[U-Boot] [PATCH v5 0/3] Allwinner V3s and Lichee Pi Zero support (w/o SPL)
Allwinner V3s is a SoC with single-core Cortex-A7 and 64MiB DRAM co-packaged in a eLQFP package, which is suitable for manual soldering.
This patchset adds basic support for it. SPL support is still missing, due to some reworks on DRAM initialization code is needed.(the co-packaged DRAM is DDR2, but the DRAM initialization code currently only support DDR3.)
Icenowy Zheng (3): sunxi: add basic V3s support sunxi: add DTSI file for V3s sunxi: add support for Lichee Pi Zero
arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-v3s-licheepi-zero.dts | 83 +++++++++ arch/arm/dts/sun8i-v3s.dtsi | 284 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 4 + arch/arm/mach-sunxi/cpu_info.c | 2 + board/sunxi/Kconfig | 15 +- board/sunxi/MAINTAINERS | 5 + configs/LicheePi_Zero_defconfig | 12 ++ include/configs/sun8i.h | 2 + include/configs/sunxi-common.h | 31 +++- include/dt-bindings/clock/sun8i-v3s-ccu.h | 107 +++++++++++ include/dt-bindings/reset/sun8i-v3s-ccu.h | 78 ++++++++ 13 files changed, 621 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/sun8i-v3s-licheepi-zero.dts create mode 100644 arch/arm/dts/sun8i-v3s.dtsi create mode 100644 configs/LicheePi_Zero_defconfig create mode 100644 include/dt-bindings/clock/sun8i-v3s-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-v3s-ccu.h
Basic U-Boot support is now present for V3s.
Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM.
As the DRAM controller code needs a big refactor, the SPL support is disabled in this version.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz Acked-by: Maxime Ripard maxime.ripard@free-electrons.com Reviewed-by: Jagan Teki jagan@openedev.com --- Changes in v5: - Fixed a regression issue on AArch64 sunxi build. Changes in v4: - Enable PSCI for the SoC. (For virtualization support, although it seems to be a joke to use virtualization on systems with 64MiB DRAM) - Add Maxime's ACK and Jagan's Reviewed-By.
Changes in v3: - Remove some dead codes.
arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 4 ++++ arch/arm/mach-sunxi/cpu_info.c | 2 ++ board/sunxi/Kconfig | 15 +++++++++++++-- include/configs/sun8i.h | 2 ++ include/configs/sunxi-common.h | 31 ++++++++++++++++++++++++++++--- 6 files changed, 50 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 85a4ec3b0e..24f85206c8 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -161,6 +161,7 @@ enum sunxi_gpio_number { #define SUN8I_GPB_UART2 2 #define SUN8I_A33_GPB_UART0 3 #define SUN8I_A83T_GPB_UART0 2 +#define SUN8I_V3S_GPB_UART0 3 #define SUN50I_GPB_UART0 4
#define SUNXI_GPC_NAND 2 diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 52be5b0551..90b3b94e51 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -110,6 +110,10 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S) + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN9I) sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index f1f6fd5ba4..15f1e0e45a 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -87,6 +87,8 @@ int print_cpuinfo(void) printf("CPU: Allwinner A83T (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_H3 printf("CPU: Allwinner H3 (SUN8I %04x)\n", sunxi_get_sram_id()); +#elif defined CONFIG_MACH_SUN8I_V3S + printf("CPU: Allwinner V3s (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN9I puts("CPU: Allwinner A80 (SUN9I)\n"); #elif defined CONFIG_MACH_SUN50I diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 37b42521a4..56b7513fe3 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -115,6 +115,15 @@ config MACH_SUN8I_H3 select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
