[U-Boot] [PATCH 1/2] mmc: sdhci: Update sdhci_send_command() to handle HS200
This patch updates sdhci_send_command() to handle MMC HS200 tuning command.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- drivers/mmc/sdhci.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 400f87e..1bbcf4b 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -161,7 +161,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, /* We shouldn't wait for data inihibit for stop commands, even though they might use busy signaling */ if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION || - cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) mask &= ~SDHCI_DATA_INHIBIT;
while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { @@ -183,7 +184,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS);
mask = SDHCI_INT_RESPONSE; - if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) mask = SDHCI_INT_DATA_AVAIL;
if (!(cmd->resp_type & MMC_RSP_PRESENT)) @@ -201,7 +203,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, flags |= SDHCI_CMD_CRC; if (cmd->resp_type & MMC_RSP_OPCODE) flags |= SDHCI_CMD_INDEX; - if (data || cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + if (data || cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) flags |= SDHCI_CMD_DATA;
/* Set Transfer mode regarding to data flag */ -- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch adds HS200 suuport for ZynqMP and enables the same for ZC1751 DC1 board which has eMMC on it.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + drivers/mmc/zynq_sdhci.c | 25 ++++++++++++++++-------- 2 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index f5a3334..96abf61 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -54,6 +54,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_CADENCE=y CONFIG_MISC=y CONFIG_DM_MMC=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index f99731f..32c2dc6 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -32,12 +32,21 @@ struct arasan_sdhci_priv { };
#if defined(CONFIG_ARCH_ZYNQMP) +#define MMC_HS200_BUS_SPEED 5 + static const u8 mode2timing[] = { - [UHS_SDR12] = UHS_SDR12_BUS_SPEED, - [UHS_SDR25] = UHS_SDR25_BUS_SPEED, - [UHS_SDR50] = UHS_SDR50_BUS_SPEED, - [UHS_SDR104] = UHS_SDR104_BUS_SPEED, - [UHS_DDR50] = UHS_DDR50_BUS_SPEED, + [MMC_LEGACY] = UHS_SDR12_BUS_SPEED, + [SD_LEGACY] = UHS_SDR12_BUS_SPEED, + [MMC_HS] = HIGH_SPEED_BUS_SPEED, + [SD_HS] = HIGH_SPEED_BUS_SPEED, + [MMC_HS_52] = HIGH_SPEED_BUS_SPEED, + [MMC_DDR_52] = HIGH_SPEED_BUS_SPEED, + [UHS_SDR12] = UHS_SDR12_BUS_SPEED, + [UHS_SDR25] = UHS_SDR25_BUS_SPEED, + [UHS_SDR50] = UHS_SDR50_BUS_SPEED, + [UHS_DDR50] = UHS_DDR50_BUS_SPEED, + [UHS_SDR104] = UHS_SDR104_BUS_SPEED, + [MMC_HS_200] = MMC_HS200_BUS_SPEED, };
#define SDHCI_HOST_CTRL2 0x3E @@ -160,9 +169,6 @@ static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) struct mmc *mmc = (struct mmc *)host->mmc; u8 uhsmode;
- if (!IS_SD(mmc)) - return; - uhsmode = mode2timing[mmc->selected_mode];
if (uhsmode >= UHS_SDR25_BUS_SPEED) @@ -175,6 +181,9 @@ static void arasan_sdhci_set_control_reg(struct sdhci_host *host) struct mmc *mmc = (struct mmc *)host->mmc; u32 reg;
+ if (!IS_SD(mmc)) + return; + if (mmc->signal_voltage == MMC_SIGNAL_VOLTAGE_180) { reg = sdhci_readw(host, SDHCI_HOST_CTRL2); reg |= SDHCI_18V_SIGNAL; -- 2.7.4
here are tabs and then spaces - one tab should be enough. I personally don't need to have tab between ] and =.
if (!IS_SD(mmc))
return;
- if (!IS_SD(mmc))
return;
- if (mmc->signal_voltage == MMC_SIGNAL_VOLTAGE_180) { reg = sdhci_readw(host, SDHCI_HOST_CTRL2); reg |= SDHCI_18V_SIGNAL;
The rest looks good.
If Jaehoon doesn't take it, I will add it via my tree.
Thanks, Michal
no reason for two spaces here.
- if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK ||
and here.
- if (data || cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK ||
and here.
Thanks, Michal
Michal Simek
