[U-Boot] Porting u-boot to new PPC440EP board
Hi, I use a new board designing based on PPC440EP evaluating board, called yosemite. I use u-boot version 1.3.1. I reduce the SDRAM and Flash size to 128M and 16M, I do the porting works as decribed in th maillist"new board SDRAM conf",which you posted in last year. http://lists.denx.de/pipermail/u-boot/2008-November/042924.html and now face the same problem when u-boot run to trap_init, and get the same error message. When I add blr instruction to the trap_init function, it return but hang befor main loop. Would you like tell me how did you solve the problem , or how can I completely porting u-boot to the new board.
Best regards, Yangguang
##########Board configuration deference############ ##Yosemite Cofiguration## FLASH (CS0) 64MBYTE NOR Flash (s29GL512N) SDRAM bank 0- 128MB bank 1- 128MB ## My Board configuration## FLASH (CS0) 16MBYTE NOR Flash (s29GL128N) SDRAM bank 0- 128MB bank 1- NONE
#########Error message when run to trap_init######### U-Boot 1.3.1 (Jul 3 2009 - 10:36:26) CPU: AMCC PowerPC 440EP Rev. C at 333.333 MHz (PLB=133, OPB=66, EBC=33 MHz) I2C boot EEPROM disabled Bootstrap Option E - Boot ROM Location EBC (16 bits) Internal PCI arbiter enabled, PCI async ext clock used 32 kB I-Cache 32 kB D-Cache Board: Yosemite - AMCC PPC440EP Evaluatio I2C: ready DRAM: 128 MB Top of RAM usable for U-Boot at: 08000000 Reserving 555k for U-Boot at: 07f75000 Reserving 264k for malloc() at: 07f33000 Reserving 144 Bytes for Board Info at: 07f32f70 Reserving 48 Bytes for Global Data at: 07f32f40 Stack Pointer at: 07f32f28 New Stack Pointer is: 07f32f28 in board_init_f, before relocate_code in board_init_r Now running in RAM - U-Boot at: 07f75000 in board_init_r, before board_early_init_r in board_init_r, after board_early_init_r in board_init_r, after relocate command table in board_init_r, before trap_init Bus Fault @ 0x07f7773c, fixup 0x00000000 Machine Check Exception. Caused by (from msr): regs 07f32e00 Data Read PLB Error Machine Check exception is imprecise NIP: 07F7773C XER: 20000000 LR: 07F7773C REGS: 07f32e00 TRAP: 0200 DEAR: 0000000 0 MSR: 00021000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00 GPR00: 07F77314 07F32EF0 0000051B 07F75000 07F7E1C8 00000000 00000000 07F7773C GPR08: 00000600 00002098 03F940AA 13DE4354 07F32CB8 00000000 07FB4500 07FF5000 GPR16: 00000400 00000000 00000000 00000000 00000000 00000000 00000000 70002000 GPR24: 07F75000 07F32F28 07F32F70 07F35000 07F32F40 07F32F40 07FB46A8 00000000 Call backtrace: 07F7E1C0 07F776B0 machine check ### ERROR ### Please RESET the board ###
#########Error message when add blr to the trap_init function######### U-Boot 1.3.1 (Jul 3 2009 - 09:25:59) CPU: AMCC PowerPC 440EP Rev. C at 333.333 MHz (PLB=133, OPB=66, EBC=33 MHz) I2C boot EEPROM disabled Bootstrap Option E - Boot ROM Location EBC (16 bits) Internal PCI arbiter enabled, PCI async ext clock used 32 kB I-Cache 32 kB D-Cache Board: Yosemite - AMCC PPC440EP Evaluation Board, Rev. FF, PCI=66 MHz I2C: ready DRAM: 128 MB Top of RAM usable for U-Boot at: 08000000 Reserving 555k for U-Boot at: 07f75000 Reserving 264k for malloc() at: 0 Reserving 144 Bytes for Board Info at: 07f32f70 Reserving 48 Bytes for Global Data at: 07f32f40 Stack Pointer at: 07f32f28 New Stack Pointer is: 07f32f28 in board_init_f, before relocate_code in board_init_r Now running in RAM - U-Boot at: 