[U-Boot] [Patch V3] drivers: mtd: spi: Add flash property for Micron mt25qu512a
mt25qu512a is rebranded after its spinoff from STM, so it is different only in term of extended jedec ID, initial JEDEC id is same as that of n25q512a.In order to avoid any confussion with respect to name new entry is added.
This flash is tested for Single I/O mode on LS1046FRWY although it also support QUAD I/O.
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v3: 1. Add version info, rebase to top v2: 2. Adding more description in commit msg
drivers/mtd/spi/spi-nor-ids.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index ec92976..d99c4c5 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -163,6 +163,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("n25q128a13", 0x20ba18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, { INFO("n25q256a", 0x20ba19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("n25q256ax1", 0x20bb19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO6("mt25qu512a", 0x20bb20, 0x104400, 64 * 1024, 1024, + SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("n25q512a", 0x20bb20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("n25q512ax3", 0x20ba20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("n25q00", 0x20ba21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) },
Applied to u-boot-spi/master
Ashish Kumar
Jagan Teki
