Re: [U-Boot] [PATCH v4] Introduced btrfs file-system with btrload command
+U-Boot et al
On Thu, Mar 7, 2013 at 2:35 AM, Adnan Ali adnan.ali@codethink.co.uk wrote:
Introduces btrfs file-system to read file from volume/sub-volumes with btrload command. This implementation has read-only support. This btrfs implementation is based on syslinux btrfs code, commit 269ebc845ebc8b46ef4b0be7fa0005c7fdb95b8d.
Here are some comments, hope it helps.
v4: btrls command added. v3: patch re-formated. v2: patch error removed.
Signed-off-by: Adnan Ali adnan.ali@codethink.co.uk
Makefile | 1 + common/Makefile | 1 + common/cmd_btr.c | 65 +++ fs/btrfs/Makefile | 51 ++ fs/btrfs/btrfs.c | 1209 ++++++++++++++++++++++++++++++++++++++++++++ fs/btrfs/crc32_c.c | 54 ++ fs/fs.c | 86 +++- include/btrfs.h | 391 ++++++++++++++ include/config_fallbacks.h | 4 + include/fs.h | 1 + 10 files changed, 1860 insertions(+), 3 deletions(-) create mode 100644 common/cmd_btr.c create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 fs/btrfs/crc32_c.c create mode 100644 include/btrfs.h
diff --git a/Makefile b/Makefile index 3305e8c..cc35e7b 100644 --- a/Makefile +++ b/Makefile @@ -261,6 +261,7 @@ endif LIBS-$(CONFIG_OF_EMBED) += dts/libdts.o LIBS-y += arch/$(ARCH)/lib/lib$(ARCH).o LIBS-y += fs/libfs.o \
fs/btrfs/libbtrfs.o \ fs/cbfs/libcbfs.o \ fs/cramfs/libcramfs.o \ fs/ext4/libext4fs.o \
diff --git a/common/Makefile b/common/Makefile index 54fcc81..093dd35 100644 --- a/common/Makefile +++ b/common/Makefile @@ -73,6 +73,7 @@ COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o COBJS-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o +COBJS-$(CONFIG_CMD_BTR) += cmd_btr.o
I actually wonder if you should avoid adding a new command and just use the generic 'load' and 'fs' commands instead?
COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o diff --git a/common/cmd_btr.c b/common/cmd_btr.c new file mode 100644 index 0000000..387e846 --- /dev/null +++ b/common/cmd_btr.c @@ -0,0 +1,65 @@ +/*
- (C) Copyright 2013 Codethink Limited
- Btrfs port to Uboot by
- Adnan Ali adnan.ali@codethink.co.uk
- project.
- MA 02111-1307 USA
- Boot support
+#include <fs.h> +#include <btrfs.h>
+char subvolname[MAX_SUBVOL_NAME];
+int do_btr_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
if (argc > 5)
strcpy(subvolname, argv[5]);
else
strcpy(subvolname, "");
This seems a bit odd. Where does subvolname go within U-Boot?
return do_load(cmdtp, flag, argc, argv, FS_TYPE_BTR, 16);
+U_BOOT_CMD(
btrload, 7, 0, do_btr_fsload,
"load binary file from a btr filesystem",
"<interface> [<dev[:part]>] <addr> <filename> [subvol_name]\n"
" - Load binary file 'filename' from 'dev' on 'interface'\n"
" to address 'addr' from better filesystem.\n"
" the load stops on end of file.\n"
" subvol_name is used read that file from this subvolume.\n"
" All numeric parameters are assumed to be hex."
With the 'load' command we have bytes and pos as two extra arguments. I think your subvol argument should be done another way.
I wonder if it should be '-s <subvol name>' before the arguments?
+static int do_btr_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
return do_ls(cmdtp, flag, argc, argv, FS_TYPE_BTR);
+U_BOOT_CMD(
btrls, 4, 1, do_btr_ls,
"list files in a directory (default /)",
"<interface> [<dev[:part]>] [directory]\n"
" - list files from 'dev' on 'interface' in a 'directory'"
diff --git a/fs/btrfs/Makefile b/fs/btrfs/Makefile new file mode 100644 index 0000000..0dd469c --- /dev/null +++ b/fs/btrfs/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = $(obj)libbtrfs.o
+AOBJS = +COBJS-$(CONFIG_FS_BTR) := crc32_c.o btrfs.o
+SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y))
+all: $(LIB) $(AOBJS)
+$(LIB): $(obj).depend $(OBJS)
$(call cmd_link_o_target, $(OBJS))
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff --git a/fs/btrfs/btrfs.c b/fs/btrfs/btrfs.c new file mode 100644 index 0000000..84a72f4 --- /dev/null +++ b/fs/btrfs/btrfs.c @@ -0,0 +1,1209 @@ +/*
- btrfs.c -- readonly btrfs support for syslinux
- Some data structures are derivated from btrfs-tools-0.19 ctree.h
- Copyright 2009 Intel Corporation; author: alek.du@intel.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, Inc., 53 Temple Place Ste 330,
- Boston MA 02111-1307, USA; either version 2 of the License, or
- (at your option) any later version; incorporated herein by reference.
+#include <linux/stat.h> +#include <command.h> +#include <asm/byteorder.h> +#include <linux/compiler.h> +#include <common.h> +#include <config.h> +#include <fs.h> +#include <btrfs.h> +#include <linux/ctype.h>
Should put:
common first then U-Boot ones, in alpha order then asm then linux
+unsigned long btr_part_offset; +/* Actual file structures (we don't have malloc yet...) */ +struct file files[MAX_OPEN]; +static u32 btrfs_crc32_table[256]; +static block_dev_desc_t *btrfs_block_dev_desc; +static disk_partition_t *part_info; +struct inode parent_inode; +extern char subvolname[MAX_SUBVOL_NAME];
+static void btrfs_init_crc32c(void) +{
- /* Bit-reflected CRC32C polynomial */
- crc32c_init(btrfs_crc32_table, 0x82F63B78);
+static inline u32 crc32c_le(u32 crc, const char *data, size_t length) +{
- return crc32c_cal(crc, data, length, btrfs_crc32_table);
+void btrfs_set_blk_dev(block_dev_desc_t *rbdd, disk_partition_t *info) +{
btrfs_block_dev_desc = rbdd;
part_info = info;
btr_part_offset = info->start;
+void btrfs_type(char num) +{
- switch(num)
case 1: printf("<FILE> "); break;
case 2: printf("<DIR> "); break;
case 7: printf("<SYM> "); break;
Spaces? Can we have enums/#define for these numbers?
default: printf("<UNKNOWN>"); break;
Remove blank line
+/* compare function used for bin_search */ +typedef int (*cmp_func)(void *ptr1, void *ptr2);
+static int bin_search(void *ptr, int item_size, void *cmp_item, cmp_func func,
int min, int max, int *slot)
int low = min;
int high = max;
int mid;
int ret;
unsigned long offset;
void *item;
while (low < high) {
mid = (low + high) / 2;
offset = mid * item_size;
item = ptr + offset;
ret = func(item, cmp_item);
if (ret < 0)
low = mid + 1;
else if (ret > 0)
high = mid;
else {
*slot = mid;
*slot = low;
return 1;
Perhaps put this function in a new lib/bsearch.c file?
