[U-Boot] [PATCH v1] imx: defconfig: Enable CONFIG_SPL_FORCE_MMC_BOOT on display5
After the following commit: commit 772b55723bcb ("imx: Introduce CONFIG_SPL_FORCE_MMC_BOOT to force MMC boot on falcon mode") it is possible to set the CONFIG_SPL_FORCE_MMC_BOOT flag, which allows using MMC device as boot device regardless of the device used by Boot ROM (FBL) as the first boot medium.
Display5 board needs this flag set to allow falcon boot from eMMC device.
Signed-off-by: Lukasz Majewski lukma@denx.de
configs/display5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 3227249413e4..91b369532d94 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SAVEENV=y CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_FORCE_MMC_BOOT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000
After the following commit: commit 772b55723bcb ("imx: Introduce CONFIG_SPL_FORCE_MMC_BOOT to force MMC boot on falcon mode") it is possible to set the CONFIG_SPL_FORCE_MMC_BOOT flag, which allows using MMC device as boot device regardless of the device used by Boot ROM (FBL) as the first boot medium. Display5 board needs this flag set to allow falcon boot from eMMC device. Signed-off-by: Lukasz Majewski lukma@denx.de
Best regards, Stefano Babic
Lukasz Majewski
sbabic@denx.de
