[U-Boot] [PATCH v2] ARM: phytec: pcm051: select board revision by Kconfig
This add a Kconfig entry that allows to set the board revision in menuconfig. So the deprecated CONFIG_SYS_EXTRA_OPTIONS is no longer needed for this boad.
Signed-off-by: Lars Poeschel poeschel@lemonage.de --- arch/arm/Kconfig | 19 +++++++++++++++++-- board/phytec/pcm051/Kconfig | 11 +++++++++-- board/phytec/pcm051/board.c | 2 +- configs/pcm051_rev1_defconfig | 3 +-- configs/pcm051_rev3_defconfig | 3 +-- 5 files changed, 29 insertions(+), 9 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 2985e6e..193a111 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -333,13 +333,28 @@ config TARGET_AM335X_IGEP0033 select DM_SERIAL select DM_GPIO
-config TARGET_PCM051 - bool "Support pcm051" +config TARGET_PCM051_REV1 + bool "Support pcm051 board revision 1 or 2" select CPU_V7 select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO + help + If you have 1358.1 written on the pcb of your pcm051, you + have a revision 1 board. Likewise if you have 1358.2 on your + board, it is a revision 2 board and this entry is for you. + +config TARGET_PCM051_REV3 + bool "Support pcm051 board revision 3" + select CPU_V7 + select SUPPORT_SPL + select DM + select DM_SERIAL + select DM_GPIO + help + If you have 1358.3 written on the pcb of your pcm051, you + have a revision 3 board and you have to select this entry.
config TARGET_DRACO bool "Support draco" diff --git a/board/phytec/pcm051/Kconfig b/board/phytec/pcm051/Kconfig index 2cc0d88..5981c72 100644 --- a/board/phytec/pcm051/Kconfig +++ b/board/phytec/pcm051/Kconfig @@ -1,7 +1,14 @@ -if TARGET_PCM051 +if TARGET_PCM051_REV1 || TARGET_PCM051_REV3
+if TARGET_PCM051_REV1 config SYS_BOARD - default "pcm051" + default "pcm051rev1" +endif + +if TARGET_PCM051_REV3 +config SYS_BOARD + default "pcm051rev3" +endif
config SYS_VENDOR default "phytec" diff --git a/board/phytec/pcm051/board.c b/board/phytec/pcm051/board.c index 1bf9d73..3e01c01 100644 --- a/board/phytec/pcm051/board.c +++ b/board/phytec/pcm051/board.c @@ -49,7 +49,7 @@ const struct dpll_params *get_dpll_ddr_params(void) return &dpll_ddr; }
-#ifdef CONFIG_REV1 +#ifdef CONFIG_TARGET_PCM051_REV1 const struct ctrl_ioregs ioregs = { .cm0ioctl = MT41J256M8HX15E_IOCTRL_VALUE, .cm1ioctl = MT41J256M8HX15E_IOCTRL_VALUE, diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 1ea9333..239ed70 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -1,5 +1,4 @@ CONFIG_ARM=y -CONFIG_TARGET_PCM051=y +CONFIG_TARGET_PCM051_REV1=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="REV1" CONFIG_CMD_NET=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index a0a32f6..7992dc3 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -1,5 +1,4 @@ CONFIG_ARM=y -CONFIG_TARGET_PCM051=y +CONFIG_TARGET_PCM051_REV3=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="REV3" CONFIG_CMD_NET=y
Doesn't work for me: arm: + pcm051_rev3 +(pcm051_rev3) scripts/Makefile.build:56: board/phytec/pcm051rev3/Makefile: No such file or directory +(pcm051_rev3) make[2]: *** No rule to make target `board/phytec/pcm051rev3/Makefile'. Stop. +(pcm051_rev3) make[1]: *** [board/phytec/pcm051rev3] Error 2 +(pcm051_rev3) make: *** [sub-make] Error 2 arm: + am335x_boneblack_vboot +(am335x_boneblack_vboot) make[1]: *** [checkdtc] Error 1 +(am335x_boneblack_vboot) make: *** [sub-make] Error 2 arm: + pcm051_rev1 +(pcm051_rev1) scripts/Makefile.build:56: board/phytec/pcm051rev1/Makefile: No such file or directory +(pcm051_rev1) make[2]: *** No rule to make target `board/phytec/pcm051rev1/Makefile'. Stop. +(pcm051_rev1) make[1]: *** [board/phytec/pcm051rev1] Error 2 +(pcm051_rev1) make: *** [sub-make] Error 2