+/* XXX: these should go into the filesystem instance structure */ +static struct btrfs_chunk_map chunk_map; +static struct btrfs_super_block sb; +static u64 fs_tree;
+static int btrfs_comp_chunk_map(struct btrfs_chunk_map_item *m1,
struct btrfs_chunk_map_item *m2)
This function could do with a comment.
if (__le64_to_cpu(m1->logical) > __le64_to_cpu(m2->logical))
return 1;
if (__le64_to_cpu(m1->logical) < __le64_to_cpu(m2->logical))
return -1;
+/* insert a new chunk mapping item */ +static void insert_map(struct btrfs_chunk_map_item *item) +{
int ret;
int slot;
int i;
if (chunk_map.map == NULL) { /* first item */
chunk_map.map_length = BTRFS_MAX_CHUNK_ENTRIES;
chunk_map.map = (struct btrfs_chunk_map_item *)
malloc(chunk_map.map_length * sizeof(*chunk_map.map));
chunk_map.map[0] = *item;
chunk_map.cur_length = 1;
return;
ret = bin_search(chunk_map.map, sizeof(*item), item,
(cmp_func)btrfs_comp_chunk_map, 0,
chunk_map.cur_length, &slot);
if (ret == 0)/* already in map */
return;
if (chunk_map.cur_length == BTRFS_MAX_CHUNK_ENTRIES) {
/* should be impossible */
printf("too many chunk items\n");
return;
Should be error return code here, right?
for (i = chunk_map.cur_length; i > slot; i--)
chunk_map.map[i] = chunk_map.map[i-1];
chunk_map.map[slot] = *item;
chunk_map.cur_length++;
- from sys_chunk_array or chunk_tree, we can convert a logical address to
- a physical address we can not support multi device case yet
+static u64 logical_physical(u64 logical)
u64 but below you return -1. Is this an error code? I suggest you fully comment your non-trivial functions with @arg, @return, etc.
struct btrfs_chunk_map_item item;
int slot, ret;
item.logical = logical;
ret = bin_search(chunk_map.map, sizeof(*chunk_map.map), &item,
if (ret == 0)
slot++;
else if (slot == 0)
return -1;
if (logical >=
chunk_map.map[slot-1].logical + chunk_map.map[slot-1].length)
return -1;
return chunk_map.map[slot-1].physical + logical -
chunk_map.map[slot-1].logical;
+int btrfs_devread(int sector, int byte_offset, int byte_len, char* buf) +{
- ALLOC_CACHE_ALIGN_BUFFER(char, sec_buf, SECTOR_SIZE);
- unsigned block_len;
- /* Get the read to the beginning of a partition */
- sector += byte_offset >> SECTOR_BITS;
- byte_offset &= SECTOR_SIZE - 1;
- if (btrfs_block_dev_desc == NULL) {
printf("** Invalid Block Device Descriptor (NULL)\n");
- if (byte_offset != 0) {
/* read first part which isn't aligned with start of sector */
if (btrfs_block_dev_desc->
block_read(btrfs_block_dev_desc->dev,
part_info->start + sector, 1,
(unsigned long *) sec_buf) != 1) {
printf(" ** btrfs_devread() read error **\n");
memcpy(buf, sec_buf + byte_offset,
min(SECTOR_SIZE - byte_offset, byte_len));
buf += min(SECTOR_SIZE - byte_offset, byte_len);
byte_len -= min(SECTOR_SIZE - byte_offset, byte_len);
sector++;
/* read sector aligned part */
block_len = byte_len & ~(SECTOR_SIZE - 1);
if (block_len == 0) {
ALLOC_CACHE_ALIGN_BUFFER(u8, p, SECTOR_SIZE);
block_len = SECTOR_SIZE;
btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev,
1, (unsigned long *)p);
memcpy(buf, p, byte_len);
return 1;
ALLOC_CACHE_ALIGN_BUFFER(u8, t, block_len);
if (btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev,
block_len / SECTOR_SIZE,
(unsigned long *) t) !=
block_len / SECTOR_SIZE) {
printf(" ** %s read error - block\n", __func__);
memcpy(buf, t, block_len);
buf += block_len;
byte_len -= block_len;
sector += block_len / SECTOR_SIZE;
if (byte_len != 0) {
/* read rest of data which are not in whole sector */
printf("* %s read error - last part\n", __func__);
memcpy(buf, sec_buf, byte_len);
- return 1;
So this function returns 1 if OK? I t might be better to return 0 if ok, -ve on error. There is an errno.h file also if you want to use it.
+} +/* btrfs has several super block mirrors, need to calculate their location */ +static inline u64 btrfs_sb_offset(int mirror) +{
u64 start = 16 * 1024;
blank line here
if (mirror)
return start << (BTRFS_SUPER_MIRROR_SHIFT * mirror);
return BTRFS_SUPER_INFO_OFFSET;
+/* find the most recent super block */ +static int btrfs_read_super_block(struct fs_info *fs) +{
int i;
int ret;
u8 fsid[BTRFS_FSID_SIZE];
u8 boots[512];
Does this need to be cache-aligned?
u64 offset;
u64 transid = 0;
struct btrfs_super_block buf;
sb.total_bytes = ~0; /* Unknown as of yet */
/*Only first header is checked for filesystem verification
mirror of this header can be used if required*/
offset = btrfs_sb_offset(0);
if ( btrfs_devread(128, 0, sizeof(struct btrfs_super_block), (char*)&buf)!=1)
return -1;
Extra blank line - actually you should check with patman/checkpatch I think.
if (buf.bytenr != offset ||
strncmp((char *)(&buf.magic), BTRFS_MAGIC, sizeof(buf.magic)))
return -1;
Don't need {}
if (i == 0)
memcpy(fsid, buf.fsid, sizeof(fsid));
else if (memcmp(fsid, buf.fsid, sizeof(fsid)))
return -1;
If this is an error then it's nice to add
debug("%s: Failed to whatever you failed to do...", __func__);
in these cases. In general it's nice to avoid printf() in drivers I think.
if (buf.generation > transid) {
memcpy(&sb, &buf, sizeof(sb));
transid = buf.generation;
+static inline unsigned long btrfs_chunk_item_size(int num_stripes) +{
return sizeof(struct btrfs_chunk) +
sizeof(struct btrfs_stripe) * (num_stripes - 1);
+static void clear_path(struct btrfs_path *path) +{
memset(path, 0, sizeof(*path));
+static int btrfs_comp_keys(struct btrfs_disk_key *k1, struct btrfs_disk_key *k2) +{
if (k1->objectid > k2->objectid)
return 1;
if (k1->objectid < k2->objectid)
return -1;
if (k1->type > k2->type)
return 1;
if (k1->type < k2->type)
return -1;
if (k1->offset > k2->offset)
return 1;
if (k1->offset < k2->offset)
return -1;
+/* compare keys but ignore offset, is useful to enumerate all same kind keys */ +static int btrfs_comp_keys_type(struct btrfs_disk_key *k1,
return 1;
return -1;
return 1;
return -1;
+/* seach tree directly on disk ... */ +static int search_tree(struct fs_info *fs, u64 loffset,
struct btrfs_disk_key *key, struct btrfs_path *path)
u8 buf[BTRFS_MAX_LEAF_SIZE];
struct btrfs_header *header = (struct btrfs_header *)buf;
struct btrfs_node *node = (struct btrfs_node *)buf;
struct btrfs_leaf *leaf = (struct btrfs_leaf *)buf;
int slot, ret;
u64 offset;
offset = logical_physical(loffset);
btrfs_devread(offset/SECTOR_SIZE, (offset%SECTOR_SIZE), sizeof(*header), (char*)header);
if (header->level) {/*node*/
btrfs_devread(((offset+sizeof(*header))/SECTOR_SIZE),((offset+sizeof(*header))%SECTOR_SIZE) ,
__le32_to_cpu(sb.nodesize) - sizeof(*header), (char *)&node->ptrs[0]);
Error check?
