[U-Boot] [PATCH v4 1/2] disk: part_efi: move code to static functions
Signed-off-by: Steve Rae srae@broadcom.com ---
Changes in v4: - move common code to static functions
disk/part_efi.c | 175 +++++++++++++++++++++++++++++++++----------------------- 1 file changed, 102 insertions(+), 73 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index efed58f..2c77f29 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -69,6 +69,105 @@ static inline int is_bootable(gpt_entry *p) sizeof(efi_guid_t)); }
+static int validate_gpt_header(gpt_header *gpt_h, lbaint_t lba, + lbaint_t lastlba) +{ + uint32_t crc32_backup = 0; + uint32_t calc_crc32; + + /* Check the GPT header signature */ + if (le64_to_cpu(gpt_h->signature) != GPT_HEADER_SIGNATURE) { + printf("%s signature is wrong: 0x%llX != 0x%llX\n", + "GUID Partition Table Header", + le64_to_cpu(gpt_h->signature), + GPT_HEADER_SIGNATURE); + return -1; + } + + /* Check the GUID Partition Table CRC */ + memcpy(&crc32_backup, &gpt_h->header_crc32, sizeof(crc32_backup)); + memset(&gpt_h->header_crc32, 0, sizeof(gpt_h->header_crc32)); + + calc_crc32 = efi_crc32((const unsigned char *)gpt_h, + le32_to_cpu(gpt_h->header_size)); + + memcpy(&gpt_h->header_crc32, &crc32_backup, sizeof(crc32_backup)); + + if (calc_crc32 != le32_to_cpu(crc32_backup)) { + printf("%s CRC is wrong: 0x%x != 0x%x\n", + "GUID Partition Table Header", + le32_to_cpu(crc32_backup), calc_crc32); + return -1; + } + + /* + * Check that the my_lba entry points to the LBA that contains the GPT + */ + if (le64_to_cpu(gpt_h->my_lba) != lba) { + printf("GPT: my_lba incorrect: %llX != " LBAF "\n", + le64_to_cpu(gpt_h->my_lba), + lba); + return -1; + } + + /* + * Check that the first_usable_lba and that the last_usable_lba are + * within the disk. + */ + if (le64_to_cpu(gpt_h->first_usable_lba) > lastlba) { + printf("GPT: first_usable_lba incorrect: %llX > " LBAF "\n", + le64_to_cpu(gpt_h->first_usable_lba), lastlba); + return -1; + } + if (le64_to_cpu(gpt_h->last_usable_lba) > lastlba) { + printf("GPT: last_usable_lba incorrect: %llX > " LBAF "\n", + le64_to_cpu(gpt_h->last_usable_lba), lastlba); + return -1; + } + + debug("GPT: first_usable_lba: %llX last_usable_lba: %llX last lba: " + LBAF "\n", le64_to_cpu(gpt_h->first_usable_lba), + le64_to_cpu(gpt_h->last_usable_lba), lastlba); + + return 0; +} + +static int validate_gpt_entries(gpt_header *gpt_h, gpt_entry *gpt_e) +{ + uint32_t calc_crc32; + + /* Check the GUID Partition Table Entry Array CRC */ + calc_crc32 = efi_crc32((const unsigned char *)gpt_e, + le32_to_cpu(gpt_h->num_partition_entries) * + le32_to_cpu(gpt_h->sizeof_partition_entry)); + + if (calc_crc32 != le32_to_cpu(gpt_h->partition_entry_array_crc32)) { + printf("%s: 0x%x != 0x%x\n", + "GUID Partition