[U-Boot] [PATCH] mpc8610hpcd: Fix PCI mapping concepts
Rename _BASE to _BUS, as it's actually a PCI bus address, separate virtual and physical addresses into _VIRT and _PHYS, and use each appopriately. This makes the code easier to read and understand, and facilitates mapping changes going forward.
Signed-off-by: Becky Bruce beckyb@kernel.crashing.org --- board/freescale/mpc8610hpcd/law.c | 4 ++-- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 12 ++++++------ include/configs/MPC8610HPCD.h | 24 +++++++++++++----------- 3 files changed, 21 insertions(+), 19 deletions(-)
diff --git a/board/freescale/mpc8610hpcd/law.c b/board/freescale/mpc8610hpcd/law.c index 2aad28a..0fc8384 100644 --- a/board/freescale/mpc8610hpcd/law.c +++ b/board/freescale/mpc8610hpcd/law.c @@ -31,8 +31,8 @@ struct law_entry law_table[] = { #if !defined(CONFIG_SPD_EEPROM) SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_512M, LAW_TRGT_IF_DDR_1), #endif - SET_LAW(CONFIG_SYS_PCIE1_MEM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), + SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_1), + SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), SET_LAW(PIXIS_BASE, LAW_SIZE_2M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCIE_2), diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 2792778..a2097a5 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -266,14 +266,14 @@ void pci_init_board(void)
/* outbound memory */ pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BASE, + CONFIG_SYS_PCIE1_MEM_BUS, CONFIG_SYS_PCIE1_MEM_PHYS, CONFIG_SYS_PCIE1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BASE, + CONFIG_SYS_PCIE1_IO_BUS, CONFIG_SYS_PCIE1_IO_PHYS, CONFIG_SYS_PCIE1_IO_SIZE, PCI_REGION_IO); @@ -321,14 +321,14 @@ void pci_init_board(void)
/* outbound memory */ pci_set_region(r++, - CONFIG_SYS_PCIE2_MEM_BASE, + CONFIG_SYS_PCIE2_MEM_BUS, CONFIG_SYS_PCIE2_MEM_PHYS, CONFIG_SYS_PCIE2_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ pci_set_region(r++, - CONFIG_SYS_PCIE2_IO_BASE, + CONFIG_SYS_PCIE2_IO_BUS, CONFIG_SYS_PCIE2_IO_PHYS, CONFIG_SYS_PCIE2_IO_SIZE, PCI_REGION_IO); @@ -370,14 +370,14 @@ void pci_init_board(void)
/* outbound memory */ pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BASE, + CONFIG_SYS_PCI1_MEM_BUS, CONFIG_SYS_PCI1_MEM_PHYS, CONFIG_SYS_PCI1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BASE, + CONFIG_SYS_PCI1_IO_BUS, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_SIZE, PCI_REGION_IO); diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index f2fe4a6..e7556ea 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -271,11 +271,13 @@ * General PCI * Addresses are mapped 1-1. */ -#define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE +#define CONFIG_SYS_PCI1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BUS +#define CONFIG_SYS_PCI1_MEM_VIRT CONFIG_SYS_PCI1_MEM_BUS #define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_BUS 0x0000000 #define CONFIG_SYS_PCI1_IO_PHYS 0xe1000000 +#define CONFIG_SYS_PCI1_IO_VIRT 0xe1000000 #define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
/* For RTL8139 */ @@ -283,18 +285,18 @@ #define _IO_BASE 0x00000000
/* controller 1, Base address 0xa000 */ -#define CONFIG_SYS_PCIE1_MEM_BASE 0xa0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS CONFIG_SYS_PCIE1_MEM_BASE +#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS CONFIG_SYS_PCIE1_MEM_BUS #define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xe3000000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */
/* controller 2, Base Address 0x9000 */ -#define CONFIG_SYS_PCIE2_MEM_BASE 0x90000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS CONFIG_SYS_PCIE2_MEM_BASE +#define CONFIG_SYS_PCIE2_MEM_BUS 0x90000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS CONFIG_SYS_PCIE2_MEM_BUS #define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_BASE 0x00000000 /* reuse mem LAW */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 /* reuse mem LAW */ #define CONFIG_SYS_PCIE2_IO_PHYS 0xe2000000 #define CONFIG_SYS_PCIE2_IO_SIZE 0x00100000 /* 1M */
@@ -362,7 +364,7 @@
#define CONFIG_SYS_DBAT1L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT1U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_1G | BATU_VS | BATU_VP) +#define CONFIG_SYS_DBAT1U (CONFIG_SYS_PCI1_MEM_VIRT | BATU_BL_1G | BATU_VS | BATU_VP) #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT1U CONFIG_SYS_DBAT1U
@@ -373,7 +375,7 @@
#define CONFIG_SYS_DBAT2L (CONFIG_SYS_PCI1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT2U (CONFIG_SYS_PCI1_IO_PHYS | BATU_BL_16M | BATU_VS | BATU_VP) +#define CONFIG_SYS_DBAT2U (CONFIG_SYS_PCI1_IO_VIRT | BATU_BL_16M | BATU_VS | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT2U CONFIG_SYS_DBAT2U
Becky Bruce