path->itemsnr[header->level] = header->nritems;
path->offsets[header->level] = loffset;
ret = bin_search(&node->ptrs[0], sizeof(struct btrfs_key_ptr),
key, (cmp_func)btrfs_comp_keys,
path->slots[header->level], header->nritems, &slot);
if (ret && slot > path->slots[header->level])
slot--;
path->slots[header->level] = slot;
ret = search_tree(fs, node->ptrs[slot].blockptr, key, path);
} else {/*leaf*/
btrfs_devread(((offset+sizeof(*header))/SECTOR_SIZE), ((offset+sizeof(*header))%SECTOR_SIZE),
(sb.leafsize) - sizeof(*header), (char *)&leaf->items);
path->offsets[0] = loffset;
ret = bin_search(&leaf->items[0], sizeof(struct btrfs_item),
key, (cmp_func)btrfs_comp_keys, path->slots[0],
slot--;
path->slots[0] = slot;
path->item = leaf->items[slot];
btrfs_devread(((offset + sizeof(*header) + leaf->items[slot].offset)/SECTOR_SIZE),
((offset + sizeof(*header) + leaf->items[slot].offset)%SECTOR_SIZE),
leaf->items[slot].size, (char*)&path->data);
Error check?
return ret;
+/* return 0 if leaf found */ +static int next_leaf(struct fs_info *fs, struct btrfs_disk_key *key, struct btrfs_path *path) +{
int slot;
int level = 1;
while (level < BTRFS_MAX_LEVEL) {
if (!path->itemsnr[level]) /* no more nodes */
return 1;
slot = path->slots[level] + 1;
if (slot >= path->itemsnr[level]) {
level++;
continue;;
path->slots[level] = slot;
path->slots[level-1] = 0; /* reset low level slots info */
search_tree(fs, path->offsets[level], key, path);
break;
if (level == BTRFS_MAX_LEVEL)
return 1;
BTW it seems pretty common in U-Boot to add a blank line before the return.
+/* return 0 if slot found */ +static int next_slot(struct fs_info *fs, struct btrfs_disk_key *key, struct btrfs_path *path) +{
int slot;
if (!path->itemsnr[0])
return 1;
slot = path->slots[0] + 1;
if (slot >= path->itemsnr[0])
return 1;
search_tree(fs, path->offsets[0], key, path);
Error check on this call?
- read chunk_array in super block
+static void btrfs_read_sys_chunk_array(void) +{
struct btrfs_disk_key *key;
struct btrfs_chunk *chunk;
int cur;
/* read chunk array in superblock */
cur = 0;
while (cur < __le32_to_cpu(sb.sys_chunk_array_size)) {
key = (struct btrfs_disk_key *)(sb.sys_chunk_array + cur);
cur += sizeof(*key);
chunk = (struct btrfs_chunk *)(sb.sys_chunk_array + cur);
cur += btrfs_chunk_item_size(chunk->num_stripes);
/* insert to mapping table, ignore multi stripes */
item.logical = key->offset;
item.length = chunk->length;
item.devid = chunk->stripe.devid;
item.physical = chunk->stripe.offset;/*ignore other stripes */
Another extra line, please fix globally.
insert_map(&item);
+/* read chunk items from chunk_tree and insert them to chunk map */ +static void btrfs_read_chunk_tree(struct fs_info *fs)
Surely this function can fail?
struct btrfs_disk_key search_key;
struct btrfs_path path;
int status;
Inconsistent indent here I think. Please fix globally.
if (!(__le64_to_cpu(sb.flags) & BTRFS_SUPER_FLAG_METADUMP)) {
if (__le64_to_cpu(sb.num_devices) > 1)
printf("warning: only support one btrfs device %d\n",
__le64_to_cpu(sb.num_devices));
return;
/* read chunk from chunk_tree */
search_key.objectid = BTRFS_FIRST_CHUNK_TREE_OBJECTID;
search_key.type = BTRFS_CHUNK_ITEM_KEY;
search_key.offset = 0;
clear_path(&path);
search_tree(fs, (sb.chunk_root), &search_key, &path);
do {
do {
if (status=btrfs_comp_keys_type(&search_key,
&path.item.key))
break;
chunk = (struct btrfs_chunk *)(path.data);
/* insert to mapping table, ignore stripes */
item.logical = path.item.key.offset;
insert_map(&item);
} while (!next_slot(fs, &search_key, &path));
if (btrfs_comp_keys_type(&search_key, &path.item.key))
break;
} while (!next_leaf(fs, &search_key, &path));
+static inline u64 btrfs_name_hash(const char *name, int len) +{
return btrfs_crc32c((u32)~1, name, len);
+static struct inode *btrfs_iget_by_inr(struct fs_info *fs, u64 inr) +{
struct inode *inode;
struct btrfs_inode_item inode_item;
int ret;
/* FIXME: some BTRFS inode member are u64, while our logical inode
is u32, we may need change them to u64 later */
Assuming you can't resolve this now, comment style:
/* * FIXME(your email): ... * ... */
search_key.objectid = inr;
search_key.type = BTRFS_INODE_ITEM_KEY;
clear_path(&path);
ret = search_tree(fs, fs_tree, &search_key, &path);
if (ret)
printf("%s search_tree failed\n", __func__);
return NULL;
inode_item = *(struct btrfs_inode_item *)path.data;
if (!(inode = alloc_inode(fs, inr, sizeof(struct btrfs_pvt_inode))))
printf("%s alloc_inode failed\n", __func__);
return NULL;
inode->ino = inr;
inode->size = inode_item.size;
inode->mode = IFTODT(inode_item.mode);
if (inode->mode == DT_REG || inode->mode == DT_LNK) {
struct btrfs_file_extent_item extent_item;
u64 offset;
/* get file_extent_item */
search_key.type = BTRFS_EXTENT_DATA_KEY;
clear_path(&path);
if (ret)
return NULL; /* impossible */
extent_item = *(struct btrfs_file_extent_item *)path.data;
if (extent_item.type == BTRFS_FILE_EXTENT_INLINE)/* inline file */
Space between ) and /*
offset = path.offsets[0] + sizeof(struct btrfs_header)
+ path.item.offset
+ offsetof(struct btrfs_file_extent_item, disk_bytenr);
else
offset = extent_item.disk_bytenr;
PVT(inode)->offset = offset;
return inode;
+static struct inode *btrfs_iget_root(struct fs_info *fs) +{
/* BTRFS_FIRST_CHUNK_TREE_OBJECTID(256) actually is first OBJECTID for FS_TREE */
return btrfs_iget_by_inr(fs, BTRFS_FIRST_CHUNK_TREE_OBJECTID);
+static struct inode *btrfs_iget(const char *name, struct inode *parent) +{
struct fs_info *fs = parent->fs;
struct btrfs_dir_item dir_item;
int ret;
search_key.objectid = parent->ino;
search_key.type = BTRFS_DIR_ITEM_KEY;
search_key.offset = btrfs_name_hash(name, strlen(name));
clear_path(&path);
if (ret)
return NULL;
dir_item = *(struct btrfs_dir_item *)path.data;
return btrfs_iget_by_inr(fs, dir_item.location.objectid);
+static int btrfs_readlink(struct inode *inode, char *buf) +{
btrfs_devread((logical_physical(PVT(inode)->offset)/SECTOR_SIZE),
(logical_physical(PVT(inode)->offset)%SECTOR_SIZE), inode->size, (char*)buf);
Error check?
buf[inode->size] = '\0';
return inode->size;
+static int btrfs_readdir(struct file *file, struct dirent *dirent) +{
struct fs_info *fs = file->fs;
struct inode *inode = file->inode;
struct btrfs_dir_item *dir_item;
int ret;
* we use file->offset to store last search key.offset, will will search
* key that lower that offset, 0 means first search and we will search
* -1UL, which is the biggest possible key
search_key.objectid = inode->ino;
search_key.offset = file->offset - 1;
clear_path(&path);
if (ret) {
return -1;
dir_item = (struct btrfs_dir_item *)path.data;
file->offset = path.item.key.offset;
dirent->d_ino = dir_item->location.objectid;
dirent->d_off = file->offset;
dirent->d_reclen = offsetof(struct dirent, d_name)
+ dir_item->name_len + 1;
dirent->d_type = IFTODT(dir_item->type);
memcpy(dirent->d_name, dir_item + 1, dir_item->name_len);
dirent->d_name[dir_item->name_len] = '\0';
btrfs_type(dir_item->type);
printf(" %s\n", dirent->d_name);
+static int btrfs_next_extent(struct inode *inode, uint32_t lstart) +{
int ret;
u64 offset;
struct fs_info *fs = inode->fs;
u32 sec_shift = SECTOR_BITS;
u32 sec_size = SECTOR_SIZE;
search_key.offset = lstart << sec_shift;
clear_path(&path);
if (ret) { /* impossible */
printf("btrfs: search extent data error\n");
These printf()s should be debug()s I think.
