[U-Boot] [PATCH 00/14] Add saveenv support for STM32MP1
This series adds saveenv support for STM32MP1 on several boot devices. STM32MP1 is able to boot on eMMC, sdcard and NOR (NAND support is not fully supported).
On eMMC and sdcard, environment is saved in EXT4 partition On NOR, environment is saved in a dedicated partition On NAND, environment is saved in a UBI volume.
This series: - enables NAND and NOR support on ev1 board - enables ENV_IS_IN_SPI_FLASH, ENV_IS_IN_UBI, ENV_IS_IN_EXT4 flags - fixes get_mtdparts() - allows to override interface, device and partition for ext4 environment - updates rule to set ENV_IS_NOWHERE value - introduce ENV_IS_IN_DEVICE
Patrice Chotard (10): stm32mp1: support dynamic MTDPARTS env: ext4: Allow overriding interface, device and partition board: stm32mp1: Add env_ext4_get_dev_part() and env_ext4_get_intf() env: allow ENV_IS_NOWHERE with other storage target stm32mp1: Add env_get_location() mtd: Fix get_mtdparts() stm32mp1: Move ENV_SIZE to Kconfig configs: stm32mp15: Enable ENV_IS_IN_UBI configs: stm32mp15: Enable ENV_IS_SPI_FLASH stm32mp1: Update env_get_location for NOR support
Patrick Delaunay (3): stm32mp1: activate NAND and NOR support on EV1 env: enable saveenv command when one CONFIG_ENV_IS_IN is activated configs: stm32mp15: Enable ENV_IS_IN_EXT4 and all relative flags
Tom Rini (1): Prepare v2019.07-rc1
Makefile | 4 +- arch/arm/dts/stm32mp157-pinctrl.dtsi | 44 ++++++++++++ arch/arm/dts/stm32mp157c-ev1.dts | 16 +++++ arch/arm/dts/stm32mp157c.dtsi | 15 ++++ arch/arm/mach-stm32mp/Kconfig | 3 + board/st/stm32mp1/stm32mp1.c | 136 +++++++++++++++++++++++++++++++++++ cmd/nvedit.c | 36 ++++++---- configs/stm32mp15_basic_defconfig | 27 +++++++ configs/stm32mp15_trusted_defconfig | 27 +++++++ drivers/mtd/mtd_uboot.c | 5 +- env/Kconfig | 20 ++---- env/ext4.c | 34 +++++---- include/configs/stm32mp1.h | 24 +++++-- 13 files changed, 340 insertions(+), 51 deletions(-)
Signed-off-by: Tom Rini trini@konsulko.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index f2c7bb6..d6a6ef1 100644 --- a/Makefile +++ b/Makefile @@ -1,9 +1,9 @@ # SPDX-License-Identifier: GPL-2.0+
VERSION = 2019 -PATCHLEVEL = 04 +PATCHLEVEL = 07 SUBLEVEL = -EXTRAVERSION = +EXTRAVERSION = -rc1 NAME =
# *DOCUMENTATION*
Add the necessary configuration to have NAND and NOR support on ev1 board for BASIC boot (with SPL) or for TRUSTED boot (with TF-A).
