[PATCH] pci: fsl: Change compatible string for mpc8548 to "fsl, mpc8548-pcie"
Upstream Linux kernel uses for mpc8548-based PCIe controllers compatible string "fsl,mpc8548-pcie". So change U-Boot fsl PCIe driver and all DTS files to use "fsl,mpc8548-pcie" instead of "fsl,pcie-mpc8548" to be compatible with Linux kernel.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/mpc8548-post.dtsi | 2 +- drivers/pci/pcie_fsl.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/dts/mpc8548-post.dtsi b/arch/powerpc/dts/mpc8548-post.dtsi index 2206f2da9feb..97c3ce6e74d6 100644 --- a/arch/powerpc/dts/mpc8548-post.dtsi +++ b/arch/powerpc/dts/mpc8548-post.dtsi @@ -27,7 +27,7 @@ };
&pcie { - compatible = "fsl,pcie-mpc8548", "fsl,pcie-fsl-qoriq"; + compatible = "fsl,mpc8548-pcie", "fsl,pcie-fsl-qoriq"; law_trgt_if = <2>; #address-cells = <3>; #size-cells = <2>; diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index cc6efdd5b464..be156daf8d49 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -646,7 +646,7 @@ static struct fsl_pcie_data t2080_data = { };
static const struct udevice_id fsl_pcie_ids[] = { - { .compatible = "fsl,pcie-mpc8548", .data = (ulong)&p1_p2_data }, + { .compatible = "fsl,mpc8548-pcie", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-p3041", .data = (ulong)&p2041_data },
Pali Rohár