return -1;
if (extent_item.encryption) {
printf("btrfs: found encrypted data, cannot continue\n");
return -1;
if (extent_item.compression) {
printf("btrfs: found compressed data, cannot continue\n");
return -1;
if (extent_item.type == BTRFS_FILE_EXTENT_INLINE) {/* inline file */
/* we fake a extent here, and PVT of inode will tell us */
+ path.item.offset
inode->next_extent.len =
(inode->size + sec_size -1) >> sec_shift;
} else {
offset = extent_item.disk_bytenr + extent_item.offset;
(extent_item.num_bytes + sec_size - 1) >> sec_shift;
inode->next_extent.pstart =
logical_physical(offset) >> sec_shift;
+static uint32_t btrfs_getfssec(struct file *file, char *buf, int sectors,
char *have_more)
u32 ret;
u32 off = PVT(file->inode)->offset % SECTOR_SIZE;
char handle_inline = 0;
if (off && !file->offset) {/* inline file first read patch */
file->inode->size += off;
handle_inline = 1;
ret = generic_getfssec(file, buf, sectors, have_more);
if (!ret)
return ret;
if (handle_inline) {/* inline file patch */
ret -= off;
memcpy(buf, buf + off, ret);
return ret;
+static void btrfs_get_fs_tree(struct fs_info *fs) +{
struct btrfs_root_item *tree;
char subvol_ok = 0;
/* check if subvol is filled by installer */
if (*subvolname) {
search_key.objectid = BTRFS_FS_TREE_OBJECTID;
search_key.type = BTRFS_ROOT_REF_KEY;
clear_path(&path);
if (search_tree(fs, __le64_to_cpu(sb.root), &search_key, &path))
next_slot(fs, &search_key, &path);
do {
do {
struct btrfs_root_ref *ref;
int pathlen, status;
&path.item.key))
break;
ref = (struct btrfs_root_ref *)path.data;
pathlen = path.item.size - sizeof(struct btrfs_root_ref);
printf("sub_vol found %s\n", (char*)(ref+1));
if (!strncmp((char*)(ref + 1), subvolname, pathlen)) {
subvol_ok = 1;
break;
if (subvol_ok)
break;
break;
This code looks familiar - did you repeat it or something similar above?
if (!subvol_ok) /* should be impossible */
printf("no subvol found\n");
/* find fs_tree from tree_root */
if (subvol_ok)
search_key.objectid = path.item.key.offset;
else /* "default" volume */
search_key.type = BTRFS_ROOT_ITEM_KEY;
search_key.offset =-1;
clear_path(&path);
search_tree(fs, (sb.root), &search_key, &path);
tree = (struct btrfs_root_item *)path.data;
fs_tree = tree->bytenr;
+/* init. the fs meta data, return the block size shift bits. */ +int btrfs_fs_init(struct fs_info *fs) +{
btrfs_init_crc32c();
btrfs_read_super_block(fs);
if (strncmp((char *)(&sb.magic), BTRFS_MAGIC, sizeof(sb.magic)))
return -1;
btrfs_read_sys_chunk_array();
btrfs_read_chunk_tree(fs);
btrfs_get_fs_tree(fs);
fs->root = btrfs_iget_root(fs);
parent_inode=*(fs->root);
return 1;
+} +static inline uint16_t file_to_handle(struct file *file) +{
- return file ? (file - files)+1 : 0;
+static inline struct file *handle_to_file(uint16_t handle) +{
- return handle ? &files[handle-1] : NULL;
- Free a refcounted inode
+void put_inode(struct inode *inode) +{
- while (inode && --inode->refcnt == 0) {
struct inode *dead = inode;
inode = inode->parent;
if (dead->name)
free((char *)dead->name);
free(dead);
- Get a new inode structure
+struct inode *alloc_inode(struct fs_info *fs, uint32_t ino, size_t data) +{
- struct inode *inode = malloc(sizeof(struct inode) + data);
blank line
- if (inode) {
inode->fs = fs;
inode->ino = ino;
inode->refcnt = 1;
- return inode;
- Get an empty file structure
+static struct file *alloc_file(void) +{
- int i;
- struct file *file = files;
- for (i = 0; i < MAX_OPEN; i++) {
if (!file->fs)
return file;
file++;
- return NULL;
- Close and free a file structure
+static inline void free_file(struct file *file) +{
- memset(file, 0, sizeof *file);
+void generic_close_file(struct file *file) +{
- if (file->inode) {
file->offset = 0;
put_inode(file->inode);
+void _close_file(struct file *file) +{
- if (file->fs)
generic_close_file(file);
- free_file(file);
+void btrfs_mangle_name(char *dst, const char *src)
Any idea what this function does, please?
- char *p = dst,ch,len;
- int i = FILENAME_MAX-1;
- len = strlen(src);
- ch = *src;
- while (!isspace(ch)) {
if (*src == '/') {
if (src[1] == '/') {
src++;
i--;
continue;
if(!len)
break;
i--;
len--;
*dst++ = *src++;
ch = *src;
- while (1) {
if (dst == p)
break;
if (dst[-1] != '/')
break;
if ((dst[-1] == '/') && ((dst - 1) == p))
break;
dst--;
i++;
- i++;
- for (; i > 0; i --)
*dst++ = '\0';
+} +int btrfs_open_file(const char *name, struct com32_filedata *filedata) +{
- int rv;
- struct file *file;
- char mangled_name[FILENAME_MAX];
- btrfs_mangle_name(mangled_name, name);
- rv = searchdir(mangled_name);
- if (rv < 0)
return rv;
- file = handle_to_file(rv);
- filedata->size = file->inode->size;
- filedata->handle = rv;
- return rv;
+int searchdir(const char *name) +{
- struct inode *inode = NULL;
- struct inode *parent = &parent_inode;
- char *pathbuf = NULL;
- char *part, *p, echar;
- int symlink_count = MAX_SYMLINK_CNT;
- if (!(file = alloc_file()))
goto err_no_close;
- p = pathbuf = strdup(name);
- if (!pathbuf)
goto err;
- do {
- got_link:
if (*p == '/') {
put_inode(parent);
parent = &parent_inode;// get_inode(this_fs->root);
do {
inode = get_inode(parent);
while (*p == '/')
p++;
if (!*p)
break;
part = p;
while ((echar = *p) && echar != '/')
p++;
*p++ = '\0';
if (part[0] == '.' && part[1] == '.' && part[2] == '\0') {
if (inode->parent) {
put_inode(parent);
parent = get_inode(inode->parent);
put_inode(inode);
inode = NULL;
if (!echar) {
/* Terminal double dots */
inode = parent;
parent = inode->parent ?
