[U-Boot] [PATCH v2] test/py: Setup variables based on HUSH selection
After adding our small zynq uboot which has hush parser off same variable tests start to failed. Use quotes only when hush is enabled.
Reported-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Stephen Warren swarren@nvidia.com ---
Changes in v2: - code taken from v1 review from Stephen
Stephen: it is your code that's why I have added your SoB line. Tests are passing for hush and !hush cases
Signed-off-by: Michal Simek michal.simek@xilinx.com --- test/py/tests/test_env.py | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index b7f960c755fe..f8694017b42a 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -125,7 +125,16 @@ def set_var(state_test_env, var, value): Nothing. """
- state_test_env.u_boot_console.run_command('setenv %s "%s"' % (var, value)) + bc = state_test_env.u_boot_console.config.buildconfig + if bc.get('config_hush_parser', None): + quote = '"' + else: + quote = '' + if ' ' in value: + pytest.skip('Space in variable value on non-Hush shell') + + state_test_env.u_boot_console.run_command( + 'setenv %s %s%s%s' % (var, quote, value, quote)) state_test_env.env[var] = value
def validate_empty(state_test_env, var):
Changes in v2:
Looks good, thanks.
Michal Simek
Stephen Warren
