[U-Boot] [PATCH V2] mx6: Support SKS-Kinkel sksimx6 Board
Board has 1GB RAM and boots from SD Card
U-Boot SPL 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54) BT_FUSE_SEL already fused, will do nothing Trying to boot from MMC1
U-Boot 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54 +0100)
CPU: Freescale i.MX6DL rev1.2 996 MHz (running at 792 MHz) CPU: Commercial temperature grade (0C to 95C) at 40C Reset cause: POR I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME]
Signed-off-by: Stefano Babic sbabic@denx.de ---
Changes since V1: - use a single if instead of switch for getcd (F. Estevam) - drop unused PHYS_SDRAM_SIZE (F. Estevam)
arch/arm/mach-imx/mx6/Kconfig | 5 + board/sks-kinkel/sksimx6/Kconfig | 11 + board/sks-kinkel/sksimx6/MAINTAINERS | 6 + board/sks-kinkel/sksimx6/Makefile | 3 + board/sks-kinkel/sksimx6/sksimx6.c | 426 +++++++++++++++++++++++++++++++++++ configs/sksimx6_defconfig | 47 ++++ include/configs/sksimx6.h | 101 +++++++++ 7 files changed, 599 insertions(+) create mode 100644 board/sks-kinkel/sksimx6/Kconfig create mode 100644 board/sks-kinkel/sksimx6/MAINTAINERS create mode 100644 board/sks-kinkel/sksimx6/Makefile create mode 100644 board/sks-kinkel/sksimx6/sksimx6.c create mode 100644 configs/sksimx6_defconfig create mode 100644 include/configs/sksimx6.h
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 18e1e67..42d4fa9 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -374,6 +374,10 @@ config TARGET_PFLA02 config TARGET_SECOMX6 bool "secomx6 boards"
+config TARGET_SKSIMX6 + bool "sks-imx6" + select SUPPORT_SPL + config TARGET_TBS2910 bool "TBS2910 Matrix ARM mini PC"
@@ -479,6 +483,7 @@ source "board/liebherr/display5/Kconfig" source "board/liebherr/mccmon6/Kconfig" source "board/logicpd/imx6/Kconfig" source "board/seco/Kconfig" +source "board/sks-kinkel/sksimx6/Kconfig" source "board/solidrun/mx6cuboxi/Kconfig" source "board/technexion/pico-imx6ul/Kconfig" source "board/tbs/tbs2910/Kconfig" diff --git a/board/sks-kinkel/sksimx6/Kconfig b/board/sks-kinkel/sksimx6/Kconfig new file mode 100644 index 0000000..3efdf9d --- /dev/null +++ b/board/sks-kinkel/sksimx6/Kconfig @@ -0,0 +1,11 @@ +if TARGET_SKSIMX6 + +config SYS_BOARD + default "sksimx6" + +config SYS_VENDOR + default "sks-kinkel" + +config SYS_CONFIG_NAME + default "sksimx6" +endif diff --git a/board/sks-kinkel/sksimx6/MAINTAINERS b/board/sks-kinkel/sksimx6/MAINTAINERS new file mode 100644 index 0000000..c1527bf --- /dev/null +++ b/board/sks-kinkel/sksimx6/MAINTAINERS @@ -0,0 +1,6 @@ +SKS-Kinkel sksimx6 +M: Stefano Babic sbabic@denx.de +S: Maintained +F: board/sks-kinkel/sksimx6/ +F: include/configs/sksimx6.h +F: configs/sksimx6_defconfig diff --git a/board/sks-kinkel/sksimx6/Makefile b/board/sks-kinkel/sksimx6/Makefile new file mode 100644 index 0000000..676a007 --- /dev/null +++ b/board/sks-kinkel/sksimx6/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +obj-y := sksimx6.o diff --git a/board/sks-kinkel/sksimx6/sksimx6.c b/board/sks-kinkel/sksimx6/sksimx6.c new file mode 100644 index 0000000..d50d408 --- /dev/null +++ b/board/sks-kinkel/sksimx6/sksimx6.c @@ -0,0 +1,426 @@ +/* + * Copyright (C) 2016 Stefano Babic sbabic@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <linux/errno.h> +#include <asm/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/video.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <asm/arch/crm_regs.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> +#include <netdev.h> +#include <miiphy.h> +#include <micrel.h> + +#include <common.h> +#include <malloc.h> +#include <fuse.