6 +92,7 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_WATCHDOG_TIMEOUT_MSECS=8000 diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 365ac00206..3bba587430 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -42,4 +42,6 @@ CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index aecf8bcde2..cec8e42c5e 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -77,6 +77,8 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index 112c301576..da61691706 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -38,4 +38,5 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX5=y CONFIG_MXC_UART=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 21ca29ad6d..c53d079f88 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -93,5 +93,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 2d351a8328..0bd686ec86 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -100,5 +100,6 @@ CONFIG_CI_UDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index a2f6fe9aa3..f516a50562 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -70,4 +70,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index b11cec3300..6b8c95f72c 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -73,4 +73,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 3cff4dd450..1266f39704 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -75,6 +75,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 86ad75cfb4..34a48af5ba 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -84,6 +84,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_DISPLAY=y CONFIG_VIDEO_TEGRA124=y CONFIG_VIDEO_BRIDGE=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 5676a26418..cb8ccd156d 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -100,6 +100,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index aff8e678e0..e57d1408ae 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -37,5 +37,7 @@ CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 5ab24ef7d3..e79c49ac37 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -73,6 +73,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index a9657d28bd..3155a9f297 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -72,6 +72,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 94d73ee051..5416b4581b 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -72,4 +72,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index ef86b0cd66..57b64c632f 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -72,4 +72,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 51d3514072..e54f3b12d4 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -68,5 +68,8 @@ CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index bf4d56ec2c..aa9c935bdd 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -72,4 +72,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 94d73ee051..5416b4581b 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -72,4 +72,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index c6f5b872c3..61e83520d5 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -72,4 +72,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 30f89d66d5..dc29f69837 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -59,4 +59,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y CONFIG_LCD=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 6c648156bc..0538a2f47e 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -57,4 +57,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y CONFIG_LCD=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 4d97ad8683..55255bf6af 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -86,6 +86,8 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index b223b75735..fb8b25f733 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -75,6 +75,8 @@ CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index bd4de5446c..75c6c9c447 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -38,6 +38,7 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index ebd6253924..4e8204ef88 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -38,6 +38,7 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 54a6ca6bb1..d50953287c 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -41,6 +41,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_LAN78XX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 345f9e995c..e76821450f 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -41,6 +41,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_LAN78XX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 9278cffd62..c0c0955131 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -41,6 +41,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_LAN78XX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index e7d8f29060..f21745b53f 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -28,6 +28,7 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 6345c56165..8cf1bb81ff 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -28,6 +28,7 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index b85f3f0a46..10fbe0db92 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -37,6 +37,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_LAN78XX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 03859211b8..2f4c7da6dc 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -38,6 +38,7 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index b4d9d01f97..fd5c3da8ca 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -94,6 +94,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 0050f5dcc4..eabdff31de 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -94,6 +94,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 98cf57bca1..fab0875d50 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -94,6 +94,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 6dbf6a4493..6b55e9585a 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -93,6 +93,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index cede144214..74fe6d42cb 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -108,6 +108,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 25ac3ccaf0..425ced92fe 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -93,6 +93,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index e054a22471..ec61db567f 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -95,6 +95,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index 68f2b164af..407c6b28b6 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -94,6 +94,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index e568429758..b02d9b4138 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -95,6 +95,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index b949764160..0527d57963 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -63,4 +63,5 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 2644bd388e..684dbe3c2a 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -64,5 +64,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 538936aa31..caf633848c 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -65,5 +65,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 74e011a8b8..1848454a6c 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -97,3 +97,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index fa3d30e73c..d90dc1d2ab 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -95,3 +95,6 @@ CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 222025898e..5f5d21df5d 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -96,3 +96,6 @@ CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 4a6b4f40cc..919c05cfb3 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -89,6 +89,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index a9e8053863..712b825037 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -86,6 +86,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 