STM32MP> nand info
Device 0: nand0, sector size 256 KiB Page size 4096 b OOB size 224 b Erase size 262144 b subpagesize 4096 b options 0x00184200 bbt options 0x00060000
STM32MP> sf probe SF: Detected mx66l51235l with page size 256 Bytes, erase size 64 KiB, total 64 MiB
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
arch/arm/dts/stm32mp157-pinctrl.dtsi | 44 ++++++++++++++++++++++++++++++++++++ arch/arm/dts/stm32mp157c-ev1.dts | 16 +++++++++++++ arch/arm/dts/stm32mp157c.dtsi | 15 ++++++++++++ configs/stm32mp15_basic_defconfig | 17 ++++++++++++++ configs/stm32mp15_trusted_defconfig | 17 ++++++++++++++ include/configs/stm32mp1.h | 3 +++ 6 files changed, 112 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157-pinctrl.dtsi index 0aae69b..9d1d386 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -210,6 +210,50 @@ }; };
+ fmc_pins_a: fmc-0 { + pins1 { + pinmux = <STM32_PINMUX('D', 4, AF12)>, /* FMC_NOE */ + <STM32_PINMUX('D', 5, AF12)>, /* FMC_NWE */ + <STM32_PINMUX('D', 11, AF12)>, /* FMC_A16_FMC_CLE */ + <STM32_PINMUX('D', 12, AF12)>, /* FMC_A17_FMC_ALE */ + <STM32_PINMUX('D', 14, AF12)>, /* FMC_D0 */ + <STM32_PINMUX('D', 15, AF12)>, /* FMC_D1 */ + <STM32_PINMUX('D', 0, AF12)>, /* FMC_D2 */ + <STM32_PINMUX('D', 1, AF12)>, /* FMC_D3 */ + <STM32_PINMUX('E', 7, AF12)>, /* FMC_D4 */ + <STM32_PINMUX('E', 8, AF12)>, /* FMC_D5 */ + <STM32_PINMUX('E', 9, AF12)>, /* FMC_D6 */ + <STM32_PINMUX('E', 10, AF12)>, /* FMC_D7 */ + <STM32_PINMUX('G', 9, AF12)>; /* FMC_NE2_FMC_NCE */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 6, AF12)>; /* FMC_NWAIT */ + bias-pull-up; + }; + }; + + fmc_sleep_pins_a: fmc-sleep-0 { + pins { + pinmux = <STM32_PINMUX('D', 4, ANALOG)>, /* FMC_NOE */ + <STM32_PINMUX('D', 5, ANALOG)>, /* FMC_NWE */ + <STM32_PINMUX('D', 11, ANALOG)>, /* FMC_A16_FMC_CLE */ + <STM32_PINMUX('D', 12, ANALOG)>, /* FMC_A17_FMC_ALE */ + <STM32_PINMUX('D', 14, ANALOG)>, /* FMC_D0 */ + <STM32_PINMUX('D', 15, ANALOG)>, /* FMC_D1 */ + <STM32_PINMUX('D', 0, ANALOG)>, /* FMC_D2 */ + <STM32_PINMUX('D', 1, ANALOG)>, /* FMC_D3 */ + <STM32_PINMUX('E', 7, ANALOG)>, /* FMC_D4 */ + <STM32_PINMUX('E', 8, ANALOG)>, /* FMC_D5 */ + <STM32_PINMUX('E', 9, ANALOG)>, /* FMC_D6 */ + <STM32_PINMUX('E', 10, ANALOG)>, /* FMC_D7 */ + <STM32_PINMUX('D', 6, ANALOG)>, /* FMC_NWAIT */ + <STM32_PINMUX('G', 9, ANALOG)>; /* FMC_NE2_FMC_NCE */ + }; + }; + i2c1_pins_a: i2c1-0 { pins { pinmux = <STM32_PINMUX('D', 12, AF5)>, /* I2C1_SCL */ diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index a6ee379..69980ca 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -92,6 +92,22 @@ }; };
+&fmc { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&fmc_pins_a>; + pinctrl-1 = <&fmc_sleep_pins_a>; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + nand: nand@0 { + reg = <0>; + nand-on-flash-bbt; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + &i2c2 { pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins_a>; diff --git a/arch/arm/dts/stm32mp157c.dtsi b/arch/arm/dts/stm32mp157c.dtsi index 9463433..dd0f4e8 100644 --- a/arch/arm/dts/stm32mp157c.dtsi +++ b/arch/arm/dts/stm32mp157c.dtsi @@ -1033,6 +1033,21 @@ dma-requests = <48>; };
+ fmc: nand-controller@58002000 { + compatible = "st,stm32mp15-fmc2"; + reg = <0x58002000 0x1000>, + <0x80000000 0x1000>, + <0x88010000 0x1000>, + <0x88020000 0x1000>, + <0x81000000 0x1000>, + <0x89010000 0x1000>, + <0x89020000 0x1000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&rcc FMC_K>; + resets = <&rcc FMC_R>; + stafmctus = "disabled"; + }; + qspi: spi@58003000 { compatible = "st,stm32f469-qspi"; reg = <0x58003000 0x1000>, <0x70000000 0x10000000>; diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index bd75df8..f5e13dd 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y @@ -37,6 +38,7 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_MTDPARTS=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_STM32_ADC=y @@ -54,6 +56,18 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_MMC=y CONFIG_STM32_SDMMC2=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_STM32_FMC2=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y CONFIG_PINCONF=y @@ -68,6 +82,9 @@ CONFIG_DM_REGULATOR_STM32_VREFBUF=y CONFIG_DM_REGULATOR_STPMIC1=y CONFIG_SERIAL_RX_BUFFER=y CONFIG_STM32_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index f82b770..cae3324 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y @@ -30,6 +31,7 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_MTDPARTS=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_STM32_ADC=y CONFIG_USB_FUNCTION_FASTBOOT=y @@ -46,6 +48,18 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_MMC=y CONFIG_STM32_SDMMC2=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_STM32_FMC2=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y CONFIG_PINCONF=y @@ -58,6 +72,9 @@ CONFIG_DM_REGULATOR_STM32_VREFBUF=y CONFIG_DM_REGULATOR_STPMIC1=y CONFIG_SERIAL_RX_BUFFER=y CONFIG_STM32_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 3069373..a28b8b3 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -85,6 +85,9 @@
#if !defined(CONFIG_SPL_BUILD)
+/* NAND support */ +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_MAX_NAND_DEVICE 1 #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \
This patch configure the default value for mtdids and mtparts dynamically according the presence of nor and nand in the board device tree
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
board/st/stm32mp1/stm32mp1.c | 85 ++++++++++++++++++++++++++++++++++++++++++++ include/configs/stm32mp1.h | 9 +++++ 2 files changed, 94 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 76917b0..360b0df 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -504,3 +504,88 @@ void board_quiesce_devices(void) { setup_led(LEDST_OFF); } + +#ifdef CONFIG_SYS_MTDPARTS_RUNTIME + +#define MTDPARTS_LEN 256 +#define MTDIDS_LEN 128 + +/** + * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. + * If we need to access it before the env is relocated, then we need + * to use our own stack buffer. gd->env_buf will be too small. + * + * @param buf temporary buffer pointer MTDPARTS_LEN long + * @return mtdparts variable string, NULL if not found + */ +static const char *env_get_mtdparts(const char *str, char *buf) +{ + if (gd->flags & GD_FLG_ENV_READY) + return env_get(str); + if (env_get_f(str, buf, MTDPARTS_LEN) != -1) + return buf; + + return NULL; +} + +/** + * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> + */ +static void board_get_mtdparts(const char *dev, + char *mtdids, + char *mtdparts) +{ + char env_name[32] = "mtdparts_"; + char tmp_mtdparts[MTDPARTS_LEN]; + const char *tmp; + + /* name of env variable to read = mtdparts_<dev> */ + strcat(env_name, dev); + tmp = env_get_mtdparts(env_name, tmp_mtdparts); + if (tmp) { + /* mtdids: "<dev>=<dev>, ...." */ + if (mtdids[0] != '\0') + strcat(mtdids, ","); + strcat(mtdids, dev); + strcat(mtdids, "="); + strcat(mtdids, dev); + + /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ + if (mtdparts[0] != '\0') + strncat(mtdparts, ";", MTDPARTS_LEN); + else + strcat(mtdparts, "mtdparts="); + strncat(mtdparts, dev, MTDPARTS_LEN); + strncat(mtdparts, ":", MTDPARTS_LEN); + strncat(mtdparts, tmp, MTDPARTS_LEN); + } +} + +void board_mtdparts_default(const char **mtdids, const char **mtdparts) +{ + struct udevice *dev; + static char parts[2 * MTDPARTS_LEN + 1]; + static char ids[MTDIDS_LEN + 1]; + static bool mtd_initialized; + + if (mtd_initialized) { + *mtdids = ids; + *mtdparts = parts; + return; + } + + memset(parts, 0, sizeof(parts)); + memset(ids, 0, sizeof(ids)); + + if (!uclass_get_device(UCLASS_MTD, 0, &dev)) + board_get_mtdparts("nand0", ids, parts); + + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) + board_get_mtdparts("nor0", ids, parts); + + mtd_initialized = true; + *mtdids = ids; + *mtdparts = parts; + debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); +} +#endif diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index a28b8b3..254aad1 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -115,6 +115,14 @@
#include <config_distro_bootcmd.h>
+#if defined(CONFIG_STM32_QSPI) || defined(CONFIG_NAND_STM32_FMC) +#define CONFIG_SYS_MTDPARTS_RUNTIME +#endif + +#define STM32MP_MTDPARTS \ + "mtdparts_nor0=256k(fsbl1),256k(fsbl2),2m(ssbl),-(nor_user)\0" \ + "mtdparts_nand0=2m(fsbl),2m(ssbl),-(UBI)\0" + /* * memory layout for 32M uncompressed/compressed kernel, * 1M fdt, 1M script, 1M pxe and 1M for splashimage @@ -130,6 +138,7 @@ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ STM32MP_BOOTCMD \ + STM32MP_MTDPARTS \ BOOTENV
#endif /* ifndef CONFIG_SPL_BUILD */
For platform which can boot on different device, this allows to override interface, device and partition from board code.