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const gpios_pads[] = { + IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL)),/* CD */ +}; + +static iomux_v3_cfg_t const enet_pads[] = { + IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | + MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | + MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | + MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +iomux_v3_cfg_t const enet_pads1[] = { + /* pin 35 - 1 (PHY_AD2) on reset */ + IOMUX_PADS(PAD_RGMII_RXC__GPIO6_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 32 - 1 - (MODE0) all */ + IOMUX_PADS(PAD_RGMII_RD0__GPIO6_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 31 - 1 - (MODE1) all */ + IOMUX_PADS(PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 28 - 1 - (MODE2) all */ + IOMUX_PADS(PAD_RGMII_RD2__GPIO6_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 27 - 1 - (MODE3) all */ + IOMUX_PADS(PAD_RGMII_RD3__GPIO6_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + IOMUX_PADS(PAD_RGMII_RX_CTL__GPIO6_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL)), + /* pin 42 PHY nRST */ + IOMUX_PADS(PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +static int mx6_rgmii_rework(struct phy_device *phydev) +{ + + /* min rx data delay */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, + 0x0); + /* min tx data delay */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, + 0x0); + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, + 0xf0f0); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + mx6_rgmii_rework(phydev); + + if (phydev->drv->config) + return phydev->drv->config(phydev); + + return 0; +} + +#define ENET_NRST IMX_GPIO_NR(1, 25) + +void setup_iomux_enet(void) +{ + SETUP_IOMUX_PADS(enet_pads); + +} + +int board_eth_init(bd_t *bis) +{ + uint32_t base = IMX_FEC_BASE; + struct mii_dev *bus = NULL; + struct phy_device *phydev = NULL; + int ret; + + setup_iomux_enet(); + + bus = fec_get_miibus(base, -1); + if (!bus) + return -EINVAL; + /* scan phy */ + phydev = phy_find_by_mask(bus, (0xf << CONFIG_FEC_MXC_PHYADDR), + PHY_INTERFACE_MODE_RGMII); + + if (!phydev) { + ret = -EINVAL; + goto free_bus; + } + ret = fec_probe(bis, -1, base, bus, phydev); + if (ret) + goto free_phydev; + + return 0; + +free_phydev: + free(phydev); +free_bus: + free(bus); + return ret; +} + +int board_early_init_f(void) +{ + SETUP_IOMUX_PADS(uart1_pads); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + /* Take in reset the ATMega processor */ + SETUP_IOMUX_PADS(gpios_pads); + gpio_direction_output(IMX_GPIO_NR(5, 4), 0); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC2_BASE_ADDR, 0}, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 0) +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + if (cfg->esdhc_base == USDHC2_BASE_ADDR) + ret = 1; + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int ret; + + SETUP_IOMUX_PADS(usdhc2_pads); + gpio_direction_input(USDHC2_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[0].max_bus_width = 4; + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[0]); + if (ret) { + printf("Warning: failed to initialize mmc dev \n"); + return ret; + } + + return 0; +} + +#if defined(CONFIG_SPL_BUILD) +#include <asm/arch/mx6-ddr.h> + +/* + * Driving strength: + * 0x30 == 40 Ohm + * 0x28 == 48 Ohm + */ +#define IMX6SDL_DRIVE_STRENGTH 0x230 + + +/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ +struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { + .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, + .dram_cas = IMX6SDL_DRIVE_STRENGTH, + .dram_ras = IMX6SDL_DRIVE_STRENGTH, + .dram_reset = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = IMX6SDL_DRIVE_STRENGTH, + .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, + .grp_ddrmode = 0x00020000, + .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, +}; + +/* MT41K128M16JT-125 */ +static struct mx6_ddr3_cfg mt41k128m16jt_125 = { + /* quad = 1066, duallite = 800 */ + .mem_speed = 1066, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 0, +}; + +static struct mx6_mmdc_calibration mx6dl_1g_mmdc_calib = { + .p0_mpwldectrl0 = 0x0043004E, + .p0_mpwldectrl1 = 0x003D003F, + .p1_mpwldectrl0 = 0x00230021, + .p1_mpwldectrl1 = 0x0028003E, + .p0_mpdgctrl0 = 0x42580250, + .p0_mpdgctrl1 = 0x0238023C, + .p1_mpdgctrl0 = 0x422C0238, + .p1_mpdgctrl1 = 0x02180228, + .p0_mprddlctl = 0x44464A46, + .p1_mprddlctl = 0x44464A42, + .p0_mpwrdlctl = 0x36343236, + .p1_mpwrdlctl = 0x36343230, +}; + +/* DDR 64bit 1GB */ +static struct mx6_ddr_sysinfo mem_qdl = { + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 1, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, + .refsel = 1, /* Refresh