[U-Boot-Users] DDR-II @ MPC8343A
All,
has anyone set up the DDR-II controller on a Freescale MPC8343A without ? As far as I can see there are only DDR-I boards from Freescale.
Are there any patches not yet posted to handle this ?
regards,
Andre Schwarz Matrix Vision
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Hi Andre,
Chances are that the MPC8343 DDR controller is much the same as the MPC8349EA controller. Here's a couple of annotated BDI2000 configuration files for the MPC8349E-MDS-PB loaded with 2.5V DDR1, and the MPC8349EA-MDS-PB board loaded with 1.8V DDR2
ftp://www.denx.de/pub/BDI2000/mpc8349e_mds_pb.cfg ftp://www.denx.de/pub/BDI2000/mpc8349ea_mds_pb.cfg
I'm not sure if it'll be of use, just wanted to mention it.
The U-Boot code for the MPC8349 handles both board types transparently. I haven't delved into the code in too much detail, but I think the code is using the SPD EEPROM information to configure the controller appropriately for DDR1 or DDR2 operation. You can probably use that code as a reference to any changes required for your MPC8343 code.
Regards, Dave
On Tue, 25 Mar 2008 18:36:47 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
All,
without what?
The MDS can do ddr2:
U-Boot 1.3.2-00097-gbc508d1 (Mar 25 2008 - 10:47:17) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c1, MPC8349E, Rev: 30 at 528 MHz, CSB: 264 MHz Board: Freescale MPC8349EMDS I2C: ready SPI: ready DRAM: 256 MB (DDR2, 64-bit, ECC on) ...
should work, only diff I see is that the 8343 is 32-bit only.
Kim
All,
without what?
typo - sorry.
Hmmm ... I get :
U-Boot 1.3.2-00075-gc5f497a-dirty (Mar 25 2008 - 19:55:00) MPC83XX
Reset Status: Check Stop, External/Internal Soft, External/Internal Hard
CPU: e300c1, MPC8343, Rev: 31 at 399.999 MHz, CSB: 266 MHz Board: Matrix Vision mvBlueLYNX-M7 I2C: ready SPI: ready DRAM: cs0_bnds = 0x0000000f cs0_config = 0x80844102 DDR:bar=0x00000000 DDR:ar=0x8000001b 256 MB
It's a 32-Bit DDR-II without ECC. 2 Chips are soldered to CS0, i.e. no EPROM present.
Since I expect something like "(DDR2, 32-Bit, ECC off)" and nothing happens there is obviously something wrong with my memory setup. Is this reasonable ?
Or am I simply missing a board specific "board_add_ram_info" ? Am I assuming right that your info string "(DDR2, 64-bit, ECC on)" comes from spd_sdram ?
Kim
I'll dig a little deeper now and ask more questions tommorow.
Thanks for your help !
regards, Andre
On Tue, 25 Mar 2008 20:41:41 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
Hmmm ... I get :
sounds like memory isn't being configured correctly. Board specific?
you can do that if you really, really, really want to see the "(DDR2.." string, but it's optional.
yes.
Kim
Hmmm ... I get :
Having a closer look to the boards show that I'm currently using 2 Micron MT47H256M8HG-3 with 2GBit each yielding a total of 512MByte DDR-II memory .... this is sad :-( Regarding to part list there should have been 1GBit Elpida chips on it.
I've seen things like this in mpc8349emds code :
#if (CFG_DDR_SIZE != 256) #warning Currenly any ddr size other than 256 is not supported #endif
Is this reasonable ? Why ?
I don't want to see it but to understand where it comes from.
yes.
Kim
regards, Andre
On Tue, 25 Mar 2008 21:25:45 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
that's in the fixed sdram init code, which could be considered reasonably unreasonable by some I suppose, since we can't guarantee the fixed settings will work with whatever memory you decide to use with it. It should work with the memory that comes with the board, though.
btw, the spd code is being used by default on the 834x mds, not this fixed_sdram stuff - it's mostly there for board porting completeness.
Kim
fixed_sdram is ok - that's what I have and want to use. I'm setting up the proper CFG_DDR_ defines in my header regarding the Manufacturer's spec.
But it is known to work, isn't it ?
Kim
regards, Andre
On Tue, 25 Mar 2008 21:54:53 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
I haven't tested it recently. Patches welcome if it doesn't.
Kim
Andre Schwarz
David Hawkins
Kim Phillips