env/ext4.c | 34 +++++++++++++++++++++------------- 1 file changed, 21 insertions(+), 13 deletions(-)
diff --git a/env/ext4.c b/env/ext4.c index 388474a..9947381 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -30,6 +30,16 @@ #include <ext4fs.h> #include <mmc.h>
+__weak const char *env_ext4_get_intf(void) +{ + return (const char *)CONFIG_ENV_EXT4_INTERFACE; +} + +__weak const char *env_ext4_get_dev_part(void) +{ + return (const char *)CONFIG_ENV_EXT4_DEVICE_AND_PART; +} + #ifdef CONFIG_CMD_SAVEENV static int env_ext4_save(void) { @@ -38,13 +48,14 @@ static int env_ext4_save(void) disk_partition_t info; int dev, part; int err; + const char *ifname = env_ext4_get_intf(); + const char *dev_and_part = env_ext4_get_dev_part();
err = env_export(&env_new); if (err) return err;
- part = blk_get_device_part_str(CONFIG_ENV_EXT4_INTERFACE, - CONFIG_ENV_EXT4_DEVICE_AND_PART, + part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); if (part < 0) return 1; @@ -54,8 +65,7 @@ static int env_ext4_save(void)
if (!ext4fs_mount(info.size)) { printf("\n** Unable to use %s %s for saveenv **\n", - CONFIG_ENV_EXT4_INTERFACE, - CONFIG_ENV_EXT4_DEVICE_AND_PART); + ifname, dev_and_part); return 1; }
@@ -65,8 +75,7 @@ static int env_ext4_save(void)
if (err == -1) { printf("\n** Unable to write "%s" from %s%d:%d **\n", - CONFIG_ENV_EXT4_FILE, CONFIG_ENV_EXT4_INTERFACE, dev, - part); + CONFIG_ENV_EXT4_FILE, ifname, dev, part); return 1; }
@@ -83,14 +92,15 @@ static int env_ext4_load(void) int dev, part; int err; loff_t off; + const char *ifname = env_ext4_get_intf(); + const char *dev_and_part = env_ext4_get_dev_part();
#ifdef CONFIG_MMC - if (!strcmp(CONFIG_ENV_EXT4_INTERFACE, "mmc")) + if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif
- part = blk_get_device_part_str(CONFIG_ENV_EXT4_INTERFACE, - CONFIG_ENV_EXT4_DEVICE_AND_PART, + part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); if (part < 0) goto err_env_relocate; @@ -100,8 +110,7 @@ static int env_ext4_load(void)
if (!ext4fs_mount(info.size)) { printf("\n** Unable to use %s %s for loading the env **\n", - CONFIG_ENV_EXT4_INTERFACE, - CONFIG_ENV_EXT4_DEVICE_AND_PART); + ifname, dev_and_part); goto err_env_relocate; }
@@ -111,8 +120,7 @@ static int env_ext4_load(void)
if (err == -1) { printf("\n** Unable to read "%s" from %s%d:%d **\n", - CONFIG_ENV_EXT4_FILE, CONFIG_ENV_EXT4_INTERFACE, dev, - part); + CONFIG_ENV_EXT4_FILE, ifname, dev, part); goto err_env_relocate; }
This allows to : - select the current device to save the environment file - select the correct EXT4 boot device instance and partition to save the environment file.
