[U-Boot] [PATCH 1/3] mx28evk: Propagate the error if cpu_eth_init() fails
If cpu_eth_init() fails we should return the error immediately.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx28evk/mx28evk.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index 3abf1fd..5005fe2 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -103,6 +103,8 @@ int board_eth_init(bd_t *bis) int ret;
ret = cpu_eth_init(bis); + if (ret) + return ret;
/* MX28EVK uses ENET_CLK PAD to drive FEC clock */ writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN,
Cc: Marek Vasut marex@denx.de Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/denx/m28evk/m28evk.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index f4453d6..33d38cf 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -116,6 +116,8 @@ int board_eth_init(bd_t *bis) int ret;
clrsetbits_le32(&clkctrl_regs->hw_clkctrl_enet, CLKCTRL_ENET_TIME_SEL_MASK | CLKCTRL_ENET_CLK_OUT_EN,
Dear Fabio Estevam,
Acked-by: Marek Vasut marex@denx.de
if (ret)
return ret;
Best regards, Marek Vasut
Applied to u-boot-imx (fix), thanks!
Best regards, Stefano Babic
If smc911x_initialize() fails we should return the error immediately.
While at it, also check the error from cpu_eth_init().
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx35pdk/mx35pdk.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/board/freescale/mx35pdk/mx35pdk.c b/board/freescale/mx35pdk/mx35pdk.c index 427c83a..9fabef5 100644 --- a/board/freescale/mx35pdk/mx35pdk.c +++ b/board/freescale/mx35pdk/mx35pdk.c @@ -251,14 +251,12 @@ int board_late_init(void)
int board_eth_init(bd_t *bis) { - int rc = -ENODEV; #if defined(CONFIG_SMC911X) - rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); + int rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); + if (rc) + return rc; #endif - - cpu_eth_init(bis); - - return rc; + return cpu_eth_init(bis); }
#if defined(CONFIG_FSL_ESDHC)
- int rc = -ENODEV;
- int rc = smc911x_initialize(0, CONFIG_SMC911X_BASE);
- if (rc)
return rc;
#endif
- return rc;
- return cpu_eth_init(bis);
Acked-by: Stefano Babic sbabic@denx.de
Fabio Estevam
Stefano Babic