927d687d3d..1488742a17 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -90,6 +90,7 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y CONFIG_W1=y CONFIG_W1_GPIO=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 7d73bcd9b9..c15c71d277 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -87,4 +87,5 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7f2f2fdbaa..2a5509a542 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -86,4 +86,5 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index a77b3c214a..e1cb1cafa0 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -87,4 +87,5 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_ATMEL_HLCD=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index d467841205..cc536ff0ba 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -184,6 +184,7 @@ CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_USB_KEYBOARD_FN_KEYS=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ed7ff78a86..64245f7cdc 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -206,6 +206,7 @@ CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_USB_KEYBOARD_FN_KEYS=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 02969f95f1..bb31b00904 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -165,6 +165,7 @@ CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_USB_KEYBOARD_FN_KEYS=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 3b0f15de88..61a8ffdef8 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -185,6 +185,7 @@ CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_USB_KEYBOARD_FN_KEYS=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 78686a95af..2cb8db96a7 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -48,6 +48,8 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_AES=y diff --git a/configs/sei510_defconfig b/configs/sei510_defconfig index 9914e286c7..f95e4d340b 100644 --- a/configs/sei510_defconfig +++ b/configs/sei510_defconfig @@ -72,6 +72,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xfada CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_MESON=y CONFIG_VIDEO_DT_SIMPLEFB=y diff --git a/configs/sei610_defconfig b/configs/sei610_defconfig index 37934fb988..6487f9815a 100644 --- a/configs/sei610_defconfig +++ b/configs/sei610_defconfig @@ -73,6 +73,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xfada CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_MESON=y CONFIG_VIDEO_DT_SIMPLEFB=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 7e7a1a1cf5..fa5174b4a1 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -84,6 +84,8 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 816fd71c48..f57aaa9305 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -85,6 +85,8 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index c9e22563a3..d04f126289 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -54,6 +54,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_STM32=y CONFIG_VIDEO_STM32_MAX_XRES=480 diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 19a7493d00..a95367197e 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -54,6 +54,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y CONFIG_VIDEO_STM32=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 14e1127cfb..358c2cd079 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -132,6 +132,9 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 791c1a94bd..a065d3e088 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -116,6 +116,9 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 5556b185b3..632f11f59b 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -115,6 +115,9 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP8=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 1cbff55599..be20e6980b 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -42,4 +42,6 @@ CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index ddff2aaa5a..6bc86b476b 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -81,4 +81,5 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_VIDEO_MVEBU=y diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index 5090f394f4..4925b14821 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -82,6 +82,8 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 8d02903316..59b6141059 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -41,5 +41,7 @@ CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index e15fec09d8..9497f0dd0f 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -78,6 +78,8 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 016a1cacbc..ca564c59b8 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -72,5 +72,6 @@ CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 805713c08b..4cde0acbf6 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -38,7 +38,7 @@ config BACKLIGHT_GPIO config VIDEO_BPP8 bool "Support 8-bit-per-pixel displays" depends on DM_VIDEO - default y if DM_VIDEO + default n help Support drawing text and bitmaps onto a 8-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -48,7 +48,7 @@ config VIDEO_BPP8 config VIDEO_BPP16 bool "Support 16-bit-per-pixel displays" depends on DM_VIDEO - default y if DM_VIDEO + default n help Support drawing text and bitmaps onto a 16-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -58,7 +58,7 @@ config VIDEO_BPP16 config VIDEO_BPP32 bool "Support 32-bit-per-pixel displays" depends on DM_VIDEO - default y if DM_VIDEO + default n help Support drawing text and bitmaps onto a 32-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -68,7 +68,7 @@ config VIDEO_BPP32 config VIDEO_ANSI bool "Support ANSI escape sequences in video console" depends on DM_VIDEO - default y if DM_VIDEO + default n help Enable ANSI escape sequence decoding for a more fully functional console. diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 7f01ee9424..2f25af7332 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -16,9 +16,9 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); - void *line; - int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; - int i; + void * __maybe_unused line; + int __maybe_unused pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; + int __maybe_unused i;
line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * vid_priv->line_length; switch (vid_priv->bpix) { @@ -76,7 +76,7 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); - int i, row; + int __maybe_unused i, row; void *line = vid_priv->fb + y * vid_priv->line_length + VID_TO_PIXEL(x_frac) * VNBYTES(vid_priv->bpix);
@@ -85,7 +85,7 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y,
for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { unsigned int idx = (u8)ch * VIDEO_FONT_HEIGHT + row; - uchar bits = video_fontdata[idx]; + uchar __maybe_unused bits = video_fontdata[idx];
switch (vid_priv->bpix) { #ifdef CONFIG_VIDEO_BPP8
Forgot to CC board maintainers. Maybe you could review or test these two patches [1],[2] on your board to confirm that these don't break frame buffer support.
[1] http://patchwork.ozlabs.org/patch/1204707 [2] http://patchwork.ozlabs.org/patch/1204704
Thanks, Anatolij
Thanks, Anatolij
Tested on mx53cx9020 Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Beckhoff Automation GmbH & Co. KG | Managing Director: Dipl. Phys. Hans Beckhoff Registered office: Verl, Germany | Register court: Guetersloh HRA 7075
Tested both patches on sama5d2_xplained board: Tested-by: Eugen Hristev eugen.hristev@microchip.com
Hi Anatolij
Tested on stm32mp157c-ev1, stm32f746-disco and stm32f769-disco .
Tested-by: Patrice Chotard patrice.chotard@st.com
Thanks
On Thu, 5 Dec 2019 18:15:49 +0100 Anatolij Gustschin agust@denx.de wrote: ...
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Eugen.Hristev@microchip.com
Patrice CHOTARD
Steffen Dirkwinkel