+config MACH_SUN8I_V3S + bool "sun8i (Allwinner V3s)" + select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select ARCH_SUPPORT_PSCI + select SUNXI_GEN_SUN6I + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 @@ -132,7 +141,8 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool - default y if MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_H3 || MACH_SUN8I_A83T + default y if MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_H3 || \ + MACH_SUN8I_A83T || MACH_SUN8I_V3S
config RESERVE_ALLWINNER_BOOT0_HEADER bool "reserve space for Allwinner boot0 header" @@ -485,7 +495,8 @@ config AXP_GPIO
config VIDEO bool "Enable graphical uboot console on HDMI, LCD or VGA" - depends on !MACH_SUN8I_A83T && !MACH_SUN8I_H3 && !MACH_SUN9I && !MACH_SUN50I + depends on !MACH_SUN8I_A83T && !MACH_SUN8I_H3 && !MACH_SUN8I_V3S && \ + !MACH_SUN9I && !MACH_SUN50I default y ---help--- Say Y here to add support for using a cfb console on the HDMI, LCD diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index a4c3fb69e4..6ac42acaea 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -21,6 +21,8 @@ #define CONFIG_SUNXI_USB_PHYS 4 #elif defined CONFIG_MACH_SUN8I_A83T #define CONFIG_SUNXI_USB_PHYS 3 +#elif defined CONFIG_MACH_SUN8I_V3S + #define CONFIG_SUNXI_USB_PHYS 1 #else #define CONFIG_SUNXI_USB_PHYS 2 #endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index d48bdac07a..5c4d18b4fa 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -75,8 +75,13 @@ #else #define SDRAM_OFFSET(x) 0x4##x #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0x41000000 /* default load address */ +/* V3s do not have enough memory to place code at 0x4a000000 */ +#ifndef CONFIG_MACH_SUN8I_V3S #define CONFIG_SYS_TEXT_BASE 0x4a000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x42e00000 +#endif /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -146,8 +151,13 @@ #define CONFIG_SYS_MMC_MAX_DEVICE 4 #endif
+#ifndef CONFIG_MACH_SUN8I_V3S /* 64MB of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (64 << 20)) +#else +/* 2MB of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (2 << 20)) +#endif
/* * Miscellaneous configurable options @@ -368,6 +378,7 @@ extern int soft_i2c_gpio_scl; * Scripts, PXE and DTBs should go afterwards, leaving the rest for the initrd. * Align the initrd to a 2MB page. */ +#define BOOTM_SIZE __stringify(0xa000000) #define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(0080000)) #define FDT_ADDR_R __stringify(SDRAM_OFFSET(FA00000)) #define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(FC00000)) @@ -380,16 +391,30 @@ extern int soft_i2c_gpio_scl; * 32M uncompressed kernel, 16M compressed kernel, 1M fdt, * 1M script, 1M pxe and the ramdisk at the end. */ - +#ifndef CONFIG_MACH_SUN8I_V3S +#define BOOTM_SIZE __stringify(0xa000000) #define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(2000000)) #define FDT_ADDR_R __stringify(SDRAM_OFFSET(3000000)) #define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(3100000)) #define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000)) #define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3300000)) +#else +/* + * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc. + * 16M uncompressed kernel, 8M compressed kernel, 1M fdt, + * 1M script, 1M pxe and the ramdisk at the end. + */ +#define BOOTM_SIZE __stringify(0x2e00000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) +#endif #endif
#define MEM_LAYOUT_ENV_SETTINGS \ - "bootm_size=0xa000000\0" \ + "bootm_size=" BOOTM_SIZE "\0" \ "kernel_addr_r=" KERNEL_ADDR_R "\0" \ "fdt_addr_r=" FDT_ADDR_R "\0" \ "scriptaddr=" SCRIPT_ADDR_R "\0" \
As we have now V3s support in board code, the V3s DTSI file should also be added.
Add also some CCU include headers to satisfy the DTSI file.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- Changes in v4: - Add Maxime's ACK.