cycles at 32KHz */ + .refr = 7, /* 8 refresh commands per refresh cycle */ +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* set the default clock gate to save power */ + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0xFFFFFFFF, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void spl_dram_init(void) +{ + if (is_cpu_type(MXC_CPU_MX6DL)) { + mt41k128m16jt_125.mem_speed = 800; + mem_qdl.rtt_nom = 1; + mem_qdl.rtt_wr = 1; + + mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_qdl, &mx6dl_1g_mmdc_calib, &mt41k128m16jt_125); + } else { + printf("Wrong CPU for this board\n"); + return; + } + + udelay(100); + +#ifdef CONFIG_MX6_DDRCAL + + /* Perform DDR DRAM calibration */ + mmdc_do_write_level_calibration(&mem_qdl); + mmdc_do_dqs_calibration(&mem_qdl); +#endif +} + +static void check_bootcfg(void) +{ + u32 val5, val6; + + fuse_sense(0, 5, &val5); + fuse_sense(0, 6, &val6); + /* Check if boot from MMC */ + if (val6 & 0x10) { + puts("BT_FUSE_SEL already fused, will do nothing\n"); + return; + } + fuse_prog(0, 5, 0x00000840); + /* BT_FUSE_SEL */ + fuse_prog(0, 6, 0x00000010); + + do_reset(NULL, 0, 0, NULL); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + gpr_init(); + + /* iomux */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Set fuses for new boards and reboot if not set */ + check_bootcfg(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig new file mode 100644 index 0000000..4543996 --- /dev/null +++ b/configs/sksimx6_defconfig @@ -0,0 +1,47 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_SKSIMX6=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_BOOTDELAY=1 +CONFIG_SILENT_CONSOLE=y +CONFIG_SILENT_U_BOOT_ONLY=y +CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL=y +CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DM=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_NETDEVICES=y +CONFIG_FEC_MXC=y +CONFIG_DM_THERMAL=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/sksimx6.h b/include/configs/sksimx6.h new file mode 100644 index 0000000..c635e9f --- /dev/null +++ b/include/configs/sksimx6.h @@ -0,0 +1,101 @@ +/* + * Copyright (C) Stefano Babic sbabic@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#ifndef __SKSIMX6_CONFIG_H +#define __SKSIMX6_CONFIG_H + +#include <config_distro_defaults.h> + +#include "mx6_common.h" +#include "imx6_spl.h" + +/* Thermal */ +#define CONFIG_IMX_THERMAL + +/* Serial */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (8 * SZ_1M) + +/* Ethernet */ +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0x01 + +#define CONFIG_MII +#define CONFIG_PHY_MICREL_KSZ9021 + +/* I2C Configs */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C2 +#define CONFIG_SYS_I2C_SPEED 100000 + +/* Filesystem support */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* MMC Configs */ +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 1 + +/* Environment organization */ +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "addcons=setenv bootargs ${bootargs} " \ + "console=${console},${baudrate}\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:${hostname}:${netdev}:off\0" \ + "addmisc=setenv bootargs ${bootargs} ${miscargs}\0" \ + "bootcmd=run mmcboot\0" \ + "bootfile=uImage\0" \ + "bootimage=uImage\0" \ + "console=ttymxc0\0" \ + "fdt_addr_r=0x18000000\0" \ + "fdt_file=imx6dl-sks-cts.dtb\0" \ + "fdt_high=0xffffffff\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "miscargs=quiet\0" \ + "mmcargs=setenv bootargs root=${mmcroot} rw rootwait\0" \ + "mmcboot=if run mmcload;then " \ + "run mmcargs addcons addmisc;" \ + "bootm;fi\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:${mmcpart} ${kernel_addr_r} boot/fitImage\0"\ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p1\0" \ + "net_nfs=tftp ${kernel_addr_r} ${board_name}/${bootfile};" \ + "tftp ${fdt_addr_r} ${board_name}/${fdt_file};" \ + "run nfsargs addip addcons addmisc;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "nfsargs=setenv bootargs root=/dev/nfs " \ + "nfsroot=${serverip}:${nfsroot},v3 panic=1\0" + +#endif
Hi Stefano,
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Fabio Estevam
Stefano Babic