Table Entry Array CRC is wrong", + le32_to_cpu(gpt_h->partition_entry_array_crc32), + calc_crc32); + return -1; + } + + return 0; +} + +static void prepare_backup_gpt_header(gpt_header *gpt_h) +{ + uint32_t calc_crc32; + uint64_t val; + + /* recalculate the values for the Backup GPT Header */ + val = le64_to_cpu(gpt_h->my_lba); + gpt_h->my_lba = gpt_h->alternate_lba; + gpt_h->alternate_lba = cpu_to_le64(val); + gpt_h->header_crc32 = 0; + + calc_crc32 = efi_crc32((const unsigned char *)gpt_h, + le32_to_cpu(gpt_h->header_size)); + gpt_h->header_crc32 = cpu_to_le32(calc_crc32); +} + #ifdef CONFIG_EFI_PARTITION /* * Public Functions (include/part.h) @@ -259,7 +358,6 @@ int write_gpt_table(block_dev_desc_t *dev_desc, const int pte_blk_cnt = BLOCK_CNT((gpt_h->num_partition_entries * sizeof(gpt_entry)), dev_desc); u32 calc_crc32; - u64 val;
debug("max lba: %x\n", (u32) dev_desc->lba); /* Setup the Protective MBR */ @@ -284,15 +382,7 @@ int write_gpt_table(block_dev_desc_t *dev_desc, != pte_blk_cnt) goto err;
- /* recalculate the values for the Backup GPT Header */ - val = le64_to_cpu(gpt_h->my_lba); - gpt_h->my_lba = gpt_h->alternate_lba; - gpt_h->alternate_lba = cpu_to_le64(val); - gpt_h->header_crc32 = 0; - - calc_crc32 = efi_crc32((const unsigned char *)gpt_h, - le32_to_cpu(gpt_h->header_size)); - gpt_h->header_crc32 = cpu_to_le32(calc_crc32); + prepare_backup_gpt_header(gpt_h);
if (dev_desc->block_write(dev_desc->dev, (lbaint_t)le64_to_cpu(gpt_h->last_usable_lba) @@ -511,10 +601,6 @@ static int is_pmbr_valid(legacy_mbr * mbr) static int is_gpt_valid(block_dev_desc_t *dev_desc, u64 lba, gpt_header *pgpt_head, gpt_entry **pgpt_pte) { - u32 crc32_backup = 0; - u32 calc_crc32; - u64 lastlba; - if (!dev_desc || !pgpt_head) { printf("%s: Invalid Argument(s)\n", __func__); return 0; @@ -527,55 +613,8 @@ static int is_gpt_valid(block_dev_desc_t *dev_desc, u64 lba, return 0; }
- /* Check the GPT header signature */ - if (le64_to_cpu(pgpt_head->signature) != GPT_HEADER_SIGNATURE) { - printf("GUID Partition Table Header signature is wrong:" - "0x%llX != 0x%llX\n", - le64_to_cpu(pgpt_head->signature), - GPT_HEADER_SIGNATURE); - return 0; - } - - /* Check the GUID Partition Table CRC */ - memcpy(&crc32_backup, &pgpt_head->header_crc32, sizeof(crc32_backup)); - memset(&pgpt_head->header_crc32, 0, sizeof(pgpt_head->header_crc32)); - - calc_crc32 = efi_crc32((const unsigned char *)pgpt_head, - le32_to_cpu(pgpt_head->header_size)); - - memcpy(&pgpt_head->header_crc32, &crc32_backup, sizeof(crc32_backup)); - - if (calc_crc32 != le32_to_cpu(crc32_backup)) { - printf("GUID Partition Table Header CRC is wrong:" - "0x%x != 0x%x\n", - le32_to_cpu(crc32_backup), calc_crc32); - return 0; - } - - /* Check that the my_lba entry points to the