[PATCH] arm64: zynqmp: Remove ltc2954 node
Remove already disabled node. GPIO connections are handled by pmufw that's why there is no reason to have it described for non secure firmware. If someone wants to handle it from OS revert this patch and also update PMUFW configuration and pinctrl setting for these GPIO pins.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-zcu100-revC.dts | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu100-revC.dts b/arch/arm/dts/zynqmp-zcu100-revC.dts index 49d5cdbba585..c5945067cd57 100644 --- a/arch/arm/dts/zynqmp-zcu100-revC.dts +++ b/arch/arm/dts/zynqmp-zcu100-revC.dts @@ -103,15 +103,6 @@ }; };
- ltc2954: ltc2954 { /* U7 */ - compatible = "lltc,ltc2954", "lltc,ltc2952"; - status = "disabled"; - trigger-gpios = <&gpio 26 GPIO_ACTIVE_LOW>; /* INT line - input */ - /* If there is HW watchdog on mezzanine this signal should be connected there */ - watchdog-gpios = <&gpio 35 GPIO_ACTIVE_HIGH>; /* MIO on PAD */ - kill-gpios = <&gpio 34 GPIO_ACTIVE_LOW>; /* KILL signal - output */ - }; - wmmcsdio_fixed: fixedregulator-mmcsdio { compatible = "regulator-fixed"; regulator-name = "wmmcsdio_fixed";
Applied. M
Michal Simek
