[PATCH] mx6cuboxi: Fix Ethernet after DT sync with Linux
The i.MX6 Cubox-i and HummingBoards can have different PHYs at varying addresses. U-Boot needs to auto-detect which phy is actually present, and at which address it is responding.
Auto-detection from multiple phy nodes specified in device-tree does not currently work correct. As a work-around merge all three possible phys into one node with the special address 0xffffffff which indicates to the generic phy driver to probe all addresses. Also fixup this fake address before booting Linux, *if* booting with U-Boot's internal dtb.
Signed-off-by: Josua Mayer josua@solid-run.com [fabio: Added the changes to imx6qdl-sr-som-u-boot.dtsi.] Signed-off-by: Fabio Estevam festevam@gmail.com Tested-by: Christian Gmeiner cgmeiner@igalia.com --- ...qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 1 + arch/arm/dts/imx6qdl-sr-som-u-boot.dtsi | 40 +++++++++++++++++++ board/solidrun/mx6cuboxi/mx6cuboxi.c | 8 +++- 3 files changed, 48 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6qdl-sr-som-u-boot.dtsi
diff --git a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi index e9b188ed6587..358cf8abc4ff 100644 --- a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include "imx6qdl-u-boot.dtsi" +#include "imx6qdl-sr-som-u-boot.dtsi"
/ { board-detect { diff --git a/arch/arm/dts/imx6qdl-sr-som-u-boot.dtsi b/arch/arm/dts/imx6qdl-sr-som-u-boot.dtsi new file mode 100644 index 000000000000..4c5f043ea92a --- /dev/null +++ b/arch/arm/dts/imx6qdl-sr-som-u-boot.dtsi @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +#include <dt-bindings/gpio/gpio.h> + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_enet_ar8035>; + phy-handle = <&phy>; + phy-mode = "rgmii-id"; + + /* + * The PHY seems to require a long-enough reset duration to avoid + * some rare issues where the PHY gets stuck in an inconsistent and + * non-functional state at boot-up. 10ms proved to be fine . + */ + phy-reset-duration = <10>; + phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + /delete-node/ ethernet-phy@1; + /delete-node/ ethernet-phy@4; + + phy: ethernet-phy@0 { + /* + * The PHY can appear either: + * - AR8035: at address 0 or 4 + * - ADIN1300: at address 1 + * Actual address being detected at runtime. + */ + reg = <0xffffffff>; + qca,clk-out-frequency = <125000000>; + qca,smarteee-tw-us-1g = <24>; + adi,phy-output-clock = "125mhz-free-running"; + }; + }; +}; diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 8edabf4404c2..fbab39e800a6 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -447,7 +447,7 @@ static int find_ethernet_phy(void) */ int ft_board_setup(void *fdt, struct bd_info *bd) { - int node_phy0, node_phy1, node_phy4; + int node_phy, node_phy0, node_phy1, node_phy4; int ret, phy; bool enable_phy0 = false, enable_phy1 = false, enable_phy4 = false; enum board_type board; @@ -479,6 +479,12 @@ int ft_board_setup(void *fdt, struct bd_info *bd) return 0; }
+ // update U-Boot's own unified phy node phy address, if present + node_phy = fdt_path_offset(fdt, "/soc/bus@2100000/ethernet@2188000/mdio/phy"); + ret = fdt_setprop_u32(fdt, node_phy, "reg", phy); + if (ret < 0) + pr_err("%s: failed to update unified PHY node address\n", __func__); + // update all phy nodes status node_phy0 = fdt_path_offset(fdt, "/soc/bus@2100000/ethernet@2188000/mdio/ethernet-phy@0"); ret = fdt_setprop_string(fdt, node_phy0, "status", enable_phy0 ? "okay" : "disabled");
Am 28.03.24 um 13:21 schrieb Fabio Estevam:
+&fec {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_microsom_enet_ar8035>;
- phy-handle = <&phy>;
- phy-mode = "rgmii-id";
- phy-reset-duration = <10>;
- phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>;
- status = "okay";
- mdio {
#size-cells = <0>;
This node name is shared with upstream imx6qdl-sr-som.dtsi
reg = <0xffffffff>;
- int node_phy, node_phy0, node_phy1, node_phy4; int ret, phy; bool enable_phy0 = false, enable_phy1 = false, enable_phy4 = false; enum board_type board;
- // update U-Boot's own unified phy node phy address, if present
- node_phy = fdt_path_offset(fdt, "/soc/bus@2100000/ethernet@2188000/mdio/phy");
This node no longer exists, unless you rename the u-boot-specific one. The u-boot node should probably have its own separate name, to ensure we do not find the upstream linux dtb ethernet-phy@0 node by mistake.
- ret = fdt_setprop_u32(fdt, node_phy, "reg", phy);
- if (ret < 0)
- // update all phy nodes status node_phy0 = fdt_path_offset(fdt, "/soc/bus@2100000/ethernet@2188000/mdio/ethernet-phy@0"); ret = fdt_setprop_string(fdt, node_phy0, "status", enable_phy0 ? "okay" : "disabled");
Am 28.03.24 um 13:51 schrieb Josua Mayer:
+&fec {
- status = "okay";
- mdio {
#size-cells = <0>;
I suggest changing their status to disabled, and keeping the nodes.
Give this one a u-boot-only internal name, maybe ethernet-phy@ff
reg = <0xffffffff>;
Look-up the u-boot-internal phy node name here
- if (ret < 0)
Just disable the u-boot-internal phy node unconditionally, or delete it. Because u-boot DTB is synced with upstream, the code below will update status properties for the standard etherent-phy@[0,1,4] nodes used by Linux.
Hi Josua,
Thanks for the suggestions.
My imx6-cuboxi board does not turn on anymore, unfortunately.
As I cannot test it, I am not comfortable doing the changes.
I hope you or Christian can submit a proper fix.
Fabio Estevam
Josua Mayer