get_inode(inode->parent) : NULL;
} else if (part[0] != '.' || part[1] != '\0') {
inode = btrfs_iget(part, parent);
if (!inode)
goto err;
if (inode->mode == DT_LNK) {
char *linkbuf, *q;
int name_len = echar ? strlen(p) : 0;
int total_len = inode->size + name_len + 2;
int link_len;
if (/*!this_fs->fs_ops->readlink ||*/
--symlink_count == 0 || /* limit check */
total_len > MAX_SYMLINK_BUF)
goto err;
linkbuf = malloc(total_len);
if (!linkbuf)
debug()
goto err;
link_len = btrfs_readlink(inode, linkbuf);
if (link_len <= 0) {
free(linkbuf);
goto err;
q = linkbuf + link_len;
if (echar) {
if (link_len > 0 && q[-1] != '/')
*q++ = '/';
memcpy(q, p, name_len+1);
} else {
*q = '\0';
free(pathbuf);
p = pathbuf = linkbuf;
put_inode(inode);
inode = NULL;
goto got_link;
inode->name = strdup(part);
inode->parent = parent;
parent = NULL;
if (!echar)
break;
if (inode->mode != DT_DIR)
goto err;
parent = inode;
inode = NULL;
} while (echar);
- } while (0);
- free(pathbuf);
- pathbuf = NULL;
- put_inode(parent);
- parent = NULL;
- if (!inode)
goto err;
- file->inode = inode;
- file->offset = 0;
- return file_to_handle(file);
+err:
- put_inode(inode);
- if (pathbuf)
free(pathbuf);
You don't need the if() - U-Boot ignores free(NULL)
- _close_file(file);
+err_no_close:
- return -1;
+static void get_next_extent(struct inode *inode) +{
- /* The logical start address that we care about... */
- uint32_t lstart = inode->this_extent.lstart + inode->this_extent.len;
- if (btrfs_next_extent(inode, lstart))
inode->next_extent.len = 0; /* ERROR */
- inode->next_extent.lstart = lstart;
+int getfssec(struct com32_filedata *filedata, char * buf) +{
- int sectors;
- char have_more;
- uint32_t bytes_read;
- uint16_t handle;
- if(filedata->size>=512)
sectors = filedata->size/SECTOR_SIZE;
sectors += (filedata->size%SECTOR_SIZE)?1:0;
- else sectors=2;
- file = handle_to_file(filedata->handle);
- bytes_read = btrfs_getfssec(file, buf, sectors, &have_more);
- if (!have_more) {
What is intended here?
- return bytes_read;
+uint32_t generic_getfssec(struct file *file, char *buf,
int sectors, char *have_more)
- struct inode *inode = file->inode;
- struct fs_info *fs = file->fs;
- uint32_t bytes_read = 0;
- uint32_t bytes_left = inode->size - file->offset;
- uint32_t sectors_left =
(bytes_left + SECTOR_SIZE - 1) >> 9;
- uint32_t lsector;
- if (sectors > sectors_left)
sectors = sectors_left;
- if (!sectors)
- lsector = file->offset >> 9;
- if (lsector < inode->this_extent.lstart ||
lsector >= inode->this_extent.lstart + inode->this_extent.len) {
/* inode->this_extent unusable, maybe next_extent is... */
inode->this_extent = inode->next_extent;
/* Still nothing useful... */
inode->this_extent.lstart = lsector;
inode->this_extent.len = 0;
- } else {
/* We have some usable information */
uint32_t delta = lsector - inode->this_extent.lstart;
inode->this_extent.len -= delta;
- inode->this_extent.pstart
= next_psector(inode->this_extent.pstart, delta);
- while (sectors) {
uint32_t chunk;
size_t len;
while (sectors > inode->this_extent.len) {
if (!inode->next_extent.len ||
inode->next_extent.lstart !=
get_next_extent(inode);
if (!inode->this_extent.len) {
/* Doesn't matter if it's contiguous... */
if (!inode->next_extent.len) {
sectors = 0; /* Failed to get anything... we're dead */
Return some sort of error here?
break;
} else if (inode->next_extent.len &&
inode->next_extent.pstart == next_pstart(&inode->this_extent)) {
/* Coalesce extents and loop */
inode->this_extent.len += inode->next_extent.len;
} else {
/* Discontiguous extents */
break;
chunk = min(sectors, inode->this_extent.len);
len = chunk << 9;//SECTOR_SHIFT(fs);
if (inode->this_extent.pstart == EXTENT_ZERO) {
memset(buf, 0, len);
} else {
btrfs_block_dev_desc->block_read( btrfs_block_dev_desc->dev,
part_info->start+(inode->this_extent.pstart), chunk, buf);
inode->this_extent.pstart += chunk;
buf += len;
sectors -= chunk;
bytes_read += len;
inode->this_extent.lstart += chunk;
inode->this_extent.len -= chunk;
- bytes_read = min(bytes_read, bytes_left);
- file->offset += bytes_read;
- if (have_more)
*have_more = bytes_read < bytes_left;
- Open a directory
+DIR *opendir(const char *path) +{
- int rv;
- rv = searchdir(path);
- if (rv < 0)
return NULL;
Can this return NULL?
- if (file->inode->mode != DT_DIR) {
_close_file(file);
return NULL;
- return (DIR *)file;
- Read one directory entry at one time
+struct dirent *readdir(DIR *dir) +{
- static struct dirent buf;
- struct file *dd_dir = (struct file *)dir;
- int rv = -1;
- if (dd_dir) {
rv = btrfs_readdir(dd_dir, &buf);
- return rv < 0 ? NULL : &buf;
- Show directory entries
+char btrfs_ls(char *dirname) +{
- struct dirent *de;
- DIR *dir;
- if(*dirname == '/' && *(dirname+1) == 0)
*dirname = '.';
- dir = opendir(dirname);
- if (dir == NULL)
return -1;
- while ((de = readdir(dir)) != NULL)
diff --git a/fs/btrfs/crc32_c.c b/fs/btrfs/crc32_c.c new file mode 100644 index 0000000..78d0447 --- /dev/null +++ b/fs/btrfs/crc32_c.c @@ -0,0 +1,54 @@ +/*
- Copied from Linux kernel crypto/crc32c.c
- Copyright (c) 2004 Cisco Systems, Inc.
- Copyright (c) 2008 Herbert Xu herbert@gondor.apana.org.au
- This program is free software; you can redistribute it and/or modify it
- under the terms of the GNU General Public License as published by the Free
- Software Foundation; either version 2 of the License, or (at your option)
- any later version.
- This is the CRC-32C table
- Generated with:
- width = 32 bits
- poly = 0x1EDC6F41
- reflect input bytes = true
- reflect output bytes = true
- Steps through buffer one byte at at time, calculates reflected
- crc using table.
+inline u32 crc32c_cal(u32 crc, const char *data, size_t length, u32 *crc32c_table) +{
while (length--)
crc = crc32c_table[(u8)(crc ^ *data++)] ^ (crc >> 8);
return crc;
+inline void crc32c_init(u32 *crc32c_table, u32 pol) +{
int i, j;
u32 v;
const u32 poly = pol; /* Bit-reflected CRC32C polynomial */
for (i = 0; i < 256; i++) {
v = i;
for (j = 0; j < 8; j++) {
v = (v >> 1) ^ ((v & 1) ? poly : 0);
crc32c_table[i] = v;
+} diff --git a/fs/fs.c b/fs/fs.c index 023e7ef..c5ca56c 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -20,9 +20,8 @@ #include <ext4fs.h> #include <fat.h> #include <fs.h>
+#include <btrfs.h>
Alpha order for headers
DECLARE_GLOBAL_DATA_PTR;
Why remove this blank line?
static block_dev_desc_t *fs_dev_desc; static disk_partition_t fs_partition; static int fs_type = FS_TYPE_ANY; @@ -79,6 +78,74 @@ static inline void fs_close_fat(void) #define fs_read_fat fs_read_unsupported #endif
+#ifdef CONFIG_FS_BTR +struct fs_info fs; +static int fs_probe_btr(void) +{
btrfs_set_blk_dev(fs_dev_desc, &fs_partition);
if (btrfs_fs_init(&fs)==-1) {
printf("btrfs probe failed\n");
return -1;
+static void fs_close_btr(void) +{ +}
+#define fs_ls_btr btrfs_ls
Please can you check latest mainline for this? I think you can use the fstypes[] array now.