LBA that contains the GPT */ - if (le64_to_cpu(pgpt_head->my_lba) != lba) { - printf("GPT: my_lba incorrect: %llX != %" PRIX64 "\n", - le64_to_cpu(pgpt_head->my_lba), - lba); + if (validate_gpt_header(pgpt_head, (lbaint_t)lba, dev_desc->lba)) return 0; - } - - /* Check the first_usable_lba and last_usable_lba are within the disk. */ - lastlba = (u64)dev_desc->lba; - if (le64_to_cpu(pgpt_head->first_usable_lba) > lastlba) { - printf("GPT: first_usable_lba incorrect: %llX > %" PRIX64 "\n", - le64_to_cpu(pgpt_head->first_usable_lba), lastlba); - return 0; - } - if (le64_to_cpu(pgpt_head->last_usable_lba) > lastlba) { - printf("GPT: last_usable_lba incorrect: %llX > %" PRIX64 "\n", - le64_to_cpu(pgpt_head->last_usable_lba), lastlba); - return 0; - } - - debug("GPT: first_usable_lba: %llX last_usable_lba %llX last lba %" - PRIX64 "\n", le64_to_cpu(pgpt_head->first_usable_lba), - le64_to_cpu(pgpt_head->last_usable_lba), lastlba);
/* Read and allocate Partition Table Entries */ *pgpt_pte = alloc_read_gpt_entries(dev_desc, pgpt_head); @@ -584,17 +623,7 @@ static int is_gpt_valid(block_dev_desc_t *dev_desc, u64 lba, return 0; }
- /* Check the GUID Partition Table Entry Array CRC */ - calc_crc32 = efi_crc32((const unsigned char *)*pgpt_pte, - le32_to_cpu(pgpt_head->num_partition_entries) * - le32_to_cpu(pgpt_head->sizeof_partition_entry)); - - if (calc_crc32 != le32_to_cpu(pgpt_head->partition_entry_array_crc32)) { - printf("GUID Partition Table Entry Array CRC is wrong:" - "0x%x != 0x%x\n", - le32_to_cpu(pgpt_head->partition_entry_array_crc32), - calc_crc32); - + if (validate_gpt_entries(pgpt_head, *pgpt_pte)) { free(*pgpt_pte); return 0; }
Implement a feature to allow fastboot to write the downloaded image to the space reserved for the Protective MBR and the Primary GUID Partition Table. Additionally, prepare and write the Backup GUID Partition Table.
Changes in v4: fix bug with partition_entry_lba in Backup GPT use common static functions
Changes in v3: - prefer leXX_to_cpu() over cpu_to_leXX() - enhance calculation of pointer to GPT Entries - prepare and write the Backup GPT (requested by: Lukasz Majewski l.majewski@samsung.com)
Changes in v2: add validation of the GPT before writing to flash (suggested by: Lukasz Majewski l.majewski@samsung.com)
README | 9 ++++++ common/fb_mmc.c | 26 ++++++++++++++-- disk/part_efi.c | 93 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/part.h | 20 +++++++++++++ 4 files changed, 145 insertions(+), 3 deletions(-)
diff --git a/README b/README index 4ca04d0..42ece99 100644 --- a/README +++ b/README @@ -1773,6 +1773,15 @@ The following options need to be configured: regarding the non-volatile storage device. Define this to the eMMC device that fastboot should use to store the image.
