[PATCH] riscv: ae350: doc: Remove CONFIG_SKIP_LOWLEVEL_INIT
The doc says CONFIG_SKIP_LOWLEVEL_INIT is in ax25-ae350.h, while actually it is not. Remove it.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
doc/board/AndesTech/ax25-ae350.rst | 19 ++++--------------- 1 file changed, 4 insertions(+), 15 deletions(-)
diff --git a/doc/board/AndesTech/ax25-ae350.rst b/doc/board/AndesTech/ax25-ae350.rst index 923649240e..b46f427f4b 100644 --- a/doc/board/AndesTech/ax25-ae350.rst +++ b/doc/board/AndesTech/ax25-ae350.rst @@ -58,15 +58,6 @@ Platform Level Interrupt Controller (PLIC) - Configurable number of targets: 1-16 - Preempted interrupt priority stack
-Configurations --------------- - -CONFIG_SKIP_LOWLEVEL_INIT: - -If you want to boot this system from SPI ROM and bypass e-bios (the -other boot loader on ROM). You should undefine CONFIG_SKIP_LOWLEVEL_INIT -in "include/configs/ax25-ae350.h". - Build and boot steps --------------------
@@ -89,12 +80,10 @@ Verification: Steps -----
-1. Define CONFIG_SKIP_LOWLEVEL_INIT to build u-boot which is loaded via gdb from ram. -2. Undefine CONFIG_SKIP_LOWLEVEL_INIT to build u-boot which is booted from spi rom. -3. Ping a server by mac driver -4. Scan sd card and copy u-boot image which is booted from flash to ram by sd driver. -5. Burn this u-boot image to spi rom by spi driver -6. Re-boot u-boot from spi flash with power off and power on. +1. Ping a server by mac driver +2. Scan sd card and copy u-boot image which is booted from flash to ram by sd driver +3. Burn this u-boot image to spi rom by spi driver +4. Re-boot u-boot from spi flash with power off and power on
Messages of U-Boot boot on AE350 board --------------------------------------
Bin Meng