+static int fs_read_btr(const char *filename, ulong addr, int offset, int len) +{
int file_len=0;
int len_read;
struct com32_filedata filedata;
int handle;
if (offset != 0) {
printf("** Cannot support non-zero offset **\n");
return -1;
handle=btrfs_open_file(filename, &filedata);
if (handle < 0) {
printf("** File not found %s Invalid handle**\n", filename);
return -1;
/*file handle is valid get the size of the file*/
len = filedata.size;
if (len == 0)
len = file_len;
len_read = getfssec(&filedata, (char *)addr);
if (len_read != len) {
printf("** Unable to read file %s **\n", filename);
return -1;
return len_read;
+#else +static inline int fs_probe_btr(void) +{
return -1;
+static inline void fs_close_btr(void) +{ +}
+#define fs_ls_btr fs_ls_unsupported +#define fs_read_btr fs_read_unsupported +#endif
#ifdef CONFIG_FS_EXT4 static int fs_probe_ext(void) { @@ -155,6 +222,10 @@ static struct { .fstype = FS_TYPE_EXT, .probe = fs_probe_ext, },
.fstype = FS_TYPE_BTR,
.probe = fs_probe_btr,
int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype) @@ -198,6 +269,9 @@ static void fs_close(void) case FS_TYPE_EXT: fs_close_ext(); break;
case FS_TYPE_BTR:
fs_close_btr();
break; default: break; }
@@ -216,6 +290,9 @@ int fs_ls(const char *dirname) case FS_TYPE_EXT: ret = fs_ls_ext(dirname); break;
case FS_TYPE_BTR:
ret = fs_ls_btr(dirname);
break; default: ret = fs_ls_unsupported(dirname); break;
@@ -237,11 +314,14 @@ int fs_read(const char *filename, ulong addr, int offset, int len) case FS_TYPE_EXT: ret = fs_read_ext(filename, addr, offset, len); break;
case FS_TYPE_BTR:
ret = fs_read_btr(filename, addr, offset, len);
break; default: ret = fs_read_unsupported(filename, addr, offset, len); break; }
fs_close(); return ret;
diff --git a/include/btrfs.h b/include/btrfs.h new file mode 100644 index 0000000..76fde8c --- /dev/null +++ b/include/btrfs.h @@ -0,0 +1,391 @@ +#ifndef _BTRFS_H_ +#define _BTRFS_H_
+#include <asm/byteorder.h> +/* type that store on disk, but it is same as cpu type for i386 arch */
+#define CURRENTDIR_MAX 15 +#define MAX_OPEN 5 +#define FILENAME_MAX 20 +#define MAX_SYMLINK_CNT 20 +#define MAX_SYMLINK_BUF 4096 +#define SECTOR_SHIFT(fs) ((fs)->sector_shift) +#define IFTODT(mode) (((mode) & 0170000) >> 12) +#define SECTOR_SIZE 0x200 +#define SECTOR_BITS 9 +#define EXTENT_ZERO ((__le32)-1) /* All-zero extent */ +#define EXTENT_VOID ((__le32)-2) /* Invalid information */ +#define DT_LNK 10 +#define DT_REG 8 +#define DT_DIR 4
I wonder if these should either go in the C file or have some sort of prefix to avoid name collision?
+#define EXTENT_SPECIAL(x) ((x) >= EXTENT_VOID) +#define MAX_SUBVOL_NAME 50 +struct _DIR_; +typedef struct _DIR_ DIR;
Should avoid typedef, and capitalized structure names.
+struct com32_filedata {
- size_t size; /* File size */
- int blocklg2; /* log2(block size) */
- uint16_t handle; /* File handle */
+struct fs_info {
btrfs_info?
- const struct fs_ops *fs_ops;
- struct device *fs_dev;
- void *fs_info; /* The fs-specific information */
- int sector_shift, sector_size;
- int block_shift, block_size;
- struct inode *root, *cwd; /* Root and current directories */
- char cwd_name[CURRENTDIR_MAX]; /* Current directory by name */
- Extent structure: contains the mapping of some chunk of a file
- that is contiguous on disk.
+struct extent {
- __le64 pstart;
- __le32 lstart; /* Logical start sector */
- __le32 len; /* Number of contiguous sectors */
+}__attribute__ ((__packed__));
+struct inode {
- struct fs_info *fs; /* The filesystem this inode is associated with */
- struct inode *parent; /* Parent directory, if any */
- const u8 *name; /* Name, valid for generic path search only */
- __le32 refcnt;
- __le32 mode; /* FILE , DIR or SYMLINK */
- __le32 size;
- __le32 blocks; /* How many blocks the file take */
- __le32 ino; /* Inode number */
- __le32 atime; /* Access time */
- __le32 mtime; /* Modify time */
- __le32 ctime; /* Create time */
- __le32 dtime; /* Delete time */
- __le32 flags;
- __le32 file_acl;
Can/should these type be int32_t / uin64_t / etc?
- struct extent this_extent, next_extent;
- u8 pvt[0]; /* Private filesystem data */
+}__attribute__ ((__packed__)); +struct file {
- __le64 offset; /* for next read */
- struct inode *inode; /* The file-specific information */
+#define NAME_MAX 20 +struct dirent {
- uint32_t d_ino;
- uint32_t d_off;
- uint16_t d_reclen;
- uint16_t d_type;
- char d_name[NAME_MAX + 1];
btrfs_dirent perhaps?
+#define btrfs_crc32c crc32c_le
Do you need this?
+#define BTRFS_SUPER_INFO_OFFSET (64 * 1024) +#define BTRFS_SUPER_INFO_SIZE 4096 +#define BTRFS_MAX_LEAF_SIZE 4096 +#define BTRFS_BLOCK_SHIFT 12
+#define BTRFS_SUPER_MIRROR_MAX 3 +#define BTRFS_SUPER_MIRROR_SHIFT 12 +#define BTRFS_CSUM_SIZE 32 +#define BTRFS_FSID_SIZE 16 +#define BTRFS_LABEL_SIZE 256 +#define BTRFS_SYSTEM_CHUNK_ARRAY_SIZE 2048 +#define BTRFS_UUID_SIZE 16
+#define BTRFS_MAGIC "_BHRfS_M"
+#define BTRFS_SUPER_FLAG_METADUMP (1ULL << 33)
+#define BTRFS_DEV_ITEM_KEY 216 +#define BTRFS_CHUNK_ITEM_KEY 228 +#define BTRFS_ROOT_REF_KEY 156 +#define BTRFS_ROOT_ITEM_KEY 132 +#define BTRFS_EXTENT_DATA_KEY 108 +#define BTRFS_DIR_ITEM_KEY 84 +#define BTRFS_INODE_ITEM_KEY 1
Might be nice to line up the values somewhat with tabs.