+ CONFIG_FASTBOOT_GPT_NAME + The fastboot "flash" command supports writing the downloaded + image to the Protective MBR and the Primary GUID Partition + Table. (Additionally, this downloaded image is post-processed + to generate and write the Backup GUID Partition Table.) + This occurs when the specified "partition name" on the + "fastboot flash" command line matches this value. + Default is GPT_ENTRY_NAME (currently "gpt") if undefined. + - Journaling Flash filesystem support: CONFIG_JFFS2_NAND, CONFIG_JFFS2_NAND_OFF, CONFIG_JFFS2_NAND_SIZE, CONFIG_JFFS2_NAND_DEV diff --git a/common/fb_mmc.c b/common/fb_mmc.c index fb06d8a..6ea3938 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -4,12 +4,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <config.h> #include <common.h> #include <fb_mmc.h> #include <part.h> #include <aboot.h> #include <sparse_format.h>
+#ifndef CONFIG_FASTBOOT_GPT_NAME +#define CONFIG_FASTBOOT_GPT_NAME GPT_ENTRY_NAME +#endif + /* The 64 defined bytes plus the '\0' */ #define RESPONSE_LEN (64 + 1)
@@ -62,7 +67,6 @@ static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, void fb_mmc_flash_write(const char *cmd, void *download_buffer, unsigned int download_bytes, char *response) { - int ret; block_dev_desc_t *dev_desc; disk_partition_t info;
@@ -76,8 +80,24 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, return; }
- ret = get_partition_info_efi_by_name(dev_desc, cmd, &info); - if (ret) { + if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) { + printf("%s: updating MBR, Primary and Backup GPT(s)\n", + __func__); + if (is_valid_gpt_buf(dev_desc, download_buffer)) { + printf("%s: invalid GPT - refusing to write to flash\n", + __func__); + fastboot_fail("invalid GPT partition"); + return; + } + if (write_mbr_and_gpt_partitions(dev_desc, download_buffer)) { + printf("%s: writing GPT partitions failed\n", __func__); + fastboot_fail("writing GPT partitions failed"); + return; + } + printf("........ success\n"); + fastboot_okay(""); + return; + } else if (get_partition_info_efi_by_name(dev_desc, cmd, &info)) { error("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition"); return; diff --git a/disk/part_efi.c b/disk/part_efi.c index 2c77f29..338010e 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -161,6 +161,8 @@ static void prepare_backup_gpt_header(gpt_header *gpt_h) val = le64_to_cpu(gpt_h->my_lba); gpt_h->my_lba = gpt_h->alternate_lba; gpt_h->alternate_lba = cpu_to_le64(val); + gpt_h->partition_entry_lba = + cpu_to_le64(le64_to_cpu(gpt_h->last_usable_lba) + 1); gpt_h->header_crc32 = 0;
calc_crc32 = efi_crc32((const unsigned char *)gpt_h, @@ -545,6 +547,97 @@ err: free(gpt_h); return ret; } + +int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf) +{ + gpt_header *gpt_h; + gpt_entry *gpt_e; + + /* determine start of GPT Header in the buffer */ + gpt_h = buf + (GPT_PRIMARY_PARTITION_TABLE_LBA * + dev_desc->blksz); + if (validate_gpt_header(gpt_h, GPT_PRIMARY_PARTITION_TABLE_LBA, + dev_desc->lba)) + return -1; + + /* determine start of GPT Entries in the buffer */ + gpt_e = buf + (le64_to_cpu(gpt_h->partition_entry_lba) * + dev_desc->blksz); + if (validate_gpt_entries(gpt_h, gpt_e)) + return -1; + + return 0; +} + +int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf) +{ + gpt_header *gpt_h; + gpt_entry *gpt_e; + int gpt_e_blk_cnt; + lbaint_t lba; + int cnt; + + if (is_valid_gpt_buf(dev_desc, buf)) + return -1; + + /* determine start of GPT Header in the buffer */ + gpt_h = buf + (GPT_PRIMARY_PARTITION_TABLE_LBA * + dev_desc->blksz); + + /* determine start of GPT Entries in the buffer */ + gpt_e = buf + (le64_to_cpu(gpt_h->partition_entry_lba) * + dev_desc->blksz); + gpt_e_blk_cnt = BLOCK_CNT((le32_to_cpu(gpt_h->num_partition_entries) * + le32_to_cpu(gpt_h->sizeof_partition_entry)), + dev_desc); + + /* write