[GIT] Pull request: u-boot-dfu (12.02.2021)
Dear Marek,
Please find this PR with fastboot improvement code rebased on top of u-boot-denx-usb tree.
CI: https://dev.azure.com/lukma633/U-Boot/_build/results?buildId=28&view=res...
(There shall be at least one follow up PR with work done by Sean).
Merge tag data/information: https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/-/tags/u-boot-dfu-12Feb2...
The following changes since commit db8fb2ffc4f3f63b9005f676ab3879a06de6cdda:
usb: dwc2: change compatible st,stm32mp1-hsotg to st,stm32mp15-hsotg (2021-02-10 22:23:35 +0100)
u-boot-dfu/master
for you to fetch changes up to a7d1b66d65972965ffbf002277bac99b0e290aee:
fastboot: add UUU command UCmd and ACmd support (2021-02-11 22:54:11 +0100)
---------------------------------------------------------------- Heiko Schocher (1): fastboot: add UUU command UCmd and ACmd support
Sean Anderson (10): mmc: sandbox: Add support for writing test: dm: Add test for fastboot mmc partition naming part: Give several functions more useful return values part: Support getting whole disk from part_get_info_by_dev_and_name_or_num part: Support string block devices in part_get_info_by_dev_and_name fastboot: Remove mmcpart argument from raw_part_get_info_by_name fastboot: Move part_get_info_by_name_or_alias after raw_part_get_info_by_name fastboot: Allow u-boot-style partitions doc: Rename k210 partitions anchor doc: Document partition specifications
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 2/12/21 7:25 PM, Lukasz Majewski wrote:
Dear Marek,
u-boot-dfu/master
Applied, thanks
Lukasz Majewski