+#define BTRFS_EXTENT_TREE_OBJECTID 2ULL +#define BTRFS_FS_TREE_OBJECTID 5ULL
+#define BTRFS_FIRST_CHUNK_TREE_OBJECTID 256ULL
+#define BTRFS_FILE_EXTENT_INLINE 0 +#define BTRFS_FILE_EXTENT_REG 1 +#define BTRFS_FILE_EXTENT_PREALLOC 2
+#define BTRFS_MAX_LEVEL 8 +#define BTRFS_MAX_CHUNK_ENTRIES 256
+#define BTRFS_FT_REG_FILE 1 +#define BTRFS_FT_DIR 2 +#define BTRFS_FT_SYMLINK 7
+#define ROOT_DIR_WORD 0x002f
+struct btrfs_dev_item {
__le64 devid;
__le64 total_bytes;
__le64 bytes_used;
__le32 io_align;
__le32 io_width;
__le32 sector_size;
__le64 type;
__le64 generation;
__le64 start_offset;
__le32 dev_group;
u8 seek_speed;
u8 bandwidth;
u8 uuid[BTRFS_UUID_SIZE];
u8 fsid[BTRFS_UUID_SIZE];
+} __attribute__ ((__packed__));
+struct btrfs_super_block {
u8 csum[BTRFS_CSUM_SIZE];
/* the first 4 fields must match struct btrfs_header */
u8 fsid[BTRFS_FSID_SIZE]; /* FS specific uuid */
__le64 bytenr; /* this block number */
__le64 flags;
/* allowed to be different from the btrfs_header from here own down */
__le64 magic;
__le64 generation;
__le64 root;
__le64 chunk_root;
__le64 log_root;
/* this will help find the new super based on the log root */
__le64 log_root_transid;
__le64 total_bytes;
__le64 bytes_used;
__le64 root_dir_objectid;
__le64 num_devices;
__le32 sectorsize;
__le32 nodesize;
__le32 leafsize;
__le32 stripesize;
__le32 sys_chunk_array_size;
__le64 chunk_root_generation;
__le64 compat_flags;
__le64 compat_ro_flags;
__le64 incompat_flags;
__le16 csum_type;
u8 root_level;
u8 chunk_root_level;
u8 log_root_level;
struct btrfs_dev_item dev_item;
char label[BTRFS_LABEL_SIZE];
__le64 cache_generation;
/* future expansion */
__le64 reserved[31];
u8 sys_chunk_array[BTRFS_SYSTEM_CHUNK_ARRAY_SIZE];
+} __attribute__ ((__packed__)); +struct btrfs_disk_key {
__le64 objectid;
u8 type;
__le64 offset;
+struct btrfs_stripe {
__le64 devid;
__le64 offset;
u8 dev_uuid[BTRFS_UUID_SIZE];
+struct btrfs_chunk {
__le64 length;
__le64 owner;
__le64 stripe_len;
__le64 type;
__le32 io_align;
__le32 io_width;
__le32 sector_size;
__le16 num_stripes;
__le16 sub_stripes;
struct btrfs_stripe stripe;
+struct btrfs_header {
/* these first four must match the super block */
__le64 bytenr; /* which block this node is supposed to live in */
__le64 flags;
/* allowed to be different from the super from here on down */
u8 chunk_tree_uuid[BTRFS_UUID_SIZE];
__le64 generation;
__le64 owner;
__le32 nritems;
u8 level;
+struct btrfs_item {
struct btrfs_disk_key key;
__le32 offset;
__le32 size;
+struct btrfs_leaf {
struct btrfs_header header;
struct btrfs_item items[];
+struct btrfs_key_ptr {
__le64 blockptr;
__le64 generation;
+struct btrfs_node {
struct btrfs_key_ptr ptrs[];
+/* remember how we get to a node/leaf */ +struct btrfs_path {
__le64 offsets[BTRFS_MAX_LEVEL];
__le32 itemsnr[BTRFS_MAX_LEVEL];
__le32 slots[BTRFS_MAX_LEVEL];
/* remember last slot's item and data */
struct btrfs_item item;
u8 data[BTRFS_MAX_LEAF_SIZE];
+/* store logical offset to physical offset mapping */ +struct btrfs_chunk_map_item {
__le64 logical;
__le64 length;
__le64 devid;
__le64 physical;
+struct btrfs_chunk_map {
struct btrfs_chunk_map_item *map;
__le32 map_length;
__le32 cur_length;
+} __attribute__ ((__packed__));;
+struct btrfs_timespec {
__le64 sec;
__le32 nsec;
+struct btrfs_inode_item {
/* nfs style generation number */
__le64 generation;
/* transid that last touched this inode */
__le64 transid;
__le64 size;
__le64 nbytes;
__le64 block_group;
__le32 nlink;
__le32 uid;
__le32 gid;
__le32 mode;
__le64 rdev;
__le64 flags;
/* modification sequence number for NFS */
__le64 sequence;
* a little future expansion, for more than this we can
* just grow the inode item and version it
__le64 reserved[4];
struct btrfs_timespec atime;
struct btrfs_timespec ctime;
struct btrfs_timespec mtime;
struct btrfs_timespec otime;
+struct btrfs_root_item {
struct btrfs_inode_item inode;
__le64 generation;
__le64 root_dirid;
__le64 bytenr;
__le64 byte_limit;
__le64 bytes_used;
__le64 last_snapshot;
__le64 flags;
__le32 refs;
struct btrfs_disk_key drop_progress;
u8 drop_level;
u8 level;
+struct btrfs_dir_item {
struct btrfs_disk_key location;
__le64 transid;
__le16 data_len;
__le16 name_len;
u8 type;
+struct btrfs_file_extent_item {
__le64 generation;
__le64 ram_bytes;
u8 compression;
u8 encryption;
__le16 other_encoding; /* spare for later use */
u8 type;
__le64 disk_bytenr;
__le64 disk_num_bytes;
__le64 offset;
__le64 num_bytes;
+struct btrfs_root_ref {
__le64 dirid;
__le64 sequence;
__le16 name_len;
- btrfs private inode information
+struct btrfs_pvt_inode {
- __le64 offset;
There is actually a __packed in linux/compiler BTW.
Nice to have comments on these functions
+void btrfs_set_blk_dev(block_dev_desc_t* rbdd , disk_partition_t *info); +int btrfs_fs_init(struct fs_info *fs); +void put_inode(struct inode *inode); +struct inode *alloc_inode(struct fs_info *fs, uint32_t ino, size_t data); +int btrfs_open_file(const char *name, struct com32_filedata *filedata); +int getfssec(struct com32_filedata *filedata, char * buf); +uint32_t generic_getfssec(struct file *file, char *buf,
int sectors, char *have_more);
+char btrfs_ls(char* ); +#define PVT(i) ((struct btrfs_pvt_inode *)((i)->pvt)) +static inline __le32 next_psector(__le32 psector, uint32_t skip) +{
- if (EXTENT_SPECIAL(psector))
return psector;
- else
return psector + skip;
+static inline __le32 next_pstart(const struct extent *e) +{
- return next_psector(e->pstart, e->len);
+static inline struct inode *get_inode(struct inode *inode) +{
- inode->refcnt++;
- return inode;
Perhaps just put these in the C file, since they are probably not called from elsewhere?
+#endif diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index bfb9680..28a0a66 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -26,4 +26,8 @@ #define CONFIG_EXT4_WRITE #endif
+#if defined(CONFIG_CMD_BTR) && !defined(CONFIG_FS_BTR) +#define CONFIG_FS_BTR +#endif
#endif /* __CONFIG_FALLBACKS_H */ diff --git a/include/fs.h b/include/fs.h index 4f30a38..3a0e7d4 100644 --- a/include/fs.h +++ b/include/fs.h @@ -21,6 +21,7 @@ #define FS_TYPE_ANY 0 #define FS_TYPE_FAT 1 #define FS_TYPE_EXT 2 +#define FS_TYPE_BTR 3
- Tell the fs layer which block device an partition to use for future
-- 1.7.9.5
Hi
On 08/03/13 05:03, Simon Glass wrote:
+U-Boot et al
Most of your comments in btrfs.c is about ported code. which we have already discussed to leave it as it for easy of future re sync. I will also wait for others to respond, so that i know what to change before sending other revision of patch. Please find my comments below
I have followed what other file-system has done, like fatload/fatls. in future we can insist on using generic commands.
- project.