MBR */ + lba = 0; /* MBR is always at 0 */ + cnt = 1; /* MBR (1 block) */ + if (dev_desc->block_write(dev_desc->dev, lba, cnt, buf) != cnt) { + printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", + __func__, "MBR", cnt, lba); + return 1; + } + + /* write Primary GPT */ + lba = GPT_PRIMARY_PARTITION_TABLE_LBA; + cnt = 1; /* GPT Header (1 block) */ + if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_h) != cnt) { + printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", + __func__, "Primary GPT Header", cnt, lba); + return 1; + } + + lba = le64_to_cpu(gpt_h->partition_entry_lba); + cnt = gpt_e_blk_cnt; + if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_e) != cnt) { + printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", + __func__, "Primary GPT Entries", cnt, lba); + return 1; + } + + prepare_backup_gpt_header(gpt_h); + + /* write Backup GPT */ + lba = le64_to_cpu(gpt_h->partition_entry_lba); + cnt = gpt_e_blk_cnt; + if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_e) != cnt) { + printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", + __func__, "Backup GPT Entries", cnt, lba); + return 1; + } + + lba = le64_to_cpu(gpt_h->my_lba); + cnt = 1; /* GPT Header (1 block) */ + if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_h) != cnt) { + printf("%s: failed writing '%s' (%d blks at 0x" LBAF ")\n", + __func__, "Backup GPT Header", cnt, lba); + return 1; + } + + return 0; +} #endif
/* diff --git a/include/part.h b/include/part.h index a496a4a..8ea9b30 100644 --- a/include/part.h +++ b/include/part.h @@ -244,6 +244,26 @@ int gpt_fill_header(block_dev_desc_t *dev_desc, gpt_header *gpt_h, */ int gpt_restore(block_dev_desc_t *dev_desc, char *str_disk_guid, disk_partition_t *partitions, const int parts_count); + +/** + * is_valid_gpt_buf() - Ensure that the Primary GPT information is valid + * + * @param dev_desc - block device descriptor + * @param buf - buffer which contains the MBR and Primary GPT info + * + * @return - '0' on success, otherwise error + */ +int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf); + +/** + * write_mbr_and_gpt_partitions() - write MBR, Primary GPT and Backup GPT + * + * @param dev_desc - block device descriptor + * @param buf - buffer which contains the MBR and Primary GPT info + * + * @return - '0' on success, otherwise error + */ +int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf); #endif
#endif /* _PART_H */
Hi Steve,
Changes in v3:
downloaded
Partition
post-processed
Table.)
the
undefined. +
- if (ret) {
- if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) {
GPT(s)\n",
__func__);
to flash\n",
__func__);
return;
download_buffer)) {
failed");
return;
fastboot_okay("");
return;
- } else if (get_partition_info_efi_by_name(dev_desc, cmd,
- gpt_h->partition_entry_lba =
cpu_to_le64(le64_to_cpu(gpt_h->last_usable_lba) + 1); gpt_h->header_crc32 = 0; calc_crc32 = efi_crc32((const unsigned char *)gpt_h, @@ -545,6 +547,97 @@ err: free(gpt_h); return ret; }
- gpt_header *gpt_h;
- gpt_entry *gpt_e;
- /* determine start of GPT Header in the buffer */
- gpt_h = buf + (GPT_PRIMARY_PARTITION_TABLE_LBA *
dev_desc->blksz);
- if (validate_gpt_header(gpt_h,
dev_desc->lba))
return -1;
- /* determine start of GPT Entries in the buffer */
- gpt_e = buf + (le64_to_cpu(gpt_h->partition_entry_lba) *
dev_desc->blksz);
- if (validate_gpt_entries(gpt_h, gpt_e))
return -1;
- gpt_entry *gpt_e;
- int gpt_e_blk_cnt;
- lbaint_t lba;
- int cnt;
- if (is_valid_gpt_buf(dev_desc, buf))
return -1;
dev_desc->blksz);
dev_desc->blksz);
- gpt_e_blk_cnt =
dev_desc);
- /* write MBR */
- lba = 0; /* MBR is always at 0 */
- cnt = 1; /* MBR (1 block) */
- if (dev_desc->block_write(dev_desc->dev, lba, cnt, buf) !=
cnt) {
")\n",
return 1;
- /* write Primary GPT */
