[PATCH] usb: dwc3: fix NULL pointer issue
The phy_bulk pointer *usb_phys is used before allocated, fix it by using a phy_bulk variable instead in xhci_dwc3_platdata struct
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- drivers/usb/host/xhci-dwc3.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 563db1a426..51c04a9de2 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -19,7 +19,7 @@ #include <linux/usb/otg.h>
struct xhci_dwc3_platdata { - struct phy_bulk *usb_phys; + struct phy_bulk phys; };
void dwc3_set_mode(struct dwc3 *dwc3_reg, u32 mode) @@ -124,7 +124,7 @@ static int xhci_dwc3_probe(struct udevice *dev) hcor = (struct xhci_hcor *)((uintptr_t)hccr + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase)));
- ret = dwc3_setup_phy(dev, plat->usb_phys); + ret = dwc3_setup_phy(dev, &plat->phys); if (ret && (ret != -ENOTSUPP)) return ret;
@@ -167,7 +167,7 @@ static int xhci_dwc3_remove(struct udevice *dev) { struct xhci_dwc3_platdata *plat = dev_get_platdata(dev);
- dwc3_shutdown_phy(dev, plat->usb_phys); + dwc3_shutdown_phy(dev, &plat->phys);
return xhci_deregister(dev); }
Chunfeng Yun
