[U-Boot] [PATCH v3 0/3] Add workaround for Cortex-A9 errata
These patches implement workaround for 2 Cortex-A9 erratas. Enable these errata workaround for MX6.
Changes since v2: - Added Acked-by Dirk Behme for PATCH 1/3 - Added Stefano for review
Changes since v1: - Enabled these erratas for MX6 as suggested by Fabio Estevam - Reused code for errata 794072 as suggested by Dirk Behme
Nitin Garg (3): ARM: Add workaround for Cortex-A9 errata 794072 ARM: Add workaround for Cortex-A9 errata 761320 MX6: Enable ARM errata workaround 794072 and 761320
README | 2 ++ arch/arm/cpu/armv7/start.S | 7 ++++++- include/configs/mx6_common.h | 2 ++ 3 files changed, 10 insertions(+), 1 deletions(-)
A short loop including a DMB instruction might cause a denial of service on another processor which executes a CP15 broadcast operation. Exists on r1, r2, r3, r4 revisions.
Signed-off-by: Nitin Garg nitin.garg@freescale.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- README | 1 + arch/arm/cpu/armv7/start.S | 2 +- 2 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/README b/README index 7cb7c4f..a496c65 100644 --- a/README +++ b/README @@ -566,6 +566,7 @@ The following options need to be configured: CONFIG_ARM_ERRATA_742230 CONFIG_ARM_ERRATA_743622 CONFIG_ARM_ERRATA_751472 + CONFIG_ARM_ERRATA_794072
If set, the workarounds for these ARM errata are applied early during U-Boot startup. Note that these options force the diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index ac1e55a..f3830c8 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -205,7 +205,7 @@ ENTRY(cpu_init_cp15) mcr p15, 0, r0, c1, c0, 0 @ write system control register #endif
-#ifdef CONFIG_ARM_ERRATA_742230 +#if (defined(CONFIG_ARM_ERRATA_742230) || defined(CONFIG_ARM_ERRATA_794072)) mrc p15, 0, r0, c15, c0, 1 @ read diagnostic register orr r0, r0, #1 << 4 @ set bit #4 mcr p15, 0, r0, c15, c0, 1 @ write diagnostic register
Full cache line writes to the same memory region from at least two processors might deadlock the processor. Exists on r1, r2, r3 revisions.
Signed-off-by: Nitin Garg nitin.garg@freescale.com --- README | 1 + arch/arm/cpu/armv7/start.S | 5 +++++ 2 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/README b/README index a496c65..b7c0f68 100644 --- a/README +++ b/README @@ -567,6 +567,7 @@ The following options need to be configured: CONFIG_ARM_ERRATA_743622 CONFIG_ARM_ERRATA_751472 CONFIG_ARM_ERRATA_794072 + CONFIG_ARM_ERRATA_761320
If set, the workarounds for these ARM errata are applied early during U-Boot startup. Note that these options force the diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index f3830c8..27be451 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -222,6 +222,11 @@ ENTRY(cpu_init_cp15) orr r0, r0, #1 << 11 @ set bit #11 mcr p15, 0, r0, c15, c0, 1 @ write diagnostic register #endif +#ifdef CONFIG_ARM_ERRATA_761320 + mrc p15, 0, r0, c15, c0, 1 @ read diagnostic register + orr r0, r0, #1 << 21 @ set bit #21 + mcr p15, 0, r0, c15, c0, 1 @ write diagnostic register +#endif
mov pc, lr @ back to my caller ENDPROC(cpu_init_cp15)
Since MX6 is Cortex-A9 r2p10, enable software workaround for errata 794072 and 761320.
Signed-off-by: Nitin Garg nitin.garg@freescale.com --- include/configs/mx6_common.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index eb107d3..8a8920f 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -20,6 +20,8 @@ #define CONFIG_ARM_ERRATA_742230 #define CONFIG_ARM_ERRATA_743622 #define CONFIG_ARM_ERRATA_751472 +#define CONFIG_ARM_ERRATA_794072 +#define CONFIG_ARM_ERRATA_761320 #define CONFIG_BOARD_POSTCLK_INIT
#ifndef CONFIG_SYS_L2CACHE_OFF