- lba = GPT_PRIMARY_PARTITION_TABLE_LBA;
- cnt = 1; /* GPT Header (1 block) */
- if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_h) !=
cnt) {
")\n",
return 1;
- lba = le64_to_cpu(gpt_h->partition_entry_lba);
- cnt = gpt_e_blk_cnt;
- if (dev_desc->block_write(dev_desc->dev, lba, cnt, gpt_e) !=
cnt) {
")\n",
return 1;
- prepare_backup_gpt_header(gpt_h);
- /* write Backup GPT */
cnt) {
")\n",
return 1;
- lba = le64_to_cpu(gpt_h->my_lba);
cnt) {
")\n",
return 1;
+} #endif
- is_valid_gpt_buf() - Ensure that the Primary GPT information is
valid
- @param dev_desc - block device descriptor
- @param buf - buffer which contains the MBR and Primary GPT info
- @return - '0' on success, otherwise error
- write_mbr_and_gpt_partitions() - write MBR, Primary GPT and
Backup GPT
Acked-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Test HW: Exynos4412 - trats2
To Marek:
This patch cleanly applies to master (SHA1:b9206e61f3d87535ac4f4b0b858e674fd1edfeaf) not u-boot-usb.
Therefore I cannot apply it to u-boot-usb based -dfu tree. We can either wait up the moment when -dfu get in sync with mainline or apply this patch to mainline directly.
I've been looking at how to do the same thing here. This is an area that suffers from each vendor doing whatever they want. Using vendor download/flash tools here is painful. They are all different because that is where the value add is. ;) What tool do you use on the host side to create the image? I have seen some vendor code to do it, or you could use parted plus a disk file and extract the partition table from it. I find either method a bit fragile and non-standard IMHO.
The 2 options I've come up with are 1) enable USB MS and use whatever host side tool you like or 2) use the existing "gpt write" command in u-boot and tie that into fastboot "oem format" command. The advantage and disadvantage of the latter is that it hides the partitioning details in u-boot from the user, but requires changing the u-boot env to change partition layout. The partitioning requirements are pretty SOC specific it seems.
I'm not saying we can't support both, but having some standardization here would be good.
Rob
Changes in v3:
if (ret) {
__func__);
__func__);
return;
return;
fastboot_okay("");
return;
gpt_header *gpt_h;
gpt_entry *gpt_e;
dev_desc->blksz);
dev_desc->lba))
return -1;
dev_desc->blksz);
return -1;
gpt_header *gpt_h;
gpt_entry *gpt_e;
int gpt_e_blk_cnt;
lbaint_t lba;
int cnt;
return -1;
dev_desc->blksz);
dev_desc->blksz);
dev_desc);
/* write MBR */
return 1;
return 1;
return 1;
return 1;
return 1;
+} #endif
- is_valid_gpt_buf() - Ensure that the Primary GPT information is valid
- write_mbr_and_gpt_partitions() - write MBR, Primary GPT and Backup GPT
1.8.5
Option two seems "good" from a not firewalling off the details point of view which means that there'll be a subset that wants to go with one anyhow.
We use an internal tool -- however, I also note that ALL of the source code for our tool is "GPL-2.0+" (expect for one file which is Public Domain) Is U-Boot (Denx) interested in supporting a "host tool"?
We also have code which creates the GPT tables from a "fastboot oem format" command, and (if I understand correctly) we have code that implements a "gpt" command line, which creates the GPT tables from env variables... If there is interest here, I could investigate further.
Rob
I wasn't trying to promote an exclusive solution with this patch (which has been accepted - Thanks!). I was just trying to have an incremental change to the existing "fastboot flash" command (to handle the GPT Tables).
Thanks, Steve
[... snip ...]
I have patches I'm working on to do this. I hope to get them sent out soon.
Rob
Hi Rob,
On Exynos4/5 it is possible to use both. One can use mass storage (UMS) and also gpt write.
