[U-Boot] [PATCH 1/2] SECURE_BOOT: Enable chain of trust on LS1012A platform
Define bootscript and its header addresses for QSPI target
Reviewed-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Sumit Garg sumit.garg@nxp.com Signed-off-by: Vinitha Pillai vinitha.pillai@nxp.com --- This patch depends on the following patch-set:
1. https://patchwork.ozlabs.org/patch/687002/ 2. https://patchwork.ozlabs.org/patch/687000/ 3. https://patchwork.ozlabs.org/patch/687001/
arch/arm/include/asm/arch-fsl-layerscape/config.h | 7 +++++++ arch/arm/include/asm/fsl_secure_boot.h | 5 +++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 11a62e8..34b3d25 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -186,6 +186,13 @@
#define GICD_BASE 0x01401000 #define GICC_BASE 0x01402000 +#define CONFIG_SYS_FSL_SFP_VER_3_2 +#define CONFIG_SYS_FSL_SEC_MON_BE +#define CONFIG_SYS_FSL_SEC_BE +#define CONFIG_SYS_FSL_SFP_BE +#define CONFIG_SYS_FSL_SRK_LE +#define CONFIG_KEY_REVOCATION +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #elif defined(CONFIG_ARCH_LS1046A) #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 diff --git a/arch/arm/include/asm/fsl_secure_boot.h b/arch/arm/include/asm/fsl_secure_boot.h index 08ba589..5ffde4e 100644 --- a/arch/arm/include/asm/fsl_secure_boot.h +++ b/arch/arm/include/asm/fsl_secure_boot.h @@ -114,6 +114,9 @@ #ifdef CONFIG_ARCH_LS1046A #define CONFIG_BS_HDR_ADDR_DEVICE 0x40780000 #define CONFIG_BS_ADDR_DEVICE 0x40800000 +#elif defined(CONFIG_ARCH_LS1012A) +#define CONFIG_BS_HDR_ADDR_DEVICE 0x400c0000 +#define CONFIG_BS_ADDR_DEVICE 0x40060000 #endif #define CONFIG_BS_HDR_SIZE 0x00002000 #define CONFIG_BS_SIZE 0x00001000 @@ -141,6 +144,8 @@ #define CONFIG_SYS_LS_PPA_ESBC_ADDR 0x600c0000 #elif defined(CONFIG_ARCH_LS1046A) #define CONFIG_SYS_LS_PPA_ESBC_ADDR 0x40740000 +#elif defined(CONFIG_ARCH_LS1012A) +#define CONFIG_SYS_LS_PPA_ESBC_ADDR 0x40480000 #endif #else #error "No CONFIG_SYS_LS_PPA_FW_IN_xxx defined"
Add QSPI Secure Boot target to enable chain of trust
board/freescale/ls1012ardb/ls1012ardb.c | 5 ++++ configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 40 +++++++++++++++++++++++++++ include/configs/ls1012a_common.h | 2 -- include/configs/ls1012ardb.h | 4 +++ 4 files changed, 49 insertions(+), 2 deletions(-) create mode 100644 configs/ls1012ardb_qspi_SECURE_BOOT_defconfig
diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 778434d..3966152 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -18,6 +18,7 @@ #include <environment.h> #include <fsl_mmdc.h> #include <netdev.h> +#include <fsl_sec.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -110,6 +111,10 @@ int board_init(void) gd->env_addr = (ulong)&default_environment[0]; #endif
+#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + return 0; }
diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig new file mode 100644 index 0000000..ebf8838 --- /dev/null +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -0,0 +1,40 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1012ARDB=y +CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT, SECURE_BOOT" +# CONFIG_CMD_IMLS is not set +CONFIG_SYS_NS16550=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-rdb" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_FSL_DSPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_RSA=y diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 80603c9..ef28480 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -128,6 +128,4 @@ #define CONFIG_PANIC_HANG #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
-#include <asm/fsl_secure_boot.h> - #endif /* __LS1012A_COMMON_H */ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 15410dd..909c26b 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -95,4 +95,8 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
+#define CONFIG_FSL_CAAM /* Enable CAAM */ + +#include <asm/fsl_secure_boot.h> + #endif /* __LS1012ARDB_H__ */
Vinitha Pillai
