[U-Boot] [PATCH] armv8: ls1088qds: Remove CONFIG_ from local defines for FPGA
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- include/configs/ls1088aqds.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 5674a5d..1f2161b 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -197,7 +197,7 @@ unsigned long get_board_ddr_clk(void); | CSPR_MSEL_GPCM \ | CSPR_V)
-#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) +#define SYS_FPGA_AMASK IFC_AMASK(64 * 1024) #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) #else @@ -226,7 +226,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_FPGA_CSPR_EXT #define CONFIG_SYS_CSPR2 CONFIG_SYS_FPGA_CSPR #define CONFIG_SYS_CSPR2_FINAL SYS_FPGA_CSPR_FINAL -#define CONFIG_SYS_AMASK2 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_AMASK2 SYS_FPGA_AMASK #define CONFIG_SYS_CSOR2 CONFIG_SYS_FPGA_CSOR #define CONFIG_SYS_CS2_FTIM0 SYS_FPGA_CS_FTIM0 #define CONFIG_SYS_CS2_FTIM1 SYS_FPGA_CS_FTIM1 @@ -262,13 +262,13 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 #define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT #define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR -#define CONFIG_SYS_CSPR3_FINAL CONFIG_SYS_FPGA_CSPR_FINAL -#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSPR3_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK3 SYS_FPGA_AMASK #define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR -#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_CS_FTIM0 -#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_CS_FTIM1 -#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_CS_FTIM2 -#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_CS_FTIM3 +#define CONFIG_SYS_CS3_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 SYS_FPGA_CS_FTIM3 #endif
#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000
Applied to fsl-qoriq master. Thanks.
York
Ashish Kumar
York Sun