Moreover, there is the dfu (which is slow but standardized) support in u-boot, which seems SoC vendor agnostic. One can use dfu-util tools on host side too.
I can share one way to update GPT by using dfu with 'gpt write' u-boot command.
1. It is possible to extract default variables when u-boot is build: { # Generate params.bin cp `find . -name "env_common.o"` copy_env_common.o
objcopy -O binary --only-section=.rodata.default_environment `find . -name "copy_env_common.o"` tr '\0' '\n' < copy_env_common.o > default_envs.txt mkenvimage -s 16384 -o params.bin default_envs.txt
rm copy_env_common.o default_envs.txt }
2. Store params.bin in a known location (the location is soc dependent). 3. Reset board and execute 'gpt write mmc 0 $partitions' to default $partitions from params.bin
This works on Exynos.
Another option would be to add special alt setting for dfu - GPT and MBR which would accept binary partition layout and store them to proper location.
Rob
Changes in v3:
downloaded
Partition
post-processed
Table.)
the
undefined. +
if (ret) {
GPT(s)\n",
__func__);
to flash\n",
__func__);
return;
download_buffer)) {
failed");
return;
fastboot_okay("");
return;
gpt_header *gpt_h;
gpt_entry *gpt_e;
dev_desc->blksz);
dev_desc->lba))
return -1;
dev_desc->blksz);
return -1;
gpt_header *gpt_h;
gpt_entry *gpt_e;
int gpt_e_blk_cnt;
lbaint_t lba;
int cnt;
return -1;
dev_desc->blksz);
dev_desc->blksz);
gpt_e_blk_cnt =
dev_desc);
/* write MBR */
cnt) {
LBAF ")\n",
return 1;
gpt_h) != cnt) {
LBAF ")\n",
return 1;
gpt_e) != cnt) {
LBAF ")\n",
return 1;
gpt_e) != cnt) {
LBAF ")\n",
return 1;
gpt_h) != cnt) {
LBAF ")\n",
return 1;
+} #endif
valid
Backup GPT
1.8.5
Hi Steve,
Changes in v4:
lbaint_t lastlba)
- uint32_t crc32_backup = 0;
- uint32_t calc_crc32;
- if (le64_to_cpu(gpt_h->signature) != GPT_HEADER_SIGNATURE) {
return -1;
- memcpy(&crc32_backup, &gpt_h->header_crc32,
- memset(&gpt_h->header_crc32, 0, sizeof(gpt_h->header_crc32));
- memcpy(&gpt_h->header_crc32, &crc32_backup,
return -1;
contains the GPT
- if (le64_to_cpu(gpt_h->my_lba) != lba) {
lba);
return -1;
last_usable_lba are
* within the disk.
- if (le64_to_cpu(gpt_h->first_usable_lba) > lastlba) {
LBAF "\n",
lastlba);
return -1;
- if (le64_to_cpu(gpt_h->last_usable_lba) > lastlba) {
LBAF "\n",
return -1;
- debug("GPT: first_usable_lba: %llX last_usable_lba: %llX
last lba: "
- calc_crc32 = efi_crc32((const unsigned char *)gpt_e,
- if (calc_crc32 !=
wrong",
calc_crc32);
return -1;
- uint64_t val;
- Public Functions (include/part.h)
u64 val;
- u32 calc_crc32;
- u64 lastlba;
wrong:"
"0x%x != 0x%x\n",
contains the GPT */
"\n",
lba);
- if (validate_gpt_header(pgpt_head, (lbaint_t)lba,
the disk. */
PRIX64 "\n",
lastlba);
PRIX64 "\n",
lastlba);
lba %"
- if (calc_crc32 !=
wrong:"
"0x%x != 0x%x\n",
calc_crc32);
- if (validate_gpt_entries(pgpt_head, *pgpt_pte)) { free(*pgpt_pte); return 0; }
To Marek:
Lukasz Majewski
Rob Herring
Steve Rae