For EXT4, device is mmc, device instance is 0 for sdcard or 1 for eMMC. The partition is set to "auto" to select the first partition with bootable flag.
board/st/stm32mp1/stm32mp1.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 360b0df..316cd48 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -19,6 +19,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/stm32.h> +#include <asm/arch/sys_proto.h> #include <power/regulator.h> #include <usb/dwc2_udc.h>
@@ -505,6 +506,29 @@ void board_quiesce_devices(void) setup_led(LEDST_OFF); }
+#if defined(CONFIG_ENV_IS_IN_EXT4) +const char *env_ext4_get_intf(void) +{ + u32 bootmode = get_bootmode(); + + switch (bootmode & TAMP_BOOT_DEVICE_MASK) { + case BOOT_FLASH_SD: + case BOOT_FLASH_EMMC: + return "mmc"; + default: + return ""; + } +} + +const char *env_ext4_get_dev_part(void) +{ + static char *const dev_part[] = {"0:auto", "1:auto", "2:auto"}; + u32 bootmode = get_bootmode(); + + return dev_part[(bootmode & TAMP_BOOT_INSTANCE_MASK) - 1]; +} +#endif + #ifdef CONFIG_SYS_MTDPARTS_RUNTIME
Allow U-Boot to get default environment for some boot mode (USB for example), and to select storage location when it is booting from flash device; ENVL_NOWHERE is present in env_locations with other one.
env/Kconfig | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 7830066..ca889cc 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -2,18 +2,12 @@ menu "Environment"
config ENV_IS_NOWHERE bool "Environment is not stored" - depends on !ENV_IS_IN_EEPROM - depends on !ENV_IS_IN_EXT4 - depends on !ENV_IS_IN_FAT - depends on !ENV_IS_IN_FLASH - depends on !ENV_IS_IN_MMC - depends on !ENV_IS_IN_NAND - depends on !ENV_IS_IN_NVRAM - depends on !ENV_IS_IN_ONENAND - depends on !ENV_IS_IN_REMOTE - depends on !ENV_IS_IN_SPI_FLASH - depends on !ENV_IS_IN_UBI - default y + default y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ + !ENV_IS_IN_FAT && !ENV_IS_IN_FLASH && \ + !ENV_IS_IN_MMC && !ENV_IS_IN_NAND && \ + !ENV_IS_IN_NVRAM && !ENV_IS_IN_ONENAND && \ + !ENV_IS_IN_REMOTE && !ENV_IS_IN_SPI_FLASH && \ + !ENV_IS_IN_UBI help Define this if you don't want to or can't have an environment stored on a storage medium. In this case the environment will still exist
Introduce ENV_IS_IN_DEVICE to test if one the CONFIG_ENV_IS_IN_ is defined and support the command saveenv even if CONFIG_ENV_IS_NOWHERE is activated
cmd/nvedit.c | 36 +++++++++++++++++++++--------------- 1 file changed, 21 insertions(+), 15 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 24a6cf7..5d723ac 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -39,18 +39,24 @@
DECLARE_GLOBAL_DATA_PTR;
-#if !defined(CONFIG_ENV_IS_IN_EEPROM) && \ - !defined(CONFIG_ENV_IS_IN_FLASH) && \ - !defined(CONFIG_ENV_IS_IN_MMC) && \ - !defined(CONFIG_ENV_IS_IN_FAT) && \ - !defined(CONFIG_ENV_IS_IN_EXT4) && \ - !defined(CONFIG_ENV_IS_IN_NAND) && \ - !defined(CONFIG_ENV_IS_IN_NVRAM) && \ - !defined(CONFIG_ENV_IS_IN_ONENAND) && \ - !defined(CONFIG_ENV_IS_IN_SATA) && \ - !defined(CONFIG_ENV_IS_IN_SPI_FLASH) && \ - !defined(CONFIG_ENV_IS_IN_REMOTE) && \ - !defined(CONFIG_ENV_IS_IN_UBI) && \ +#if defined(CONFIG_ENV_IS_IN_EEPROM) || \ + defined(CONFIG_ENV_IS_IN_FLASH) || \ + defined(CONFIG_ENV_IS_IN_MMC) || \ + defined(CONFIG_ENV_IS_IN_FAT) || \ + defined(CONFIG_ENV_IS_IN_EXT4) || \ + defined(CONFIG_ENV_IS_IN_NAND) || \ + defined(CONFIG_ENV_IS_IN_NVRAM) || \ + defined(CONFIG_ENV_IS_IN_ONENAND) || \ + defined(CONFIG_ENV_IS_IN_SATA) || \ + defined(CONFIG_ENV_IS_IN_SPI_FLASH) || \ + defined(CONFIG_ENV_IS_IN_REMOTE) || \ + defined(CONFIG_ENV_IS_IN_UBI) + +#define ENV_IS_IN_DEVICE + +#endif + +#if !defined(ENV_IS_IN_DEVICE) && \ !defined(CONFIG_ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|MMC|FAT|EXT4|\ NAND|NVRAM|ONENAND|SATA|SPI_FLASH|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE @@ -749,7 +755,7 @@ ulong env_get_ulong(const char *name, int base, ulong default_val) }
