[U-Boot] [PATCH 1/3] ARM: zynqmp: Wire up ethernet controllers
Wire up ethernet controllers and enable MII and BOOTP options.
arch/arm/include/asm/arch-zynqmp/hardware.h | 5 +++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 5 +++++ board/xilinx/zynqmp/zynqmp.c | 25 +++++++++++++++++++++++++ include/configs/xilinx_zynqmp.h | 21 +++++++++++++++++++++ 4 files changed, 56 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 15bd519bfbe1..5d191e848cca 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -11,6 +11,11 @@ #define ZYNQ_SERIAL_BASEADDR0 0xFF000000 #define ZYNQ_SERIAL_BASEADDR1 0xFF001000
+#define ZYNQ_GEM_BASEADDR0 0xFF0B0000 +#define ZYNQ_GEM_BASEADDR1 0xFF0C0000 +#define ZYNQ_GEM_BASEADDR2 0xFF0D0000 +#define ZYNQ_GEM_BASEADDR3 0xFF0E0000 + #define ZYNQ_SPI_BASEADDR0 0xFF040000 #define ZYNQ_SPI_BASEADDR1 0xFF050000
diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 3ca15cb6e588..f5c90d11dc40 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -8,6 +8,11 @@ #ifndef _ASM_ARCH_SYS_PROTO_H #define _ASM_ARCH_SYS_PROTO_H
+/* Setup clk for network */ +static inline void zynq_slcr_gem_clk_setup(u32 gem_id, unsigned long clk_rate) +{ +} + int zynq_sdhci_init(unsigned long regbase); int zynq_slcr_get_mio_pin_status(const char *periph);
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index f5ff64d988e5..fb43cb0b9aa2 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -51,6 +51,31 @@ void reset_cpu(ulong addr) { }
+int board_eth_init(bd_t *bis) +{ + u32 ret = 0; + +#if defined(CONFIG_ZYNQ_GEM) +# if defined(CONFIG_ZYNQ_GEM0) + ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR0, + CONFIG_ZYNQ_GEM_PHY_ADDR0, 0); +# endif +# if defined(CONFIG_ZYNQ_GEM1) + ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR1, + CONFIG_ZYNQ_GEM_PHY_ADDR1, 0); +# endif +# if defined(CONFIG_ZYNQ_GEM2) + ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR2, + CONFIG_ZYNQ_GEM_PHY_ADDR2, 0); +# endif +# if defined(CONFIG_ZYNQ_GEM3) + ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR3, + CONFIG_ZYNQ_GEM_PHY_ADDR3, 0); +# endif +#endif + return ret; +} + #ifdef CONFIG_CMD_MMC int board_mmc_init(bd_t *bd) { diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 8cb276ca709d..9ed8771ff507 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -76,6 +76,16 @@ #define CONFIG_CMD_ELF #define CONFIG_MP
+#define CONFIG_CMD_MII + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_MAY_FAIL +#define CONFIG_BOOTP_SERVERIP + /* SPI */ #ifdef CONFIG_ZYNQ_SPI # define CONFIG_SPI_FLASH_SST @@ -130,6 +140,17 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_MAXARGS 64
+/* Ethernet driver */ +#if defined(CONFIG_ZYNQ_GEM0) || defined(CONFIG_ZYNQ_GEM1) || \ + defined(CONFIG_ZYNQ_GEM2) || defined(CONFIG_ZYNQ_GEM3) +# define CONFIG_NET_MULTI +# define CONFIG_ZYNQ_GEM +# define CONFIG_MII +# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN +# define CONFIG_PHYLIB +# define CONFIG_PHY_MARVELL +#endif + /* I2C */ #if defined(CONFIG_SYS_I2C_ZYNQ) # define CONFIG_CMD_I2C
Enable SATA for the ZynqMP targets.
arch/arm/include/asm/arch-zynqmp/hardware.h | 2 ++ board/xilinx/zynqmp/zynqmp.c | 10 ++++++++++ include/configs/xilinx_zynqmp.h | 11 +++++++++++ include/configs/xilinx_zynqmp_ep.h | 1 + 4 files changed, 24 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 5d191e848cca..7640eabad13e 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -25,6 +25,8 @@ #define ZYNQ_SDHCI_BASEADDR0 0xFF160000 #define ZYNQ_SDHCI_BASEADDR1 0xFF170000
+#define ZYNQMP_SATA_BASEADDR 0xFD0C0000 + #define ZYNQMP_CRL_APB_BASEADDR 0xFF5E0000 #define ZYNQMP_CRL_APB_TIMESTAMP_REF_CTRL_CLKACT 0x1000000
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index fb43cb0b9aa2..88fe3e844f5b 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -7,6 +7,8 @@
#include <common.h> #include <netdev.h> +#include <ahci.h> +#include <scsi.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include <asm/io.h> @@ -51,6 +53,14 @@ void reset_cpu(ulong addr) { }
+#ifdef CONFIG_SCSI_AHCI_PLAT +void scsi_init(void) +{ + ahci_init((void __iomem *)ZYNQMP_SATA_BASEADDR); + scsi_scan(1); +} +#endif + int board_eth_init(bd_t *bis) { u32 ret = 0; diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 9ed8771ff507..68853b64de53 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -169,6 +169,17 @@ # define CONFIG_SYS_EEPROM_SIZE (64 * 1024) #endif
+#ifdef CONFIG_AHCI +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_CMD_SCSI +#endif + #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */
diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index 40a110dab2fd..c872f7ce8aac 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -20,6 +20,7 @@ #define CONFIG_ZYNQ_I2C0 #define CONFIG_SYS_I2C_ZYNQ #define CONFIG_ZYNQ_EEPROM +#define CONFIG_AHCI
#include <configs/xilinx_zynqmp.h>
Add one more print to make clear which EL level U-Boot runs.
board/xilinx/zynqmp/zynqmp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 88fe3e844f5b..0c9a81414458 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -17,6 +17,8 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { + printf("EL Level:\tEL%d\n", current_el()); + return 0; }
Michal Simek