07f75000 in board_init_r, before board_early_init_r in board_init_r, after board_early_init_r in board_init_r, after relocate command table in board_init_r, before trap_init in board_init_r, after trap_init FLASH: flash detect cfi fwc addr ff000000 cmd 0 0 8bit x 8 bit fwc addr ff000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff000010 is= ff 51 fwc addr ff000555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff000010 is= ff 51 fwc addr ff000000 cmd 0 0000 16bit x 8 bit fwc addr ff0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr ff000020 is= 0051 5151 fwc addr ff000aaa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr ff000020 is= 0051 5151 fwc addr ff000000 cmd 0 0000 16bit x 16 bit fwc addr ff0000aa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr ff000020 is= 0051 0051 is= cmd 52(R) addr ff000022 is= 0052 0052 is= cmd 59(Y) addr ff000024 is= 0059 0059 ushort addr is at ff000050 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x2 addr[2] = 0x0 addr[3] = 0x0 retval = 0x2 device interface is 2 found port 2 chip 2 port 16 bits chip 16 bits ushort addr is at ff000026 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x2 addr[2] = 0x0 addr[3] = 0x0 retval = 0x2 fwc addr ff000000 cmd f0 00f0 16bit x 16 bit fwc addr ff000aaa cmd aa 00aa 16bit x 16 bit fwc addr ff000554 cmd 55 0055 16bit x 16 bit fwc addr ff000aaa cmd 90 0090 16bit x 16 bit fwc addr ff000000 cmd f0 00f0 16bit x 16 bit fwc addr ff0000aa cmd 98 0098 16bit x 16 bit ushort addr is at ff00002a info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x40 addr[2] = 0x0 addr[3] = 0x0 retval = 0x40 ff000020 : 00 51 00 52 00 59 00 02 00 00 00 40 00 00 00 00 .Q.R.Y.....@.... ff000030 : 00 00 00 00 00 00 00 27 00 36 00 00 00 00 00 07 .......'.6...... ff000040 : 00 07 00 0a 00 00 00 03 00 05 00 04 00 00 00 18 ................ ff000050 : 00 02 00 00 00 05 00 00 00 01 00 7f 00 00 00 00 ................ ff000060 : 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ff000070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ff000080 : 00 50 00 52 00 49 00 31 00 33 00 10 00 02 00 01 .P.R.I.1.3...... ff000090 : 00 00 00 08 00 00 00 00 00 02 00 b5 00 c5 00 05 ................ manufacturer is 2 manufacturer id is 0x1 device id is 0x7e device id2 is 0x2101 cfi version is 0x3133 size_ratio 1 port 16 bits chip found 1 erase regions long addr is at ff00005a info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x7f addr[2] = 0x0 addr[3] = 0x0 addr[4] = 0x0 addr[5] = 0x0 addr[6] = 0x0 addr[7] = 0x2 erase_region_count = 128 erase_region_size = 131072 ushort addr is at ff000054 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x5 addr[2] = 0x0 addr[3] = 0x0 retval = 0x5 fwc addr ff000000 cmd f0 00f0 16bit x 16 bit flash_protect ON: from 0xFFF80000 to 0xFFFBA9FF protect on 124 protect on 125 flash_protect ON: from 0xFFF60000 to 0xFFF7FFFF protect on 123 flash_protect ON: from 0xFFF40000 to 0xFFF41FFF protect on 122 16 MB *** Warning - bad CRC, using default environment PCI: Bus Dev VenId DevId Class Int
1.3.1 is quite old. I strongly suggest that you update to a recent version.
You can't just exit the trap. You need to solve the problem that issuing the trap before you can really proceed further.
This could have several reasons. One is incorrect SDRAM setup. Other are possible as well. Not sure what's going on here.
Best regards, Stefan
Stefan Roese
yangguang3501