#ifndef CONFIG_SPL_BUILD -#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) +#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) static int do_env_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -1205,7 +1211,7 @@ static cmd_tbl_t cmd_env_sub[] = { #if defined(CONFIG_CMD_RUN) U_BOOT_CMD_MKENT(run, CONFIG_SYS_MAXARGS, 1, do_run, "", ""), #endif -#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) +#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), #endif U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 0, do_env_set, "", ""), @@ -1280,7 +1286,7 @@ static char env_help_text[] = #if defined(CONFIG_CMD_RUN) "env run var [...] - run commands in an environment variable\n" #endif -#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) +#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) "env save - save environment\n" #endif #if defined(CONFIG_CMD_NVEDIT_EFI)
Enable ENV_IS_IN_EXT4 and all relative flags to be able to load/save environment in EXT4 partition.
This will allows to load/save environment on both sdcard and eMMC. As for stm32mp15, bootfs has not the same partition number on sdcard and on eMMC, we use "auto" key which allows to find the first partition in device with bootable flag which is partition 4 on sdcard and partition 2 on eMMC.
configs/stm32mp15_basic_defconfig | 5 +++++ configs/stm32mp15_trusted_defconfig | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index f5e13dd..051c1de 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -41,6 +41,11 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="mmc" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" +CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_STM32_ADC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index cae3324..f09f0e4 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -33,6 +33,11 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="mmc" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" +CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_STM32_ADC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000
In case of several environment location support, env_get_location is needed to select the correct location depending of the boot device .
board/st/stm32mp1/stm32mp1.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 316cd48..4f7d24a 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -7,6 +7,7 @@ #include <config.h> #include <clk.h> #include <dm.h> +#include <environment.h> #include <g_dnl.h> #include <generic-phy.h> #include <i2c.h> @@ -506,6 +507,28 @@ void board_quiesce_devices(void) setup_led(LEDST_OFF); }
+enum env_location env_get_location(enum env_operation op, int prio) +{ + u32 bootmode = get_bootmode(); + + if (prio) + return ENVL_UNKNOWN; + + switch (bootmode & TAMP_BOOT_DEVICE_MASK) { +#ifdef CONFIG_ENV_IS_IN_EXT4 + case BOOT_FLASH_SD: + case BOOT_FLASH_EMMC: + return ENVL_EXT4; +#endif +#ifdef CONFIG_ENV_IS_IN_UBI + case BOOT_FLASH_NAND: + return ENVL_UBI; +#endif + default: + return ENVL_NOWHERE; + } +} + #if defined(CONFIG_ENV_IS_IN_EXT4) const char *env_ext4_get_intf(void) {
When ENV_IS_IN_UBI is enable, get_mtdparts is called before relocation.
During first get_mtdparts() call, mtdparts is not available in environment, it can be retrieved by calling board_mtdparts_default(), but following env_set() do nothing as we are before relocation. Finally mtdparts is still not available in environment.
At second get_mtdparts() call, use_defaults is false, but mtdparts is still not in environment and is NULL.
Remove use_defaults bool, only mtdparts criteria is useful.