arch/arm/dts/sun8i-v3s.dtsi | 284 ++++++++++++++++++++++++++++++ include/dt-bindings/clock/sun8i-v3s-ccu.h | 107 +++++++++++ include/dt-bindings/reset/sun8i-v3s-ccu.h | 78 ++++++++ 3 files changed, 469 insertions(+) create mode 100644 arch/arm/dts/sun8i-v3s.dtsi create mode 100644 include/dt-bindings/clock/sun8i-v3s-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-v3s-ccu.h
diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi new file mode 100644 index 0000000000..ebefc0fefe --- /dev/null +++ b/arch/arm/dts/sun8i-v3s.dtsi @@ -0,0 +1,284 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/clock/sun8i-v3s-ccu.h> +#include <dt-bindings/reset/sun8i-v3s-ccu.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&gic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + clocks = <&ccu CLK_CPU>; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; + }; + + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + mmc0: mmc@01c0f000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c0f000 0x1000>; + clocks = <&ccu CLK_BUS_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc1: mmc@01c10000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c10000 0x1000>; + clocks = <&ccu CLK_BUS_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@01c11000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c11000 0x1000>; + clocks = <&ccu CLK_BUS_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usb_otg: usb@01c19000 { + compatible = "allwinner,sun8i-h3-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun8i-v3s-usb-phy"; + reg = <0x01c19400 0x2c>, + <0x01c1a800 0x4>; + reg-names = "phy_ctrl", + "pmu0"; + clocks = <&ccu CLK_USB_PHY0>; + clock-names = "usb0_phy"; + resets = <&ccu RST_USB_PHY0>; + reset-names = "usb0_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ccu: clock@01c20000 { + compatible = "allwinner,sun8i-v3s-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + rtc: rtc@01c20400 { + compatible = "allwinner,sun6i-a31-rtc"; + reg = <0x01c20400 0x54>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + }; + + pio: pinctrl@01c20800 { + compatible = "allwinner,sun8i-v3s-pinctrl"; + reg = <0x01c20800 0x400>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; + + uart0_pins_a: uart0@0 { + pins = "PB8", "PB9"; + function = "uart0"; + bias-pull-up; + }; + + mmc0_pins_a: mmc0@0 { + pins = "PF0", "PF1", "PF2", "PF3", + "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; + }; + }; + + timer@01c20c00 { + compatible = "allwinner,sun4i-a10-timer"; + reg = <0x01c20c00 0xa0>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + }; + + wdt0: watchdog@01c20ca0 { + compatible = "allwinner,sun6i-a31-wdt"; + reg = <0x01c20ca0 0x20>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + }; + + uart0: serial@01c28000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28000 0x400>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; + status = "disabled"; + }; + + uart1: serial@01c28400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28400 0x400>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + status = "disabled"; + }; + + uart2: serial@01c28800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28800 0x400>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; + status = "disabled"; + }; + + gic: interrupt-controller@01c81000 { + compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x1000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + }; +}; diff --git a/include/dt-bindings/clock/sun8i-v3s-ccu.h b/include/dt-bindings/clock/sun8i-v3s-ccu.h new file mode 100644 index 0000000000..c0d5d5599c --- /dev/null +++ b/include/dt-bindings/clock/sun8i-v3s-ccu.h @@ -0,0 +1,107 @@ +/* + * Copyright (c) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun8i-h3-ccu.h, which is: + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN8I_V3S_H_ +#define _DT_BINDINGS_CLK_SUN8I_V3S_H_ + +#define CLK_CPU 14 + +#define CLK_BUS_CE 20 +#define CLK_BUS_DMA 21 +#define CLK_BUS_MMC0 22 +#define CLK_BUS_MMC1 23 +#define CLK_BUS_MMC2 24 +#define CLK_BUS_DRAM 25 +#define CLK_BUS_EMAC 26 +#define CLK_BUS_HSTIMER 27 +#define CLK_BUS_SPI0 28 +#define CLK_BUS_OTG 29 +#define CLK_BUS_EHCI0 30 +#define CLK_BUS_OHCI0 31 +#define CLK_BUS_VE 32 +#define CLK_BUS_TCON0 33 +#define CLK_BUS_CSI 34 +#define CLK_BUS_DE 35 +#define CLK_BUS_CODEC 36 +#define CLK_BUS_PIO 37 +#define CLK_BUS_I2C0 38 +#define CLK_BUS_I2C1 39 +#define CLK_BUS_UART0 40 +#define