- MA 02111-1307 USA
- Boot support
if (argc > 5)
else
The subvolname is extern in btrfs.c, but this can be changed by calling function in btrfs.c
+U_BOOT_CMD(
UBoot pattern for all file-system command uses same syntax. i.e btrload <interface> [<dev[:part]>] <addr> <filename> [subvol_name]
+U_BOOT_CMD(
Should put:
Ack
part_info = info;
- switch(num)
Ack
Remove blank line
int low = min;
int high = max;
int mid;
int ret;
void *item;
if (ret < 0)
low = mid + 1;
else if (ret > 0)
high = mid;
else {
*slot = mid;
*slot = low;
return 1;
part of ported.
part of port.
return 1;
return -1;
int ret;
int slot;
int i;
return;
return;
return;
part of port.
part of port.
int slot, ret;
if (ret == 0)
slot++;
else if (slot == 0)
return -1;
if (logical >=
return -1;
sector++;
return 1;
buf += block_len;
- return 1;
part of port.
blank line here
part of port. but Ack
if (mirror)
int i;
int ret;
u8 boots[512];
No, see btrfs_devread()
u64 offset;
u64 transid = 0;
return -1;
Again ported code issue
return -1;
Don't need {}
Ack
if (i == 0)
return -1;
return 1;
return -1;
return 1;
return -1;
return 1;
return -1;
return 1;
return -1;
return 1;
return -1;
int slot, ret;
u64 offset;
Error check?
ported code issue.
slot--;
} else {/*leaf*/
slot--;
Error check?
ported code issue
return ret;
int slot;
int level = 1;
return 1;
level++;
continue;;
break;
return 1;
Ack
int slot;
return 1;
return 1;
ported code issue.
int cur;
cur = 0;
Ack
insert_map(&item);
Port issue.
int status;
Ack
return;
clear_path(&path);
do {
do {
&path.item.key))
break;
insert_map(&item);
break;
int ret;
- FIXME(your email): ...
Ack will change comment style.
clear_path(&path);
if (ret)
return NULL;
return NULL;
inode->ino = inr;
u64 offset;
clear_path(&path);
if (ret)
Ack
+ path.item.offset
else
return inode;
int ret;
clear_path(&path);
if (ret)
return NULL;
Error check?
Port issue.
return inode->size;
int ret;
clear_path(&path);
if (ret) {
return -1;
int ret;
u64 offset;
clear_path(&path);
Ack
return -1;
return -1;
return -1;
+ path.item.offset
} else {
char *have_more)
u32 ret;
handle_inline = 1;
if (!ret)
return ret;
ret -= off;
return ret;
char subvol_ok = 0;
if (*subvolname) {
clear_path(&path);
do {
do {
&path.item.key))
break;
subvol_ok = 1;
break;
if (subvol_ok)
break;
break;
Ported Code. No repetition.
if (subvol_ok)
clear_path(&path);
return -1;
return 1;
if (dead->name)
free(dead);
blank line
Ack
- if (inode) {
inode->fs = fs;
inode->ino = ino;
inode->refcnt = 1;
- return inode;
- int i;
if (!file->fs)
return file;
file++;
- return NULL;
file->offset = 0;
- if (file->fs)
- free_file(file);
Just verification for white space in file name. can be removed.
- ch = *src;
if (*src == '/') {
src++;
i--;
continue;
if(!len)
break;
i--;
len--;
*dst++ = *src++;
ch = *src;
- while (1) {
if (dst == p)
break;
if (dst[-1] != '/')
break;
break;
dst--;
i++;
- i++;
*dst++ = '\0';
- int rv;
- if (rv < 0)
return rv;
- return rv;
goto err_no_close;
- if (!pathbuf)
goto err;
- do {
- got_link:
if (*p == '/') {
put_inode(parent);
do {
while (*p == '/')
p++;
if (!*p)
break;
part = p;
p++;
*p++ = '\0';
put_inode(parent);
put_inode(inode);
inode = NULL;
if (!echar) {
inode = parent;
if (!inode)
goto err;
char *linkbuf, *q;
int link_len;
goto err;
if (!linkbuf)
debug()
Ack
goto err;
free(linkbuf);
goto err;
if (echar) {
*q++ = '/';
} else {
*q = '\0';
free(pathbuf);
put_inode(inode);
inode = NULL;
goto got_link;
parent = NULL;
if (!echar)
break;
goto err;
parent = inode;
inode = NULL;
} while (echar);
- } while (0);
- free(pathbuf);
- pathbuf = NULL;
- parent = NULL;
- if (!inode)
goto err;
- file->offset = 0;
+err:
- put_inode(inode);
- if (pathbuf)
free(pathbuf);
Ack
+err_no_close:
- return -1;
- int sectors;
- char have_more;
- uint16_t handle;
- else sectors=2;
- if (!have_more) {
Needs removal.
- uint32_t lsector;
- if (!sectors)
- } else {
- while (sectors) {
uint32_t chunk;
size_t len;
This also part of port.
break;
} else {
break;
} else {
buf += len;
sectors -= chunk;
bytes_read += len;
- if (have_more)
- Open a directory
- int rv;
- if (rv < 0)
return NULL;
upon error searchdir returns -1. So condition can be true.
_close_file(file);
return NULL;
- int rv = -1;
- if (dd_dir) {
- DIR *dir;
*dirname = '.';
- if (dir == NULL)
return -1;
- Generated with:
- width = 32 bits
- poly = 0x1EDC6F41
- crc using table.
while (length--)
return crc;
int i, j;
u32 v;
v = i;
+#include <btrfs.h>
Ack
Ack
return -1;
Ok, will do it.
int file_len=0;
int len_read;
int handle;
if (offset != 0) {
return -1;
if (handle < 0) {
return -1;
if (len == 0)
len = file_len;
return -1;
return len_read;
return -1;
- #ifdef CONFIG_FS_EXT4 static int fs_probe_ext(void) {
case FS_TYPE_BTR:
fs_close_btr();
case FS_TYPE_BTR:
case FS_TYPE_BTR:
Ack, will add prefix.
Ack
+struct fs_info {
btrfs_info?
Ack
+struct extent {
- __le64 pstart;
+struct inode {
- __le32 refcnt;
- __le32 size;
- __le32 flags;
- __le32 file_acl;
ported header. can be changed need to wait others review.
- uint32_t d_ino;
- uint32_t d_off;
- uint16_t d_type;
Ack
Do you need this?
Yeah
Ack
__le64 devid;
__le64 total_bytes;
__le64 bytes_used;
__le32 io_align;
__le32 io_width;
__le32 sector_size;
__le64 type;
__le64 generation;
__le32 dev_group;
u8 seek_speed;
u8 bandwidth;
__le64 flags;
__le64 magic;
__le64 generation;
__le64 root;
__le64 chunk_root;
__le64 log_root;
__le64 total_bytes;
__le64 bytes_used;
__le64 num_devices;
__le32 sectorsize;
__le32 nodesize;
__le32 leafsize;
__le32 stripesize;
__le16 csum_type;
u8 root_level;
u8 log_root_level;
__le64 objectid;
u8 type;
__le64 offset;
__le64 devid;
__le64 offset;
__le64 length;
__le64 owner;
__le64 stripe_len;
__le64 type;
__le32 io_align;
__le32 io_width;
__le32 sector_size;
__le16 num_stripes;
__le16 sub_stripes;
__le64 flags;
__le64 generation;
__le64 owner;
__le32 nritems;
u8 level;
__le32 offset;
__le32 size;
__le64 blockptr;
__le64 generation;
__le64 logical;
__le64 length;
__le64 devid;
__le64 physical;
__le32 map_length;
__le32 cur_length;
__le64 sec;
__le32 nsec;
__le64 generation;
__le64 transid;
__le64 size;
__le64 nbytes;
__le64 block_group;
__le32 nlink;
__le32 uid;
__le32 gid;
__le32 mode;
__le64 rdev;
__le64 flags;
__le64 sequence;
__le64 reserved[4];
__le64 generation;
__le64 root_dirid;
__le64 bytenr;
__le64 byte_limit;
__le64 bytes_used;
__le64 flags;
__le32 refs;
u8 drop_level;
u8 level;
__le64 transid;
__le16 data_len;
__le16 name_len;
u8 type;
__le64 generation;
__le64 ram_bytes;
u8 compression;
u8 encryption;
u8 type;
__le64 disk_bytenr;
__le64 offset;
__le64 num_bytes;
__le64 dirid;
__le64 sequence;
__le16 name_len;
- __le64 offset;
Ack
return psector;
- else
- inode->refcnt++;
- return inode;
These are inline functions. But can go in btrfs.c
- #endif /* __CONFIG_FALLBACKS_H */
-- 1.7.9.5
Adnan Ali