Fixes: commit 5ffcd50612f6 ("mtd: Use default mtdparts/mtids when not defined in the environment")
drivers/mtd/mtd_uboot.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index d638f70..0a41ed4 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -122,7 +122,6 @@ static const char *get_mtdparts(void) { __maybe_unused const char *mtdids = NULL; static char tmp_parts[MTDPARTS_MAXLEN]; - static bool use_defaults = true; const char *mtdparts = NULL;
if (gd->flags & GD_FLG_ENV_READY) @@ -130,7 +129,7 @@ static const char *get_mtdparts(void) else if (env_get_f("mtdparts", tmp_parts, sizeof(tmp_parts)) != -1) mtdparts = tmp_parts;
- if (mtdparts || !use_defaults) + if (mtdparts) return mtdparts;
#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) @@ -144,8 +143,6 @@ static const char *get_mtdparts(void) if (mtdparts) env_set("mtdparts", mtdparts);
- use_defaults = false; - return mtdparts; }
Move ENV_SIZE from include/configs/stm32mp1.h to arch/arm/mach-stm32mp/Kconfig
Increase ENV_SIZE from 4 to 8 Ko
arch/arm/mach-stm32mp/Kconfig | 3 +++ env/Kconfig | 2 +- include/configs/stm32mp1.h | 5 ----- 3 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 73aa382..5a7f40d 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -23,6 +23,9 @@ config SPL config SYS_SOC default "stm32mp"
+config ENV_SIZE + default 0x2000 + config TARGET_STM32MP1 bool "Support stm32mp1xx" select ARCH_SUPPORT_PSCI if !STM32MP1_TRUSTED diff --git a/env/Kconfig b/env/Kconfig index ca889cc..1091c89 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -464,7 +464,7 @@ config ENV_EXT4_FILE It's a string of the EXT4 file name. This file use to store the environment (explicit path to the file)
-if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARC +if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARC || ARCH_STM32MP
config ENV_OFFSET hex "Environment Offset" diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 254aad1..51f1736 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -43,11 +43,6 @@ */ #define CONFIG_SYS_LOAD_ADDR STM32_DDR_BASE
-/* - * Env parameters - */ -#define CONFIG_ENV_SIZE SZ_4K - /* ATAGs */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS
Add all relative flags needed by ENV_IS_IN_UBI
configs/stm32mp15_basic_defconfig | 4 ++++ configs/stm32mp15_trusted_defconfig | 4 ++++ include/configs/stm32mp1.h | 4 ++++ 3 files changed, 12 insertions(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 051c1de..e8f170d 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -39,13 +39,17 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_UBI=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" +CONFIG_ENV_UBI_PART="UBI" +CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_STM32_ADC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index f09f0e4..61d4467 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -32,12 +32,16 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" +CONFIG_ENV_UBI_PART="UBI" +CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_STM32_ADC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 51f1736..e9bd551 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -43,6 +43,10 @@ */ #define CONFIG_SYS_LOAD_ADDR STM32_DDR_BASE
+#if defined(CONFIG_ENV_IS_IN_UBI) +#define CONFIG_ENV_UBI_VOLUME_REDUND "uboot_config_r" +#endif + /* ATAGs */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS
Add all relative flags needed by ENV_IS_IN_SPI_FLASH
Reserved a 256KB partition in NOR to save the U-Boot environment.
configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + include/configs/stm32mp1.h | 7 ++++++- 3 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index e8f170d..93066aa 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 61d4467..949b56a 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index e9bd551..f541132 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -47,6 +47,11 @@ #define CONFIG_ENV_UBI_VOLUME_REDUND "uboot_config_r" #endif
+#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_SECT_SIZE SZ_256K +#define CONFIG_ENV_OFFSET 0x00280000 +#endif + /* ATAGs */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS @@ -119,7 +124,7 @@ #endif
#define STM32MP_MTDPARTS \ - "mtdparts_nor0=256k(fsbl1),256k(fsbl2),2m(ssbl),-(nor_user)\0" \ + "mtdparts_nor0=256k(fsbl1),256k(fsbl2),2m(ssbl),256k(u-boot-env),-(nor_user)\0" \ "mtdparts_nand0=2m(fsbl),2m(ssbl),-(UBI)\0"
Update env_get_location() to be able to save environment into NOR (SPI_FLASH).
board/st/stm32mp1/stm32mp1.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 4f7d24a..af607c5 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -524,6 +524,10 @@ enum env_location env_get_location(enum env_operation op, int prio) case BOOT_FLASH_NAND: return ENVL_UBI; #endif +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH + case BOOT_FLASH_NOR: + return ENVL_SPI_FLASH; +#endif default: return ENVL_NOWHERE; }
Sorry, i sent one useless patch, i will resend this series
Patrice
This series:
Patrice CHOTARD
Patrice Chotard