CLK_BUS_UART1 41 +#define CLK_BUS_UART2 42 +#define CLK_BUS_EPHY 43 +#define CLK_BUS_DBG 44 + +#define CLK_MMC0 45 +#define CLK_MMC0_SAMPLE 46 +#define CLK_MMC0_OUTPUT 47 +#define CLK_MMC1 48 +#define CLK_MMC1_SAMPLE 49 +#define CLK_MMC1_OUTPUT 50 +#define CLK_MMC2 51 +#define CLK_MMC2_SAMPLE 52 +#define CLK_MMC2_OUTPUT 53 +#define CLK_CE 54 +#define CLK_SPI0 55 +#define CLK_USB_PHY0 56 +#define CLK_USB_OHCI0 57 + +#define CLK_DRAM_VE 59 +#define CLK_DRAM_CSI 60 +#define CLK_DRAM_EHCI 61 +#define CLK_DRAM_OHCI 62 +#define CLK_DE 63 +#define CLK_TCON0 64 +#define CLK_CSI_MISC 65 +#define CLK_CSI0_MCLK 66 +#define CLK_CSI1_SCLK 67 +#define CLK_CSI1_MCLK 68 +#define CLK_VE 69 +#define CLK_AC_DIG 70 +#define CLK_AVS 71 + +#define CLK_MIPI_CSI 73 + +#endif /* _DT_BINDINGS_CLK_SUN8I_V3S_H_ */ diff --git a/include/dt-bindings/reset/sun8i-v3s-ccu.h b/include/dt-bindings/reset/sun8i-v3s-ccu.h new file mode 100644 index 0000000000..b58ef21a2e --- /dev/null +++ b/include/dt-bindings/reset/sun8i-v3s-ccu.h @@ -0,0 +1,78 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun8i-v3s-ccu.h, which is + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN8I_V3S_H_ +#define _DT_BINDINGS_RST_SUN8I_V3S_H_ + +#define RST_USB_PHY0 0 + +#define RST_MBUS 1 + +#define RST_BUS_CE 5 +#define RST_BUS_DMA 6 +#define RST_BUS_MMC0 7 +#define RST_BUS_MMC1 8 +#define RST_BUS_MMC2 9 +#define RST_BUS_DRAM 11 +#define RST_BUS_EMAC 12 +#define RST_BUS_HSTIMER 14 +#define RST_BUS_SPI0 15 +#define RST_BUS_OTG 17 +#define RST_BUS_EHCI0 18 +#define RST_BUS_OHCI0 22 +#define RST_BUS_VE 26 +#define RST_BUS_TCON0 27 +#define RST_BUS_CSI 30 +#define RST_BUS_DE 34 +#define RST_BUS_DBG 38 +#define RST_BUS_EPHY 39 +#define RST_BUS_CODEC 40 +#define RST_BUS_I2C0 46 +#define RST_BUS_I2C1 47 +#define RST_BUS_UART0 49 +#define RST_BUS_UART1 50 +#define RST_BUS_UART2 51 + +#endif /* _DT_BINDINGS_RST_SUN8I_H3_H_ */
Lichee Pi Zero is a development board with a V3s SoC, which features 64MiB DRAM co-packaged within the SoC, a TF slot, a SPI NOR slot (not soldered in production batch), a 40-pin RGB LCD connector and some extra pins available as 2.54mm pins or stamp holes.
Add support for it.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes in v4: - Removed NONSEC disabling for Lichee Pi Zero board. - Enriched commit message.
arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-v3s-licheepi-zero.dts | 83 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/LicheePi_Zero_defconfig | 12 +++++ 4 files changed, 102 insertions(+) create mode 100644 arch/arm/dts/sun8i-v3s-licheepi-zero.dts create mode 100644 configs/LicheePi_Zero_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eb68c204bb..83df114dd8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -294,6 +294,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ sun8i-h3-nanopi-neo.dtb +dtb-$(CONFIG_MACH_SUN8I_V3S) += \ + sun8i-v3s-licheepi-zero.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts new file mode 100644 index 0000000000..3d9168cbae --- /dev/null +++ b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts @@ -0,0 +1,83 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-v3s.dtsi" +#include "sunxi-common-regulators.dtsi" + +/ { + model = "Lichee Pi Zero"; + compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&mmc0 { + pinctrl-0 = <&mmc0_pins_a>; + pinctrl-names = "default"; + broken-cd; + bus-width = <4>; + vmmc-supply = <®_vcc3v3>; + status = "okay"; +}; + +&uart0 { + pinctrl-0 = <&uart0_pins_a>; + pinctrl-names = "default"; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 2321b8b08f..640c26328a 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -182,6 +182,11 @@ M: Jelle de Jong jelledejong@powercraft.nl S: Maintained F: configs/Lamobo_R1_defconfig
+LICHEEPI-ZERO BOARD +M: Icenowy Zheng icenowy@aosc.xyz +S: Maintained +F: configs/LicheePi_Zero_defconfig + LINKSPRITE-PCDUINO BOARD M: Zoltan Herpai wigyori@uid0.hu S: Maintained diff --git a/configs/LicheePi_Zero_defconfig b/configs/LicheePi_Zero_defconfig new file mode 100644 index 0000000000..c147084849 --- /dev/null +++ b/configs/LicheePi_Zero_defconfig @@ -0,0 +1,12 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_V3S=y +CONFIG_DRAM_CLK=360 +CONFIG_DRAM_ZQ=14779 +CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero" +# CONFIG_CONSOLE_MUX is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_NETDEVICES is not set
Icenowy Zheng
